Accesorios aliexpress mk3
Favoritos: ositoerik, ROBERTO206, Stealnick, asaltacunas, tsi125, Alleya, Qore, tonnety, Juantxu, mk3Granaino, dani10s, damsolu, clotza, Levanius, pjdelburgo, frigolin, drnrd, Bass8V, Joali, toniRG, Jastur, morat86, _warcry_, Nikobellic, Lopagan666, Lyern, basuvi, rob3r7o, Lady, Danisisa_cupra
Seguidores: jose007dt, adri.f1, adrii18600, IronTor21, toniespejolara719, Hovig, trazas, drnrd, Chuskon, ecolibra, Gus-Gus, suarez22, TomH30, danone10, viktor_ct_95, pozyano, ChusTj, kennit0, Lopess85, er_trompe, rfaus, Gsclosada, djcastle, sergi303, DBS83, Ivensound, Hectoor57, JoseDel, agus_piscis10, jagman, warcryrivas, carrasco13, Triple R, luigi323, digital77, PuertoLeon, El Gonzo, LeonComeIbiza, dRoXe, osjamil, xjuliox, Per3zo, dPintos, VapaV, Igor, kukikukarron, Sanz, fur, chisyelamos, diegoporta97, carlosgzlez, leonfr76, smpxque, inamarlo, R1k4rd0, iviHDR, Moigijon, jd_zuri, surgeon, mk3Granaino, jajereal, ncx, juancete, Pokayoke, Jorge75016, DESMOCHEEE!!!, Guillen222, V de Viana, D83, riclanico, tonnety, lead, rrttrr, CuPra3004Drive, jguirao, Brandenor, triguero, Pedrost, perikolu, Alvi, Edu1589, victor david, aironsam14, Chema Sat, Josepo79, Senuto, sesmero87, Rapiru, Sergt, Llisus, richard_11, vanscampa, nifer, BEDIA, SantiagoSanchez, nachomart, quimiko, barrosdepor, Eohn94, Flow-Rider, puskas65, Snooker83, Angeleitor, Morales92, Rober_SR, Piro25, cucci, RamonLaC, erlanz, Raaz, DiegoR, Brunozp, pablomus85, kwatto, msmdraven, iNFeCTeD, MartinLeon, antelo85, Maikermx, josean-opc, El_pelos44, Mr.Chuflas, SantiPMI, Chrohu, LuigiVisio, joga, Atajunen, lafu1988, daniel.velarde77, galelir, rpv, Link, jose.a.llamas, eyebee, D.Acuña, Manzi, bluesbreaker88, Lady, higuerashxc, Warelio, St17, carlitos24, ginyu 83, Jastur, talanito, victorvOrtiz, Alf68, AlvaroRamlo, Yagadri, ebcuatro, MaNDuN, Davidv, Andertxu7, garruz666, antoniofdezpas, josearillaperez., MaximusRoco, ezanchi
Re: Accesorios aliexpress mk3
Notapor PuertoLeon el 24 Sep 2020, 18:18
Welder escribió:
PuertoLeon escribió:Será este accesorio compatible con nuestros leones mk3??
Lo veo muy parecido y que puede encajar... Qué me decís??
€ 8,59 11%OFF | Pegatinas para el coche, 1 unidad, de acero inoxidable, ajuste del panel de ajuste del aire acondicionado, cubierta de decoración para el 2018 2019 Volkswagen VW T-ROC
https://a.aliexpress.com/_B1Cb8T
Enviado desde mi SM-G950F mediante Tapatalk
Si te fijas más abajo verás que uno de los comentarios es de alguien que lo ha montado en un Ateca, y v con foto y todo, así que te valdrá supongo.
Yo creo que si, veo la misma consola aunque me interesa en negro brillo. Le pregunté al vendedor a ver si lo puede tener disponible...
Algún accesorio más del Ateca valdría para los mk3??
PuertoLeon
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 41 veces
Notapor angelchc el 24 Sep 2020, 19:15
Hola a todos.
Soy el propietario de un Seat Leon ST de 2019 y he mirado en aliexpress una tapa para la bateria. He estado a punto de comprar esta: https://es.aliexpress.com/item/32981769459.html?spm=a2g0o.productlist.0.0.4163464f1TNTwA&algo_pvid=c845df29-314b-49bd-b50c-9b1a3d3c7b66&algo_expid=c845df29-314b-49bd-b50c-9b1a3d3c7b66-1&btsid=0bb0622e16009674634076224ed9db&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
Pero en los comentarios dicen que no vale para el modelo de gasolina, que le viene grande. ¿Alguien me puede confirmar alguna tapa que le sirva un modelo de gasolina? Es que mirando en la descripcion no pone nada y no me fio de preguntar al vendedor.
