Accesorios aliexpress mk3
Favoritos: ositoerik, ROBERTO206, Stealnick, asaltacunas, tsi125, Alleya, Qore, tonnety, Juantxu, mk3Granaino, dani10s, damsolu, clotza, Levanius, pjdelburgo, frigolin, drnrd, Bass8V, Joali, toniRG, Jastur, morat86, _warcry_, Nikobellic, Lopagan666, Lyern, basuvi, rob3r7o, Lady, Danisisa_cupra
Seguidores: jose007dt, adri.f1, adrii18600, IronTor21, toniespejolara719, Hovig, trazas, drnrd, Chuskon, ecolibra, Gus-Gus, suarez22, TomH30, danone10, viktor_ct_95, pozyano, ChusTj, kennit0, Lopess85, er_trompe, rfaus, Gsclosada, djcastle, sergi303, DBS83, Ivensound, Hectoor57, JoseDel, agus_piscis10, jagman, warcryrivas, carrasco13, Triple R, luigi323, digital77, PuertoLeon, El Gonzo, LeonComeIbiza, dRoXe, osjamil, xjuliox, Per3zo, dPintos, VapaV, Igor, kukikukarron, Sanz, fur, chisyelamos, diegoporta97, carlosgzlez, leonfr76, smpxque, inamarlo, R1k4rd0, iviHDR, Moigijon, jd_zuri, surgeon, mk3Granaino, jajereal, ncx, juancete, Pokayoke, Jorge75016, DESMOCHEEE!!!, Guillen222, V de Viana, D83, riclanico, tonnety, lead, rrttrr, CuPra3004Drive, jguirao, Brandenor, triguero, Pedrost, perikolu, Alvi, Edu1589, victor david, aironsam14, Chema Sat, Josepo79, Senuto, sesmero87, Rapiru, Sergt, Llisus, richard_11, vanscampa, nifer, BEDIA, SantiagoSanchez, nachomart, quimiko, barrosdepor, Eohn94, Flow-Rider, puskas65, Snooker83, Angeleitor, Morales92, Rober_SR, Piro25, cucci, RamonLaC, erlanz, Raaz, DiegoR, Brunozp, pablomus85, kwatto, msmdraven, iNFeCTeD, MartinLeon, antelo85, Maikermx, josean-opc, El_pelos44, Mr.Chuflas, SantiPMI, Chrohu, LuigiVisio, joga, Atajunen, lafu1988, daniel.velarde77, galelir, rpv, Link, jose.a.llamas, eyebee, D.Acuña, Manzi, bluesbreaker88, Lady, higuerashxc, Warelio, St17, carlitos24, ginyu 83, Jastur, talanito, victorvOrtiz, Alf68, AlvaroRamlo, Yagadri, ebcuatro, MaNDuN, Davidv, Andertxu7, garruz666, antoniofdezpas, josearillaperez., MaximusRoco, ezanchi
Re: Accesorios aliexpress mk3
Notapor Warelio el 11 Feb 2021, 08:41
El mando de la puerta de mi garaje es también pequeño y cabe perfecto en ese hueco de la llave, genial para tenerlo siempre a mano sin tener que andar buscándolo por el resto de huecos y manejarlo sin tener que moverlo de ahí.
Enviado desde mi Pixel 4 XL mediante Tapatalk
Warelio
Moderador de Racing
Agradecido: 1182 veces
Notapor Xavi_FR el 11 Feb 2021, 19:30
mgrondona escribió:
Xavi_FR escribió:Os dejo aquí mis adquisiciones de AliExpress,
Cubierta magnética para parasol de coche, parabrisas de coche.
https://a.aliexpress.com/_uQlQUx
Humidificador de aire portátil para coche de tamaño mini.
https://a.aliexpress.com/_vrbmIB
Ambientador de perfume para rejilla
https://a.aliexpress.com/_uxPhqb
Mando a distancia Mini puerta parking.
https://a.aliexpress.com/_uyg6dH
Tanto la cubierta como el humidificador no los e probado aún. El ambientador la verdad que estéticamente queda bien pero no vale la pena, no desprende nada de olor. Lo mejor es el mando, funciona perfectamente y encaja bien en el hueco que tenemos al lado del freno eléctrico. Desde que lo tengo, solo lo e quitado de ahí para cambiarle la pila.
