Buenas, en mi Leon ST del 2017 con full link, tengo instalada la versión actual:
Hardware: H31
Software: 0363
Cual es la versión actualizada necesito?
León Mk3 - Actualización infotainment
- Seguidores: 183
- Favoritos: 41
- Vistas: 582.483
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000
Seguidores: kenny_fonseca, ncx, Lavadora, juancete, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, jeroc, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: León Mk3 - Actualización infotainment
Deslizándose con CH4
lorens78 - Primeros Pasos
- Agradecido: 15 veces
Octacon escribió:Tu unidad es mib 2 standard, cambiarlo a la high si lo haces tu te puede costar entre 500€-600€ puedes usar algunas unidades Skoda o VW tambien entonces puedes bajar un poco mas el precio entre 350-500 aprox (eso si buscando mucho) tambien tienes que mirar si tienes audio beats porque entonces mi consejo es que cambiaras la el amplificador tambien. Hay compañeros del foro que dicen que tienen una solucion para que funcione el audio de la high con beats, pero si lo haces tu mi consejo es que cambies el amplificador, es pasar un cable de fibra y cambiar los cables de sitio, yo tengo parametros del amplificador beats high para Seat y tambien los esquemas. Asi que si te animad yo te puedo ayudar porque yo lo hice!RSCupra escribió:Buenas, mi leon 2019 me pone:
Hardware: H50
Entiendo que no es high no?? Cuanto cuesta cambiarlo a la high?? Qué aporta??
Gracias.
Hola tengo montado un ampli high y unidad también pero no suena muy bien ya que me distorsionan los twiters a lo mejor es por no llevar el dataset de SEAT creo que montaron el de golf 7 repineando como este, si pudieras hacharme una mano te lo agradecería y si hay que contribuir con algo igual, sé que los cupra r mk3 lo llevaban de serie así. Un saludo
BOSS_KILLER - Nuev@ por aqui
Hola, que ampli high llevas, por la manera que me lo dices eso de repinear me da a mi que algo hay mal alli, de la 5f al ampli que va por cableado o fibra? Si quieres que sea la convesacion mas agil, te he escrito un privado para decirte como contactar conmigoBOSS_KILLER escribió:Octacon escribió:Tu unidad es mib 2 standard, cambiarlo a la high si lo haces tu te puede costar entre 500€-600€ puedes usar algunas unidades Skoda o VW tambien entonces puedes bajar un poco mas el precio entre 350-500 aprox (eso si buscando mucho) tambien tienes que mirar si tienes audio beats porque entonces mi consejo es que cambiaras la el amplificador tambien. Hay compañeros del foro que dicen que tienen una solucion para que funcione el audio de la high con beats, pero si lo haces tu mi consejo es que cambies el amplificador, es pasar un cable de fibra y cambiar los cables de sitio, yo tengo parametros del amplificador beats high para Seat y tambien los esquemas. Asi que si te animad yo te puedo ayudar porque yo lo hice!RSCupra escribió:Buenas, mi leon 2019 me pone:
Hardware: H50
Gracias.
Octacon - Leoner@ avanzad@
- Agradecido: 90 veces
no funcionan los enlaces de descarga
carlosst77 - Asidu@ en la selva
- Agradecido: 12 veces
Buenos días a todos! Los que tengan una MIB2 H41 (Software Train MST2_EU_SE_ZR_P04xxx) tienen disponible la versión 0480 (hasta hace poco la última era la 0479) para actualizar la 5F. Os dejo el enlace de mega donde la he subido. Instalada hace un par de días y funciona correctamente
https://mega.nz/file/S6ghwJyI#TheBOJTH_ ... ipEWDrxYqk
lucky_38 - Nuev@ por aqui
- Agradecido: 14 veces
¿Se conocen las novedades?
Se venden difusores limpiaparabrisas: viewtopic.php?f=4&t=139668
Berma09 - Nuev@ por aqui
- Agradecido: 7 veces
yo tengo la 1477 juraría , puedo instalar la ultima directamente ? o hay que pasar por las intermedias??
carlosst77 escribió:yo tengo la 1477 juraría , puedo instalar la ultima directamente ? o hay que pasar por las intermedias??
