O prueba también en ajustes "reestablece de fábrica" para que borre todo, puede que solucione el problema.
León Mk3 - Actualización infotainment
- Seguidores: 183
- Favoritos: 41
- Vistas: 572.479
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000
Seguidores: kenny_fonseca, ncx, Lavadora, juancete, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, jeroc, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: Actualización infotainment
Lo probare
csabafr2013 - Asidu@ en la selva
- Agradecido: 13 veces
Si te sirve de algo, restablecido de fabrica y con errores
corderazo - Primeros Pasos
Si pero los errores os borre
que version es la que has puesto
aprietatuercas1974 - Aqui + que con la novi@
- Coche: Leon MK1 2.8 Cupra 4 V6 204cv
- Agradecido: 356 veces
Primero la 330 y luego la 346
Hola amigos lo intente actualizar otra vez pero no se puede
Enviado desde mi iPad utilizando Tapatalk
Si sabe alguno cómo hacerlo que me ayude por favor
csabafr2013 escribió:Primero la 330 y luego la 346
Has conseguido poner el St fr ?
golf_1990 - Asidu@ en la selva
- Agradecido: 12 veces
No tío no hay manera
Si sabe alquilen con el obdelven reiniciar el infotaimen o volver actualizarlo
csabafr2013 escribió:Si sabe alquilen con el obdelven reiniciar el infotaimen o volver actualizarlo
Creo que te estás desesperando un poco, tienes que hacer las cosas con paciencia, y dedicarle tiempo.
Y por lo visto o se te ha instalado mal la actualización o has desconfiado mediante obd o vagcom
Enviado desde mi Mi-4c mediante Tapatalk
Davido2790 - Leoner@ avanzad@
- Agradecido: 81 veces
Vale, leida las últimas 20 páginas, y veo que para el H30 no hay nada para actualizar
LeidenSpain - Aqui + que con la novi@
- Agradecido: 59 veces
No sé pero bueno cuando salga otra actualización ya lo haré de momento funciona bien ahora pasientia
csabafr2013 escribió:No sé pero bueno cuando salga otra actualización ya lo haré de momento funciona bien ahora pasientia
Vamos a ver. Estas cosas hay que tomarselas con calma porque si no tu te atacas de los nervios y los demás no podemos ayudarte porque al final no alcanzamos a comprender finalmente que es lo que te está pasando y lo que estás haciendo.
No estamos en un chat, es un foro y para un buen entendimiento y un buen soporte hay que exponer con claridad que está ocurriendo y esperar que alguién pueda dar soporte al problema,(Muchas veces no se puede contestar de inmediato, existe una vida fuera de este foro) si no esto se llena de mensajes solapados que tienes que ir saltandote para poder llegar a un correcto entendimiento.
Creo entender lo siguiente:
Después de la actualización todo Ok, has detectado que no te aparece el modelo ST FR en pantalla y además en la sección del clima en Setup no te aparece la imagen y no te deja operar con esa pantalla.
¿Es correcto?
Lo de la imagen del ST FR ya te dije ayer como se hace y no hay otra manera.
Una vez realizado, normalmente con cambiar de pantalla (Radio) y volver a Car, se refresca la pantalla y ya sale el modelo programado.
Otra opción es reiniciar el infotainment, pulsando en el botón del volumen hasta que se reinicie.
Al hacerlo deberá arrancar mostrando el logotipo SEAT FR, si no es así algo has hecho mal.
Lo del clima no tengo ni idea el motivo por el cual no te aparece en la sección Setup.
Pero podemos comprobar por si acaso :
en la 5F
- Car Function Adaptations Gen 2
------ Menu display clima configuration -- OPCIONES: (Activado)
------ Menu display clima configuration over threshold -- OPCIONES: (Activado)
- Car Function List Bap Gen 2
------ Climatic master 0x01 -- OPCIONES (Activado - No activado)
------ Climatic master 0x01 msg bus -- OPCIONES (Bus datos confort)
Ya sé que el menú principal te aparece pero comprueba estos datos por si cambiase algo.
Hasta donde yo sé no se puede bajar de versión.
Sin embargo creo que si que se puede REINSTALAR la misma versión que tienes, incluso permite reinstalar un solo modulo de la lista que aparece seleccionada cuando vas a actualizar .
Es posible que por una mala lectura de algún modulo en la tarjeta no haya instalado correctamente.
No tienes porque preocuparte al intentar reinstalar, si no es posible realizarlo te lo dirá y no se producirá la instalación.
Yo no puedo garantizarte que sea así tal y como te he dicho porque no lo he realizado, pero algo he leido al respecto y además tiene cierta lógica que permita la reinstalación en caso de fallar parte de la actualzación.
Si realizas los cambios de lo del ST FR comentanos que te sale al reiniciar el infotainment, que modelo de coche te sale (Pero fijate bien) el FR solo se diferencia del normal por el paragolpes delantero que la linea frontal sube hasta la matricula y el logo en la rejilla, pero claro es muy pequeño.
De todos modos lo tienes facil: Hazlo mediante Aplicaciones del Obdeleven que es mas rapido. Cambialo al Cupra y comprueba si cambia.
- Agradecido: 1256 veces
Usuarios navegando por este Foro: Semrush y 9 invitados
