Accesorios aliexpress mk3
Favoritos: ositoerik, ROBERTO206, Stealnick, asaltacunas, tsi125, Alleya, Qore, tonnety, Juantxu, mk3Granaino, dani10s, damsolu, clotza, Levanius, pjdelburgo, frigolin, drnrd, Bass8V, Joali, toniRG, Jastur, morat86, _warcry_, Nikobellic, Lopagan666, Lyern, basuvi, rob3r7o, Lady, Danisisa_cupra
Seguidores: jose007dt, adri.f1, adrii18600, IronTor21, toniespejolara719, Hovig, trazas, drnrd, Chuskon, ecolibra, Gus-Gus, suarez22, TomH30, danone10, viktor_ct_95, pozyano, ChusTj, kennit0, Lopess85, er_trompe, rfaus, Gsclosada, djcastle, sergi303, DBS83, Ivensound, Hectoor57, JoseDel, agus_piscis10, jagman, warcryrivas, carrasco13, Triple R, luigi323, digital77, PuertoLeon, El Gonzo, LeonComeIbiza, dRoXe, osjamil, xjuliox, Per3zo, dPintos, VapaV, Igor, kukikukarron, Sanz, fur, chisyelamos, diegoporta97, carlosgzlez, leonfr76, smpxque, inamarlo, R1k4rd0, iviHDR, Moigijon, jd_zuri, surgeon, mk3Granaino, jajereal, ncx, juancete, Pokayoke, Jorge75016, DESMOCHEEE!!!, Guillen222, V de Viana, D83, riclanico, tonnety, lead, rrttrr, CuPra3004Drive, jguirao, Brandenor, triguero, Pedrost, perikolu, Alvi, Edu1589, victor david, aironsam14, Chema Sat, Josepo79, Senuto, sesmero87, Rapiru, Sergt, Llisus, richard_11, vanscampa, nifer, BEDIA, SantiagoSanchez, nachomart, quimiko, barrosdepor, Eohn94, Flow-Rider, puskas65, Snooker83, Angeleitor, Morales92, Rober_SR, Piro25, cucci, RamonLaC, erlanz, Raaz, DiegoR, Brunozp, pablomus85, kwatto, msmdraven, iNFeCTeD, MartinLeon, antelo85, Maikermx, josean-opc, El_pelos44, Mr.Chuflas, SantiPMI, Chrohu, LuigiVisio, joga, Atajunen, lafu1988, daniel.velarde77, galelir, rpv, Link, jose.a.llamas, eyebee, D.Acuña, Manzi, bluesbreaker88, Lady, higuerashxc, Warelio, St17, carlitos24, ginyu 83, Jastur, talanito, victorvOrtiz, Alf68, AlvaroRamlo, Yagadri, ebcuatro, MaNDuN, Davidv, Andertxu7, garruz666, antoniofdezpas, josearillaperez., MaximusRoco, ezanchi
Re: Accesorios aliexpress mk3
Notapor Warelio el 12 Sep 2019, 20:56
Jastur escribió:@warelio y como va la funda?¿ pegada con algo o se cierra con unos clicks o como?¿
Son 2 piezas, colocas la llave y se cierra encarando y presionando ambas partes hasta que escuches un click. No hay pegamento ni cinta adhesiva, es muy sencillo de colocar y encaja perfectamente en la llave. El llavero que te viene de regalo lleva un tornillo para montarlo en el hueco que deja la llave.
Un saludo,
Warelio
Moderador de Racing
Agradecido: 1183 veces
Notapor little bastard el 13 Sep 2019, 10:07
Mr.Chuflas escribió:
little bastard escribió:
shaume escribió:Buenas, alguien ha cambiado la luz del maletero en un leon ST? O la bombilla.
Veo que tiene poca luminosidad lo que no se si lleva la misma luz que el leon normal, en aliexpress indican leon mk3 solamente. Gracias!
Yo lo cambie por este;
https://es.aliexpress.com/item/32888280 ... 63c0NuIJYt
Es impresionante la diferencia de Luz. Antes no se veia nada y ahora tengo que abrir el maletero con gafas de sol. :si: :si:
tu coche trae dos puntos de luz en el maletero? (lo digo por el link que has puesto, que te venden dos juntos)
No solo trae uno pero compre el pack de 2 para otro compañero. :ok:
little bastard
Agradecido: 82 veces
Notapor lafu1988 el 21 Sep 2019, 10:15
Alguien ha comprado esto? Lo he visto en un video de youtube en un León 5F para el maletero. Lo llevan los vw sirocco y son unos topes pero que además llevan unos muelles que cuando le das al mando para abrir, el maletero hace que este se abra más de lo normal y no tengas que tirar de la S sino simplemente tirar del borde así se evita romper con el tiempo la S.
¿Sabéis el precio en recambios oficial?
