Accesorios aliexpress mk3
Favoritos: ositoerik, ROBERTO206, Stealnick, asaltacunas, tsi125, Alleya, Qore, tonnety, Juantxu, mk3Granaino, dani10s, damsolu, clotza, Levanius, pjdelburgo, frigolin, drnrd, Bass8V, Joali, toniRG, Jastur, morat86, _warcry_, Nikobellic, Lopagan666, Lyern, basuvi, rob3r7o, Lady, Danisisa_cupra
Seguidores: jose007dt, adri.f1, adrii18600, IronTor21, toniespejolara719, Hovig, trazas, drnrd, Chuskon, ecolibra, Gus-Gus, suarez22, TomH30, danone10, viktor_ct_95, pozyano, ChusTj, kennit0, Lopess85, er_trompe, rfaus, Gsclosada, djcastle, sergi303, DBS83, Ivensound, Hectoor57, JoseDel, agus_piscis10, jagman, warcryrivas, carrasco13, Triple R, luigi323, digital77, PuertoLeon, El Gonzo, LeonComeIbiza, dRoXe, osjamil, xjuliox, Per3zo, dPintos, VapaV, Igor, kukikukarron, Sanz, fur, chisyelamos, diegoporta97, carlosgzlez, leonfr76, smpxque, inamarlo, R1k4rd0, iviHDR, Moigijon, jd_zuri, surgeon, mk3Granaino, jajereal, ncx, juancete, Pokayoke, Jorge75016, DESMOCHEEE!!!, Guillen222, V de Viana, D83, riclanico, tonnety, lead, rrttrr, CuPra3004Drive, jguirao, Brandenor, triguero, Pedrost, perikolu, Alvi, Edu1589, victor david, aironsam14, Chema Sat, Josepo79, Senuto, sesmero87, Rapiru, Sergt, Llisus, richard_11, vanscampa, nifer, BEDIA, SantiagoSanchez, nachomart, quimiko, barrosdepor, Eohn94, Flow-Rider, puskas65, Snooker83, Angeleitor, Morales92, Rober_SR, Piro25, cucci, RamonLaC, erlanz, Raaz, DiegoR, Brunozp, pablomus85, kwatto, msmdraven, iNFeCTeD, MartinLeon, antelo85, Maikermx, josean-opc, El_pelos44, Mr.Chuflas, SantiPMI, Chrohu, LuigiVisio, joga, Atajunen, lafu1988, daniel.velarde77, galelir, rpv, Link, jose.a.llamas, eyebee, D.Acuña, Manzi, bluesbreaker88, Lady, higuerashxc, Warelio, St17, carlitos24, ginyu 83, Jastur, talanito, victorvOrtiz, Alf68, AlvaroRamlo, Yagadri, ebcuatro, MaNDuN, Davidv, Andertxu7, garruz666, antoniofdezpas, josearillaperez., MaximusRoco, ezanchi
Re: Accesorios aliexpress mk3
Notapor Warelio el 08 Abr 2021, 13:07
Gus-Gus escribió:
Warelio escribió:Buenas, os dejo otra chuminada de nuestros amigos orientales. Esta vez son unos embellecedores de aluminio para los botones reguladores de altura de los reposacabezas delanteros, llevan adhesivo de doble cara, el aro grande encaja perfecto, el círculo pequeño no lo he probado pero creo que también está hecho a la medida. Los he recibido hoy pero el enlace de donde los compré ya no existe aunque hay otras opciones de otros vendedores, incluso en otros colores. Os dejo fotos y cuando los tenga montados pondré otra con el resultado final. Aquí tenéis enlace de uno parecido que seguro también vale para el León, aunque este no añade la pieza redonda interna, solamente el aro externo.
https://es.aliexpress.com/item/40011597 ... web201603_
Saludos,[ Imagen ][ Imagen ]
Enviado desde mi Pixel 4 XL mediante Tapatalk
Pone que son del Karoq, los del Kodiak sabes si valdrán?
Diría que valen para casi cualquier modelo generalista del grupo VAG, desde luego para el León sirven pero recomiendo que añadas un poco de cinta de doble cara aparte de la que lleva porque como suele ocurrir la calidad del adhesivo que le ponen deja un poco que desear... Como dije en el anterior post, la pieza en forma de circulo del interior encaja bien pero impide que se pueda accionar el botón regulador del reposacabezas porque es un pelín más grande de diámetro y eso hace que el botón no pueda pulsarse, yo lo llevo todo instalado porque no toco nunca el reposacabezas pero puede ser que alguien que suele regularlo a menudo si pega ese círculo le moleste. El anillo exterior no molesta para nada y también encaja perfecto, es en ese anillo donde recomiendo añadir un poco de cinta de doble cara para que no se despegue.
Warelio
Moderador de Racing
Agradecido: 1183 veces
Notapor Gus-Gus el 08 Abr 2021, 19:07
Creo que me arriesgaré con estos
Vamos a ahorrar juntos en AliExpress con cupones de nuevo usuario.
¡Toma € 0,86 en cupones!
https://a.aliexpress.com/_vPoPqZ
Las medidas más o menos creo que valen. Entiendo que el aro exterior va pegado encima del negro original verdad? Supongo que por eso es un poco más grande, adjunto fotos.
