Accesorios aliexpress mk3
Favoritos: ositoerik, ROBERTO206, Stealnick, asaltacunas, tsi125, Alleya, Qore, tonnety, Juantxu, mk3Granaino, dani10s, damsolu, clotza, Levanius, pjdelburgo, frigolin, drnrd, Bass8V, Joali, toniRG, Jastur, morat86, _warcry_, Nikobellic, Lopagan666, Lyern, basuvi, rob3r7o, Lady, Danisisa_cupra
Seguidores: jose007dt, adri.f1, adrii18600, IronTor21, toniespejolara719, Hovig, trazas, drnrd, Chuskon, ecolibra, Gus-Gus, suarez22, TomH30, danone10, viktor_ct_95, pozyano, ChusTj, kennit0, Lopess85, er_trompe, rfaus, Gsclosada, djcastle, sergi303, DBS83, Ivensound, Hectoor57, JoseDel, agus_piscis10, jagman, warcryrivas, carrasco13, Triple R, luigi323, digital77, PuertoLeon, El Gonzo, LeonComeIbiza, dRoXe, osjamil, xjuliox, Per3zo, dPintos, VapaV, Igor, kukikukarron, Sanz, fur, chisyelamos, diegoporta97, carlosgzlez, leonfr76, smpxque, inamarlo, R1k4rd0, iviHDR, Moigijon, jd_zuri, surgeon, mk3Granaino, jajereal, ncx, juancete, Pokayoke, Jorge75016, DESMOCHEEE!!!, Guillen222, V de Viana, D83, riclanico, tonnety, lead, rrttrr, CuPra3004Drive, jguirao, Brandenor, triguero, Pedrost, perikolu, Alvi, Edu1589, victor david, aironsam14, Chema Sat, Josepo79, Senuto, sesmero87, Rapiru, Sergt, Llisus, richard_11, vanscampa, nifer, BEDIA, SantiagoSanchez, nachomart, quimiko, barrosdepor, Eohn94, Flow-Rider, puskas65, Snooker83, Angeleitor, Morales92, Rober_SR, Piro25, cucci, RamonLaC, erlanz, Raaz, DiegoR, Brunozp, pablomus85, kwatto, msmdraven, iNFeCTeD, MartinLeon, antelo85, Maikermx, josean-opc, El_pelos44, Mr.Chuflas, SantiPMI, Chrohu, LuigiVisio, joga, Atajunen, lafu1988, daniel.velarde77, galelir, rpv, Link, jose.a.llamas, eyebee, D.Acuña, Manzi, bluesbreaker88, Lady, higuerashxc, Warelio, St17, carlitos24, ginyu 83, Jastur, talanito, victorvOrtiz, Alf68, AlvaroRamlo, Yagadri, ebcuatro, MaNDuN, Davidv, Andertxu7, garruz666, antoniofdezpas, josearillaperez., MaximusRoco, ezanchi
Re: Accesorios aliexpress mk3
Notapor Warelio el 11 Oct 2020, 22:58
Hovig escribió:
Warelio escribió:
jlbpmr escribió:Espero a ver fotos del hidraulico solo, la verdad es que en el MkI que tenia era una pasada de bien, este con la barra es una jodienda.
Pongo foto del que yo he comprado, a la espera de que me llegue y lo monte. Me lo han recomendado expresamente, es caro en comparación a lo que hay pero me han asegurado que merece la pena y con uno solo basta.
Hola compañero! Puedes poner referencia o link de donde lo has comprado! Se ve con mejor acabado que con las de AliExpress a parte Mejor uno que dos!! Gracias
No lo he comprado en ninguna web, lo he comprado recomendado por un amigo a un grupo de ingenieros de Madrid que se dedican a diseñar este tipo de piezas y las venden, por eso solamente con uno es suficiente y su calidad es alta, también sale más caro que los hidráulicos de AliExpress pero como solamente voy a instalarlo una vez por eso prefiero algo de calidad y que no me de problemas a la larga. Cuando lo reciba la próxima semana pondré más fotos y cómo queda instalado.
Warelio
Moderador de Racing
Agradecido: 1183 veces
Notapor tuthankamenn el 12 Oct 2020, 10:06
En mi antiguo Passat tb tenía un amortiguador.
La verdad q es más cómodo,pero tampoco es una cosa q esté abriendo cada día.
Es mi opinión.
Sdos
SEAT LEON ST FR 1.5 ECOTSI AUT. 150CV
Mi cacharro viewtopic.php?f=43&t=132699
tuthankamenn
Agradecido: 17 veces
Notapor Jastur el 19 Oct 2020, 10:25
Warelio escribió:Nueva chuchería recibida...
