Accesorios aliexpress mk3
Seguidores: jose007dt, adri.f1, adrii18600, IronTor21, toniespejolara719, Hovig, trazas, drnrd, Chuskon, ecolibra, Gus-Gus, suarez22, TomH30, danone10, viktor_ct_95, pozyano, ChusTj, kennit0, Lopess85, er_trompe, rfaus, Gsclosada, djcastle, sergi303, DBS83, Ivensound, Hectoor57, JoseDel, agus_piscis10, jagman, warcryrivas, carrasco13, Triple R, luigi323, digital77, PuertoLeon, El Gonzo, LeonComeIbiza, dRoXe, osjamil, xjuliox, Per3zo, dPintos, VapaV, Igor, kukikukarron, Sanz, fur, chisyelamos, diegoporta97, carlosgzlez, leonfr76, smpxque, inamarlo, R1k4rd0, iviHDR, Moigijon, jd_zuri, surgeon, mk3Granaino, jajereal, ncx, juancete, Pokayoke, Jorge75016, DESMOCHEEE!!!, Guillen222, V de Viana, D83, riclanico, tonnety, lead, rrttrr, CuPra3004Drive, jguirao, Brandenor, triguero, Pedrost, perikolu, Alvi, Edu1589, victor david, aironsam14, Chema Sat, Josepo79, Senuto, sesmero87, Rapiru, Sergt, Llisus, richard_11, vanscampa, nifer, BEDIA, SantiagoSanchez, nachomart, quimiko, barrosdepor, Eohn94, Flow-Rider, puskas65, Snooker83, Angeleitor, Morales92, Rober_SR, Piro25, cucci, RamonLaC, erlanz, Raaz, DiegoR, Brunozp, Fofio, pablomus85, kwatto, msmdraven, iNFeCTeD, MartinLeon, antelo85, Maikermx, josean-opc, El_pelos44, Mr.Chuflas, SantiPMI, Chrohu, LuigiVisio, joga, Atajunen, lafu1988, daniel.velarde77, galelir, rpv, tsi125, Link, jose.a.llamas, eyebee, D.Acuña, Manzi, bluesbreaker88, Lady, higuerashxc, Warelio, St17, carlitos24, ginyu 83, Jastur, talanito, victorvOrtiz, Alf68, AlvaroRamlo, Yagadri, ebcuatro, MaNDuN, Davidv, Andertxu7, garruz666, antoniofdezpas, josearillaperez., MaximusRoco, ezanchi
Re: Accesorios aliexpress mk3
Notapor garruz666 el 11 Nov 2018, 17:32
QaSaR escribió:En mi caso tengo:
Aliexpress:
connector mechero con 2 usb:
https://es.aliexpress.com/item/car-char ... 63c0sywnQu
Q.
Has probado el nuevo filtro de aire? Hace mas ruido? Se nota algo de potencia? Cuenta, cuenta :)
Hoy me pillo unos pedales (los tipicos), 2 portavasos y el cepillo para limpiar las rendias de la salida de aire. Todo esto esta mas que dicho en este tema :)
Con esto a mi lista hay que sumarle, y todo va bien: cubrecerraduras logo fr, red maletero, rejillas salida aire pies traseros, 2 fundas de llave de silicona, red con belcro para maletero.
Leon 2018 FR Line 1.4 125CV Red Desire
---> viewtopic.php?f=43&t=125774 <---
garruz666
Agradecido: 38 veces
Notapor QaSaR el 12 Nov 2018, 01:01
Aliexpress:
Q.
Hola compañero!
Pues el filtro no creo que se "note" mucho sinceramente. Es mas un tema de lo comodo que es hacerle tu el mantenimiento y que SEAT no me cobre 60€ cada vez que me cambia el filtro original de papel... aumento de potencia y demas... no creo, simplemente el coche respira mejor.
Mi experiencia con estos filtros es que en general no notas mucho o nada. En un caso, el de mi moto actual, el filtro K&N es demasiado permisivo, y a bajas vueltas perjudica un poco la salida, sorprendentemente. En el coche no he notado nada, ni mejor ni peor, creo que la ganancia si es que hay alguna es muy dificil de apreciar asi a simple vista.
De tu lista, a mi me sobran las fundas de llave de silicona, como ya puse unos posts mas atras, son una kk, yo tb la compre y la acabé tirando. Como la llave sale lateralmente, la funda es como... como un libro o un pan de frankfurt, tiene todo el lado abierto, asi que se abre (como el libro o como el pan del frankfurt jajajaja) y es poco comoda la verdad.
Los pedales tb los acabo de poner este finde. Mirate el video que hay en el hilo sobre los pedales, es perfecto y ayuda luego a k desmontes perfecto.