La versión 480 que se comenta anteriormente es para las NaviSystem estándar (Technisat - MIB2STD), y tu tienes un NaviSystem Plus (Harman - MIB2HGH) por la versión de firmware que indicas (1447)
Son modelos distintos de fabricantes distintos, y cada una tiene que tener su propia versión de firmware. Por supuesto, NO SON INTERCAMBIABLES. Si le metes un firmware que no corresponda a tu unidad, obtendrás un caro pisapapeles.
- Agradecido: 2021 veces
Hola como les pasa a algunos yo tengo esto:
Leon mk3 marzo 2013 con Radio mib1
5F0035846
039
0151
Podéis decir si podemos actualizar a la versión 480 porque he leido por ahi que se queda la pantala en negro.
Mil gracias
5F0035846
039
0151
Mil gracias
Carlolet - Nuev@ por aqui
Re: Actualización infotainment
Prexus escribió:Hola amigos no se si recordais el post que os puse pidiendo ayuda sobre la instalacion de mi equipo con hw: 039 pues bien despues de estar en la seat y decirme que tenia que poner una radio nueba sin darme solucion ninguna y cobrarme 30 euros por el escaneo... pues revisando los archivos de aztualizacion... e consegido hoy aztualizarlo!!!
Muchas gracias a todos igualmente!
Hola una pregunta yo tengo la version 5f0035846 con hw 039 y soft 0151
Tu pudiste pasar de esta a la ultima para los mib1, por si podrias indicarme pasos.
Buenos días! Por fin me he animado a cambiar la pantalla de 6"5 a 8" y todo correcto. He actualizado después de leerme las 203 paginas de este post y encontrar los dichosos enlaces de descarga.
Tenía la 245, pasé por la 330 y ahora tengo la 346, que supuestamente es la ultima que puedo poner a mi H24. (No tengo navegador)
Pensaba que actualizando a la 0346 conseguiría el nuevo aspecto de mosaico, ya que no me gusta nada el de carrusel, de echo fue mi principal motivación para actualizar. Había visto fotos de gente supuestamente con la 346 que había conseguido el nuevo aspecto, pero ahora estoy
Hay forma de cambiarlo? la 346 no debería de llevar el nuevo aspecto mosaico? Con mi H24 sin navegador y v346, hay forma de seguir actualizando a una versión que tenga ese aspecto?
Gracias de antemano y muchas gracias por todo el curro que permite que gente como yo sin muchos conocimientos pueda hacerle tantas chapuzas a nuestros Leones
urkolink - Primeros Pasos
Carlolet escribió:Hola como les pasa a algunos yo tengo esto:
5F0035846
039
0151
Mil gracias
La versión 480 de la que se comenta en los últimos mensajes del hilo es para las unidades MIB2 Technisat, por lo que no es válida para tu unidad si es una MIB1.
jasoriab escribió:carlosst77 escribió:yo tengo la 1477 juraría , puedo instalar la ultima directamente ? o hay que pasar por las intermedias??
Osea que yo ya tengo la mas actual ??
carlosst77 escribió:Osea que yo ya tengo la mas actual ??
Eso es, la última versión conocida para el NaviSystem Plus de SEAT (MIB2High - Harman) es la 1447, que es la que indicas que ya tienes instalada.
jasoriab escribió:carlosst77 escribió:Osea que yo ya tengo la mas actual ??
León Mk4 - Actualización mapas MIB3 SEAT 2021 Foro: AudioCar y MultimediaCar Autor: jasoriab Respuestas: 88 |
Fallo centralita led seat leon mk3 Foro: Leon III - Mecánica / Electricidad / Electrónica Autor: Davidsuarez13 Respuestas: 0 |
León Mk3 - Modulo Carplay/Android Auto para MIB1 y MIB2 Foro: AudioCar y MultimediaCar Autor: excelance Respuestas: 1 |
Conociendo mi LEON "FR" Foro: General Autor: Josebgnz Respuestas: 0 |
Incidencias varias nuevo Seat Leon Foro: Leon IV - Mecánica / Electricidad / Electrónica Autor: ma.cantero Respuestas: 324 |
