Accesorios aliexpress mk3
Favoritos: ositoerik, ROBERTO206, Stealnick, asaltacunas, tsi125, Alleya, Qore, tonnety, Juantxu, mk3Granaino, dani10s, damsolu, clotza, Levanius, pjdelburgo, frigolin, drnrd, Bass8V, Joali, toniRG, Jastur, morat86, _warcry_, Nikobellic, Lopagan666, Lyern, basuvi, rob3r7o, Lady, Danisisa_cupra
Seguidores: jose007dt, adri.f1, adrii18600, IronTor21, toniespejolara719, Hovig, trazas, drnrd, Chuskon, ecolibra, Gus-Gus, suarez22, TomH30, danone10, viktor_ct_95, pozyano, ChusTj, kennit0, Lopess85, er_trompe, rfaus, Gsclosada, djcastle, sergi303, DBS83, Ivensound, Hectoor57, JoseDel, agus_piscis10, jagman, warcryrivas, carrasco13, Triple R, luigi323, digital77, PuertoLeon, El Gonzo, LeonComeIbiza, dRoXe, osjamil, xjuliox, Per3zo, dPintos, VapaV, Igor, kukikukarron, Sanz, fur, chisyelamos, diegoporta97, carlosgzlez, leonfr76, smpxque, inamarlo, R1k4rd0, iviHDR, Moigijon, jd_zuri, surgeon, mk3Granaino, jajereal, ncx, juancete, Pokayoke, Jorge75016, DESMOCHEEE!!!, Guillen222, V de Viana, D83, riclanico, tonnety, lead, rrttrr, CuPra3004Drive, jguirao, Brandenor, triguero, Pedrost, perikolu, Alvi, Edu1589, victor david, aironsam14, Chema Sat, Josepo79, Senuto, sesmero87, Rapiru, Sergt, Llisus, richard_11, vanscampa, nifer, BEDIA, SantiagoSanchez, nachomart, quimiko, barrosdepor, Eohn94, Flow-Rider, puskas65, Snooker83, Angeleitor, Morales92, Rober_SR, Piro25, cucci, RamonLaC, erlanz, Raaz, DiegoR, Brunozp, Fofio, pablomus85, kwatto, msmdraven, iNFeCTeD, MartinLeon, antelo85, Maikermx, josean-opc, El_pelos44, Mr.Chuflas, SantiPMI, Chrohu, LuigiVisio, joga, Atajunen, lafu1988, daniel.velarde77, galelir, rpv, tsi125, Link, jose.a.llamas, eyebee, D.Acuña, Manzi, bluesbreaker88, Lady, higuerashxc, Warelio, St17, carlitos24, ginyu 83, Jastur, talanito, victorvOrtiz, Alf68, AlvaroRamlo, Yagadri, ebcuatro, MaNDuN, Davidv, Andertxu7, garruz666, antoniofdezpas, josearillaperez., MaximusRoco, ezanchi
Re: Accesorios aliexpress mk3
Notapor Agonza86 el 23 Sep 2019, 16:10
tevaadarelsol escribió:
ZXVolcane escribió:
tevaadarelsol escribió:En mi caso llevo los hidráulicos cambiados para la apertura automática, y en verano con el calor los pistones cogen más presión y va perfecto, pero en invierno con más frío el portón no se sube, se queda solamente desencajado y cuando yo lo subo unos centímetros ya se abre... Estaría bien saber si estos muelles le darían el primer "empujoncito" y así se solucionaría del todo el problema
Enviado desde mi ONEPLUS A6003 mediante Tapatalk
Buenas @tevaadarelsol,
Si te miras el video que dicen los compis del VW Sirocco el chico monta esos topes para solucionar lo que te pasa a ti en invierno, le da ese empujon al principio para que suba.
Bueno pues los he pillado, cuando me lleguen ya comentaré qué tal.
Por cierto, veo en el vídeo que el chaval ajusta algo con una llave Allen... Qué es exactamente?
Gracias!
