Seguidores: golf_1990, josusanchez5b, Jastur, r11ourense, MerioE, davidddgt, jose.a.llamas, gato125, Pkt, byChule, Hovig, SorianoFco, jygalvan, CubanPitbull, corderazo, israher, iDavid9669, nyro, pirulo79, Edu1589, ramargo75, javi.ferrer, kikelin, aleejandroogm, Trimmer, car212121, LeoST, Besaygf, kinipc, Rasekfighter, Romera, MartinLeon, camamaleon, Aceroinox1a, jramis, Juanquique, josele77, marlop, Peje, Pedrost, bailyibz, wiki88, teltronik, gogua, sirkez, carlosgzlez, mcecho, genialsoft, aironsam14, JoseCa, Dandy_gsi, vanscampa, Joseibz, trekam, La_jungla, jorgecrackets, aigort, msmdraven, IRO, Jorge75016, alejandro_javier, ivan0909, jmfcoto, viktor_ct_95, maxxg2, olgalberto1, danifusi, Josepo79, er_trompe, miyobe, jande, Petri, itz18, jagman, serguey79, rafapadilla93, Mate, undernok, lead, lead, csabafr2013, jluis, olmeras, LeidenSpain, osjamil, Valerofr150, flope63, Herrdoktor, pocososinos, carrasco13, pichonclv, C.reina, Daner84, inamarlo, aguscalderon, BaZZ, yujakantabro, Fonek, LARABA, juanmaroger, juanmac, Kipu, IvanMc2, garrafa2, Linker89, mihai G, Igor, bronce702, creasy1977, Gsclosada, lebowski, jaro_84, charly425, leonfr76, DBS83, joseanvazquez501, M3rs, borgio, NOCIVOX, FcoJ.M.N., VillaSB, t4alberto, lytry32.hc, david_gz, Kasky, diegol147, jasoriab, jninomo, jmiturbe, chetelopez, utopia95, Dreziel, jonatan1988, xsoldadito, Illan, Fernandoestrada, jd_zuri, Juande667, xjuliox, Bettor, solanomor01, Chinyero, volkov, braulioT, Maikermx, iNowack, D83, MORKAS, dRoXe, JaviMarquez, danitre, Davi_TGI, DiegoR, ertate, cuenka16, nicotzioras, Spok68, urbion, linxes, kukikukarron, Talnoseque, Hyperr, VapaV, jfermar, Moigijon, slyjay73, DuckToy, nachomart, Iosu21, sbarri, sebasresa, Beiró, Llisus, agus_piscis10, Action SVG, Alc16, Trivi83, eyebee, riclanico, Per3zo, Qore, lolorm, abollao, Alvi, sergi303, Xilenos, barret, Gus_Fring, malloc, TomH30, jmofcb, paco_22_22, luigi323, Chelazo, dani10s, victor david, Yeiem93, Luiggi7, Guillen222, yoflipo, nenazojuanma, nitro_g4074, Senuto, gabivvamesia, javichu312, richard_11, Yery, Ivensound, El_pelos44, rvicario76, Mr.Chuflas, subaru_3, eruizm, Gomez89, barubita, Nicoplas, javibmw, el_noi_80, kapi21, satoo, barrosdepor, camaon99, craken, Flow-Rider, Castro87, Kikedecefe, xexpir, Cristian2014mx, _Juansp, jornefra, cucci, Pablitofr, Pablitofr, Rober_SR, kevinhtbs, chocoleitos, RamonLaC, cesarsl, drnrd, conquepoquico, hectordrums, Neuw84, bertoco, dondani96, cupralex, Octacon, pablomus85, josean-opc, davidap13, Raaz, erlanz, canijo82, MarcosRG86, Alianma, SinName, mSx, evomaoleon, BertopenST, a.cuadros71, Lumara, Gendos22, borjayadri2, litllevill, Jandrew, galelir, Josep20, borjiguez, THC77, di360, Juanjocantabria, grijan 2.0, copii92, JDMG, Morales92, nadiia.bcn93, yo_javi89, yurkli, Atajunen, carlo13, Desertcuervo, floppy666, amg129, manjerico, Franr50, iNFeCTeD, Rotemburgero, Link, kivamz, dj_ferrix, manu5, Vagabundo, aaronfdez, Manzi, Perilla, juanaco, pepetgi, pistoleromtb, cp_jj, diepecu2, Freddy169, Welmonk, JaquetónST, alrodri, LuisNM, Rekoba, bizu, ginyu 83, ephreon, rr7mo, Def89, CrisFRST5F, Mohoska, gilen44, ayl, SantiPMI, Jesús Peinado, 05kar, Lata8, Adrián pcg, Warelio, carlosVACA, trazas, barris31, danieleon, enriquevalera, antonioagui95, tito68, Sarge86, victorvOrtiz, bigpicha, ericoperico, JulinM, AlvaroRamlo, josermancol, Davidv, flotter, V de Viana, zainao, LeónST, rubiotuning, RacingSport
Notapor cvillajos el 03 Abr 2017, 16:05
bronce702 escribió:Hola, le ha pasado ha alguien que al meter el mod del stagin de agujas no le funcione cuando mete el contacto la primera vez pero luego si saca la llave y lo vuelve a meter si? Ha que es debido?
