Accesorios aliexpress mk3
Favoritos: ositoerik, ROBERTO206, Stealnick, asaltacunas, tsi125, Alleya, Qore, tonnety, Juantxu, mk3Granaino, dani10s, damsolu, clotza, Levanius, pjdelburgo, frigolin, drnrd, Bass8V, Joali, toniRG, Jastur, morat86, _warcry_, Nikobellic, Lopagan666, Lyern, basuvi, rob3r7o, Lady, Danisisa_cupra
Seguidores: jose007dt, adri.f1, adrii18600, IronTor21, toniespejolara719, Hovig, trazas, drnrd, Chuskon, ecolibra, Gus-Gus, suarez22, TomH30, danone10, viktor_ct_95, pozyano, ChusTj, kennit0, Lopess85, er_trompe, rfaus, Gsclosada, djcastle, sergi303, DBS83, Ivensound, Hectoor57, JoseDel, agus_piscis10, jagman, warcryrivas, carrasco13, Triple R, luigi323, digital77, PuertoLeon, El Gonzo, LeonComeIbiza, dRoXe, osjamil, xjuliox, Per3zo, dPintos, VapaV, Igor, kukikukarron, Sanz, fur, chisyelamos, diegoporta97, carlosgzlez, leonfr76, smpxque, inamarlo, R1k4rd0, iviHDR, Moigijon, jd_zuri, surgeon, mk3Granaino, jajereal, ncx, juancete, Pokayoke, Jorge75016, DESMOCHEEE!!!, Guillen222, V de Viana, D83, riclanico, tonnety, lead, rrttrr, CuPra3004Drive, jguirao, Brandenor, triguero, Pedrost, perikolu, Alvi, Edu1589, victor david, aironsam14, Chema Sat, Josepo79, Senuto, sesmero87, Rapiru, Sergt, Llisus, richard_11, vanscampa, nifer, BEDIA, SantiagoSanchez, nachomart, quimiko, barrosdepor, Eohn94, Flow-Rider, puskas65, Snooker83, Angeleitor, Morales92, Rober_SR, Piro25, cucci, RamonLaC, erlanz, Raaz, DiegoR, Brunozp, pablomus85, kwatto, msmdraven, iNFeCTeD, MartinLeon, antelo85, Maikermx, josean-opc, El_pelos44, Mr.Chuflas, SantiPMI, Chrohu, LuigiVisio, joga, Atajunen, lafu1988, daniel.velarde77, galelir, rpv, Link, jose.a.llamas, eyebee, D.Acuña, Manzi, bluesbreaker88, Lady, higuerashxc, Warelio, St17, carlitos24, ginyu 83, Jastur, talanito, victorvOrtiz, Alf68, AlvaroRamlo, Yagadri, ebcuatro, MaNDuN, Davidv, Andertxu7, garruz666, antoniofdezpas, josearillaperez., MaximusRoco, ezanchi
Re: Accesorios aliexpress mk3
Notapor IggyAl92 el 15 Mar 2023, 12:49
PuertoLeon escribió:Hola que tal, os comparto el resultado de vinilo en carbono en la parte interior todas las puertas. Era lo que faltaba por poner, pues el salpicadero y consola central, ya lo tenía.
Enviado desde mi SM-A525F mediante Tapatalk
Buenas compi, ¿puedes pasar link a los vinilos?
Gracias!
IggyAl92
Notapor SantiPMI el 15 Mar 2023, 13:12
IggyAl92 escribió:Buenos días compañeros,
estoy pensando en renovar un poco mi Seat León Xcellence Plus del 2017, y quería escuchar ideas de los accesorios que hayáis comprado y os hayan gustado para vuestros vehículos.
En principio admito todo tipo de cambio (pedales, alfombrillas, cosas del maletero, proyector con luz...), o cosas útiles que os sirvan a diario, como productos de limpieza, fundas de volante...
He mirado algunas de las páginas del primer post pero la mayoría aparecen como productos descatalogados o dan error las webs, ¿tenéis algo más actualizado?
Gracias!!
Yo tengo montada luz interior LED, las alfombrillas de goma que puse en un post anterior y los "cubiletes" para los asideros de las puertas delanteras. Y una goma que hace la medida exacta del maletero que compré en Amazon.
Busco los links y los voy poniendo
Bombillas
€ 17,45 35%de DESCUENTO | Bombilla LED para el interior del automóvil, kit de bombillas bus CAN para el coche, luz de lectura, 100% compatible con Seat León MK3, 5F, 5F1, 5F5, 5F8, de 2013 a 2018, 13 uds.
https://a.aliexpress.com/_EJuUrrH
Embellecedor llave
€ 3,66 26%de DESCUENTO | Xinyuexin-carcasa plegable para llave de coche, pieza de Metal sin llave para Vw Gollf 7 MK7, Skoda Octavia A7, Seat, Golf Mk7
https://a.aliexpress.com/_EvPwhoR
Cajas puertas
€ 14,72 16%de DESCUENTO | RUIYA-caja de almacenamiento lateral para puerta de coche, contenedor con reposabrazos, caja de almacenamiento, accesorios interiores de automóvil, para Leon MK3 Typ 5F 2013-2019
https://a.aliexpress.com/_EHtQNRz
Esterilla maletero
Pro-Line 5907377549291 Maletero https://amzn.eu/d/j1ez3qg
SantiPMI
Coche: Leon MK3 1.0 TSI 115cv
Agradecido: 27 veces
Notapor IggyAl92 el 15 Mar 2023, 15:07
Gracias!!
