Accesorios aliexpress mk3
Favoritos: ositoerik, ROBERTO206, Stealnick, asaltacunas, tsi125, Alleya, Qore, tonnety, Juantxu, mk3Granaino, dani10s, damsolu, clotza, Levanius, pjdelburgo, frigolin, drnrd, Bass8V, Joali, toniRG, Jastur, morat86, _warcry_, Nikobellic, Lopagan666, Lyern, basuvi, rob3r7o, Lady, Danisisa_cupra
Seguidores: jose007dt, adri.f1, adrii18600, IronTor21, toniespejolara719, Hovig, trazas, drnrd, Chuskon, ecolibra, Gus-Gus, suarez22, TomH30, danone10, viktor_ct_95, pozyano, ChusTj, kennit0, Lopess85, er_trompe, rfaus, Gsclosada, djcastle, sergi303, DBS83, Ivensound, Hectoor57, JoseDel, agus_piscis10, jagman, warcryrivas, carrasco13, Triple R, luigi323, digital77, PuertoLeon, El Gonzo, LeonComeIbiza, dRoXe, osjamil, xjuliox, Per3zo, dPintos, VapaV, Igor, kukikukarron, Sanz, fur, chisyelamos, diegoporta97, carlosgzlez, leonfr76, smpxque, inamarlo, R1k4rd0, iviHDR, Moigijon, jd_zuri, surgeon, mk3Granaino, jajereal, ncx, juancete, Pokayoke, Jorge75016, DESMOCHEEE!!!, Guillen222, V de Viana, D83, riclanico, tonnety, lead, rrttrr, CuPra3004Drive, jguirao, Brandenor, triguero, Pedrost, perikolu, Alvi, Edu1589, victor david, aironsam14, Chema Sat, Josepo79, Senuto, sesmero87, Rapiru, Sergt, Llisus, richard_11, vanscampa, nifer, BEDIA, SantiagoSanchez, nachomart, quimiko, barrosdepor, Eohn94, Flow-Rider, puskas65, Snooker83, Angeleitor, Morales92, Rober_SR, Piro25, cucci, RamonLaC, erlanz, Raaz, DiegoR, Brunozp, pablomus85, kwatto, msmdraven, iNFeCTeD, MartinLeon, antelo85, Maikermx, josean-opc, El_pelos44, Mr.Chuflas, SantiPMI, Chrohu, LuigiVisio, joga, Atajunen, lafu1988, daniel.velarde77, galelir, rpv, Link, jose.a.llamas, eyebee, D.Acuña, Manzi, bluesbreaker88, Lady, higuerashxc, Warelio, St17, carlitos24, ginyu 83, Jastur, talanito, victorvOrtiz, Alf68, AlvaroRamlo, Yagadri, ebcuatro, MaNDuN, Davidv, Andertxu7, garruz666, antoniofdezpas, josearillaperez., MaximusRoco, ezanchi
Re: Accesorios aliexpress mk3
Notapor PuertoLeon el 14 Jun 2019, 21:24
Agonza86 escribió:
PuertoLeon escribió:
Agonza86 escribió:Decir que compré éstos intermitentes dinámicos para los retrovisores https://s.click.aliexpress.com/e/t7EvZ0rA7
y quedan genial! En casa en 10 días, en 15 minutos montados. Son una pijadita, pero le dan un toque al coche diferente. Los he puesto ahora, con el tiempo ya os diré. Saludos!
Impacientes por ver el resultado!!
Enviado desde mi SM-G950F mediante Tapatalk
La mejor foto que pude sacar jeje.
Este video es de la misma marca pero en un Golf
https://youtu.be/XUJZ3Gsrx3Y
Ahora sería cómo configurarlo para que no de fallo.... para los que somos un desastre
No hay que configurar nada, es quitar los originales y poner los dinámicos. Entre 10 y 15 minutos se tarda, no más. No aparece ningún tipo de error ni nada, es facilísimo.
Saludos!!
En serio??? Pues ya me has picado! Chuche para el Felino
PuertoLeon
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 41 veces
Notapor el_mengue el 15 Jun 2019, 08:02
USB-C
https://s.click.aliexpress.com/e/R9saHc8
NO COMPREIS ESTE CABLE
No funciona bien. Me causo reinicio en el infointertiment. Además tiene luz led, lo que un consumo más cuando apagas el coche mientras no desconecta todo.
el_mengue
Agradecido: 10 veces
Notapor nifer el 15 Jun 2019, 11:09
el_mengue escribió:USB-C
Que a tí no te funcione o no cumpla tus expectativas no quiere decir que a los demás si les pueda servir
nifer
Notapor Bomber0 el 15 Jun 2019, 12:24
viewtopic.php?f=9&t=125535&start=120#p2080171
Siento decepcionaros :cuñao:
Los reinicios del info estan a la Horden del día.
Seat Leon FR TSI 2.0 -->MiCarro Imagen.
Kawasaki ER-6F --> MiBici Imagen
Bomber0
Coche: Otro modelo SEAT
Agradecido: 191 veces
Notapor Mr.Chuflas el 15 Jun 2019, 23:46
Sr.Thompson17 escribió:
thadeusx escribió:
erlanz escribió:
thadeusx escribió:No sé si cuenta como accesorio ni es de AliExpress pero os cuento...