Detalles y comentarios aquí:
http://www.clubseatleon.net/viewtopic.php?f=8&t=97892
cvillajos
Agradecido: 3572 veces
Notapor bronce702 el 03 Abr 2017, 16:19
Gracias!
bronce702
Notapor turbin el 03 Abr 2017, 20:17
Hola compis, ayer baje al coche y estuve mirando de activar alguna cosilla más, unas bien y otras no, ante todo, agradecer el gran trabajo de los compañeros que comparten con nosotros estos mod's y activaciones.
- Visualizar Menú Limpiacristales -> ya estaba activo, pero no veo donde.
- Visualizar Menú Frenos -> ya estaba activo, pero no veo donde.
- Activar fondo carbono en Infotainment -> Realizado Ok.
- Activar alarma perimetrica en coches sin alarma -> Realizado Ok.
- Apertura total del techo solar en apertura confort -> ya estaba activo, pero cuando sueltas el boton se queda donde sueltes no sigue solo abriendose.
- Activación luces de emergencia en caso de colisión -> Realizado
- Activación luces de emergencia en caso de frenada brusca -> Realizado Ok.
- Activar luces automaticas en caso de lluvia -> nok, me da error de codigo
- Coming Home y Leaving Home solo DRL, sin luces de cruce (Faros Led) -> Realizado pero no funciona, se sigue enciendo todo, lo curioso es que ahora la iluminación del cuadro varia su intensidad según la luz exterior, y no se si ya lo hacia o es por tocar algo de esto.
Sigo sin que me funcione lo de visualizar perfiles de conducción al arrancar, quizas no sea compatible con algo que tenga activo, como el fondo de carbono o el test agujas...
Volkswagen Touareg 3.0 Tdi 240cv. Premium Bluemotion Technology Tech.
turbin
Agradecido: 47 veces
Notapor csabafr2013 el 03 Abr 2017, 20:29
Hola una pregunta sabéis si los mod del leon funciona con el ateca
Enviado desde mi iPad utilizando Tapatalk
csabafr2013
Notapor diego_alx el 03 Abr 2017, 20:57
Alguien se fijó que ahora en la app de obdeleven hay una aplicación para desactivar el sistema start/stop? Sabéis que método usa exactamente para desactivarlo esa app?
Enviado desde mi Aquaris M5 mediante Tapatalk
diego_alx
Coche: Leon MK3 1.5 TGI 130cv
Notapor javigody el 03 Abr 2017, 21:09
diego_alx escribió:Alguien se fijó que ahora en la app de obdeleven hay una aplicación para desactivar el sistema start/stop? Sabéis que método usa exactamente para desactivarlo esa app?
Lleva bastante tiempo esa app, la que si han metido nueva es la de las señales de tráfico y el highbeam
javigody
Agradecido: 274 veces
Notapor diego_alx el 03 Abr 2017, 21:13
Ah ok, es que de momento no tengo el aparato, estoy pensando en comprarlo, pero le hecho un vistazo a la app alguna vez para ver que ponen. No sabes por casualidad qué método usa para desactivarlo verdad?
