Seguidores: golf_1990, josusanchez5b, Jastur, r11ourense, MerioE, davidddgt, jose.a.llamas, gato125, Pkt, byChule, Hovig, SorianoFco, jygalvan, CubanPitbull, corderazo, israher, iDavid9669, nyro, pirulo79, Edu1589, ramargo75, javi.ferrer, kikelin, aleejandroogm, Trimmer, car212121, LeoST, Besaygf, kinipc, Rasekfighter, Romera, MartinLeon, camamaleon, Aceroinox1a, jramis, Juanquique, josele77, marlop, Peje, Pedrost, bailyibz, wiki88, teltronik, gogua, sirkez, carlosgzlez, mcecho, genialsoft, aironsam14, JoseCa, Dandy_gsi, vanscampa, Joseibz, trekam, La_jungla, jorgecrackets, aigort, msmdraven, IRO, Jorge75016, alejandro_javier, ivan0909, jmfcoto, viktor_ct_95, maxxg2, olgalberto1, danifusi, Josepo79, er_trompe, miyobe, jande, Petri, itz18, jagman, serguey79, rafapadilla93, Mate, undernok, lead, lead, csabafr2013, jluis, olmeras, LeidenSpain, osjamil, Valerofr150, flope63, Herrdoktor, pocososinos, carrasco13, pichonclv, C.reina, Daner84, inamarlo, aguscalderon, BaZZ, yujakantabro, Fonek, LARABA, juanmaroger, juanmac, Kipu, IvanMc2, garrafa2, Linker89, mihai G, Igor, bronce702, creasy1977, Gsclosada, lebowski, jaro_84, charly425, leonfr76, DBS83, joseanvazquez501, M3rs, borgio, NOCIVOX, FcoJ.M.N., VillaSB, t4alberto, lytry32.hc, david_gz, Kasky, diegol147, jasoriab, jninomo, jmiturbe, chetelopez, utopia95, Dreziel, jonatan1988, xsoldadito, Illan, Fernandoestrada, jd_zuri, Juande667, xjuliox, Bettor, solanomor01, Chinyero, volkov, braulioT, Maikermx, iNowack, D83, MORKAS, dRoXe, JaviMarquez, danitre, Davi_TGI, DiegoR, ertate, cuenka16, nicotzioras, Spok68, urbion, linxes, kukikukarron, Talnoseque, Hyperr, VapaV, jfermar, Moigijon, slyjay73, DuckToy, nachomart, Iosu21, sbarri, sebasresa, Beiró, Llisus, agus_piscis10, Action SVG, Alc16, Trivi83, eyebee, riclanico, Per3zo, Qore, lolorm, abollao, Alvi, sergi303, Xilenos, barret, Gus_Fring, malloc, TomH30, jmofcb, paco_22_22, luigi323, Chelazo, dani10s, victor david, Yeiem93, Luiggi7, Guillen222, yoflipo, nenazojuanma, nitro_g4074, Senuto, gabivvamesia, javichu312, richard_11, Yery, Ivensound, El_pelos44, rvicario76, Mr.Chuflas, subaru_3, eruizm, Gomez89, barubita, Nicoplas, javibmw, el_noi_80, kapi21, satoo, barrosdepor, camaon99, craken, Flow-Rider, Castro87, Kikedecefe, xexpir, Cristian2014mx, _Juansp, jornefra, cucci, Pablitofr, Pablitofr, Rober_SR, kevinhtbs, chocoleitos, RamonLaC, cesarsl, drnrd, conquepoquico, hectordrums, Neuw84, bertoco, dondani96, cupralex, Octacon, pablomus85, josean-opc, davidap13, Raaz, erlanz, canijo82, MarcosRG86, Alianma, SinName, mSx, evomaoleon, BertopenST, a.cuadros71, Lumara, Gendos22, borjayadri2, litllevill, Jandrew, galelir, Josep20, borjiguez, THC77, di360, Juanjocantabria, grijan 2.0, copii92, JDMG, Morales92, nadiia.bcn93, yo_javi89, yurkli, Atajunen, carlo13, Desertcuervo, floppy666, amg129, manjerico, Franr50, iNFeCTeD, Rotemburgero, Link, kivamz, dj_ferrix, manu5, Vagabundo, aaronfdez, Manzi, Perilla, juanaco, pepetgi, pistoleromtb, cp_jj, diepecu2, Freddy169, Welmonk, JaquetónST, alrodri, LuisNM, Rekoba, bizu, ginyu 83, ephreon, rr7mo, Def89, CrisFRST5F, Mohoska, gilen44, ayl, SantiPMI, Jesús Peinado, 05kar, Lata8, Adrián pcg, Warelio, carlosVACA, trazas, barris31, danieleon, enriquevalera, antonioagui95, tito68, Sarge86, victorvOrtiz, bigpicha, ericoperico, JulinM, AlvaroRamlo, josermancol, Davidv, flotter, V de Viana, zainao, LeónST, rubiotuning, RacingSport
Notapor JoseXeiko el 16 Feb 2017, 21:48
ThExxDooM escribió:Hola, lo primero mil gracias a @miceor por toda la información y ejemplos, he podido activar todas las funciones que he querido salvo la de coming/leaving home, tengo luces full led pero no tengo sensor de luz/lluvia... He leído por todo el post y no me ha parecido encontrar alguna solución al caso, por eso quería preguntar si alguien al final ha podido hacerlo sin el sensor y que me explique un poco cómo se hace que llevo 2 días dándole vueltas y no hago otra cosa que probar con el coche ^_^ Gracias!
