Si miceor tienes toda la razón. Lo intenté volver actualizar y no me sale iniciar actualización lo intentare como tú dices aver que pasa
León Mk3 - Actualización infotainment
- Seguidores: 188
- Favoritos: 42
- Vistas: 656.532
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000, LeonFR80bsv
Seguidores: kenny_fonseca, ncx, Lavadora, barris31, juancete, ivantxe, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, gorkansr, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, danirodrigueze30, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, AlvaroPM13, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, Jansel, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
csabafr2013 - Asidu@ en la selva
- Agradecido: 13 veces
Re: Actualización infotainment
Y perdonar por lo pesado que soy gracias a todos por entenderme
Si sabes miceor como se puede volver a instalar ayúdame
@csabafr2013 edita los post si se te ocurren mas preguntas, se llenan las páginas de mensajes cortos y luego si queremos buscar algo es un show...
@miceor yo esta tarde probaré también lo del modelo, a ver que ocurre.
Gracias !
Gracias !
golf_1990 - Asidu@ en la selva
- Agradecido: 12 veces
Si pongo climatic master 0x01 en no activo pe desapareas de la pantalla
Probado al reiniciar sale el logro de SEAT FR pero el coche no cambia
csabafr2013 escribió:Probado al reiniciar sale el logro de SEAT FR pero el coche no cambia
Ya te lo han dicho varios compañeros, esto no es un chat, escribe tus conclusiones en un mismo post, se hace muy dificil la lectura de un hilo. Al final vas a conseguir que no te hagan caso.
javigody - Aqui + que con la novi@
- Agradecido: 274 veces
Ok perdonarme ahora los apuntó todo bien
Enviado desde mi iPad utilizando Tapatalk
Ok os explico lo que ma pasado
Primero. Actualize el infotaimen estaba en H24 0245 y primero lo que puse es 330 todo ok y luego el 346 no me dio ningún fallo y luego borre los fallos con el obd asta aquí perfecto. Luego cuando entre en el car no me salía my modelo de coche SEAT León FR St lo probé como me dijo miceor y le agradesco por todo. Y ni en el clima no me sale el salpicadero puedo cambiar temperatura y de más
Ahora espero que me entendéis y perdonarme no volveré a molestaros con tantos mensajes lo escribiré todo detalle . Gracias a todos otra ves
Bueno, pues ahora vayamos por partes a ver que podemos ir arreglando.
Entiendo que ya te sale el coche en formato ST porque lo cambiaste ayer.
Ahora puedes ir probando a cambiar de modelo y apuntar los resultados para descartar que sea un Bug.
Haciendo esto, unicamente cambias el modelo del coche no el formato del mismo.
1 - Módulo 5F - Electrónica de información 1. Code (20103)
2 - Codificación extendida (Modo texto)
3 - Byte 18 Screenings
Valor en 0 - Seat Normal.
Valor en 1 - Seat FR
Valor en 2 - Seat Cupra
Valor en 3 - Seat Ecomotive
Valor en 5 - Seat Xperience
Valor en 6 - Seat FR Line
Yo te voy a dar un consejo, empieza por poner el cupra porque es el mas llamativo de todos y lo vas a ver perfectamente.
Una vez realizado, bien cambias de pantalla, pulsa radio y luego Car o reinicias el infotainment y comprueba a ver si se muestra el modelo.
Si cambia el modelo y coincide vamos por buen camino, si no coincide y te sale otro que no sea el normal, tendremos que realizar la prueba completa con todos los bits del listado anterior y apuntar lo que sale en cada bit, no sea que en esa versión hayan cambiado algo.
Yo no puedo probarlo ahora mismo, sino ya te lo estaria poniendo aqui. (He prestado mi OBDeleven a un compañero y no puedo mirarlo)
Pero como el mio es el ST normal me aparece bien y no me he estado a cambiarlo después de actualizar.
Haz los pasos que te digo y nos cuentas que te sale en cada caso. Hazlo con paciencia.