En este mensaje, diego_alx ha recibido un agradecimiento de:
xantia333 (03 Abr 2017, 22:08)
diego_alx
Notapor javigody el 03 Abr 2017, 21:28
Cuando yo lo hice cambio solo voltaje
En este mensaje, javigody ha recibido un agradecimiento de:
diego_alx (03 Abr 2017, 21:32)
javigody
Notapor cvillajos el 03 Abr 2017, 22:56
csabafr2013 escribió:Hola una pregunta sabéis si los mod del leon funciona con el ateca
Habrá algunos que sí, otros que serán parecidos y otros que no valdrán. Todo depende de centralitas y equipamiento.
csabafr2013 (04 Abr 2017, 05:14)
cvillajos
Notapor cvillajos el 03 Abr 2017, 23:06
turbin escribió:Hola compis, ayer baje al coche y estuve mirando de activar alguna cosilla más, unas bien y otras no, ante todo, agradecer el gran trabajo de los compañeros que comparten con nosotros estos mod's y activaciones.
Algunos, sobre todo los del tema luces, no los tengo y no sabría muy bien decirte....
Pero los dos primeros (de habilitar un menú) lo harían sobre 'CAR > Ajustes' seguramente.
Sobre el que no consigues de los modos de conducción al arrancar, lamento decirte que por eso no es, porque yo lo tuve una temporada activo conjunto a ambos que comentas que pueden no ser compatibles.
Si me acuerdo mañana miro el historial en mi PC para comparar cambios.
cvillajos
Notapor YeSL el 04 Abr 2017, 11:40
Buenas chicos, a ver si me podéis ayudar, tengo la pantalla de 5,8 y ya tengo el cable mitsumi RCA y ahora ando volviéndome loco para encontrar un cable que me conecte el móvil con RCA, tenéis algún enlace dónde encontrarlo? Ya que por ahora solo he podido comprobar el VIM con una Wii jajaja
Muchas gracias!
YeSL
Notapor cvillajos el 04 Abr 2017, 12:48
YeSL escribió:Buenas chicos, a ver si me podéis ayudar, tengo la pantalla de 5,8 y ya tengo el cable mitsumi RCA y ahora ando volviéndome loco para encontrar un cable que me conecte el móvil con RCA, tenéis algún enlace dónde encontrarlo? Ya que por ahora solo he podido comprobar el VIM con una Wii jajaja
Muchas gracias!
Pero esto no tiene mucho que ver con OBDeleven @YeSL ...
Mira en el subforo "AudioCar / MultimediaCar". Hay varias soluciones para visualizar el móvil en las pantallas de 5,8" vía Mitshumi-RCA.
YeSL (04 Abr 2017, 15:41)
cvillajos
Notapor stewei el 04 Abr 2017, 20:06
Creo haber leido alguna vez que no todas las Can-Gateway eran compatibles con esa funcion.
stewei
Agradecido: 465 veces
Notapor teltronik el 04 Abr 2017, 21:00
hola buenas noches...alguien a provado el mod.de cerrar los cristales con lluvia..pero en vez de que se cierre el coche apagado ....solo se cierren los cristales pero si esta el coche encendido?
teltronik
Agradecido: 18 veces
Notapor Cup_Racing el 05 Abr 2017, 17:46
Aquí os dejo el error que me da que comente páginas atrás sobre las luces en los pies.
Lo da tanto en la drcha como izquierda.
Indicar que las llevo puenteadas a los asientos traseros por dos plafonitos comprados en Aliexpress para poner las luces en los pies.
Cup_Racing
Agradecido: 19 veces
Nuevo León por Madrid
Foro: Presentaciones
Autor: Pampanilla
Respuestas: 0
Hilo del León mkIV e-hybrid
Foro: General
Autor: vkr84
Respuestas: 610
SEAT Leon 1.0 TSI S&S Style XS 81 kW 110CV
Autor: Waltry
Respuestas: 5
LEON ST Special Edition
Autor: Buils2
Respuestas: 6
León Cupra 290
Autor: Beet
Respuestas: 5