Iluminación de confort:
Coming Home Verbaustatus:
no disponible--------------------------->manual(si lo pones en automatico NO FUNCIONA
Menuesteuerung Coming Home Werkseinstellung:
inactivo--------------------------------->activado(los segundos que quieras que te aparezcan en el menu)
Menueeinstellung Cominghome:
inactivo----------------------------->activado
Coming home Leuchten:
luz de cruce------------------------>Fog lights si quieres que se enciendan los antinieblas en lugar de las de cruce
Coming-home Einschaltereignis:
ignition--------------------------------->driver door
El resto lo dejas como estaba.
El leaving home no funciona en los coches que no tienen sensor de luz.(Por lo menos lo que yo he visto y probado 1millon de veces)
El coming home se activa dando una rafaga antes de abrir la puerta del conductor, y con el contacto quitado.
Funciona perfectamente y queda bastante chulo.
Ya si quieres cambiar las luces que se enciendan con el coming home sigue los mods que hay en el primer post.
Seat Ibiza Style Connect Blue :culo2:
-Obdeleven Pro
-ELM 327
-Modo espejo sin VIM
JoseXeiko
Agradecido: 44 veces
Notapor ThExxDooM el 16 Feb 2017, 23:05
Gracias por responder, mañana lo pruebo y comento si me sale :ok:
ThExxDooM
Coche: Leon MK3 1.4 TSI 122cv
Notapor JoseXeiko el 17 Feb 2017, 12:13
Buenos días, he intentado hacer el mod de @xagico de cambiar el logo de seat, y creo que coincide con este mod que puso @ miceor, y no cambia la pantalla incial sino el logo de seat.
Cambiar pantalla Inicial
Con este mod, cambiamos la pantalla primera que nos muestra en el infotainment
1 - Módulo 17 - Cuadro de instrumentos- Code (25327)
2 - Codificación extendida (Modo texto)
3 - Pantalla inicial
4 - Seleccionar una de las ocho opciones - Variante 1 por defecto
Hay que tener en cuenta que yo lo hice con el fis monocromo, y lo unico que paso fue que al arrancar el coche no me apareció la palabra seat en el fis. Puede ser(haber si alguien lo comprueba) que si es el fis a color si cambie y se vea bastante diferente.
Haber que tal.
-Obdeleven Pro
-ELM 327
JoseXeiko
Notapor hagiwara2002 el 17 Feb 2017, 16:39
hagiwara2002
Notapor TSILimited el 17 Feb 2017, 20:27
Perdonad mi desconocimiento pero acabo de descubrir este aparato en el foro. ¿Basicamente es como un cable Vagcom pero con el móvil a través de bluetooth? ¿Teniendo el 12.12.0 merece la pena comprarlo?
- Entrando en el mundo SEAT -
!Para las rectas, motores; y para las curvas, cojones!
En este mensaje, TSILimited ha recibido un agradecimiento de:
Kaisen (17 Feb 2017, 21:26)
TSILimited
Coche: Leon MK3 1.2 TSI 105cv
Agradecido: 69 veces
Notapor Kaisen el 17 Feb 2017, 21:31
TSILimited escribió:Perdonad mi desconocimiento pero acabo de descubrir este aparato en el foro. ¿Basicamente es como un cable Vagcom pero con el móvil a través de bluetooth? ¿Teniendo el 12.12.0 merece la pena comprarlo?
Si, exacto, yo tengo el 12.12 y desde que tengo este no lo he vuelto a usar, es muchisimo mas comodo, el único problema es que necesitas tener datos en el movil para poder usarlo, pero hoy en dia todos lo tenemos, y sino wifi, aunque esto ya no es tan comodo.
