Accesorios aliexpress mk3
Favoritos: ositoerik, ROBERTO206, Stealnick, asaltacunas, tsi125, Alleya, Qore, tonnety, Juantxu, mk3Granaino, dani10s, damsolu, clotza, Levanius, pjdelburgo, frigolin, drnrd, Bass8V, Joali, toniRG, Jastur, morat86, _warcry_, Nikobellic, Lopagan666, Lyern, basuvi, rob3r7o, Lady, Danisisa_cupra
Seguidores: jose007dt, adri.f1, adrii18600, IronTor21, toniespejolara719, Hovig, trazas, drnrd, Chuskon, ecolibra, Gus-Gus, suarez22, TomH30, danone10, viktor_ct_95, pozyano, ChusTj, kennit0, Lopess85, er_trompe, rfaus, Gsclosada, djcastle, sergi303, DBS83, Ivensound, Hectoor57, JoseDel, agus_piscis10, jagman, warcryrivas, carrasco13, Triple R, luigi323, digital77, PuertoLeon, El Gonzo, LeonComeIbiza, dRoXe, osjamil, xjuliox, Per3zo, dPintos, VapaV, Igor, kukikukarron, Sanz, fur, chisyelamos, diegoporta97, carlosgzlez, leonfr76, smpxque, inamarlo, R1k4rd0, iviHDR, Moigijon, jd_zuri, surgeon, mk3Granaino, jajereal, ncx, juancete, Pokayoke, Jorge75016, DESMOCHEEE!!!, Guillen222, V de Viana, D83, riclanico, tonnety, lead, rrttrr, CuPra3004Drive, jguirao, Brandenor, triguero, Pedrost, perikolu, Alvi, Edu1589, victor david, aironsam14, Chema Sat, Josepo79, Senuto, sesmero87, Rapiru, Sergt, Llisus, richard_11, vanscampa, nifer, BEDIA, SantiagoSanchez, nachomart, quimiko, barrosdepor, Eohn94, Flow-Rider, puskas65, Snooker83, Angeleitor, Morales92, Rober_SR, Piro25, cucci, RamonLaC, erlanz, Raaz, DiegoR, Brunozp, pablomus85, kwatto, msmdraven, iNFeCTeD, MartinLeon, antelo85, Maikermx, josean-opc, El_pelos44, Mr.Chuflas, SantiPMI, Chrohu, LuigiVisio, joga, Atajunen, lafu1988, daniel.velarde77, galelir, rpv, Link, jose.a.llamas, eyebee, D.Acuña, Manzi, bluesbreaker88, Lady, higuerashxc, Warelio, St17, carlitos24, ginyu 83, Jastur, talanito, victorvOrtiz, Alf68, AlvaroRamlo, Yagadri, ebcuatro, MaNDuN, Davidv, Andertxu7, garruz666, antoniofdezpas, josearillaperez., MaximusRoco, ezanchi
Re: Accesorios aliexpress mk3
Notapor Warelio el 05 Jun 2020, 09:44
Manzi escribió:El mío está fabricado en diciembre del 19, 1.5 tsi.
Pero mi maletero me parece diferente, las esquinas del fondo que hace con la parte trasera de los asientos no tiene esa curva suave y tampoco esos chaflanes laterales para todas las formas del cubre maletero
Pues si ese no te sirve ya no sé qué decirte, el que llevo yo para el ST desde luego que no tiene esas formas tan extrañas por la parte delantera, es más cuadrado porque el maletero de los ST es de formas cuadradas. Tendrás que buscar alguno que sea universal y se pueda recortar para encajarlo a la medida. De todas formas en uno de los comentarios de Amazon un comprador decía algo así como que se tenía que desmontar la red lateral para poder meter la goma por ese hueco y una vez metida volver a poner la red, quizás haciendo eso encaje el trozo que sobra y puedas ponerla bien después, no te puedo ayudar más porque no me he fijado bien en los maleteros de los 5P por dentro.
Warelio
Moderador de Racing
Agradecido: 1183 veces
Notapor tuthankamenn el 05 Jun 2020, 09:52
Manzi ¿tú tienes el leon corto? Porque warelio tiene el st,el familiar.
