Hi!
I have retrofitted Virtual Cockpit to my car. It is v2 cluster... I also changed the gateway to 3Q0907530AA version.
I have activated "Cupra mode" and now I wonder if it is possible to get that "Engine load" meter working?!? Am I missing / having some wrong codings or does those values come "somewhere else in car"??
And for those different views in vc... in center screen there is following options: Classic, View1, View2, and View3, but no Automatic option.... should it be in that way?
I also don´t get boost readings at center screen in sportHmi mode... does something same causes that?
And also offroad view is missing...
My car has reftrofitted hacked Mib2 High unit.
Car is still model year 2014 if that accefts to something.
Thanks for any help, idea or comments about those issues!!
mods obd virtual cockpit MK3
- Seguidores: 75
- Favoritos: 16
- Vistas: 146.572
Favoritos: fegavo, Xilenos, cuenxis, FrA1l3, adri0894, RBJ67, barrosdepor, frigolin, VillaSB, toniRG, trazas, LEMY69, Chinyero, rob3r7o, Eibol, davidddgt
Seguidores: carlo13, gogua, Fran22_9, Karlosmad, El_pelos44, ElGos, Atajunen, Corsus, adri0894, sampi_33, Flow-Rider, Luigi MK3, FrA1l3, Snooker83, VillaSB, Xilenos, Youkiler, xaco, DBS83, Fitis, Chelazo, MORKAS, VapaV, spongemak, Guillen222, cota49, juanfr83, JM_Design, Hectoor57, Gables, Javirul0, javichu312, juanbb, volkov, mateusz0, Korkoless, kwatto, Panz, cupralex, erlanz, viktor_ct_95, mSx, davidmosan, Hovig, leonfrrojito, csabafr2013, msmdraven, Cristian2014mx, gaizkaereno1, jasoriab, Mr.Chuflas, Josep20, JDMG, davidvilao, Chrohu, loeches, Octacon, Edu1589, Maikermx, Rotemburgero, Chinyero, DiegoR, LEMY69, manjerico, chifli, trazas, naranjito, snetterton, davidddgt, ericoperico, Davidv, danieleon, Warelio, ChusTj, Lanero909
Pave - Nuev@ por aqui
- Agradecido: 4 veces
Re: mods obd virtual cockpit MK3
Buenos días, quería preguntaros algo
Puse con el obd el cuadro sport central y todo bien, ahora el inconveniente, cuando me llaman por teléfono se me cambia al de los dos relojes, es normal? O es así
Enviado desde mi POCO F2 Pro mediante Tapatalk
Eloy_P.G - Asidu@ en la selva
- Agradecido: 52 veces
Es normal, igual que si quieres cambiar las opciones desde los botones.Eloy_P.G escribió:Buenos días, quería preguntaros algo
Enviado desde mi VOG-L29 mediante Tapatalk
Rotemburgero - Aun con la L
- Agradecido: 23 veces
Hola
Le acabo de instalar el virtual cockpit a mi leon, pero hay una cosa que me gustaria cambiar y no se como se hace, y es que no quiero que me coja el mismo color de las luces ambiente en la pantalla multimedia, me gustaria que quedara como en esta foto:
que codificacion tendria que hacer para cambiarlo?
pacoooooo - Asidu@ en la selva
- Agradecido: 40 veces
Hola @pacoooooo
Para eso necesitas actualizar la versión del firmware de tu unidad de guantera (5F) a una 51x si tienes navegador estándar. Si tienes un Navisystem Plus, con la versión 1409 te aseguro que funciona.
PD: O tu perfil está mal, o está mal configurado el cuentarevoluciones, porque en tu perfil aparece que tienes un TDI y la escala del VC es para las revoluciones de un motor gasolina (suponiendo que esa foto sea de tu coche, claro ).
- Agradecido: 2021 veces
Lo que quiere es colores diferentes, por lo que tendría que poner una versión más antigua, un downgrade.jasoriab escribió:Hola @pacoooooo
juanbb - Leoner@ mayor del reino
- Agradecido: 354 veces
Tienes razón @juanbb había entendido al revés lo que preguntaba @pacoooooo
¿Es posible un downgrade en las MIB2? Desconozco en concreto si las MIB2 lo permiten, pero muchos dispositivos no dejan instalar una versión anterior a la que tenga en ese momento.
Otra opción sería buscar una unidad de segunda mano con un firmware 47x si hablamos del NaviSystem estándar, pero va a costar más el collar que el perro, como se suele decir.
Perdon porque creo que me he explicado a medias, la foto no es de mi coche, la he sacado de otro foro , pero era para poner un ejemplo de lo que quiero.