Hola @Warelio, los he comprado yo y el del conductor queda bien pero suelto, en cambio el del copiloto encaja mas justo. Has puesto algo para que quede mas ajustado el del conductor?
Gracias.
Jastur
Agradecido: 35 veces
Notapor Warelio el 19 Oct 2020, 11:14
Gracias.
Supongo que te refieres a las piezas de los asideros de las puerta delanteras, ¿no? En mi caso ambos encajan perfectamente, el del copiloto algo más justo pero en ningún caso se me mueven al circular, una vez te acostumbras que al abrir la puerta se ha de agarrar de una forma distinta ya ni te enteras que lo llevas. Supongo que si pones un poco de cinta de doble cara eso quedará bien sujeto sin moverse, yo no he puesto nada y no se me ha salido ninguna vez.
Warelio
Moderador de Racing
Notapor Jastur el 19 Oct 2020, 11:20
Gracias.
Vale si, nada era eso que la del copiloto queda mas justa, pero mover no se mueve.
Gracias.
Jastur
Notapor Warelio el 19 Oct 2020, 11:27
Jastur escribió:
Gracias.
Gracias.
La pieza del copiloto entra más justa porque la parte interna del asidero original del coche no está apenas desgastada del uso. El asidero que más se desgasta es el del conductor de tanto abrir y cerrar la puerta, por eso esa pieza encaja más holgada, pasa la mano por dentro de un asidero y del otro y verás la diferencia de tacto. Si esa pieza se instala en un coche completamente nuevo seguro que ambas encajarían igual de ajustadas.
Warelio
Moderador de Racing
Notapor Warelio el 23 Oct 2020, 10:13
Ya tengo instalado el hidráulico que os comenté para el capó, lo he publicado en el hilo específico con fotos para no desviar el tema aquí por si queréis echar un vistazo. Dejo el enlace abajo.
viewtopic.php?f=40&t=105088&p=2133363#p2133363
Warelio
Moderador de Racing
Notapor PuertoLeon el 26 Oct 2020, 15:03
Bueno pues por fin ha llegado! Se retrasó pero llegó. Aunque cuando haga calor ya veré si sirve o no , porque ahora en otoño...hasta que no llegue el calor.
Es cómodo, se pliega y ocupa poco espacio aunque lo veo pequeño para todo el parabrisas...
Saludos! Imagen
Enviado desde mi SM-G950F mediante Tapatalk
PuertoLeon
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 41 veces
Notapor Warelio el 26 Oct 2020, 15:18
PuertoLeon escribió:Bueno pues por fin ha llegado! Se retrasó pero llegó. Aunque cuando haga calor ya veré si sirve o no , porque ahora en otoño...hasta que no llegue el calor.
Saludos! [ Imagen ]
Tiene buena pinta, ya nos contarás qué tal se comporta en los días de calor.
Warelio
Moderador de Racing
Notapor arlot el 28 Oct 2020, 18:56
Gracias.
Me ocurre lo mismo, será cuestión de ponerle un poco de cita de doble cara
Vamoooooooooooooos
arlot
Agradecido: 977 veces
Notapor Warelio el 28 Oct 2020, 20:43
Gracias.
Es por lo que comenté más arriba, el tirador del conductor siempre estará más desgastado de abrir y cerrar la puerta por eso el del conductor encaja mejor que el del acompañante que al no estar tan gastado el tirador entra más justo.
Enviado desde mi Pixel 4 XL mediante Tapatalk
Warelio
Moderador de Racing
Notapor ecolibra el 28 Oct 2020, 20:46
Gracias.
Yo les he puesto una especie de terciopelo fino adhesivo que venden en ferreterías o tiendas de bricolaje,asi quedan de quita y pon y tienen un ajuste perfecto.
ecolibra
Coche: Leon MK2 1.6 TDI 105cv
Agradecido: 23 veces
Notapor Warelio el 28 Oct 2020, 20:50
ecolibra escribió:
Gracias.
Pues no sé, a mí me encajan perfectos, el del copiloto algo más justo pero no se mueve para nada y queda a ras del tirador como el otro.
Warelio
Moderador de Racing
Notapor arlot el 29 Oct 2020, 21:24
Un poco de fieltro en ambos lados de cajetín, y queda bien clavado
Vamoooooooooooooos
arlot
Notapor ecolibra el 29 Oct 2020, 21:26
arlot escribió:Un poco de fieltro en ambos lados de cajetín, y queda bien clavado
Exacto! Asi mismo lo hice yo.
ecolibra