En este mensaje, Kaisen ha recibido un agradecimiento de:
TSILimited (17 Feb 2017, 22:00)
Kaisen
Agradecido: 380 veces
Notapor TSILimited el 17 Feb 2017, 21:59
Me acababa de contestar antes de leer tu respuesta. Pero ahora me surge otra duda. ¿El OBDeleven solamente funciona en dispositivos Android? ¿No lo hay para iOS? Justo cuando me cambio de bando :cry:
TSILimited
Notapor Fonek el 17 Feb 2017, 23:08
Siento decirte que solo funciona con Android.
A mí me ha pasado igual. Aunque yo tenía IOS un poco antes que el León.
Yo lo que suelo hacer es bajarme la tablet al coche que si es android. Aunque lo que tengo pensado hacer es pillarme un Xperia Z de segunda mano y dejarlo exclusivamente para el coche, y usarlo para el Mirror link. Para música, Gps, y para el Obdeleven claro. Lo único que tiene que compartir internet del iOS al Android cada vez que quieras usarlo para Obdeleven
En este mensaje, Fonek ha recibido un agradecimiento de:
TSILimited (18 Feb 2017, 00:20)
Fonek
Agradecido: 26 veces
Notapor Gerni9 el 17 Feb 2017, 23:20
hagiwara2002 escribió:Hola, una pregunta para poder mostrar el modelo cupra en estado de vehiculo y demas como seria? Para el FR se que es esto:
Yo hice esa pregunta hace tiempo, sin respuesta. El mio es un FR pero en el estado del vehículo por mucho que cambio el coche me sigue saliendo el mismo. Un Style creo. Tema de pantalla 5,8 " y de los primeros.
Gerni9
Notapor IntruderST el 17 Feb 2017, 23:44
Os dejo vídeo de los halogenos
https://youtu.be/chJp9Cn6J6g
Se quedan apagadas las diurnas hasta que acaba intermitente, no está así en la lista de mods @miceor
3 - Leuchte4TFL LB4
4 - Lichtfunktion C 4 -- (Cambiar valor a Not Active)
5 - Dimmwert GH 4 -- (Cambiar valor al deseado)
6 - Lichtfunktion G 4 -- Cambiar a BLINKEN LINKS AKTIV (beide Phasen)
7 - Dimming direction GH 4 -- (Cambiar valor a Minimize)
8 - Leuchte5TFL RB32
9 - Lichtfunktion C 5 -- (Cambiar valor a Not Active)
10 - Dimmwert GH 5 -- (Cambiar valor al deseado)
11 - Lichtfunktion G 5 -- Cambiar a BLINKEN RECHTS AKTIV (beide Phasen )
12 - Dimming direction GH 5 -- (Cambiar valor a Minimize)
Espero q os guste
MI MAQUINA http://www.clubseatleon.net/viewtopic.php?f=43&t=119015
EN UNA FABRICA DE COCHES LO MAS SENCILLO SON LOS COCHES
IntruderST
Agradecido: 31 veces
Notapor TSILimited el 18 Feb 2017, 00:20
No es mala idea, de hecho hasta ya me merecería arreglar la pantalla del que tenía antes. Gracias por la idea Fonek :ok:
TSILimited
Notapor cvillajos el 18 Feb 2017, 05:57
Las de 5,8" están muy limitadas respecto a las configuraciones de los vehículos a mostrar, pero las 6,5" dan mucho juego:
http://www.clubseatleon.net/viewtopic.php?f=8&t=119490&start=15#p1921610
cvillajos
Agradecido: 3575 veces
Notapor flope63 el 18 Feb 2017, 11:07
Chicos,para ios existe aplicacion ican, que es como vagcom,lo hizo chaval que se llama eltiobarbas,funciona con obd2 wifi, y sirve perfectamente para las codificaciones que uno puede necesitar,no hace VIM como obdeleven, pero para reste vale
En este mensaje, flope63 ha recibido 2 agradecimientos de:
TSILimited (18 Feb 2017, 11:13), XaGiCo (18 Feb 2017, 11:19)
flope63
Agradecido: 23 veces
Notapor hagiwara2002 el 18 Feb 2017, 12:13
pues si quieres como el FR pon tal cual he puesto la imagen, yo es que quería saber tb el cupra.
hagiwara2002
Notapor SiiLVYA el 18 Feb 2017, 22:16
Hola, una pregunta. En el apartado "reiniciar" las opciones "reinicio completo" y "reinicio del software" que hacen exactamente? Lo pone todo de fábrica? Gracias.
SiiLVYA
Usuarios navegando por este Foro: Majestic-12 [Bot] y 21 invitados