Bombillas
Embellecedor llave
Cajas puertas
Esterilla maletero
Buenas, muy interesante todo lo que comentas.
¿Las luces interiores que trae el Seat no son LED?, y en caso de que no lo sean, ¿son fáciles de instalar las que mandas en el enlace?
La caja de almacenamiento lateral la veo super útil, la pido ya de ya!! jajaj
Luego otra cosa, si alguno ha pedido las pegatinas para los faros traseros:
https://es.aliexpress.com/item/10050021 ... Redirect=y
¿Cuál es la que mejor se adapta? He visto que hay tamaños a elegir: HATCHBACK y STATION WAGON/ST, y 4 colores también a elegir.
IggyAl92
Notapor SantiPMI el 15 Mar 2023, 15:25
Gracias!!
Bombillas
Embellecedor llave
Cajas puertas
Esterilla maletero
Las luces interiores no eran Led en mi caso, súper fácil de instalar, sustituir una por otra
En las pegatinas de faros depende HATCHBACK es el Leon corto, el WAGON STATION/ST es el largo
SantiPMI
Notapor IggyAl92 el 16 Mar 2023, 08:26
Gracias!!
Bombillas
Embellecedor llave
Cajas puertas
Esterilla maletero
Ah vale, tengo que mirar si las mías son LED o no, las exteriores almenos sí lo son.
Mi coche es Seat León Xcellence Plus del 2017, ¿sabes si es corto o largo? jaja
Ayer pedi 8 chuches de Ali, a ver que tal llegan, os mandaré fotitos!!
IggyAl92
Notapor SantiPMI el 16 Mar 2023, 09:08
Gracias!!
Bombillas
Embellecedor llave
Cajas puertas
Esterilla maletero
Pues si tu no sabes las medidas de tu coche, si es el ST o el normal, pues mal vamos . Pero se me ocurren dos cosas, por comparacion con otro que veas en la calle o si tiene mucho mucho maletero, .....
SantiPMI
Notapor IggyAl92 el 16 Mar 2023, 10:10
Cierto, no lei lo de "ST", el mio es el normal o corto.
¿Alguno que haya pedido las pegatinas del marco para los faros traseros?
En el link que pasé (https://es.aliexpress.com/item/10050021 ... Redirect=y) hay 20 vendidos y algunas malas opiniones, por saber si alguno de vosotros las compró.
IggyAl92
Notapor IggyAl92 el 28 Mar 2023, 15:07
Buenas tardes,
os mando ya las 2 cosas que he puesto en mi Seat León Xcellence Mk3: embellecedor para la rosca de la iluminación y las cajitas de almacenamiento:
Me ha llegado también el USB que da iluminación interior pero aún no he mirado como se configura para cambiar el color, aumentar brillo... y otras cosas que abriré próximamente.
IggyAl92
Notapor FR-Matt Line el 29 Mar 2023, 00:28
Hola...
Parece que queda muy bien el anillo decorativo del mando de las luces... si es posible, indícanos el enlace donde lo compraste.
Los USB de colores con posibilidad de variar la intensidad también están muy bien. Yo tengo dos en los USB de las plazas traseras iluminando en color rojo (proyectan la luz hacia abajo), y un tercero pegado en la parte superior del hueco donde se deja el móvil, todos con una intensidad más bien baja para que no molesten.
FR-Matt Line
Coche: Leon MK3 2.0 TSI 190cv
Agradecido: 89 veces
Notapor ecolibra el 29 Mar 2023, 05:00
IggyAl92 escribió:Buenas tardes,
Yo como puse en otro mensaje,también puse el anillo,queda muy bien,pero en mi caso entro tan a presión,que creo que si algún día tengo que sacar el mando de luces para algo,saldrá destrozado
Enviado desde mi M2102J20SG mediante Tapatalk
ecolibra
Coche: Leon MK2 1.6 TDI 105cv
Agradecido: 23 veces
Notapor IggyAl92 el 29 Mar 2023, 08:54
FR-Matt Line escribió:Hola...
Buenas compi,
el anillo embellecedor es cierto que queda genial, el link es este:
https://es.aliexpress.com/item/40009225 ... pt=glo2esp
El USB lo conecté y me dio poquita luz, supongo que se puede configurar eso, igual que lo del cambio de color, pero no le dediqué mucho tiempo.
Creo que mi León no tiene USB traseros, ¿son fáciles de instalar?
IggyAl92
Notapor IggyAl92 el 29 Mar 2023, 08:55
Me pasó igual jajaja se salía de un lado y le di unos golpes, ha quedado encajadísimo :lol:
IggyAl92
Notapor Llisus el 10 Abr 2023, 16:44
Realmente encajan bien? No se mueven? Es que me da que como se coje de ahí para cerrar la puerta, van a estar todo el rato moviéndose en el hueco..
Enviado desde mi 21051182G mediante Tapatalk
Llisus
Agradecido: 32 veces
Notapor IggyAl92 el 11 Abr 2023, 09:29
Se mueven, sobretodo la de piloto, no queda fjia. Estoy pensando hacer algún invento porque cada vez que abro la puerta casi me la llevo, la de copiloto más o menos queda encajada.
IggyAl92
Notapor kwatto el 11 Abr 2023, 09:48
el problema es que, aunque parezca mentira, con el uso, el agarrador del lado del conductor, da de sí. Yo lo solucioné con un par de trozos de cinta de doble cara y ya no se mueve.
kwatto
Agradecido: 60 veces
Usuarios navegando por este Foro: Anthropic, Semrush y 15 invitados
