Accesorios aliexpress mk3
Favoritos: ositoerik, ROBERTO206, Stealnick, asaltacunas, tsi125, Alleya, Qore, tonnety, Juantxu, mk3Granaino, dani10s, damsolu, clotza, Levanius, pjdelburgo, frigolin, drnrd, Bass8V, Joali, toniRG, Jastur, morat86, _warcry_, Nikobellic, Lopagan666, Lyern, basuvi, rob3r7o, Lady, Danisisa_cupra
Seguidores: jose007dt, adri.f1, adrii18600, IronTor21, toniespejolara719, Hovig, trazas, drnrd, Chuskon, ecolibra, Gus-Gus, suarez22, TomH30, danone10, viktor_ct_95, pozyano, ChusTj, kennit0, Lopess85, er_trompe, rfaus, Gsclosada, djcastle, sergi303, DBS83, Ivensound, Hectoor57, JoseDel, agus_piscis10, jagman, warcryrivas, carrasco13, Triple R, luigi323, digital77, PuertoLeon, El Gonzo, LeonComeIbiza, dRoXe, osjamil, xjuliox, Per3zo, dPintos, VapaV, Igor, kukikukarron, Sanz, fur, chisyelamos, diegoporta97, carlosgzlez, leonfr76, smpxque, inamarlo, R1k4rd0, iviHDR, Moigijon, jd_zuri, surgeon, mk3Granaino, jajereal, ncx, juancete, Pokayoke, Jorge75016, DESMOCHEEE!!!, Guillen222, V de Viana, D83, riclanico, tonnety, lead, rrttrr, CuPra3004Drive, jguirao, Brandenor, triguero, Pedrost, perikolu, Alvi, Edu1589, victor david, aironsam14, Chema Sat, Josepo79, Senuto, sesmero87, Rapiru, Sergt, Llisus, richard_11, vanscampa, nifer, BEDIA, SantiagoSanchez, nachomart, quimiko, barrosdepor, Eohn94, Flow-Rider, puskas65, Snooker83, Angeleitor, Morales92, Rober_SR, Piro25, cucci, RamonLaC, erlanz, Raaz, DiegoR, Brunozp, pablomus85, kwatto, msmdraven, iNFeCTeD, MartinLeon, antelo85, Maikermx, josean-opc, El_pelos44, Mr.Chuflas, SantiPMI, Chrohu, LuigiVisio, joga, Atajunen, lafu1988, daniel.velarde77, galelir, rpv, Link, jose.a.llamas, eyebee, D.Acuña, Manzi, bluesbreaker88, Lady, higuerashxc, Warelio, St17, carlitos24, ginyu 83, Jastur, talanito, victorvOrtiz, Alf68, AlvaroRamlo, Yagadri, ebcuatro, MaNDuN, Davidv, Andertxu7, garruz666, antoniofdezpas, josearillaperez., MaximusRoco, ezanchi
Re: Accesorios aliexpress mk3
Notapor ekiste el 26 Nov 2019, 11:02
garruz666 escribió:Y yo que pague 14€ solo por las de dentro del reposabrazos delantero... En cuanto lleguen comentad que tal :)
mmm no se si hablamos de las mismas gomas... yo al concesionario le dije que quería estas que adjunto.. y todo ello vale menos de 15 eur (me lo regalaron). No pedí las del reposabrazos trasero pq no pedí ese extra.. pero al final me vino no se porque (quizás por pedir tapicería alcántara).
Pero para el FR que ya viene con lineas rojas.. creo que me compraré estas que habéis puesto (a parte creo que vienen las de los laterales que esas no las tengo).
ekiste
Coche: Leon MK3 1.5 TGI 130cv
Notapor JOOAAAN el 28 Nov 2019, 13:22
JOOAAAN escribió:
JOOAAAN escribió:
Warelio escribió:
erlanz escribió:
Warelio escribió:Lo que hace una simple pieza metálica... Cómo cambia la llave del coche y le da un aspecto más lujoso. Además esta que he comprado es de metal, no es la típica de plástico cromada y me venía con un tornillo Torx y la llave también Torx, todo un detalle.
Una pregunta que enlace es el de unos post más atrás?, has quitado bien el tornillo de tu llave? Si tienes el enlace actualizado me lo podrías pasar porfa
El tornillo lo quité sin problema y no se me ha roto como han comentado algunos compañeros. Con la misma llave que incluyen en el envío lo quitas ya que también es TORX y la guardaré porque no es fácil encontrar ese tamaño tan pequeño. Te pongo más abajo el enlace de lo que compré yo.
https://es.aliexpress.com/item/32816495 ... 63c0mnmPbs
Es un poco mas caro de los enlaces que tenia yo, pero si viene llave y todo lo pillo aquí, gracias!
EDITO:
Por cierto, hay un cupón hasta el dia 21 de -1,82€ para comprar este producto!
Quedaría en 5,02€, el dia 8 de Noviembre en casa!
:tirachinas:
Pues gente, acabo de flipar. :shock: Me acaba de llegar la piezecita, con su tornillito (muy bien acabado, la verdad) y la llave (de Cr-Vn). :cool: Incluso me ha sorprendido la bolsa en la que venia, con abrefacil y la pieza en un lado y en otro el tornillo y la llave...
...Pero lo mejor ha sido ver la etiqueta: Si no es original, poco le falta. :o
Y todo por 5€. :banana:
QaSaR escribió:Pues tienen buena pinta... solo faltaria ver un poco la calidad de las piezas, pero pintan bien! Me estoy hasta planteandome pillarlos... total por 30 y pocos €... si duran un par de años tampoco seria dinero tirado...
Q.
