Pero hay algo de eso en AliExpress o hay que comprar una lámina e ir recortando??
Accesorios aliexpress mk3
- Seguidores: 160
- Favoritos: 30
- Vistas: 431.066
Favoritos: ositoerik, ROBERTO206, Stealnick, asaltacunas, tsi125, Alleya, Qore, tonnety, Juantxu, mk3Granaino, dani10s, damsolu, clotza, Levanius, pjdelburgo, frigolin, drnrd, Bass8V, Joali, toniRG, Jastur, morat86, _warcry_, Nikobellic, Lopagan666, Lyern, basuvi, rob3r7o, Lady, Danisisa_cupra
Seguidores: jose007dt, adri.f1, adrii18600, IronTor21, toniespejolara719, Hovig, trazas, drnrd, Chuskon, ecolibra, Gus-Gus, suarez22, TomH30, danone10, viktor_ct_95, pozyano, ChusTj, kennit0, Lopess85, er_trompe, rfaus, Gsclosada, djcastle, sergi303, DBS83, Ivensound, Hectoor57, JoseDel, agus_piscis10, jagman, warcryrivas, carrasco13, Triple R, luigi323, digital77, PuertoLeon, El Gonzo, LeonComeIbiza, dRoXe, osjamil, xjuliox, Per3zo, dPintos, VapaV, Igor, kukikukarron, Sanz, fur, chisyelamos, diegoporta97, carlosgzlez, leonfr76, smpxque, inamarlo, R1k4rd0, iviHDR, Moigijon, jd_zuri, surgeon, mk3Granaino, jajereal, ncx, juancete, Pokayoke, Jorge75016, DESMOCHEEE!!!, Guillen222, V de Viana, D83, riclanico, tonnety, lead, rrttrr, CuPra3004Drive, jguirao, Brandenor, triguero, Pedrost, perikolu, Alvi, Edu1589, victor david, aironsam14, Chema Sat, Josepo79, Senuto, sesmero87, Rapiru, Sergt, Llisus, richard_11, vanscampa, nifer, BEDIA, SantiagoSanchez, nachomart, quimiko, barrosdepor, Eohn94, Flow-Rider, puskas65, Snooker83, Angeleitor, Morales92, Rober_SR, Piro25, cucci, RamonLaC, erlanz, Raaz, DiegoR, Brunozp, Fofio, pablomus85, kwatto, msmdraven, iNFeCTeD, MartinLeon, antelo85, Maikermx, josean-opc, El_pelos44, Mr.Chuflas, SantiPMI, Chrohu, LuigiVisio, joga, Atajunen, lafu1988, daniel.velarde77, galelir, rpv, tsi125, Link, jose.a.llamas, eyebee, D.Acuña, Manzi, bluesbreaker88, Lady, higuerashxc, Warelio, St17, carlitos24, ginyu 83, Jastur, talanito, victorvOrtiz, Alf68, AlvaroRamlo, Yagadri, ebcuatro, MaNDuN, Davidv, Andertxu7, garruz666, antoniofdezpas, josearillaperez., MaximusRoco, ezanchi
barrosdepor - Nuev@ por aqui
Re: Accesorios aliexpress mk3
Pues no he mirado la verdad
BEDIA - Aun con la L
- Agradecido: 36 veces
Tengo un MK3 y me gustaría cambiar el logo FR de la parrilla delantera, para empezar no se si ese va pegado o con tornillo, alguien sabe?
El que quiero poner es en color negro, sabéis donde encontrarlo?
Este es el que quiero:
Alex Hdez - Asidu@ en la selva
- Agradecido: 21 veces
Ese lo llevo yo y lo compre en AliExpress. Pero es para la parte trasera. No vale para poner en la rejilla.Alex Hdez escribió:Tengo un MK3 y me gustaría cambiar el logo FR de la parrilla delantera, para empezar no se si ese va pegado o con tornillo, alguien sabe?
Enviado desde mi SM-A750FN mediante Tapatalk
- Agradecido: 354 veces
Yo tambien estoy interesado en ese logo todo en negro, he buscado en aliexpress pero para la parrilla delantera solo hay el rojo/negro en dos combinaciones, el negro entero no lo he conseguido encontgrar... estaba pensando en adaptar uno de los que vienen con adhesivo pegandole dos varillas roiscadas para poder colocarlo en la parrilla tal y como viene el de serie
Leon Mk3 2.0 TDI 150CV ST
xjuliox - Nuev@ por aqui
A mi me acaban de llegar para mi leon ST de finales del 2018 los siguientes artículos.
