Accesorios aliexpress mk3
Favoritos: ositoerik, ROBERTO206, Stealnick, asaltacunas, tsi125, Alleya, Qore, tonnety, Juantxu, mk3Granaino, dani10s, damsolu, clotza, Levanius, pjdelburgo, frigolin, drnrd, Bass8V, Joali, toniRG, Jastur, morat86, _warcry_, Nikobellic, Lopagan666, Lyern, basuvi, rob3r7o, Lady, Danisisa_cupra
Seguidores: jose007dt, adri.f1, adrii18600, IronTor21, toniespejolara719, Hovig, trazas, drnrd, Chuskon, ecolibra, Gus-Gus, suarez22, TomH30, danone10, viktor_ct_95, pozyano, ChusTj, kennit0, Lopess85, er_trompe, rfaus, Gsclosada, djcastle, sergi303, DBS83, Ivensound, Hectoor57, JoseDel, agus_piscis10, jagman, warcryrivas, carrasco13, Triple R, luigi323, digital77, PuertoLeon, El Gonzo, LeonComeIbiza, dRoXe, osjamil, xjuliox, Per3zo, dPintos, VapaV, Igor, kukikukarron, Sanz, fur, chisyelamos, diegoporta97, carlosgzlez, leonfr76, smpxque, inamarlo, R1k4rd0, iviHDR, Moigijon, jd_zuri, surgeon, mk3Granaino, jajereal, ncx, juancete, Pokayoke, Jorge75016, DESMOCHEEE!!!, Guillen222, V de Viana, D83, riclanico, tonnety, lead, rrttrr, CuPra3004Drive, jguirao, Brandenor, triguero, Pedrost, perikolu, Alvi, Edu1589, victor david, aironsam14, Chema Sat, Josepo79, Senuto, sesmero87, Rapiru, Sergt, Llisus, richard_11, vanscampa, nifer, BEDIA, SantiagoSanchez, nachomart, quimiko, barrosdepor, Eohn94, Flow-Rider, puskas65, Snooker83, Angeleitor, Morales92, Rober_SR, Piro25, cucci, RamonLaC, erlanz, Raaz, DiegoR, Brunozp, pablomus85, kwatto, msmdraven, iNFeCTeD, MartinLeon, antelo85, Maikermx, josean-opc, El_pelos44, Mr.Chuflas, SantiPMI, Chrohu, LuigiVisio, joga, Atajunen, lafu1988, daniel.velarde77, galelir, rpv, Link, jose.a.llamas, eyebee, D.Acuña, Manzi, bluesbreaker88, Lady, higuerashxc, Warelio, St17, carlitos24, ginyu 83, Jastur, talanito, victorvOrtiz, Alf68, AlvaroRamlo, Yagadri, ebcuatro, MaNDuN, Davidv, Andertxu7, garruz666, antoniofdezpas, josearillaperez., MaximusRoco, ezanchi
Re: Accesorios aliexpress mk3
Notapor jasoriab el 13 Mar 2018, 12:48
St17 escribió:
garruz666 escribió:Hola. Hoy me han llegado 3 cosas del Aliexpress, en solo 10 dias!
Los difusores de aire tienen buena pinta, aunque huelen algo a plastico, asi q lo dejo abierto hasta el sabado que los ponga. La red de 70x70 no tiene mala pinta. Parece que estira y los enganches son de plastico duro (a ver lo q duran). La rejilla con belcro tampoco tiene mala pinta y no huele a nada raro. Habra q ponerla y hacerle fotos.
A los q tiene la red de 70x70. Queda bien? Hace su papel?
los aireadores en aliexpress recuerdas si pediste una unidad, es decir va la pareja o al comprar hay que indicar 2 como cantidad a comprar?
Van por parejas. Yo pedí una unidad, y en la caja de cartón viene una pareja de aireadores.
jasoriab
Agradecido: 2055 veces
Notapor St17 el 13 Mar 2018, 12:52
ok genial!! estan ahora en 5,90 en alguna pag. de aliexpress y en otras en 7,19 a ver si las pillo entonces. gracias
St17
Notapor garruz666 el 14 Mar 2018, 09:14
Tu pides una unidad y el chino te manda ambos. Es como los zapatos, compras una caja y dentro te vienen ambos lados. No te preocupes, yo tambien tenia esa duda :)
PD: recomiendo si o si los embellecedores de las puertas. El cambio del antes y del despues es abismal, ademas de que es algo que se ve si o si nada mas abrir la puerta. Es mas, no se como los coches salen de casa tan feos en ese aspecto! Yo los pedi en negro, por el color de la tapiceria alcantara.
Leon 2018 FR Line 1.4 125CV Red Desire
---> viewtopic.php?f=43&t=125774 <---
garruz666
Agradecido: 38 veces
Notapor Ángel Panizo el 14 Mar 2018, 09:56
Porfa, puedes poner el link de los aireadores y de los embellecesores.
Y si pones una foto de como quedan en tu LEONCITO, lo bordas....
Ángel Panizo
Coche: Leon MK3 1.2 TSI 105cv
Agradecido: 53 veces
Notapor jd_zuri el 14 Mar 2018, 10:29
Yo los aireadores no conseguí ponerselos, se caían todo el rato, creo que por la presión de la moqueta, tampoco pude meterlos por "dentro", entre la moqueta y el plastico de la salida, y me dí por vencido. Creo que el problema es que en mi coche esa parte viene rematada realmente mal, deja mucho hueco por algunos lados (se ve el metal de la carroceria vamos) y por otros apretadisimo contra la salida del aire.