Yo ,aunque no tengo aun el protector,tb tengo el st y por la silueta del que pone warelio se adaptaria perfecto
SEAT LEON ST FR 1.5 ECOTSI AUT. 150CV
Mi cacharro viewtopic.php?f=43&t=132699
tuthankamenn
Agradecido: 17 veces
Notapor Manzi el 05 Jun 2020, 10:03
El mío es el corto
Manzi
Notapor Manzi el 06 Jun 2020, 17:29
En respuesta a esto, mi coche es el león 5f corto, tiene dos posiciones la tapa del maletero y años lados dos huecos con tapas de plástico rígido.
Y el de mi colega que tiene un año, es diferente.
Alguien sabe que cubre maletero vale para el mío?Imagen
Manzi
Notapor Warelio el 08 Jun 2020, 07:29
Manzi escribió:En respuesta a esto, mi coche es el león 5f corto, tiene dos posiciones la tapa del maletero y años lados dos huecos con tapas de plástico rígido.
Alguien sabe que cubre maletero vale para el mío?[ Imagen ]
Lo único que se me ocurre es que uno lleve algún tipo de extra tipo Storage pack en el maletero y el otro no, pero las formas internas del maletero deberían ser las mismas para ambos, a no ser que uno sea TGI y pierda espacio por el depósito de gas.
Warelio
Moderador de Racing
Notapor tuthankamenn el 09 Jun 2020, 16:42
Ya me he pillado el protector del maletero,En este caso,por Amazon
He seguido el consejo de Warelio y he cogido el que me dijo,ni que decir que encaja como un guante.
No entiendo las reseñas que dicen que no va bien o que es pequeño..Una de dos,o se han equivocado de protector o no tienen el st.
En la parte cercana a los asientos hace como rampa,al igual que hace la madera,por el resto un escalon de unos 2/3 cm
Solo encaja en la parte baja del st,en mi caso del 19.
Las fotos están hechas recién sacado de la caja.
Sdos.
tuthankamenn
Notapor Mr.Nobody el 09 Jun 2020, 18:08
Cuando yo compre el coche (2018) el doble fondo de maletero para el Leon 5 puertas era parte del "Pack Almacenaje".
Como era "raro" pedir ese extra no hay ( o yo no conseguí encontrar ) un cubremaletero de foam o similar para poner en la bandeja.
La única opción es hacerte uno casero.
~ MK3 MY18 - 1.4 TSI 125CV - Xcellence Plus ~ + info
Mr.Nobody
Agradecido: 66 veces
Notapor jlbpmr el 09 Jun 2020, 20:42
tuthankamenn escribió:Ya me he pillado el protector del maletero,En este caso,por Amazon
Sdos.
Tienes el enlace ??? Precio ?? Queda muy bien.
jlbpmr
Agradecido: 113 veces
Notapor tuthankamenn el 09 Jun 2020, 21:07
tuthankamenn
Notapor Manzi el 09 Jun 2020, 22:13
Pues estoy ralladisimo...no hay protección para mi maletero...
Manzi
Notapor Manzi el 09 Jun 2020, 22:35
Esta es de la página de Seat.
No existe el cubre maletero para león 5f con storage pack.
Le tendré que comprar un cubre perros de esos pero me parece un mojon.ImagenImagen
Manzi
Notapor Mr.Nobody el 09 Jun 2020, 23:43
Manzi escribió:Esta es de la página de Seat.
Le tendré que comprar un cubre perros de esos pero me parece un mojon.[ Imagen ][ Imagen ]
Con un poco de maña y paciencia...
https://www.bauhaus.es/bases-antidesliz ... c/10001588
https://www.bauhaus.es/alfombras-de-esp ... p/21315006
Yo no he tenido tiempo y solo llevo una especie de antideslizante de alfombras , pero en cuanto pueda me fabrico algo con eso.
Es mas feo si...
Mr.Nobody
Notapor Eohn94 el 10 Jun 2020, 15:36
Buenas a todos! Llevo tiempo siguiendo este foro y en concreto este hilo de accesorios pero este es mi primer aporte. El modelo de mi coche es un Leon mk3 Fr Plus 5p de finales del 2017.
Os dejo a continuación una lista de todas las cosas que he ido recopilando de los distintos aportes de los compis, dejo enlaces (de los que siguen disponibles ya que algunos vendedores ya no están) y algunas fotos de como quedan puestos.
Cojín Reposabrazos:
https://es.aliexpress.com/item/33026755210.html?spm=a2g0s.9042311.0.0.67cc4c4dLMjTUt
Se adapta bastante bien y es cómodo porque lleva un poco de acolchado. Va cogido al propio reposabrazos con unas gomas por debajo.