Cuando pruebes el mando comentanos que tal va, que me interesa comprar uno así... Gracias!!
Enviado desde mi Mi A3 mediante Tapatalk
Estos mandos van genial, llevo con uno 2 años y esta semana he tenido que cambiar la pila y de nuevo funcionando. He comprado otro para tenerlo de repuesto,lo que si hay que tener en cuenta, es que tienes que buscar uno que sea compatible con el modelo de tu mando original. Una vez que lo tienes copias el mando, haces la copia del mando original y luego haces que la centralita reconozca dándole de alta el mando y listo.
https://youtu.be/A6AiFPssFT0
Mi mando es el mismo que el del vídeo y yo no tuve que desmontar centralita, presionar botón apuntando a la centralita " pitido centralita" y listo.
Seat Leon ST FR TSI 130cv.
En mi linea
Xavi_FR
Agradecido: 37 veces
Notapor Xavi_FR el 11 Feb 2021, 20:16
El humidificador lo compré hace ya un tiempo y funciona bien, además de noche ilumina la zona del posavasos con luces led que cambian de color y queda bonito. Si añades aceite de esencias al agua huele bastante bien.
La cubierta esa magnética es buena idea, lamentablemente durará poco en el coche porque depende de dónde vivas o dónde lo aparques te durará menos de 1 día... ya sabemos que hay gente que se pirra por lo que no es suyo...
No es para colocarla para la nieve ni durante la noche si es fuera de mis tierras jajajaja. La cubierta la compré para usarla cuando voy a la playa, como tiene la zona reflectante, se puede usar tanto para la calor como para el frio.La verdad que es rápido de colocar y parte de la cubierta queda sujeta dentro del interior del coche. Yo la verdad que deje de usar el típico parasol que colocamos dentro.Esto es poner y cuando llegas, tirás de una punta lo doblas y listo.
Con mi anterior coche "C4 gran Picasso" ya lo hacía así por qué tapar una luna de 72" por dentro era un engorro.
En mi linea
Xavi_FR
Notapor AK2502- 5F19 el 22 Feb 2021, 00:31
Buenas he visto el alerón para el León en Aliexpress esta por 60€ alguien lo ha pedido? Parece que llega bastante bien por ese precio. Es este https://a.aliexpress.com/_uxB6kl
AK2502- 5F19
Notapor Warelio el 22 Feb 2021, 09:30
La calidad de ese alerón... Muy barato lo veo... Después has de contar lo que te cobren por pintarlo porque suelen venir solamente imprimados. Además si lo has de homologar después vas a tener problemas porque dudo que el vendedor te entregue cualquier tipo de certificado, documento o factura. Si quieres montar un alerón y no quieres tener después problemas en cuanto a documentación, homologaciones y sobretodo calidad del producto lo suyo es gastarte la pasta y buscar uno original. Es algo que solamente vas a instalar una vez y olvidarte del tema. Además de asegurarte que será perfectamente compatible con el coche. Como siempre la decisión final es de uno mismo, pero cuanta más información tengas mejor. Después de todo lo que he comprado para el coche por AliExpress, y te aseguro que he comprado bastantes cosas, llego a la conclusión que lo realmente merece la pena son los pequeños accesorios y añadidos simples porque son baratos y de buena calidad por lo general. Si te vas ya a piezas más grandes y "elaboradas" la cosa cambia y aunque obviamente no se van a romper el primer día, ya instalarlas no suele ser tarea sencilla y envejecen peor con el paso del tiempo por la calidad de los materiales empleados.
Warelio
Moderador de Racing
Notapor Lito69 el 22 Feb 2021, 10:25
Luisete86 escribió:https://es.aliexpress.com/item/32809060446.html
Teneis experiencia de comprar estos recambios?
Funciona bien, al menos los de marca bosch de ebay, o que dicen que son bosch, así me tiré 10 años con unos bosch aerotwin en el leon 1, cambiando sólo la tira.
Yo estoy buscando para poner la tablet a la niña detras del reposacabezas, compré lo de detrás del asiento, organizador o algo así, a la novia le dije que era para poner las cosas pero realmente es para que no me manche el asiento con los pies, pero pongo la tablet ahí y no se sujeta bien.