Por lo que se ve en el video creo suponer que tal vez regule la dureza del muelle.
Mi misil: viewtopic.php?f=43&t=112454
Life on the road, V8 POWER :bandit: :bandit: :bandit:
Agonza86
Agradecido: 403 veces
Notapor lafu1988 el 23 Sep 2019, 17:24
lafu1988 escribió:
Agonza86 escribió:Aquí os dejo el vídeo que os dije, estaba equivocado, la referencia es de un Scirocco, cierto, y no, no impulsa el maletero tanto como dije, eso lo hacía con añadiendo unos muelles al amortiguador:
https://youtu.be/jls1XU7FR0Q
Si ese es el mismo vídeo que vi yo. Tiene buena pinta y no creo que haga mucha fuerza para cerrar los muelles y además se puede ajustar la altura y si lo montaba vw en el sirocco... Yo el lunes pregunto en seat y comento el precio que me dicen pero en aliexpress ronda los 25€ la pareja.
Acabo de ir a seat y dos unidades 20€ con iva por lo que ya están pedidos y llegan en 3 días. En AliExpress y Ebay son más caros 25-30€ con gastos de envío y tardan 1 mes. Ya comentaré que tal van.
Si vais a pedirlo hay que decir que es una referencia de VW ya que lo monta el sirocco
lafu1988
Agradecido: 217 veces
Notapor Jastur el 23 Sep 2019, 17:28
Que referencia de sirocco son los que has pedido en la seat, puede que me interesen los oficiales viendo el precio.
Jastur
Agradecido: 35 veces
Notapor tevaadarelsol el 23 Sep 2019, 17:44
Exacto, acabo de pedirlos en la Volkswagen y me han dado precio de 10.23€ cada uno, y entrega en 2 - 3 días.
La referencia es 1K8827761D.
tevaadarelsol
Agradecido: 199 veces
Notapor lafu1988 el 23 Sep 2019, 17:49
Sii eso mismo, es que no recordaba el pico y he puesto 20€ jejeje
No compensa pedir en AliExpress por que vale más caro, tarda un mes y no serán originales oem.
Por unos o por otros este foro es un no parar de xuxes jajajajajaja
lafu1988
Notapor Warelio el 25 Sep 2019, 12:21
Nueva pijada recibida de Aliexpress... No es barata pero sí es de calidad y está muy bien construida. Y es para una zona que la verdad no entiendo cómo pueden dejarla sin proteger y con el tiempo la tela acaba estropeándose y queda fea. Además para mi gusto queda mucho mejor acabada esa zona de los asientos delanteros y protege la tapicería contra las pisadas. Pese a que no indica que sea compatible con nuestros Leones encaja perfectamente como podéis ver en la foro y sin necesidad de utilizar ni herramientas, ni cortar nada ni utilizar las tiras adhesivas que lleva incluida. Es colocar entre los 2 soportes y listo, queda perfectametne fijado. Por las letras R-Line ni me preocupo porque puedo poner una pegatina FR o taparlas de alguna forma o dejarlo tal cual, tampoco me molesta.
Un saludo,
Warelio
Moderador de Racing
Agradecido: 1144 veces
Notapor JOOAAAN el 25 Sep 2019, 12:33
Warelio escribió:Nueva pijada recibida de Aliexpress... No es barata pero sí es de calidad y está muy bien construida. Y es para una zona que la verdad no entiendo cómo pueden dejarla sin proteger y con el tiempo la tela acaba estropeándose y queda fea. Además para mi gusto queda mucho mejor acabada esa zona de los asientos delanteros y protege la tapicería contra las pisadas. Pese a que no indica que sea compatible con nuestros Leones encaja perfectamente como podéis ver en la foro y sin necesidad de utilizar ni herramientas, ni cortar nada ni utilizar las tiras adhesivas que lleva incluida. Es colocar entre los 2 soportes y listo, queda perfectametne fijado. Por las letras R-Line ni me preocupo porque puedo poner una pegatina FR o taparlas de alguna forma o dejarlo tal cual, tampoco me molesta.