Muchas gracias
angelchc
Coche: Leon MK3 1.0 TSI 115cv
Notapor perinkel el 24 Sep 2020, 19:31
Creo que no hay nadie que venda esa tapa más pequeña, salen todas de la misma fábrica juraría y luego es vendida por varios vendedores. Yo compre esa y si, es cierto que queda grande, pero se puede enganchar, yo como tengo pensado cuando toque cambiar la batería, poner el modelo de 70 amperios, pues ya la tengo y mientras tanto hace que el vano motor, luzca un poco más
perinkel
Agradecido: 29 veces
Notapor jlbpmr el 25 Sep 2020, 11:48
angelchc escribió:Hola a todos.
Muchas gracias
Yo tengo esa y cubre toda la bateria, en el Cupra por lo menos
jlbpmr
Agradecido: 112 veces
Notapor perinkel el 25 Sep 2020, 13:24
Muchas gracias
Claro,pero es que el Cupra si lleva la batería grande de 70 A y por eso la cubre totalmente,los que no son Cupra ni Diésel,usan una batería de 60 A que es más pequeña unos 4-5 cm y de ahí lo que comenta el compañero
perinkel
Notapor dudufonica el 25 Sep 2020, 16:58
Pue soy juraría llevar una de 70.ª,1.5 gasolina 150cv.
dudufonica
Notapor jlbpmr el 26 Sep 2020, 02:41
Muchas gracias
Ok, como puso lo de gasolina pense, coño, el Cupra es gasolina y le va perfecta, ok entonces.
jlbpmr
Notapor MauroST el 27 Sep 2020, 22:08
Yo compre esta hace un par de semanas y perfecta para el ST 1.5TSI DSG7
https://m.es.aliexpress.com/item/329491 ... 63c0jjazY4
MauroST
Notapor dudufonica el 28 Sep 2020, 10:21
1.5 ecotsi 150cv fr fast edition de julio 2020 Bateria de 70A
dudufonica
Notapor PuertoLeon el 29 Sep 2020, 12:17
Comprado! A ver si vale la pena... Colgaré fotos...
€ 7,89 30%OFF | Coche parabrisas sombrillas Flodable Auto frente parasol para ventanilla reflectante Viseras para Seat Leon MK2 MK3 Auto Accesorios
https://a.aliexpress.com/_mOlD3dt
PuertoLeon
Notapor Jastur el 29 Sep 2020, 14:48
PuertoLeon escribió:Comprado! A ver si vale la pena... Colgaré fotos...
Este me iba a animar yo a comprarlo, ahora esperare a ver como queda cuando te llegue.
Jastur
Agradecido: 35 veces
Notapor jose.a.llamas el 29 Sep 2020, 20:26
dudufonica escribió:1.5 ecotsi 150cv fr fast edition de julio 2020 Bateria de 70A
Yo tengo la misma batería en un 1.5 TGI (gas natural) ¿te encaja bien la tapa del enlace?
Enviado desde mi SM-T830 mediante Tapatalk
jose.a.llamas
Agradecido: 10 veces
Notapor PuertoLeon el 29 Sep 2020, 20:34
20 días... Y subo foto...
PuertoLeon
Notapor KevinFr2 el 08 Oct 2020, 11:56
Bueno chicos , yo ya he recibido mis muelles de capó , y tapa de motor de Aliexpress.
Super contento con las compras, los muelles super fácil de montar, y la tapa viene con emblema Seat y es una pasada.
Muelles montados
https://es.aliexpress.com/item/40001837 ... 63c0MBsRls
Tapa de motor.
https://es.aliexpress.com/item/32948962 ... 63c0MBsRls
Última edición por KevinFr2 el 08 Oct 2020, 12:03, editado 2 veces en total
KevinFr2
Coche: Leon MK2 1.4 TSI 125cv
Agradecido: 20 veces
Notapor jlbpmr el 08 Oct 2020, 12:02
Hay que taladrar o algo para poner los muelles ??
jlbpmr
Usuarios navegando por este Foro: AhrefsBot, Anthropic, Google [Bot] y 17 invitados
