Problema con las cerraduras
Seguidores: Brunold, surgeon, Llisus
Notapor Khazad el 13 Feb 2017, 08:15
Pues eso, otro mas con problemas con las famosas cerraduras VAG, me toco en el golf y hace un par de años la del maletero del Leon, ahora toca la del conductor y empieza a fallar la trasera izquierda.
He pasado vagcom y este es el resultado
Código: Seleccionar todo
Chassis Type: 1P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77
VIN: VSSZZZ1PZ8   Mileage: 189910km/118004miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
[b]42-Door Elect, Driver -- Status: Malfunction 0010[/b]
44-Steering Assist -- Status: OK 0000
[b]46-Central Conv. -- Status: Malfunction 0010[/b]
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
[b]62-Door, Rear Left -- Status: Malfunction 0010[/b]
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 1T0 959 701 G    HW: 1K0 959 793 M
   Component: J386  TUER-SG FT    1129
   Revision: 31008001    Serial number: 00000000278707
   Coding: 0000176
   Shop #: WSC 04941 785 00200
   VCID: 3B75D1677A907BC6811-806E
2 Faults Found:
01552 - Motor for Central Locking; Drivers Door (V56); Lock
            012 - Electrical Fault in Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 3
                    Fault Frequency: 4
                    Reset counter: 72
                    Mileage: 189840 km
                    Time Indication: 0
00928 - Locking Module for Central Locking; Front Driver Side (F220)
            008 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 3
                    Fault Frequency: 33
                    Reset counter: 33
                    Mileage: 189731 km
                    Time Indication: 0
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0204
   Revision: 00020000    Serial number: 00000000000000
   Coding: 998000005283CC7F7F06850560084F86307C00
   VCID: 8305E987C2E04306091-80D6
   Subsystem 5 - Part No: 1P0 951 171 A
   Component: Innenraumueberw.010 4974
   Coding: 00000000
   Shop #: WSC 04941
   Subsystem 6 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Subsystem 7 - Component:       NGS n.mounted
1 Fault Found:
01135 - Interior Monitoring Sensors
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 72
                    Time Indication: 0
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 1K0 959 703 N    HW: 1K0 959 795 H
   Component: J388   TUER-SG HL   1108
   Revision: 11006001    Serial number: 00000002014118
   Coding: 0000144
1 Fault Found:
00930 - Locking Module for Central Locking; Rear Left (F222)
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 67
                    Mileage: 189836 km
                    Time Indication: 0
¿Sabeis del alguna web fiable para comprarlas a un precio interesante? Estoy pensando en cambiarlas yo pero he visto que es complicado, espero poder hacerlo yo y no tener que pasar por taller oficial.
Tambien me sale otro fallo, ¿son los volumétricos?
Khazad
Coche: Leon MK2 2.0 16v 140cv
Re: Problema con las cerraduras
Notapor victarraco el 13 Feb 2017, 08:18
Khazad escribió:Pues eso, otro mas con problemas con las famosas cerraduras VAG, me toco en el golf y hace un par de años la del maletero del Leon, ahora toca la del conductor y empieza a fallar la trasera izquierda.
   Coding: 0000176
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 4
                    Reset counter: 72
                    Mileage: 189840 km
                    Time Indication: 0
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 33
                    Reset counter: 33
                    Mileage: 189731 km
                    Time Indication: 0
   Coding: 00000000
   Shop #: WSC 04941
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 72
                    Time Indication: 0
   Coding: 0000144
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 67
                    Mileage: 189836 km
                    Time Indication: 0
en desguace están por 30€ y están bastante bien si vas a la casa son 200€ más mano de obra y hay diferentes web que las venden
victarraco
Coche: Leon MK2 1.9 TDI 105cv
Agradecido: 15 veces
Notapor Khazad el 13 Feb 2017, 08:50
victarraco escribió:en desguace están por 30€ y están bastante bien si vas a la casa son 200€ más mano de obra y hay diferentes web que las venden
De desguace puse una en el golf por 30€, para el seat no se que hacer, mire alguna y me pedían 70-80€ pero a saber como están, a lo mejor están mas trotadas que otra cosa.
Desde luego se han lucido con las cerraduras y no son baratas.
Khazad
Notapor victarraco el 13 Feb 2017, 08:59
Dímelo a mí que tengo el lado derecho inutilizado hace ya años por pereza la verdad y la del conductor me a fallado alguna vez que otra pero vamos compre el wd-40 le eche bien bien por todos sitios y no a vuelto a fallar lo mismo las otras están a falta de lubricante y yo sin saberlo pero por no desmontar la puerta se puede dar dinero
victarraco
Notapor Khazad el 13 Feb 2017, 09:15
victarraco escribió:Dímelo a mí que tengo el lado derecho inutilizado hace ya años por pereza la verdad y la del conductor me a fallado alguna vez que otra pero vamos compre el wd-40 le eche bien bien por todos sitios y no a vuelto a fallar lo mismo las otras están a falta de lubricante y yo sin saberlo pero por no desmontar la puerta se puede dar dinero
La del conductor lleva un tiempo dando avisos, a veces va bien 15 días y de repente falla, sin tocar vuelve a ir bien y así pero claro cualquier día dejara de ir.
Acabo de llamar a un desguace por ver si me merece la pena y las tenían agotadas.
Khazad
Notapor netbrowzer el 13 Feb 2017, 15:43
Yo he mirado en 4-5 desguaces de mi zona para la del maletero.... y nada, ninguno la tiene. Por lo visto van buscadas y mucho.
Mods aplicados: Pitidos cierre / apertura, alarma en FIS, luces emergencia y parpadeo frenos en frenada emergencia, Staging.
Falta cierre por lluvia, retrovisor derecho "parking"
netbrowzer
Agradecido: 104 veces
Notapor victarraco el 13 Feb 2017, 16:47
Están súper solicitadas en algunas web de recambios con la ref e encontrado yo
victarraco
Notapor netbrowzer el 13 Feb 2017, 17:17
victarraco escribió:Están súper solicitadas en algunas web de recambios con la ref e encontrado yo
Y esa web es......
netbrowzer
Notapor victarraco el 13 Feb 2017, 17:24
http://www.cesvirecambios.com/catalogse ... at+leon+1p
Como está por ejemplo
victarraco
Notapor victor29.mlg el 14 Feb 2017, 10:34
Que problema tienes? Exactamente
Enviado desde mi Redmi Note 3 mediante Tapatalk
victor29.mlg
Notapor freeminds el 15 Feb 2017, 13:33
Otro que se une al fallo de cerraduras, en mi caso la del conductor.
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Part No: 1T0 959 701 C
Component: Tuer-SG 024 2429
Coding: 0000176
Shop #: WSC 06441 785 00200
VCID: 37643CDFDF4D71BAEE4AB51-8062
2 Faults Found:
El fallo que me da es que con el mando le das a abrir y rebota y sigue cerrada, incluso veo desde fuera el botoncito de la llave del medio del habitáculo y sigue encendido como que esta cerrado. Me obliga a abrir siempre con llave, e incluso con la llave el 10% de las veces ni abre, y tengo que darle a cerrar y abrir con la llave hasta que abre.
Ayer mismo me pedí una de aliexpress que no tenía mala crítica, y total para lo malas que son las originales, pruebo con la china que al menos es nueva y por 53e en casa, y en desguace cuesta eso o más y no sabes como esta.
https://es.aliexpress.com/item/FOR-Volk ... 0.0.i3uYQC
-- León II 2.0 TDI BKD 140cv Reprogramado 175cv --
freeminds
Notapor stewei el 17 Feb 2017, 08:08
freeminds escribió:Otro que se une al fallo de cerraduras, en mi caso la del conductor.
Coding: 0000176
2 Faults Found:
@freeminds ¿Que las originales son malas? ¿Cuántas veces has cambiado de cerradura? ¿Cuántos años tiene tu coche?
stewei
Agradecido: 465 veces
Notapor victarraco el 17 Feb 2017, 09:13
Coding: 0000176
2 Faults Found:
malas no malísimas en 10 años que tiene mi coche llevo más de 5 con la trasera derecha inutilizada y hace 5 meses la delantera derecha, en ocasiones me a fallado la del conductor. Y son 200€ cada una en la casa
victarraco
Coding: 0000176
2 Faults Found:
victarraco
Notapor freeminds el 17 Feb 2017, 09:31
Coding: 0000176
2 Faults Found:
Hombre teniendo en cuenta que tengo el coche desde hace 5 meses y ya voy a cambiarle una, y he hablado con el anterior propietario que es vecino mío, así como con mí hermano y compañeros de trabajo que tb lo tienen con distintas motorizaciones.....y todos han cambiado en varias ocasiones cerraduras... Sí son malas, malísimas, todos coinciden en que es el cáncer del coche...así que no sé por qué te sorprende que ponga eso. Saludos
freeminds