Cojín Reposacabezas:
https://es.aliexpress.com/item/33003219492.html?spm=a2g0s.9042311.0.0.67cc4c4dLMjTUt
Personalmente creía que sería molesto, pero resulta bastante cómodo una vez que le coges la posición. Va cogido con unas gomas que llevan engrape, por lo que es bastante fácil de poner y quitar.
Funda Reposacabezas:
https://es.aliexpress.com/item/32997245147.html?spm=a2g0s.9042311.0.0.67cc4c4dLMjTUt
(En la foto anterior se ve como queda en los asientos delanteros)
Todo y que no llevan diferentes formas, se adaptan bastante bien a los 5 reposacabezas. Adicionalmente llevan un bolsillo pequeño en la parte trasera. Lleva una tira de velcro que permite ajustarlos muy bien.
Cubrecinturones:
https://es.aliexpress.com/item/32965970139.html?spm=a2g0s.9042311.0.0.67cc4c4dLMjTUt
(Podéis ver en las fotos anteriores como quedan tanto en los delanteros como en los traseros)
Personalmente son muy cómodos. Van cerrados con una tira de velcro que hace que sea rápido ponerlos y quitarlos.
Leds rojos en reposapiés delanteros:
https://es.aliexpress.com/item/33009183349.html?spm=a2g0s.9042311.0.0.67cc4c4dLMjTUt
Los he montado gracias al siguiente brico de un compi del foro:
https://www.clubseatleon.net/viewtopic.php?f=40&t=132493&p=2112330&hilit=led+consola#p2112330
Iluminan mucho más que los blancos que tenía de serie y van más a juego con todo el interior con detalles en rojo.
Gomas interiores:
https://es.aliexpress.com/item/4000389066502.html?spm=a2g0s.9042311.0.0.67cc4c4dLMjTUt
(No he sacado más fotos, pero todas encajan bien en todos los huecos)
Se adaptan genial a todos los huecos y ayuda bastante a evitar las rayadas accidentales.
También están con los bordes en blanco en este vendedor:
https://es.aliexpress.com/item/4000761331140.html?spm=a2g0s.8937460.0.0.6dc72e0eWo07h2
Proyectores puertas:
El vendedor ya no está disponible, pero si buscáis en ali encontrareis varios del mismo estilo.
Por el precio no esperaba gran cosa, pero se ven bastante bien. La única pega es que la cinta adhesiva que llevan es bastante mala y recomiendo hacer uso de una de mayor calidad.
Cubrehuecos entre asientos delanteros:
Van muy bien para evitar que se caigan las cosas por esos molestos huecos. Van cogidos al cierre del cinturón y la única pega que puedo poner es que hay que doblarlos un poco por la parte delantera para que no quede la punta colgando.
Mechero con dos usb e indicador de corriente:
Dos puertos de carga usb adicionales. El indicador led de corriente el único uso que le veo es para asegurarte de que está bien enchufado, sin más.
Pedales metálicos:
https://es.aliexpress.com/item/32663925646.html?spm=a2g0s.9042311.0.0.274263c0EBnB8q
Montados siguiendo el brico de un compi del foro:
https://www.clubseatleon.net/viewtopic.php?f=10&t=103582&hilit=pedales
Quedan increíblemente bien y son muy cómodos al conducir.
Cubrecerraduras:
Validos para las 4 puertas, un pequeño detalle que para mi gusto le da un toque. La cinta que traen parecía malilla, pero llevan puestos 1 año y aguantan sin problema.
Red pequeña para maletero:
https://es.aliexpress.com/item/32963406864.html?spm=a2g0s.9042311.0.0.274263c0kFmaFZ
Una red para llevar algunos trapos o similar. Va pegada con velcro por lo que se quita muy fácil.
Rejillas de ventilación bajo los asientos:
https://es.aliexpress.com/item/32884417239.html?spm=a2g0s.9042311.0.0.274263c0kFmaFZ
Encajan a la perfección y evitan que se cuelen objetos por el conducto. La cinta que llevan aguanta bastante bien, en 1 año tan solo se me despegaron 1 vez al darle con los pies, los volví a colocar y ahí siguen aguantando.
Trapo microfibra:
https://es.aliexpress.com/item/32924004961.html?spm=a2g0s.9042311.0.0.274263c0EBnB8q
Va bastante bien para interior.
Cepillo para huecos y rejillas de clima:
https://es.aliexpress.com/item/32803416481.html?spm=a2g0s.9042311.0.0.274263c0EBnB8q
Muy útil para rincones y para las rejillas del aire.
Funda de silicona para llave:
https://es.aliexpress.com/item/32849019186.html?spm=a2g0s.9042311.0.0.274263c0EBnB8q
Para mi gusto abulta demasiado y se queda un poco abierta, por lo que la he dejado puesta en la llave de repuesto que nunca la uso.
Tira efecto fibra de carbono para lip frontal:
https://es.aliexpress.com/item/32918238135.html?spm=a2g0s.9042311.0.0.274263c0EBnB8q
No he llegado a montarla, el efecto de carbono se ve muy falso y brillo demasiado a plástico. Personalmente no lo recomiendo
Goma antideslizante para salpicadero:
https://es.aliexpress.com/item/32953643134.html?spm=a2g0s.9042311.0.0.67cc4c4dLMjTUt
Tal cual se ve en las fotos del vendedor, es bastante grande por lo que puedes poner un móvil o similar.
Limpiaparabrisas (Este lo tengo pendiente de llegar, pero por la opinión de otros compis creo que irá bien)
https://es.aliexpress.com/item/32845789948.html?spm=a2g0s.9042311.0.0.67cc4c4dLMjTUt
A continuación, os dejo una lista de las cosas que tengo pendiente de ir pidiendo, la mayoría sacadas de aportes en este mismo hilo.
Placas metálicas iluminadas en las puertas:
https://es.aliexpress.com/item/32947830824.html?spm=a2g0s.8937460.0.0.6dc72e0eWo07h2
Elevador de capo con amortiguador:
https://es.aliexpress.com/item/4000183786249.html?spm=a2g0s.8937460.0.0.6dc72e0eWo07h2
Trapos con logo seat:
https://es.aliexpress.com/item/4000212095150.html?spm=a2g0s.8937460.0.0.6dc72e0eWo07h2
https://es.aliexpress.com/item/32951886471.html?spm=a2g0s.8937460.0.0.6dc72e0eWo07h2
Red grande para maletero:
https://es.aliexpress.com/item/4000329616592.html?spm=a2g0s.8937460.0.0.6dc72e0eWo07h2
Led marcha atrás:
https://es.aliexpress.com/item/32765326318.html?spm=a2g0s.8937460.0.0.6dc72e0eWo07h2
Huecos adicionales en las puertas:
https://es.aliexpress.com/item/4000898885144.html?spm=a2g0s.8937460.0.0.6dc72e0eWo07h2
Distribuidor para el interior del reposabrazos:
https://es.aliexpress.com/item/4000895508595.html?spm=a2g0s.8937460.0.0.6dc72e0eWo07h2
Llavero FR:
https://es.aliexpress.com/item/4000518011142.html?spm=a2g0s.8937460.0.0.6dc72e0eWo07h2
Intermitentes dinámicos en retrovisores:
https://es.aliexpress.com/item/32994378209.html?spm=a2g0s.8937460.0.0.6dc72e0eWo07h2
Intermitentes dinámicos traseros:
https://es.aliexpress.com/item/4000797828292.html?spm=a2g0s.8937460.0.0.6dc72e0eWo07h2
Elevador de matero desde la llave:
Siguiendo el brico que ya hay en el foro (https://www.clubseatleon.net/viewtopic.php?f=40&t=118426&p=1902599&hilit=apertura+automatica+porton#p1902599)
Espero que a alguien le sea de utilidad y aprovecho para dar las gracias a todos por sus aportes en el foro. Saludos!
Eohn94
Notapor Mr.Nobody el 10 Jun 2020, 21:40
¿cuanto llevas con esta goma? Yo tengo una similar y un día que la moví me dio la sensación de que esa zona del salpicadero tenia unas "burbujas" .
Lo mismo es una paja mental mia...la he dejado por que resulta muy útil pero siempre me queda la duda.
Mr.Nobody
Notapor gaaas el 10 Jun 2020, 21:54
Eohn94 escribió:Buenas a todos! Llevo tiempo siguiendo este foro y en concreto este hilo de accesorios pero este es mi primer aporte. El modelo de mi coche es un Leon mk3 Fr Plus 5p de finales del 2017.
Gracias por la recopilación, vendrá muy bien a mucha gente, ya que este hilo es ya muy largo.
Esto de Aliexpress es un vicio!
gaaas
Agradecido: 10 veces