Realmente lo que importa es la calidad de los amortiguadores, porque lo demás es metálico y no debería dar problemas...
Si los amortiguadores tienen medidas "normales", a malas si fallan se ponen unos buenos.
Pues chic@s, ayer fuí a recojer el coche (por fin) y lo primero que hize al llevar a casa fué la piececita.
Sin lugar a dudas, un "must have". Eso si, el infarto que os dará cuando el tornillo a medio quitar se pase de rosca no os lo va a quitar nadie, así que aseguraros que la pieza nueva tiene llave y tornillo nuevo. Al quitar el tornillo de serie ir con mucho cuidado y, aunque se pasara igual, intentar que quede lo suficientemen te salido como para acabar de quitarlo con unos alicates, si no la abreis liado. El tornillo parece de mantequilla. El nuevo que me vino a mi perfecto, entró suave y la llave no tenía juego.
De 10. Brutal.
JOOAAAN
Agradecido: 38 veces
Notapor yurkli el 29 Nov 2019, 14:19
El portagafas donde va el tirador, lo mas barato que he visto: https://www.aliexpress.com/item/3287218 ... uqQno&mp=1 para los leones con "pestaña" y no con tornillo :D
yurkli
Notapor peri_kot el 23 Dic 2019, 16:45
Hola a todos,
Sabéis alguno si hay manera de conseguir este accesorio de alguna forma mas barata?
https://www.seataccesoriescatalogue.net ... /1776/3341
Es una pelicula transparente que se pone en el borde del maletero para prevenir golpearlo al sacar o meter algún objeto.
peri_kot
Notapor Warelio el 23 Dic 2019, 16:49
Es lamentable que por un trozo de film de plástico transparente te cobren más de 20 €. Yo creo que si compras un rollo de aeronfix para forrar libros y lo cortas a la medida y forma del parachoques te sale mucho más económico y te queda igual de bien.
Warelio
Moderador de Racing
Agradecido: 1183 veces
Notapor Fernix72 el 23 Dic 2019, 17:11
peri_kot escribió:Hola a todos,
Por AliExpress vas a encontrar protectores de goma o imitaciones de fibra de carbono. A mi personalmente no me gusta como queda, pero va en gustos.
https://m.es.aliexpress.com/item/400022 ... 06e&is_c=N
Fernix72
Agradecido: 19 veces
Notapor peri_kot el 23 Dic 2019, 17:24
Gracias a todos,
Creo que voy a buscar una solución alternativa porque si, es un abuso el precio del mismo.
peri_kot
Notapor Fernix72 el 23 Dic 2019, 18:16
Warelio escribió:Después de mucho buscar por fín encontré las alfombrillas antideslizantes para el Seat León, además vienen para absolutamente todos los huecos, incluso los huecos de las puertas y para el hueco del posavasos del reposabrazos trasero. Aquí os dejo el enlace. Tenéis que buscarlo como Seat Leon Cupra 5F Coche Accesorios Antideslizante y os aparece casi al principio.
https://es.aliexpress.com/item/40003890 ... b201603_52
Hola. Sólo era para preguntar por las alfombrillas antideslizantes que habíais encontrado en AliExpress. Si os habían llegado a alguno, si tenían buena pinta, se adaptaban bien a los huecos o si podíais colgar alguna foto de cómo quedaban.
Gracias. Un saludo.
Fernix72
Notapor TaKo16v el 28 Dic 2019, 18:50
Cosas interesantes de las cuales ya he comprado alguna.
Gracias por el aporte
TaKo16v
Coche: Leon MK3 2.0 TSI 190cv
Notapor angeljimenez el 02 Ene 2020, 21:54
angeljimenez
Agradecido: 17 veces
Notapor Juamgang el 02 Ene 2020, 23:49
angeljimenez escribió:Alguien ha probado algo de esto por si sirve para nuestro leon?
https://es.aliexpress.com/item/33052133 ... 2l4df&mp=1
https://es.aliexpress.com/item/40000437 ... 2l4df&mp=1
En dock de carga estoy casi seguro de que sí. De todas formas, muchos lo hemos hecho nosotros, a lo casero xD
Juamgang
Notapor BEDIA el 04 Ene 2020, 10:07
Gracias. Un saludo.
A mi me llegaron ayer, hepuesto dos o tres y la verdad es que encajan perfectas. Cuando ponga todas hago foto y la paso, os dejo una de como vienen en la caja
BEDIA
Agradecido: 36 veces
Notapor xTinieblaSx el 04 Ene 2020, 12:57
Quizás te interese, aunque le tengas que hacer tu la forma:
https://es.aliexpress.com/item/32949293 ... ym0re&mp=1
xTinieblaSx
Notapor San5f el 04 Ene 2020, 19:44
Muy buen hilo, aporto mi granito para los que quieran forrar puertas, huecos, apoyabrazos, etc...,estilo cupra,no es de ali pero si alguien lo tiene o quiere pongo enlace. Yo me lo voy a pedir, cuando me llegue subo foto, en YouTube sale un video de un chaval con un cupra que se lo pone
https://iyzi.link/djY
San5f
Notapor jlbpmr el 04 Ene 2020, 21:43
San5f escribió:Muy buen hilo, aporto mi granito para los que quieran forrar puertas, huecos, apoyabrazos, etc...,estilo cupra,no es de ali pero si alguien lo tiene o quiere pongo enlace. Yo me lo voy a pedir, cuando me llegue subo foto, en YouTube sale un video de un chaval con un cupra que se lo pone
Que es ??
jlbpmr
Agradecido: 113 veces
Usuarios navegando por este Foro: Anthropic, Google [Bot] y 16 invitados