Redes traseras. son de puta madre, yo tb llevo una. Y la alfombrilla del maletero, la de goma.
Los cubre cerraduras con el logo FR tb los llevo, facilisimos de montar.
Q.
Seat León 2.0 TDI ST DSG 184cv blanco nevada (link hilo proyecto) <-- página 1 con todos los links de chuches :sobrao:
En este mensaje, QaSaR ha recibido un agradecimiento de:
garruz666 (12 Nov 2018, 13:01)
QaSaR
Agradecido: 75 veces
Notapor MAM el 14 Nov 2018, 00:22
Hola, tengo un Xperience, y me gustaria llevar el logo Xp en la rejilla delantera, que se ve muy austera. Conoceis algún proveedor de este emblema apto para esta aplicación? Puesto que el lleva detras es bastante pequeño, y va pegado, seria mejor con el tipico tornillo y tuerca, supongo que parecido al de FR.
MAM
Agradecido: 86 veces
Notapor cordobitax el 15 Nov 2018, 07:57
y de bombillicas led no pillais na??
Agradecido: 389 veces
Notapor Pedrost el 15 Nov 2018, 08:33
cordobitax escribió:y de bombillicas led no pillais na??
Yo compre estás para los intentes https://s.click.aliexpress.com/e/clmDh3T3
y esta para el antiniebla y marcha atrás
https://s.click.aliexpress.com/e/b8bCfsbP
Aunque ahora con culo(st) desde 2003 enamorado de la fiera de seat :enamorado:
Se agradece dándole al :ok:
Pedrost
Agradecido: 281 veces
Notapor QaSaR el 15 Nov 2018, 11:15
Yo es que pillé el mio con el pak Full Led, y solo llevo las antinieblas, que me dá nosequé cambiarlas por LED... aunque lo tengo ahi entre ceja y ceja... pero solo encuentro chinorris y me da cosa...
Q.
QaSaR
Notapor sic58 el 15 Nov 2018, 14:32
Q.
Ponte los del restiling que son led lo único que creo que tendrías que cambiar el paragolpes
Enviado desde mi MI MAX 2 mediante Tapatalk
sic58
Notapor arlot el 15 Nov 2018, 14:36
Q.
Pues a mi el otro dia al pasar la ITV no la pasé por "Falta Grave" = llevar bombillas leds en los antinieblas. Asi que volví a montar las originales, y la pasé sin problemas.
Paso de liarme a cambiarlas otra vez; para volver a cambiarlas de aqui a 2 años. Hasta los cojones de los tocapelotas de las ITVs
arlot
Agradecido: 975 veces
Notapor juanbb el 15 Nov 2018, 14:39
Q.
Eran blancas o amarillas?
juanbb
Agradecido: 354 veces
Notapor arlot el 15 Nov 2018, 14:41
Eran blancas
arlot
Notapor juanbb el 15 Nov 2018, 14:44
arlot escribió:Eran blancas
No entiendo como el restyling las lleva blancas y por ponerlas en el pre ya sea defecto grave. No se que diferencia habra.
juanbb
Notapor Pedrost el 15 Nov 2018, 14:47
Da igual el tono del led, lo que no se permite es modificar nada que tenga que ver con la iluminación delantera del coche, yo para evitar eso monte en los antinieblas las halógenos de Philips de 6000K se asemejan a la luz led aunque evidentemente no es el mismo tono, pero me quito de problemas con la ITV
El restyling viene homologado para llevar antinieblas LED, es como sí aún Styles le montan la iluminación LED o xenon, no pasa itv
Última edición por Pedrost el 15 Nov 2018, 14:53, editado 2 veces en total
Pedrost
Notapor arlot el 15 Nov 2018, 14:49
Lo mismo pensé, si los de ahora llevan los antinieblas con led, pues no habrá problema; pues no, defecto grave y a cambiarlas si quieres pasar la ITV :enfurecido: :enfurecido:
arlot
Notapor Cjlopez el 15 Nov 2018, 14:51
No la pasaste porque el dispositivo es decir el faro no está homologado para luces de led, si para antiniebla halógena. Cada uno tiene su codificación y por eso te echaría para atrás el inspector.
A parte que le deslumbrará bastante seguro.
Enviado desde mi Redmi Note 5 mediante Tapatalk
En este mensaje, Cjlopez ha recibido un agradecimiento de:
arlot (15 Nov 2018, 15:10)
Cjlopez
Notapor arlot el 15 Nov 2018, 15:10
Seguramente sea por lo que comentas, si no está homologado no lo está; pero vamos que las antinieblas no son luces con las que vayas todo el dia encendidas. Seguiremos con las halógenas y fuera problemas.
arlot
Usuarios navegando por este Foro: Semrush y 30 invitados
