Me ha salido un error al buscar "Nuevos post"
NotaPublicado: 03 Nov 2008, 00:58
por Invitado
Este es en cuestion:
Código: Seleccionar todo
Could not insert search results
DEBUG MODE
SQL Error : 1062 Entrada duplicada '967707233' para la clave 1
INSERT INTO nuke_phpbb_search_results (search_id, session_id, search_time, search_array) VALUES(967707233, 'b1d90f84b2422ef214e76a892e496568', 1225670220, 'a:7:{s:14:"search_results";s:1692:"13123, 17679, 18109, 19500, 22131, 22452, 24934, 25706, 28560, 28669, 29680, 29713, 29807, 30932, 31592, 33264, 36110, 36934, 38156, 38987, 40266, 40674, 40832, 41236, 41656, 42013, 42042, 43362, 43447, 43725, 44550, 44562, 44891, 45352, 45651, 45666, 45782, 45890, 45985, 46144, 46225, 46243, 46349, 46363, 46377, 46601, 46732, 46747, 46753, 46758, 46820, 46852, 46890, 46957, 47009, 47031, 47184, 47249, 47264, 47273, 47359, 47389, 47435, 47473, 47474, 47490, 47570, 47584, 47609, 47611, 47622, 47649, 47661, 47676, 47694, 47761, 47859, 47865, 47896, 47904, 47936, 47945, 47999, 48010, 48039, 48097, 48124, 48136, 48150, 48162, 48196, 48216, 48239, 48249, 48291, 48305, 48308, 48311, 48323, 48357, 48361, 48370, 48401, 48419, 48424, 48432, 48433, 48434, 48452, 48462, 48471, 48474, 48479, 48481, 48483, 48485, 48496, 48501, 48508, 48518, 48529, 48533, 48544, 48552, 48559, 48564, 48578, 48581, 48593, 48594, 48602, 48610, 48613, 48631, 48635, 48637, 48642, 48650, 48653, 48655, 48658, 48664, 48667, 48669, 48670, 48675, 48678, 48680, 48681, 48684, 48685, 48686, 48687, 48694, 48696, 48697, 48700, 48710, 48711, 48713, 48714, 48720, 48725, 48727, 48728, 48729, 48731, 48732, 48734, 48735, 48736, 48737, 48740, 48743, 48744, 48745, 48746, 48748, 48749, 48751, 48752, 48753, 48754, 48755, 48756, 48757, 48758, 48759, 48760, 48761, 48762, 48763, 48764, 48765, 48766, 48767, 48768, 48769, 48770, 48771, 48772, 48773, 48774, 48775, 48776, 48777, 48778, 48779, 48780, 48781, 48782, 48783, 48784, 48785, 48786, 48787, 48788, 48789, 48790, 48791, 48792, 48793, 48794, 48795, 48796, 48797, 48798, 48799, 48800, 48801, 48802, 48803, 48804, 48805, 48806, 48807, 48808, 48809, 48811, 48812, 48813, 48814";s:17:"total_match_count";i:242;s:12:"split_search";N;s:7:"sort_by";i:0;s:8:"sort_dir"
;s:4:"DESC";s:12:"show_results";s:6:"topics";s:12:"return_chars";i:200;}')
Line : 735
File : search.php
Solo me ha pasado una vez... pero lo notifico ^^
NotaPublicado: 03 Nov 2008, 07:45
por Fenix
Veo que el mundo se va a acabar, o al menos eso interpreto en la 5º linea numerica.... ten cuidado... si te vuelve a salir metete en la cama y cubrete la cabeza con papel de aluminio y despues tapate hasta arriba con la manta... xDD
NotaPublicado: 03 Nov 2008, 08:38
por CrAfTy
que buen bug! :lol:
Buen trabajo Kriminus!
Re: Me ha salido un error al buscar "Nuevos post"
NotaPublicado: 03 Nov 2008, 10:30
por DEW-SCENTED
CrAfTy escribió:que buen bug! :lol:
Y estamos esperando tu crafty sugerencia.
NotaPublicado: 03 Nov 2008, 13:16
por BhEaN
No es nada crítico, es solo que no se ha podido guardar la búsqueda que estabas haciendo porque el ID ya se había guardado... es un fallo muy raro porque ese caso no debería darse nunca, pero no he logrado reproducir el fallo, asi que estaré atento por si vuelve a pasar...
Gracias por el aviso,
NotaPublicado: 03 Nov 2008, 21:29
por Sonic_206
BhEaN escribió:
Gracias por el aviso, tiquismikis
:troncharse:
NotaPublicado: 03 Nov 2008, 22:11
por Invitado
BhEaN escribió:Buenas,
No es nada crítico,
Entonces... es grave!!!!
Vamos a morir todos !!!!!!!!!!!!!!!!!!!
NotaPublicado: 03 Nov 2008, 22:26
por Polete
mola
NotaPublicado: 04 Nov 2008, 00:27
por Blanco
Yo no queria decirlo... pero desde que Chusmi habla con el servidor... las cosas no estan llendo nada bien...
NotaPublicado: 04 Nov 2008, 08:22
por CrAfTy
:P
Blanco escribió:Yo no queria decirlo... pero desde que Chusmi habla con el servidor... las cosas no estan llendo nada bien...
:troncharse:
NotaPublicado: 05 Nov 2008, 20:47
por Sonic_206
Antes molaba... 8)
NotaPublicado: 05 Nov 2008, 21:02
por DEW-SCENTED
Antes molaba... 8)
Hombre a mi me sigue molando, ya que siempre me hace una felacion cada noche por eso me contento.
NotaPublicado: 05 Nov 2008, 21:05
por Sonic_206
Cabron, que fino :chiflado:
:maruja: ese vocabulario!!!!
NotaPublicado: 06 Nov 2008, 08:13
por CrAfTy
Antes molaba... 8)
:o estas fatal dew!
aprovecha la minima q puede para poner el iconillo ese... :lol:
NotaPublicado: 06 Nov 2008, 14:09
por sufitdi
Fenix escribió:Veo que el mundo se va a acabar, o al menos eso interpreto en la 5º linea numerica.... ten cuidado... si te vuelve a salir metete en la cama y cubrete la cabeza con papel de aluminio y despues tapate hasta arriba con la manta... xDD
Pues porque te has parado en la quinta linea, porque si identificas la sexta, se ha iniciado la autodestrucción masiva del foro por simulación de ataque de virus a la base de datos, esta en el apartado C del manual F de la base de datos Alfa.
El proveedor del servicio se va a cagar en nuestras muelas... :lol:
