Accesorios aliexpress mk3
Favoritos: ositoerik, ROBERTO206, Stealnick, asaltacunas, tsi125, Alleya, Qore, tonnety, Juantxu, mk3Granaino, dani10s, damsolu, clotza, Levanius, pjdelburgo, frigolin, drnrd, Bass8V, Joali, toniRG, Jastur, morat86, _warcry_, Nikobellic, Lopagan666, Lyern, basuvi, rob3r7o, Lady, Danisisa_cupra
Seguidores: jose007dt, adri.f1, adrii18600, IronTor21, toniespejolara719, Hovig, trazas, drnrd, Chuskon, ecolibra, Gus-Gus, suarez22, TomH30, danone10, viktor_ct_95, pozyano, ChusTj, kennit0, Lopess85, er_trompe, rfaus, Gsclosada, djcastle, sergi303, DBS83, Ivensound, Hectoor57, JoseDel, agus_piscis10, jagman, warcryrivas, carrasco13, Triple R, luigi323, digital77, PuertoLeon, El Gonzo, LeonComeIbiza, dRoXe, osjamil, xjuliox, Per3zo, dPintos, VapaV, Igor, kukikukarron, Sanz, fur, chisyelamos, diegoporta97, carlosgzlez, leonfr76, smpxque, inamarlo, R1k4rd0, iviHDR, Moigijon, jd_zuri, surgeon, mk3Granaino, jajereal, ncx, juancete, Pokayoke, Jorge75016, DESMOCHEEE!!!, Guillen222, V de Viana, D83, riclanico, tonnety, lead, rrttrr, CuPra3004Drive, jguirao, Brandenor, triguero, Pedrost, perikolu, Alvi, Edu1589, victor david, aironsam14, Chema Sat, Josepo79, Senuto, sesmero87, Rapiru, Sergt, Llisus, richard_11, vanscampa, nifer, BEDIA, SantiagoSanchez, nachomart, quimiko, barrosdepor, Eohn94, Flow-Rider, puskas65, Snooker83, Angeleitor, Morales92, Rober_SR, Piro25, cucci, RamonLaC, erlanz, Raaz, DiegoR, Brunozp, pablomus85, kwatto, msmdraven, iNFeCTeD, MartinLeon, antelo85, Maikermx, josean-opc, El_pelos44, Mr.Chuflas, SantiPMI, Chrohu, LuigiVisio, joga, Atajunen, lafu1988, daniel.velarde77, galelir, rpv, Link, jose.a.llamas, eyebee, D.Acuña, Manzi, bluesbreaker88, Lady, higuerashxc, Warelio, St17, carlitos24, ginyu 83, Jastur, talanito, victorvOrtiz, Alf68, AlvaroRamlo, Yagadri, ebcuatro, MaNDuN, Davidv, Andertxu7, garruz666, antoniofdezpas, josearillaperez., MaximusRoco, ezanchi
Re: Accesorios aliexpress mk3
Notapor Warelio el 10 Jul 2020, 11:44
gaaas escribió:Bueno, pues compré la tapa para la batería que muchos compañeros han comprado, y pese a ser del tamaño correcto para la batería de un TDI, la tapa no encaja.
Me hace interferencia con el conector que en otro hilo leí que servia para desconectar el Star&Stop. Dejo imagen del conector que interfiere con la tapa de la batería.
La tapa que compré es esta. Aunque creo que es la misma en todos los vendedores.
https://es.aliexpress.com/item/32981769 ... 63c0mTYvDt
Atención a los que tengan un MY20 TDI Fast Ed. porque pueden encontrarse con que no encaje por culpa del conector este. No sé si el conector es más largo o porqué interfiere, el caso es que tendré que tirar de Dremel si quiero aprovechar la tapa.
Yo la compré en su día y en mi caso el conector que mencionas no me molestó para colocarla, el mío es un MY18 y salvo que hayan cambiado los conectores de las baterías en los últimos modelos debería servir. No la compré a ese vendedor de Aliexpress concretamente pero vamos, que debería ser la misma.
Yo compré esta concretamente:
https://es.aliexpress.com/item/32848599 ... 63c0CZEi8w
Warelio
Moderador de Racing
Agradecido: 1183 veces
Notapor Raulribarroja el 14 Jul 2020, 14:04
Buenas tarde , alguien compro unos protectores para los asientos , como una barra que acopla en la parte trasera de los asientos delanteros para que no se marquen al entrar . Alguien los ha visto ? Gracias
Raulribarroja
Coche: Otro modelo SEAT
Notapor Agonza86 el 14 Jul 2020, 14:11
Raulribarroja escribió:Buenas tarde , alguien compro unos protectores para los asientos , como una barra que acopla en la parte trasera de los asientos delanteros para que no se marquen al entrar . Alguien los ha visto ? Gracias
Me suena que alguien los ha cogido, con el logotipo R de VW. Mírate unas páginas más atrás que aparece.
Agonza86
Agradecido: 409 veces
Notapor Warelio el 14 Jul 2020, 14:20
Yo los compré hace ya tiempo y muy contento con ellos, encajan a la perfección.
Warelio
Moderador de Racing
Notapor Warelio el 14 Jul 2020, 14:29
El vendedor al que se los compré ya no los tiene disponibles pero si escribes en el buscador Seat Anti Kick aparecen de otros vendedores y alguno seguro que te vale porque son para coches del grupo VAG y esa zona es común para casi todos y son idénticos a los que yo compré.
Warelio
Moderador de Racing
Notapor ecolibra el 14 Jul 2020, 14:32
Warelio escribió:
Agonza86 escribió:
Warelio escribió:Nueva chuchería recibida...
Están curiosos los cajoncitos esos, ajustan perfectos?
Yo seguro que no se los voy a poner por un simple motivo: cuantos más huecos y cajones, más cosas guardas. Y al final acaban llenos de bolis, mecheros, monedajas sueltas etc jajajajajaja
Saludos!!
Encajan clavados y quedan a ras del hueco, yo los he puesto por la sencilla razón de proteger el asidero de contra el desgaste, de tanto abrir y cerrar la puerta sobretodo la del conductor ¿no te has dado cuenta de que se acaba desgastando el hueco del asidero y acaba quedando el plástico liso por dentro como si hubiera perdido rugosidad? Pues por eso lo he puesto principalmente, así protejo esa zona ya que ahora es la pieza esa la que agarro para abrir y cerrar la puerta. El hueco que queda solamente podrás poner clips y monedas, y como mucho un mando a distancia de los de parking o el Vía T.
Quedan firmes a la hora de tirar para cerrar la puerta? O quedan sueltos? Es que al no llevar adhesivo... Los pedi el otro dia,pero ahora me queda esa duda...
ecolibra
Coche: Leon MK2 1.6 TDI 105cv
Agradecido: 23 veces
Notapor ecolibra el 14 Jul 2020, 14:33
Una pregunta... Alguien a comprado la bandeja para el apoyabrazos? Es para sustituir a la de serie,o es para tener 2 huecos?
ecolibra
Notapor Warelio el 14 Jul 2020, 17:00
Saludos!!
Si quieres que no se mueva en absoluto le pones un poco de cinta de doble cara fina y listo, ni se moverá
Warelio
Moderador de Racing
Notapor Warelio el 14 Jul 2020, 17:02
ecolibra escribió:Una pregunta... Alguien a comprado la bandeja para el apoyabrazos? Es para sustituir a la de serie,o es para tener 2 huecos?
Está pensada para tener 2 huecos
Warelio
Moderador de Racing
Notapor ecolibra el 14 Jul 2020, 17:39
Warelio escribió:
Saludos!!
Vaya.. no queria hacer eso.. las queria de quita y pon... Se mueven en exceso dejándolas tal cual? Tu como las llevas?
ecolibra
Notapor Warelio el 15 Jul 2020, 07:39
ecolibra escribió:
Warelio escribió:
Saludos!!
Son de quita y pon, las pones y quedan encajadas en el hueco pero se quitan igual de fácil que se ponen. Yo las llevo tal cual me llegaron, encajadas en el hueco de la puerta y listo. Dejándolas tal cual no se mueven ni se salen a no ser que te dediques a meter el coche por caminos bacheados a toda leche y hagas rallies. Las llevo desde hace unos días y de momento todo perfecto, ni se nota que están y quedan perfectamente integradas en la puerta, ya expliqué el motivo por el que las puse, no para tener más huecos portaobjetos sino para proteger el tirador de la puerta del desgaste de abrir y cerrar cada día.
Warelio
Moderador de Racing
Notapor ecolibra el 15 Jul 2020, 09:35
Warelio escribió:
ecolibra escribió:
Warelio escribió:
Saludos!!
Para eso mismo los quiero yo,para proteger del desgaste,como hueco porta objetos,yo personalmente no le veo mucha utilidad,prefiero dejar el asidero para lo que es,abrir y cerrar la puerta...
ecolibra
Notapor sjreggy el 15 Jul 2020, 11:08
ecolibra escribió:
Warelio escribió:
ecolibra escribió:
Warelio escribió:
Saludos!!
Yo creo que puede ser perfecto para llevar el mando a distancia de apertura de la puerta de garaje... veremos cuando llegue.
sjreggy
Notapor ecolibra el 15 Jul 2020, 11:15
sjreggy escribió:
ecolibra escribió:
Warelio escribió:
ecolibra escribió:
Warelio escribió:
Saludos!!
Yo el mando del garaje lo llevo en el hueco de delante de la palanca de cambios
ecolibra
Notapor PuertoLeon el 19 Jul 2020, 16:45
#Aliexpress € 8,09 10%OFF | Panel de reflexión de espejo de estilo de coche BC, película adhesiva de triángulo decorativo trasero de columna para Chevrolet Cruze sedan hatchback
https://a.aliexpress.com/_BUOZxf
Hola conocéis si hay algo parecido a esto para el León? Estoy preguntando a varios vendedores pero no doy con ninguno que lo tenga...
Enviado desde mi SM-G950F mediante Tapatalk
PuertoLeon
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 41 veces
Usuarios navegando por este Foro: Anthropic, Semrush y 14 invitados