Yo tengo un leon fr My 18, la unidad de guantera es la High con el ultimo firmware y hackeada hardware H54 softeware 1409, y el cockpit que tengo es el ultimo
Buenas, os cuento, me instalaron un cockpit y una unidad de radio con conector de fibra hace 1 mes y pico, hasta ahí tofo perfecto, pero no puedo acceder al menú del cuadro de instrumentos para cambiar las esferas como me apetezca, solo las predeterminadas con el boton view.
Lo que me han comentado es que es por la GW, llevo una 3q0 montada, los bytes que sale más arriba los he activado, pero sigue sin salir.
Sabéis si puede ser que solo necesite una actualización de SW de la gateway? Cabe la posibilidad de meter un SW más nuevo y ya está? O se tiene que cambiar el hardware tambien?
- SEAT Ibiza 6k2 1.9TDI 90 plata
- SEAT Leon 5f FR 2.0TDI 150 stage 1 rojo desire
Jorgh7 - Nuev@ por aqui
De qué año es tu coche ?Jorgh7 escribió:Buenas, os cuento, me instalaron un cockpit y una unidad de radio con conector de fibra hace 1 mes y pico, hasta ahí tofo perfecto, pero no puedo acceder al menú del cuadro de instrumentos para cambiar las esferas como me apetezca, solo las predeterminadas con el boton view.
leonfrrojito - Leoner@ avanzad@
- Agradecido: 178 veces
leonfrrojito escribió:De qué año es tu coche ?Jorgh7 escribió:Buenas, os cuento, me instalaron un cockpit y una unidad de radio con conector de fibra hace 1 mes y pico, hasta ahí tofo perfecto, pero no puedo acceder al menú del cuadro de instrumentos para cambiar las esferas como me apetezca, solo las predeterminadas con el boton view.
2017 modelo 2018
Si quieres envíame un privado y me conecto por TeamViewer y te digo .Jorgh7 escribió:leonfrrojito escribió:De qué año es tu coche ?Jorgh7 escribió:Buenas, os cuento, me instalaron un cockpit y una unidad de radio con conector de fibra hace 1 mes y pico, hasta ahí tofo perfecto, pero no puedo acceder al menú del cuadro de instrumentos para cambiar las esferas como me apetezca, solo las predeterminadas con el boton view.
2017 modelo 2018
leonfrrojito escribió:Si quieres envíame un privado y me conecto por TeamViewer y te digo .Jorgh7 escribió:leonfrrojito escribió:De qué año es tu coche ?Jorgh7 escribió:Buenas, os cuento, me instalaron un cockpit y una unidad de radio con conector de fibra hace 1 mes y pico, hasta ahí tofo perfecto, pero no puedo acceder al menú del cuadro de instrumentos para cambiar las esferas como me apetezca, solo las predeterminadas con el boton view.
2017 modelo 2018
Al ser usuario nuevo no puedo mandar privados, cuando pueda te escribo
Jorgh7 escribió:leonfrrojito escribió:Si quieres envíame un privado y me conecto por TeamViewer y te digo .Jorgh7 escribió:leonfrrojito escribió:De qué año es tu coche ?Jorgh7 escribió:Buenas, os cuento, me instalaron un cockpit y una unidad de radio con conector de fibra hace 1 mes y pico, hasta ahí tofo perfecto, pero no puedo acceder al menú del cuadro de instrumentos para cambiar las esferas como me apetezca, solo las predeterminadas con el boton view.
2017 modelo 2018
Que te falta, el menu para configurar el cockpit en la radio?
Se llama display configuration en adaptaciones creo recordar.
- Agradecido: 237 veces
pacoooooo escribió:Hola
Eso hice yo cagandola, jajajaa, ponia rojo y salia el que le daba la gana, el rojo solo aparecia o en el cuadro o en la radio.
- Agradecido: 104 veces
León Mk3 - Cambiar SSS por Beats Foro: AudioCar y MultimediaCar Autor: aaronpet98 Respuestas: 1 |
Escapes al medio seat leon mk3 estilo golf 6 r Foro: Tuning Autor: yungchacho Respuestas: 1 |
León Mk3 - Autorradios Android Foro: AudioCar y MultimediaCar Autor: ipardoma Respuestas: 1765 |
León Mk3 - Recuperar puerto usb original con radio alpine Foro: AudioCar y MultimediaCar Autor: eleon Respuestas: 3 |
OBDeleven - Dudas y Mods para León MK3 Foro: Informática / Interfaces / Diagnosis Autor: miceor Respuestas: 8531 |