Bombillas para el interior - Perfectas y tiradas de precio , iluminan un monton
https://es.aliexpress.com/item/10Pcs-Au ... 63c0PU1QBe
Bombillas Canbus para el interior - Perfectas y 35centimos cada una , en tienda te las cobran a 6€ la pareja
https://es.aliexpress.com/item/Alta-cal ... 63c0PU1QBe
Pedales racing para el coche iguales que los del cupra
https://es.aliexpress.com/item/Car-styl ... 63c0PU1QBe
Os lo recomiendo
Os lo recomiendo
KevinFr2 - Asidu@ en la selva
- Agradecido: 20 veces
Tienes ya puestas las bombillas?KevinFr2 escribió:A mi me acaban de llegar para mi leon ST de finales del 2018 los siguientes artículos.
Os lo recomiendo
Te dan algún problema de que parpadeen de vez en cuando?
Yo compré unas cuantas en un chino del pueblo y cada 2x3 parpadean como si fuese una discoteca, al rato paran y luego vuelven a parpadear
dRoXe - Leoner@ avanzad@
- Agradecido: 90 veces
Alguna de esas son de las que van en la zona de los pies???
Os lo recomiendo
- Agradecido: 264 veces
Os lo recomiendo
Gracias. He pedido los pedales
LoCo2006 - Nuev@ por aqui
javijave escribió:Alguna de esas son de las que van en la zona de los pies???
Las de los pies son T10 w5w, hay que tener en cuenta que parte de la bombilla queda "rodeada" por el conector así que la bombilla debe tener aproximadamente el mismo diametro o menos
Bomber0 - Leoner@ avanzad@
- Coche: Otro modelo no SEAT
- Agradecido: 190 veces
Joe macho!!! Todo esto me supera.
Como se sabe el tamaño? jeejejejej
Bomber0 escribió:javijave escribió:Alguna de esas son de las que van en la zona de los pies???
javijave escribió:Joe macho!!! Todo esto me supera.
Yo he comprado estas para los pies, son rectas desde el conector y entran a la perfección. Te puedes hacer una idea de que es igual de ancha la "bombilla" que el conector.
https://es.aliexpress.com/item/2-piezas ... 87856.html
Muchas gracias como siempre por todo.Bomber0 escribió:javijave escribió:Joe macho!!! Todo esto me supera.
Voy a buscarlas en color rojo.
Enviado desde mi Aquaris X Pro mediante Tapatalk
xjuliox escribió:Alex Hdez escribió:Tengo un MK3 y me gustaría cambiar el logo FR de la parrilla delantera, para empezar no se si ese va pegado o con tornillo, alguien sabe?
Tranquiloss que ya os traigo la solución, en esta pagina los podeis encontrar en negro brillo, las hay de la parrilla y de atras, eso si, vale 45 eurazos. Podreis encontrar muchas mas cosas y exclusivas. El unico problema que tengo con esto es que no me deja hacer el pedido, por mas que intento, me dice que el metodo de envio no vale y que cambie la direccion, a ver si alguien prueba y me dice..
https://rr-dsign.de/shop/seat-embleme-l ... r-zeichen/
J19 - Asidu@ en la selva
- Agradecido: 18 veces
J19 escribió:Tranquiloss que ya os traigo la solución, en esta pagina los podeis encontrar en negro brillo, las hay de la parrilla y de atras, eso si, vale 45 eurazos. Podreis encontrar muchas mas cosas y exclusivas. El unico problema que tengo con esto es que no me deja hacer el pedido, por mas que intento, me dice que el metodo de envio no vale y que cambie la direccion, a ver si alguien prueba y me dice..
Te doy una solución mas barata, compras el logo en SEAT y compras pintura negra en spray, que es basicamente lo que han hecho, si te fijas en las fotos se ven los bordes del cromado y que se han dado varias capas de pintura.
Usuarios navegando por este Foro: Semrush y 26 invitados