Lito69
Agradecido: 240 veces
Notapor AK2502- 5F19 el 22 Feb 2021, 10:40
Gracias por el consejo Warelio. La otra opción que tengo barajada es en Ebay sale en 95 ya pintado y eh visto en YouTube que llega bien y en fibra de vidrio. Lo que tengo la duda de si viene con algún certificado no lo creo, por si algún día hago proyecto.
AK2502- 5F19
Notapor Warelio el 22 Feb 2021, 13:07
AK2502- 5F19 escribió:Gracias por el consejo Warelio. La otra opción que tengo barajada es en Ebay sale en 95 ya pintado y eh visto en YouTube que llega bien y en fibra de vidrio. Lo que tengo la duda de si viene con algún certificado no lo creo, por si algún día hago proyecto.
Dudo mucho que te venga con un certificado. 95 € será del mismo estilo que el que se venderá de AliExpress pero más caro al enviarse desde Europa. Eso ya has de valorarlo tú, ¿y dices que ya viene pintado por 95 €? ¿En el color de tu carrocería o el que tu elijas? Pero si por pintar el alerón en cualquier taller ya te piden ese dinero...
Warelio
Moderador de Racing
Notapor AK2502- 5F19 el 23 Feb 2021, 08:20
Pintado en negro venía y en Aliexpress viene en negro tambien. El de Ebay no lo veo pero hay unos pocos del estilo este con los flaps por 135..https://www.ebay.es/itm/233651634633
Lo que si que veo una burrada los 300 o 400 que piden en la Seat.. Si alfinal me decido a comprarlo ya subiré alguna foto y opinión por si alguien se anima!!
AK2502- 5F19
Notapor Warelio el 23 Feb 2021, 10:01
Vienen imprimados normalmente. Cualquier añadido que se le ponga al coche a posterior de ese estilo me parece una burrada en el precio pero es como está la cosa montada y si lo quieres lo has de pagar... Suerte con el alerón, ya nos contarás cómo es y qué tal el montaje.
Warelio
Moderador de Racing
Notapor Veronica_L el 24 Feb 2021, 09:28
Gracias por la aportación.
¿Qué tal la calidad, merece la pena?
Veronica_L
Coche: Leon MK2 2.0 16v 170cv
Notapor SantiPMI el 01 Mar 2021, 15:41
Creo que en cerca de los 1800 mensajes no ha salido
Es para el Golf 7, no sé si el volante es el mismo. No he visto nada de FR, que tampoco sé si el volante del FR lleva eso
€ 2,15 49%OFF | Protector para volante de coche etiqueta coche productos embellecedor decorativo tiras para GOLF 7 Tiguan Lavida Bora Sagitar Jetta Santana Teramont
https://a.aliexpress.com/_ve6YGp
Enviado desde mi SM-T720 mediante Tapatalk
SantiPMI
Coche: Leon MK3 1.0 TSI 115cv
Agradecido: 27 veces
Notapor Warelio el 01 Mar 2021, 15:48
SantiPMI escribió:Creo que en cerca de los 1800 mensajes no ha salido
Ese embellecedor no sirve para el volante del León MK3. Son volantes distintos.
Warelio
Moderador de Racing
Notapor PuertoLeon el 01 Mar 2021, 18:14
Hola buenas tardes
Quiero comprar las luces de matricula en Led, pero las que hay son de 6500k...no es demasiado? Bueno o habría que mirar los lúmenes, 126 sería suficiente? Tampoco quiero que deslumbren y que alguno de verde te la lie... Qué tal vuestra experiencia con estos plafones?
Gracias saludos!
Enviado desde mi SM-G950F mediante Tapatalk
Última edición por PuertoLeon el 01 Mar 2021, 18:41, editado 1 vez en total
PuertoLeon
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 41 veces
Notapor PuertoLeon el 01 Mar 2021, 18:15
Lástima! Por más que he buscado... Para León no hay nada parecido... Salvo que lo vinilemos no??...
PuertoLeon
Usuarios navegando por este Foro: Anthropic, Google [Bot] y 17 invitados
