De momento, esto es lo que hay recopilado:
Mediasystem Plus
H24 - 0252
Navegador standard
H50 - 0514
Enviado desde mi SM-G950F mediante Tapatalk
León Mk3 - Actualización infotainment
- Seguidores: 183
- Favoritos: 41
- Vistas: 582.090
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000
Seguidores: kenny_fonseca, ncx, Lavadora, juancete, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, jeroc, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Cherno01 - Nuev@ por aqui
- Agradecido: 5 veces
Re: Actualización infotainment
Mm mm de la H24 no havia una versión 346?
dinoBCN - Primeros Pasos
Sí, pero no es oficial, estoy anotando sólo versiones que instalen en concesionario/fábricadinoBCN escribió:Mm mm de la H24 no havia una versión 346?
Hey, muy buenas a todos, quería haceros una consulta, tenía en mi Leon 5f 2016 con una pantalla de 5* y compre otra de 6.5* con modulo full link y sus respectivos cables. Lo tengo todo conectado perfecto, me salía que tenia protección de componentes porque la pantalla era de un ibiza, y se lo quite en una casa SEAT, pero ahora se me han borrado muchísimas cosas y no funcionan, dicen que hay que parametizarla, sabrían decirme como se hace o que debo hacer? Gracias a todos de antemano.
Ale3ex - Nuev@ por aqui
swords90 escribió:miceor escribió:Bueno, pues os pongo algunas actualizaciones QUE HE ENCONTRADO DE CASUALIDAD para Mib1 y Mib2.
Mib1 - Pantalla de 5.8"
Versión de la actualización : 0480 (Ultima versión compatible con el dispositivo)
Equipos compatibles con esta actualización : MIB 1GEN 5,8" con HW:041 FW:0425
Descargar el archivo desde:
Drive--- https://drive.google.com/open?id=0BxJGznK3NRXVRGRFWlJwaDhjNlU
Descomprimir el archivo. La estructura final debe quedar de la siguiente forma:
Carpeta: SEAT_NAV_SSB
Carpeta: SEAT_PLUS_SSB
Archivo: metainfo2.txt
Copiar las dos carpetas y el archivo en una tarjeta SD Class 10 de 8 GB (Si usais una tarjeta lenta, la actualización se puede eternizar, con la Class 10 tarda unos 40 minutos)
Buenos días!!!
He intentado descargar el archivo y me sale el siguiente error:
Sorry, you can't view or download this file at this time.
Too many users have viewed or downloaded this file recently. Please try accessing the file again later. If the file you are trying to access is particularly large or is shared with many people, it may take up to 24 hours to be able to view or download the file. If you still can't access a file after 24 hours, contact your domain administrator.
Podrías resubirlo? O esto es temporal?
Muchas gracias!!!
Me autocito, descargado e instalado sin problemas, debía de ser algún error temporal.
Gracias!!
swords90 - Nuev@ por aqui
Este es mi Infotaiment de Mayo de 2018....
Cupra R 300 DSG
- Agradecido: 938 veces
Una high, hay sw mas reciente.CarlosTSi escribió:Este es mi Infotaiment de Mayo de 2018....
juanbb - Leoner@ mayor del reino
- Agradecido: 354 veces
Amigo, tu sonido es BEATS Audio?, que tal va??, yo tengo problemas con el mio... a los 10 minutos comienza a escucharse un tronido en todas las bocinas, sin importar eq, orientacion de sonido, volumen de entrada, etc.
NOECUBI1 escribió:El mío venía con esta. Lo recogí él lunes[ Imagen ]
soropeza - Nuev@ por aqui
Buenas, de la de 8'' no hay nada?
Lo importante no es el destino sino el camino.
Simoncheli - Asidu@ en la selva
- Coche: Cupra Leon 2.0 TSI 300cv
- Agradecido: 20 veces
Ell sonido es el que viene de serie, no se si es Beats audio, no tengo ni idea. El equipamiento es excellence Edition. Y no he notado nada raro en él sonidosoropeza escribió:Amigo, tu sonido es BEATS Audio?, que tal va??, yo tengo problemas con el mio... a los 10 minutos comienza a escucharse un tronido en todas las bocinas, sin importar eq, orientacion de sonido, volumen de entrada, etc.
Saludos!NOECUBI1 escribió:El mío venía con esta. Lo recogí él lunes[ Imagen ]
NOECUBI1 - Aun con la L
- Agradecido: 9 veces
Yo con H50, 0514. en dispositivo 5F0035877.
Lleva beats audio, VC, lane assist, fist assit.
No lleva DAB, aunque he visto gente con mi dispositivo con DAB de serie, osea que sera cuestion de activarlo por vagcom, y la antena ver si la montaron en fabrica o hay que instalarlo.
juanenrak82 - Nuev@ por aqui
Viene con dab la radio, pero sin antena, tendras que comprarla, por 9 o 10 las venden en amazon.juanenrak82 escribió:Yo con H50, 0514. en dispositivo 5F0035877.
Buenas noches, he leído este hilo, pero no puedo solicitar por mensaje privado al ser nuevo.