Última edición por miceor el 06 Dic 2016, 11:00, editado 1 vez en total
- Agradecido: 1259 veces
¿Alguien más con un ST FR que haya actualizado a la 346? A lo mejor ese firmware no tiene todas las imágenes de todos los modelos cargados. La cuestión es si notas algún cambio con las configuraciones que te ha comentado @miceor.
- Agradecido: 3613 veces
No me explique bien miceor me sale el leon normal no el st aún que cambie el cupra o fr el coche no cambia solo cambia a encender la pantalla
cvillajos escribió:¿Alguien más con un ST FR que haya actualizado a la 346? A lo mejor ese firmware no tiene todas las imágenes de todos los modelos cargados. La cuestión es si notas algún cambio con las configuraciones que te ha comentado @miceor.
Yo también, el clima me sale mas completo que al chaval, pero el coche me sale un connect parece... Luego probaré lo que dice miceor, si no cambia a lo mejor se podría probar no actualizar esos módulos ?
My párese que ya lo sé lo que a pasado es culpa mía es por tener el motor arancado y la calefacción que estaba lloviendo y hacía frío por eso tenía el motor en marcha que pensé que se queda sin batería ahora es lo que ay no ay solución de remediarlo
OK.
O sea no te cambia ni de modelo ni de formato.
Yo en estos casos lo que haria es directamente irme a los polos opuestos.
Me explico:
Para comprobar que se produce un cambio después de cada programación realizo un cambio radical.
Ya ahora intentaria cambiarlo a un coche diferente y ver si se realiza el cambio.
Os pongo algunos ejemplos:
Sabemos que haciendo esto cambiamos el acabado del coche:
Que haciendolo en modo bytes sería asi:
Byte 18 :
Ningún bit activado - Seat Normal
Activando bit 0 - Seat FR
Activando bit 1 - Seat Cupra
Activando bits 0 y 1 - Seat Ecomotive
Activando bits 0 y 2 - Seat Xperience
Activando bits 1 y 2 - Seat FR Line
El resto de valores no cambian a otro modelo.
Cambiando esto se cambia la variante del coche :
- Codificacion extendida (Modo texto)
- Byte 2 Car Derivate
Valor = 3 Muestra el modelo ST
Valor = 2 Muestra el modelo SC
Y cambiando esto se cambia el modelo del coche:
- Byte 1 Car Generation
Valor = 3 Seat León
Valor = 2 Seat Ibiza
Pero luego dependiendo de las combinaciones salen otros modelos:
Por ejemplo. Combinaciones de los tres ultimos parámetros:
- Byte 1 Car Class ------------ 3
- Byte 1 Car Generation ----- 7
- Byte 2 Car Derivate -------- 3
Da un resultado de un Seat León ST
- Byte 2 Car Derivate -------- 2
Da un resultado de un Seat León corto 5 puertas
- Byte 1 Car Class ------------ 2
- Byte 1 Car Generation ----- 5
- Byte 2 Car Derivate -------- 0
Da un resultado de un Ibiza corto 5 puertas
- Byte 2 Car Derivate -------- 4
Da un resultado de un Ibiza corto 3 puertas
Da un resultado de un Ibiza ST
- Byte 2 Car Derivate -------- 1
Da un resultado de un Toledo
Por tanto, es cuestión de probar y ver si los cambios son efectivos.
Me explico:
Byte 18 :
Valor = 3 Seat León
Ruidos en el Nuevo Leon MK3 Foro: Leon III - Mecánica / Electricidad / Electrónica Autor: sarge Respuestas: 2506 |
Leon MK4 - Grupo! Foro: Entre amiguetes / Enlaces de interés / Off-topics Autor: builionfr Respuestas: 40 |
Copelas Leon FR 130cv Foro: Leon I - Mecánica / Electricidad / Electrónica Autor: SmirFR Respuestas: 9 |
Distancia y posición en mm de las insignias leon fr mk1 Foro: Leon I - Mecánica / Electricidad / Electrónica Autor: angelgvillalba Respuestas: 3 |
Problema con aire acondicionado León fr mk1 Foro: Leon I - Mecánica / Electricidad / Electrónica Autor: Paranohia Respuestas: 26 |
Usuarios navegando por este Foro: AhrefsBot, Anthropic y 3 invitados