Seat León ST Xcellence Advanced 2.0 TDI 150CV Plata Urban + gancho remolque.
jd_zuri
Agradecido: 44 veces
Notapor Mr.Nobody el 14 Mar 2018, 10:43
Aireadores
https://es.aliexpress.com/item/AX-Under ... 83898.html
Aprovecho para preguntar a los que tienen kessy... ¿usais algún bloqueo de RFID en casa?
~ MK3 MY18 - 1.4 TSI 125CV - Xcellence Plus ~ + info
Mr.Nobody
Agradecido: 66 veces
Notapor St17 el 14 Mar 2018, 11:24
tienes fotos de como quedan los embellecedores en negro?? mi duda es si comprarlos en negro :zoquete: :zoquete:
St17
Notapor VapaV el 14 Mar 2018, 13:43
Aireadores
No. Si me quiero ir tranquilo, cierro el coche dejando la apertura del coche con kessy desconectada (cierras con mando el coche y antes de 5 segundos tocas el sensor de la puerta).
Enviado desde mi Redmi Note 4 mediante Tapatalk
VapaV
Agradecido: 34 veces
Notapor garruz666 el 14 Mar 2018, 19:47
Aqui las fotos de mi coche, en la seccion de fotos (o como se llame):
Ahi podeis ver los aireadores. Por suerte tapan por completo el difusor de aire y ademas tapa el hueco que habia entre el terciopelo q rodea el difusor y el propio difusor (antes se veia un poco de color rojo alrededor del difusor). A mi me entro a la primera, perfecto, sin problemas ni historias, y de momento ahi siguen (la prox vez que suba al coche me agachare a mirarlos).
El embellecedor en negro queda precioso, aunque en la foto habia mucha luz dandole de pleno y parece gris (asi te puedes tambien hacer una idea de como queda en gris :) ). De que color tienes el coche? El mio es rojo deseo, el oscuro, y la tapiceria es la alcantara en negro, asique el gris no le pegaba nada de nada. Por eso negro.
https://es.aliexpress.com/item/Car-Styl ... 70336.html
Tambien podeis ver como queda la funda del mando, el cubremaleteros caro oficial de Seat, la red con belcro para ponerla en el lado del maletero y la red cubreequipaje. Proximamente, cuando le ponga las ruedas de verano, subire las fotos de las llantas de 18" con los tapones en negro con el logo FR que ya tengo en casa.
Si alguien tiene alguna duda que lo diga y en poder le hago unas fotos al detalle de lo que querais ver y las subo, pido paciencia :)
garruz666
Notapor andeu el 14 Mar 2018, 20:54
Hola a ver si me poeis ayudar estoy mirando ponerle a mi st las laminas inox puertas pero pone asta modelo 2016 y el mio sera 2018 ( lo stoy esperando ) me sirven o tengo k buscar de mi año
Enviado desde mi S60 mediante Tapatalk
andeu
Agradecido: 10 veces
Notapor Mr.Nobody el 14 Mar 2018, 23:42
Ya tengo pensado comprar el OBD Shield o similar.
No me parece mala idea una pegatina de este estilo.
Esta la he visto por ebay , pero hay mas modelos
https://www.ebay.es/itm/2-x-OBD-PORT-DI ... 2263661657
¿algo similar?
Mr.Nobody
Notapor dRoXe el 15 Mar 2018, 00:18
http://s.aliexpress.com/eMf6r2A3?fromSns=
Yo he pillado estas pegatinas, cuando lleguen pondre fotos y dare mi opinion
dRoXe
Agradecido: 90 veces
Notapor garruz666 el 15 Mar 2018, 09:16
andeu escribió:Hola a ver si me poeis ayudar estoy mirando ponerle a mi st las laminas inox puertas pero pone asta modelo 2016 y el mio sera 2018 ( lo stoy esperando ) me sirven o tengo k buscar de mi año
Hola. Te refieres a estas? (creo q no)
https://es.aliexpress.com/store/product ... autifyAB=0
O a las que se ven en la foto esta? (El link vende la red del maletero, no las laminas de acero inoxidable) Yo tambien busco esas laminas de acero inoxidable, pero no se si valen para el Leon "sin culo".
garruz666
Notapor Dado el 15 Mar 2018, 11:22
Hola, yo creo que el compi se refiere a las que van cuando abres las puertas abajo, (ahora algunas incluso con luz) esas que suele poner "SEAT", no la del maletero, de hecho la del maletero en mi ST style advance viene de serie.
Dado
Agradecido: 48 veces
Notapor garruz666 el 15 Mar 2018, 13:34
Dado escribió:
Vale, ahora caigo yo tambien. Mi FR Line las trae cromadas de serie al abrir las puertas, y no se si pone Leon FR, o Leon, o Seat, o FR... pero algo pone :)
Ahora lo pregunto yo: alguien tiene las laminas metalicas que se ponen en el maletero para cuando tienes q apoyar algo no se arañe el plastico? Son como las que he puesto el link de arriba, pero no las encuentro (aunque en su dia las vi en eliexpress) y ahora me llaman la atencion. Tambien saber si valen para el que NO es ST. Y q tal van? Fotos propias? :)
Gracias.
garruz666