Mis datos son:
número de pieza 5QA035824
HARD: H24
SOFW: 0241
CODEC 2101.0.0.8
Muchas gracias
Mis datos son:
HARD: H24
SOFW: 0241
CODEC 2101.0.0.8
Muchas gracias
AAAJDA - Nuev@ por aqui
Con tantas y tantas páginas e información me estoy haciendo la picha un lío... En las versiones de los infotaiments hay un nº de Hardware y otros números de software aparte de otras numeraciones y códecs de Bluetooth y demás. Hasta donde yo entiendo, el nº de la versión de Hardware no debería de cambiar si se actualiza el infotaiment ya que salvo que cambies la pieza el Hardware es el dispositivo físico, el modelo que cada uno lleva instalado. Por ejemplo yo tengo la versión de Hardware H41 y Software 0468, en el caso de que actualizara la versión solamente se cambiaría la versión de Software y quizás las versiones de la radio, Codecs de Audio o bluetooth pero la versión de Hardware debería ser siempre H41 ya que no he cambiado en ningún momento la pieza. Pero he estado leyendo lo que algunos han escrito y al actualizar también les ha cambiado la versión de Hardware cuando no debería de haber cambiado. Por otro lado coches de mismo equipamiento, versión incluso antiguëdad resulta que unos tiene Hardware H41, otros H40, otros H50... Por lo tanto si eso es así es un lío de narices porque cuando se refieren al Hardware no se están refieren a la pieza física que tenemos instalada en sí. El León 5 F es el mismo nombre para todos, versión del vehículo global, después cada uno con sus extras, versiones y demás pero la pieza es León 5F. No sé si me habéis entendido...
Warelio - Moderador de Racing
- Agradecido: 1145 veces
Warelio escribió:Con tantas y tantas páginas e información me estoy haciendo la picha un lío... En las versiones de los infotaiments hay un nº de Hardware y otros números de software aparte de otras numeraciones y códecs de Bluetooth y demás. Hasta donde yo entiendo, el nº de la versión de Hardware no debería de cambiar si se actualiza el infotaiment ya que salvo que cambies la pieza el Hardware es el dispositivo físico, el modelo que cada uno lleva instalado. Por ejemplo yo tengo la versión de Hardware H41 y Software 0468, en el caso de que actualizara la versión solamente se cambiaría la versión de Software y quizás las versiones de la radio, Codecs de Audio o bluetooth pero la versión de Hardware debería ser siempre H41 ya que no he cambiado en ningún momento la pieza. Pero he estado leyendo lo que algunos han escrito y al actualizar también les ha cambiado la versión de Hardware cuando no debería de haber cambiado. Por otro lado coches de mismo equipamiento, versión incluso antiguëdad resulta que unos tiene Hardware H41, otros H40, otros H50... Por lo tanto si eso es así es un lío de narices porque cuando se refieren al Hardware no se están refieren a la pieza física que tenemos instalada en sí. El León 5 F es el mismo nombre para todos, versión del vehículo global, después cada uno con sus extras, versiones y demás pero la pieza es León 5F. No sé si me habéis entendido...
Hola @Warelio
Sí, cuando actualizas el firmware, se cambia la versión de SW, que en tu caso tienes actualmente la 0468. La versión de HW nunca cambia, ya que corresponde al hardware (piezas físicas) de tu unidad infotainment.
Ahora, también tienes que tener en cuenta el nº de referencia de tu unidad. Para el HW41, hay dos referencias distintas, que pueden tener el mismo SW, en este caso la 5QA035846B y la 5QA035874. En este caso, la diferencia es hardware (aunque tengan la misma versión HW) ya que la -846B NO tiene salida de fibra óptica, lo que no ha hace compatible con VC, y la -874 SÍ tiene salida de fibra óptica, y es la que montan actualmente si pides el León con VC y navegador normal.
No tengo muy claro si le puedes meter una misma imagen de firmware a dos unidades con referencias distintas, aunque tengan las mismas versiones de HW y SW. Eso SEAT lo sabrá...
Lo que no he visto nunca, es que al actualizar una unidad, se te haya cambiado la versión de HW ¿Donde has leído eso?
Si las unidades tiene distintas versiones de HW, son fisicamente distintas, (una puede ser un navegador plus, o que esté fabricada por otro fabricante). Ahí si que no puedes usar un firmware de una H40 para una H41 porque te la cargarías, no arrancaría y tendrías un caro pisapapeles.
- Agradecido: 2021 veces
Incidencias varias nuevo Seat Leon Foro: Leon IV - Mecánica / Electricidad / Electrónica Autor: ma.cantero Respuestas: 324 |
León Mk3 - Cambiar SSS por Beats Foro: AudioCar y MultimediaCar Autor: aaronpet98 Respuestas: 1 |
Nuevo León eTSI 150 DSG Foro: Presentaciones Autor: jgleal Respuestas: 2 |
León Mk4 - Actualizaciones sistema de infotainment Foro: AudioCar y MultimediaCar Autor: Yundas Respuestas: 1730 |
Escapes al medio seat leon mk3 estilo golf 6 r Foro: Tuning Autor: yungchacho Respuestas: 1 |