Cada vez que conectaba el móvil al Full Link me sobraba un montón de cable que quedaba colgando y el móvil no cabía bien en el hueco ya que el conector micro USB chocaba con el marco.
Bueno pues anoche pedí en Amazon el siguiente cable corto y con los conectores a 90º que ha llegado esta mañana y con el que desaparece el problema... Mano de santo
Interesante tienes enlace? Precio?
Bueno yo es que soy un ansias así que por no esperar un envío desde China opté por la opción cara y entrega en un día.
System-S – Cable Micro USB 90 ° Grados de ángulo de Izquierda acodado Macho a USB 2.0 Tipo A (Male) 90 ° hacia la Izquierda, Cable de Datos Cable de Carga Aprox. 27 cm https://www.amazon.es/dp/B01N7ZE55F/ref ... 2Cb10QY2FX
Hay versiones de USB o USB-C
https://es.aliexpress.com/item/TIEGEM-d ... 63c0bhlXbf
Éste tengo yo (el de 30cm) y perfecto.
ya me ha llegado y funciona pera, hasta me va mejor el mirrorlink que con el cable anterior :ok:
Gracias nuevamente
Mr.Chuflas
Agradecido: 257 veces
Notapor Sr.Thompson17 el 16 Jun 2019, 11:06
Gracias nuevamente
Ídem.
A mi también me va perfecto y el tamaño me parece de lo más adecuado.
Sr.Thompson17
Coche: Leon MK1 1.8 20v 125cv
Notapor Luisete86 el 19 Jun 2019, 08:16
Alguien tiene experiencia comprando la tapa del motor por AE?
https://es.aliexpress.com/item/Para-VW- ... b201603_60
Por estetica o se nota que cubre para evitar mierda
Luisete86
Agradecido: 34 veces
Notapor kwatto el 19 Jun 2019, 08:59
Luisete86 escribió:Alguien tiene experiencia comprando la tapa del motor por AE?
yo la tengo y además de la estética, como no, también ayuda a que ensucie menos. Te pongo el link del tema que está abierto. En él tienes links con vendedores de aliexpress más baratos que el que has puesto, así como los logos de Seat para tapar el de VW que viene por defecto.
viewtopic.php?f=10&t=118561
kwatto
Agradecido: 60 veces
Notapor capuchu el 20 Jun 2019, 18:35
garruz666 escribió:Hola. Estoy mirando en el aliexpress las piezas que van en el centro de la llanta. En mi caso trae de 18 con el logo blanco de seat sobre fondo negro. He visto en aliexpress pero la mayoria son pegatinas y lo q quiero es quitar el de casa y poner uno nuevo con ponga FR o otra cosa.
Alguien los ha comprado y puede poner alguna foto? Van bien? Quedan bien? Dan problemas?
yo cambie las llantas y las tapas centrales...mira como me ha quedado.
capuchu
Coche: Leon MK3 1.4 TSI 140cv
Agradecido: 35 veces
Notapor capuchu el 20 Jun 2019, 18:40
Diego_aseks97 escribió:Yo para mi seat leon FR he cojido en Aliexpress:
Tapones para ruedas, fundas para las llaves, cubrecerraduras, pedales cromados, embellecedores para las aletas cromados, alfombrillas de goma.
Lo demas no me ha llegado de momento.
los tapones de valvulas te van a durar el tiempo de ponerlos...
capuchu
Notapor Angeleitor el 20 Jun 2019, 18:52
Yo le puse unos OZ de seguridad, a ver si alguno tiene huev** a quitarlos
Enviado desde mi iPhone X utilizando Tapatalk
Leon FR ED. 2.0 TSI 190CV fulllllll :banana:
Angeleitor
Coche: Leon MK3 2.0 TSI 190cv
Agradecido: 69 veces
Notapor Warelio el 21 Jun 2019, 10:17
Acabo de pedir esto en Aliexpress... 1,68 €/unidad Portes incluidos.
https://es.aliexpress.com/item/1-l-mpar ... 63c0c6iuCS
Cuando las reciba ya pondré fotos para que veáis cómo ilumina, mi idea es dejarlas conectadas en las tomas USB que hay en las salidas de aire de las plazas traseras y que iluminen indirectamente algo esa zona, al menos que haya unos pequeños puntos de luz en la zona baja ya que de serie no los montan debajo de los asientos. He comprado las de luz blanca más que nada para que tenga un tono similar a la iluminación Led del resto del vehículo.
Warelio
Moderador de Racing
Agradecido: 1182 veces
Notapor little bastard el 21 Jun 2019, 10:38
Warelio escribió:Acabo de pedir esto en Aliexpress... 1,68 €/unidad Portes incluidos.
Esperando tu fedback Warelio. :ok:
little bastard
Agradecido: 82 veces
Notapor Warelio el 21 Jun 2019, 10:53
En cuanto me lleguen os cuento... Si cumple medianamente con lo que dice el anuncio desde luego es un buen apaño, barato barato y sin desmontar nada y susceptible de romper algo del coche para un manazas como yo. :lol:
Warelio
Moderador de Racing
Notapor el_mengue el 22 Jun 2019, 00:11
En casi 2000 km siempre he ido con bluetooth y Android Auto. El único reinicio ha sido con ese cable y a los dos minutos.
Seguiremos informando.
el_mengue