REF: 1K8827761D
https://www.google.com/amp/s/m.aliexpre ... 44198.html
Última edición por lafu1988 el 21 Sep 2019, 17:03, editado 1 vez en total
lafu1988
Agradecido: 218 veces
Notapor Agonza86 el 21 Sep 2019, 14:44
lafu1988 escribió:Alguien ha comprado esto? Lo he visto en un video de youtube en un León 5F para el maletero. Lo llevan los vw sirocco y son unos topes pero que además llevan unos muelles que cuando le das al mando para abrir, el maletero hace que este se abra más de lo normal y no tengas que tirar de la S sino simplemente tirar del borde así se evita romper con el tiempo la S.
Yo lo he visto en un vídeo de Youtube, sustituye a los topes de goma originales sin muelle y hace lo que dices, pulsas el botón de apertura del maletero y como el muelle hace mucha presión impulsa como unos 20cm al portón. En el video que vi la referencia era de Skoda.
Agonza86
Agradecido: 409 veces
Notapor tevaadarelsol el 21 Sep 2019, 17:03
Y digo yo, a la hora de cerrarlo no habrá que empujar demasiado?
Enviado desde mi ONEPLUS A6003 mediante Tapatalk
tevaadarelsol
Agradecido: 200 veces
Notapor lafu1988 el 21 Sep 2019, 17:04
El lunes voy a seat y pregunto precio para ver si sale rentable o mejor aliexpress
lafu1988
Notapor Agonza86 el 22 Sep 2019, 09:16
Aquí os dejo el vídeo que os dije, estaba equivocado, la referencia es de un Scirocco, cierto, y no, no impulsa el maletero tanto como dije, eso lo hacía con añadiendo unos muelles al amortiguador:
https://youtu.be/jls1XU7FR0Q
Agonza86
Notapor lafu1988 el 22 Sep 2019, 09:31
Agonza86 escribió:Aquí os dejo el vídeo que os dije, estaba equivocado, la referencia es de un Scirocco, cierto, y no, no impulsa el maletero tanto como dije, eso lo hacía con añadiendo unos muelles al amortiguador:
Si ese es el mismo vídeo que vi yo. Tiene buena pinta y no creo que haga mucha fuerza para cerrar los muelles y además se puede ajustar la altura y si lo montaba vw en el sirocco... Yo el lunes pregunto en seat y comento el precio que me dicen pero en aliexpress ronda los 25€ la pareja.
lafu1988
Notapor Morales92 el 22 Sep 2019, 09:55
Si tenéis el mod de cambiar los hidráulicos del maletero y sale más económico.
Morales92
Coche: Otro modelo SEAT
Notapor lafu1988 el 22 Sep 2019, 10:54
Morales92 escribió:Si tenéis el mod de cambiar los hidráulicos del maletero y sale más económico.
Ya pero yo no quiero que se abra el maletero solo como hacen los hidráulicos y los muelles, yo quiero poder tirar del maletero para arriba sin tener que tirar de la S para poder abrirlo cuando pulso el botón del mando. Seré rarito jejejejeje
lafu1988
Notapor tevaadarelsol el 22 Sep 2019, 17:28
En mi caso llevo los hidráulicos cambiados para la apertura automática, y en verano con el calor los pistones cogen más presión y va perfecto, pero en invierno con más frío el portón no se sube, se queda solamente desencajado y cuando yo lo subo unos centímetros ya se abre... Estaría bien saber si estos muelles le darían el primer "empujoncito" y así se solucionaría del todo el problema
tevaadarelsol
Notapor JOOAAAN el 23 Sep 2019, 13:51
tevaadarelsol escribió:En mi caso llevo los hidráulicos cambiados para la apertura automática, y en verano con el calor los pistones cogen más presión y va perfecto, pero en invierno con más frío el portón no se sube, se queda solamente desencajado y cuando yo lo subo unos centímetros ya se abre... Estaría bien saber si estos muelles le darían el primer "empujoncito" y así se solucionaría del todo el problema
Interesante aportación, ya que en el hilo del Brico todo el mundo habla maravillas y no podia ser todo tan bueno. Creo que después de ese comentario me he desencantado con el brico, porque si encima de que cuesta mucho mas bajarlo no sube siempre, pues vendita la gracia... :avergonzado:
JOOAAAN
Agradecido: 38 veces
Notapor ZXVolcane el 23 Sep 2019, 14:07
Buenas @tevaadarelsol,
Si te miras el video que dicen los compis del VW Sirocco el chico monta esos topes para solucionar lo que te pasa a ti en invierno, le da ese empujon al principio para que suba.
ZXVolcane
Agradecido: 64 veces
Notapor tevaadarelsol el 23 Sep 2019, 15:12
Bueno pues los he pillado, cuando me lleguen ya comentaré qué tal.
Por cierto, veo en el vídeo que el chaval ajusta algo con una llave Allen... Qué es exactamente?
Gracias!
tevaadarelsol
Notapor lafu1988 el 23 Sep 2019, 16:08
Gracias!
La altura de los topes para que el maletero quede bien ajustado
lafu1988
Usuarios navegando por este Foro: Anthropic, ByteDance (Bytespider) y 18 invitados