Aqui tenéis mi Leon.
viewtopic.php?f=43&t=126141
Gus-Gus
Agradecido: 29 veces
Notapor Warelio el 08 Abr 2021, 19:58
Si si, las medidas cuadran y encajará, el problema lo tendrás con la pieza circular que por milímetros no te dejará pulsar el botón de los reposacabezas. Por lo demás quedan genial y a la medida. Sobretodo añade cinta de doble cara porque la que llevan se acaba despegando. Correcto, el aro exterior va pegado en el aro exterior del reposacabezas.
Warelio
Moderador de Racing
Notapor talanito el 08 Abr 2021, 22:01
Otra chorrada por aquí, recién puesta, son tres piezas, la goma interior que "envuelve" a la llave en sí, y recubre botonera, como la típica funda de silicona de los móviles; y luego dos carcasas, frontal y trasera, que se encajan con una pestaña y dos tornillos (viene con 3 tornillos pequeños, y un destornillador).
Chorrada pero molón. Creo que me costó 4€ o así
https://m.es.aliexpress.com/item/400111 ... .jpg_.webpImagenImagen
Enviado desde mi M2007J20CG mediante Tapatalk
talanito
Agradecido: 10 veces
Notapor Xavi_FR el 09 Abr 2021, 19:59
talanito escribió:Otra chorrada por aquí, recién puesta, son tres piezas, la goma interior que "envuelve" a la llave en sí, y recubre botonera, como la típica funda de silicona de los móviles; y luego dos carcasas, frontal y trasera, que se encajan con una pestaña y dos tornillos (viene con 3 tornillos pequeños, y un destornillador).
https://m.es.aliexpress.com/item/400111 ... .jpg_.webp[ Imagen ][ Imagen ]
Me uno con la funda y añado Vagcom
Seat Leon ST FR TSI 130cv.
En mi linea
Xavi_FR
Agradecido: 37 veces
Notapor ecolibra el 09 Abr 2021, 21:04
Queda la llave muy gorda?
Enviado desde mi Redmi Note 8 Pro mediante Tapatalk
ecolibra
Coche: Leon MK2 1.6 TDI 105cv
Agradecido: 23 veces
Notapor Xavi_FR el 09 Abr 2021, 21:10
Un poco si, pero merece la pena
En mi linea
Xavi_FR
Notapor MAZDACENERO el 10 Abr 2021, 01:01
Tiene buena pinta. La voy a pedir.
Última edición por cvillajos el 10 Abr 2021, 05:31, editado 1 vez en total
Razón: Edición quotes
MAZDACENERO
Notapor MAZDACENERO el 10 Abr 2021, 01:05
Miiister escribió:acabo de pillar los retros dinámicos a ver que tal sale.
¿algún video de como ponerlo?
Yo tambien los he pillado,a ver cuamdo me llegan.
MAZDACENERO
Notapor bigpicha el 11 Abr 2021, 01:32
https://youtu.be/wOcrr_Ll3p8
Yo los puse y quedan de vicio !! ( A ver la duración) y se ven mucho mejor de día y de noche.
Eso sí, en la carcasa derecha tardé unos 10min en quitarla por miedo a romper las patillas...usar la herramienta que viene de plastico para quitar algunas partes.. (luego en la del piloto tardé 1min)
Estas luces de retrovisor dinámicas valen para el MK4M
bigpicha
Agradecido: 35 veces
Notapor Warelio el 11 Abr 2021, 01:35
No, esos dinámicos no sirven para el MK4, los espejos son diferentes. Has de buscar algunos que sean específicos. No sé si ya los habrán diseñado pero no tardarán.
Warelio
Moderador de Racing
Notapor AK2502- 5F19 el 11 Abr 2021, 11:52
Buenas perdón por la tardanza estado falta de tiempo, comentar el tema del alerón de AliExpress.. La verdad super contento con el producto lo recomiendo 100%. Vino sin ningún rasguño, bien empaquetado, la pintura clavada y el envío en solo 20 días a Bcn. A falta de montarlo por tiempo en cuanto lo ponga subo fotos. Saludos!!
AK2502- 5F19
Notapor RGF2595 el 12 Abr 2021, 10:04
AK2502- 5F19 escribió:Buenas perdón por la tardanza estado falta de tiempo, comentar el tema del alerón de AliExpress.. La verdad super contento con el producto lo recomiendo 100%. Vino sin ningún rasguño, bien empaquetado, la pintura clavada y el envío en solo 20 días a Bcn. A falta de montarlo por tiempo en cuanto lo ponga subo fotos. Saludos!!
¿Algún problema con Aduanas?
León MK3 16´ FR Advanced 1.4 TSI ACT 150CV - Azul mediterráneo
Ateca 20´ FR Edition 2.0 TDI 150CV - Gris Rodium
RGF2595
Agradecido: 9 veces
Notapor AK2502- 5F19 el 12 Abr 2021, 18:39
0 problemas
AK2502- 5F19
Notapor JuananBFK el 13 Abr 2021, 14:20
Hola a todos, hoy me llego unas pegatinas para el interior de la consola que viene en negro piano para poner en carbono, os dejo unas fotos para que veáis como queda, lo único que los que tenemos el botón de arranque hay que hacer el agujero, por lo demás bien, paciencia pero bien jejejeje
JuananBFK
