León Mk3 - Actualización infotainment
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000
Seguidores: kenny_fonseca, ncx, Lavadora, juancete, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, jeroc, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: Actualización infotainment
Notapor tevaadarelsol el 03 Dic 2016, 10:43
miceor escribió:La otra opción, como ya dije en su momento:
miceor escribió:
Cristianibias escribió:Bueno despues de actualizarlo todo ha salido bien lo unico que me ha desaparecido la opcion de conectar por mirrolink si alguien puede echarme una mano
He estado dandole vueltas al tema de que desaparezca el Mirrorlink en al menos un caso que conocemos.
Me gustaria saber si antes de la actualización llevaba el VIM+Mirrorlink desactivado, no sea que al llevarlo así la actualización interprete que no está disponible y lo deja fuera.
Se me ocurre probar en ese caso en concreto a entrar en el menú de ingeniero y Activarlo desde el menú y ver que ocurre. Si lo haces, luego salte del menú de ingeniero y reinicia el infotainment a ver si aparece de nuevo el Mirrorlink.
Tambien puedes comprobar estos valores:
En la 5F, entra en Vehicle configuration y abajo del todo mira esto -----Mirror_link -- (Function off_HMI off).
Si lo cambias de valor, Reinicia el Infotainment.
Comprueba que esté como se indica.
Por tanto yo haría lo siguiente:
Con OBDeleven :
Modulo 5F
- Vehicle configuration -- Opciones
----- Mirror_link -- (Function off_HMI off - Fucntion on_HMI on - Function on_HMI off)
Yo lo tengo en Function off_HMI off
Si no os deja cambiarlo, entrad a Cambiar sesión dentro de la 5F y elegid Modo desarrollador y hacedlo como desarrolladores.
Asi deberia funcionar.
Con VAgCom
Modulo 5F
Adaptations menu
Vehicle Configuration
Buscar Mirrorlink y cambiar el valor de 0 a 1
En VagCom no sé si me he saltado algo, lo estoy poniendo de memoria(Poned los pasos si lo haceis alguno)
Reportad resultados
Gracias @miceor, acabo de probarlo con el OBDEleven.
En mi caso el valor estaba en Function off_HMI off, lo he cambiado a Function on_HMI on y ya me sale el menú en la pantalla, lo que no sé es si será funcional porque no tengo móvil con mirrorlink para probarlo...
Sent from my Nexus 5 using Tapatalk
tevaadarelsol
Agradecido: 199 veces
Notapor miceor el 03 Dic 2016, 10:47
Gracias por el reporte.
Si antes era funcional, ahora lo es también.
Cambiandolo unicamente afecta a la visualización en pantalla.
Me alegro que por fin lo tengamos controlado, al menos con OBDeleven.
¿Entraste en modo normal o como desarrollador?
Para ir actualizando el post y poner los pasos definitivos.
He comprobado el mio y también está en On todo, no me habia fijado desde la última vez que lo miré.
miceor
Agradecido: 1256 veces
Notapor tevaadarelsol el 03 Dic 2016, 12:01
miceor escribió:Gracias por el reporte.
Lo he podido hacer en modo normal
tevaadarelsol
Notapor corderazo el 03 Dic 2016, 12:08
Ok, gracias, lo pruebo cuando salga del curro a las 14
corderazo
Notapor jony83 el 03 Dic 2016, 14:20
He actualizado con la 330 y todo bien . Al intentar actualizar a la 0346 me sale esto, y no puedo hacer nada.
Puede ser que se me haya descomprimido mal y no estén todos los archivos????
jony83
Agradecido: 20 veces
Notapor jeroc el 03 Dic 2016, 14:30
Actualizado mi equipo, un 5,8 my15 con navegador y sound system con hw40 y software 425 al 480... Todo ok, a falta de probarlo mas mas parece que va algo mas fluido... Y no se si me lo parece pero me da la impresion que los detalles graficos estan mas pulidos, aunque el interface es el mismo.
No tengo vagcom por lo que no puedo ver si hay algun error registrado.
jeroc
Agradecido: 10 veces
Notapor golf_1990 el 03 Dic 2016, 15:21
jony83 escribió:He actualizado con la 330 y todo bien . Al intentar actualizar a la 0346 me sale esto, y no puedo hacer nada.
No has mezclado las dos versiones en la sd no ?
golf_1990
Notapor manugl el 03 Dic 2016, 15:37
miceor escribió:Me temo que no
Me temo que a un hw 039 y software 0421 tampoco se le puede hacer nada,no?
manugl
Notapor jony83 el 03 Dic 2016, 15:52
Nono. He formateado la tarjeta y he copiado el nuevo
jony83
Notapor jony83 el 03 Dic 2016, 19:27
Ya he descubierto el problema....luego intentare actualizar.
jony83
Notapor miceor el 03 Dic 2016, 20:33
Ya está actualizado el Post de las actualizaciones con el procedimiento de Actualización y como solucionar los errores que se puedan producir así como la desaparición del Mirrorlink en la pantalla.
Si surgiese algún otro contratiempo digno de mención lo incluiré en el Post.
Lo teneis aqui: viewtopic.php?f=9&t=118140&start=600#p1928908
miceor
Notapor corderazo el 04 Dic 2016, 06:50
Buenos dias ya vuelve a salir el logo de mirrorlink, pero en opciones no sale la opción de preferencia de uso y sólo me arranca android auto, a ver si lo desinstalo luego y pruebo
corderazo
Notapor miceor el 04 Dic 2016, 11:21
Tendrás que reiniciar el Infotainment para que lea los parámetros, supongo.
miceor
Notapor aprietatuercas1974 el 04 Dic 2016, 12:13
corderazo escribió:Buenos dias ya vuelve a salir el logo de mirrorlink, pero en opciones no sale la opción de preferencia de uso y sólo me arranca android auto, a ver si lo desinstalo luego y pruebo
tu telefono es compatible con mirrorlink,porque si no lo es cuando conectas el telefono android te sale el icono de con lo que es compatible.
Han cambiado la interfaz,antes se cambiaba la conexion en ajustes y ponias mirrorlink o android auto,ahora conectas el telefono y si es compatible con los dos te deja elegir como conectarlo
Última edición por aprietatuercas1974 el 04 Dic 2016, 13:30, editado 1 vez en total
aprietatuercas1974
Coche: Leon MK1 2.8 Cupra 4 V6 204cv
Agradecido: 356 veces
Notapor golf_1990 el 04 Dic 2016, 13:13
Pues a mi me ha desaparecido el de mirrorlink y el de apple...WTF
@miceor
golf_1990