Un saludo,
Enlace?
JOOAAAN
Agradecido: 38 veces
Notapor Warelio el 25 Sep 2019, 12:55
Un saludo,
Enlace?
Aquí lo tienes:
https://es.aliexpress.com/item/10000071 ... 2e0eq2fjqM
Warelio
Moderador de Racing
Notapor arlot el 25 Sep 2019, 15:22
Esperaré tu valoración para lanzarme a comprarlos para un ST,
arlot
Agradecido: 975 veces
Notapor lafu1988 el 27 Sep 2019, 19:45
Bueno lo prometido es deuda, ya está montado y funciona perfecto justo lo que estaba buscando que se abriera el maletero desde el mando lo justo para no tener que tirar de la S.
La única diferencia con los de antes es que hay que hacer un poco más de fuerza para cerrar pero tampoco mucho pero al tener el muelle se nota.
Para los que lo quieren como ayuda de apertura con el kit de muelles creo que si os valdrá porque empuja con fuerza unos 2 cm hacia arriba cuando abres.
Para montarlos he hecho lo mismo que el del video, abrir el tornillo Allen, bajar al máximo la altura y volver apretar el tornillo y así va perfecto.
Al final me ha costado un poco menos, me ha hecho una rebaja del 10% cuando he ido a pagar, 18,40€ los dos con IVA, sino vale 10,23€ (creo recordar) la unidad.
ImagenImagen
lafu1988
Notapor drnrd el 28 Sep 2019, 09:34
little bastard escribió:
shaume escribió:Buenas, alguien ha cambiado la luz del maletero en un leon ST? O la bombilla.
Veo que tiene poca luminosidad lo que no se si lleva la misma luz que el leon normal, en aliexpress indican leon mk3 solamente. Gracias!
Yo lo cambie por este;
https://es.aliexpress.com/item/32888280 ... 63c0NuIJYt
Es impresionante la diferencia de Luz. Antes no se veia nada y ahora tengo que abrir el maletero con gafas de sol. :si: :si:
Buenos dias
Pedí estas mismas ,las monté y pese a que los pines de la clema no eran exactamente iguales,la conecté y encendía perfectamente en parado.El problema surge al arrancar el coche,me salta un fallo cada pocos segundos en el que se encienden todas las luces de los plafones y ademas aparece en el panel como se abre y se cierra el portón del maletero.
Probé con ambos plafones e incluso he hecho un cable nuevo por si fallaban los dos que traía ,pero sigue igual.
¿alguien puede echarme una mano??
drnrd
Notapor mmolalb el 29 Sep 2019, 19:13
Maypirineos escribió:Alguien sabe un cubre volante para los fr? Achatado me refiero,, he comprado el cubrevolante ese que es una tela que tienes que poner encima del volante y coserlo.. pero queda con muchos priegues
Encontraste algún cubre volante? Estoy loco buscando y no encuentro ninguno, mi novia ha cogido el coche y ha arañado un poco el volante por debajo de la zona achatada, quiero ponerle una funda o cubre volante... no vaya a repetir la gracia
mmolalb
Notapor little bastard el 01 Oct 2019, 10:08
Buenos dias
pues a mi eso no me ha pasado. :ok:
little bastard
Agradecido: 82 veces
Notapor Pedrost el 02 Oct 2019, 00:28
Buenos dias
Eso se puede solucionar con un diodo como lleva el plafón de serie, pásame fotos de como es es el plafón y te digo donde ponerlo
Aunque ahora con culo(st) desde 2003 enamorado de la fiera de seat :enamorado:
Se agradece dándole al :ok:
Pedrost
Agradecido: 281 veces
Notapor drnrd el 08 Oct 2019, 22:28
Buenos dias
Compré otro y me va genial.De todas formas,te subiré las fotos y así le echo un ojo.
drnrd
Usuarios navegando por este Foro: Anthropic y 60 invitados
