Hola Buenas tardes.
Hoy iba con el coche circulando y se me encendio la luz de la resistencia parpadeando, cuando llegue a casa le he pasado el Vag-Com y este ha sido el resultado.
Address 01: Engine Labels: Redir Fail!
Part No SW: 03G 906 018 GP HW: 03G 906 018 GP
Component: R4 2.0l PPD1.2 G 1172
Revision: --H42--- Serial number: SEX7Z0G931Q08E
Coding: 0050072
Shop #: WSC 03462 781 67344
VCID: 79FDE9D74B19
4 Faults Found:
012295 - Camshaft Position Sensor (G40): No Signal
P3007 - 006 - Short to Plus
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 69
Reset counter: 40
Mileage: 102873 km
Time Indication: 0
Date: 2000.00.00
Time: 15:57:24
Freeze Frame:
RPM: 2048 /min
Torque: 104.0 Nm
Speed: 11.0 km/h
Bin. Bits: 11111111
(no units): 6.0
(no units): 118.0
Time: 0.00 s
000833 - Camshaft Position Sensor (G40): Implausible Signal
P0341 - 006 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 21
Reset counter: 35
Mileage: 106201 km
Time Indication: 0
Date: 2000.00.00
Time: 17:11:09
Freeze Frame:
RPM: 160 /min
Torque: 96.0 Nm
Speed: 0.0 km/h
(no units): 0.0
Steering Angle: 0.00°
Angle: 0.0 °
(no units): 1.0
000802 - Engine Speed Sensor (G28): No Signal
P0322 - 006 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00000001
Fault Priority: 5
Fault Frequency: 8
Reset counter: 25
Mileage: 106325 km
Time Indication: 0
Date: 2000.00.00
Time: 18:00:24
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Bin. Bits: 00000001
Bin. Bits: 00000011
(no units): 1.0
Angle: 0.0 °
012600 - Intake Manifold Runner Control: Regulation Deviation
P3138 - 006 - Short to Plus
Freeze Frame:
Fault Status: 11000001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 106814 km
Time Indication: 0
Date: 2000.00.00
Time: 17:29:28
Freeze Frame:
RPM: 1184 /min
Torque: 72.0 Nm
Speed: 17.0 km/h
Mass Air / Rev.: 512.3 mg/str
Mass Air / Rev.: 615.9 mg/str
Lambda: -27.3 %
Text: Kein Messwert verfuegbar
Readiness: N/A
Decir que llevo 1 mes mas o menos que cuando intento arrancar el coche en caliente tenia que alargar mucho el motor de arranque. No siempre pero si algunas veces.
He leido que puede ser a causa del sensor G-28?
Que opinais de los fallos en general?
Alguien podria hecharme una mano?
Por lo demas el coche va bien he borrado los fallos y he arrancado el coche de nuevo y no han vuelto a salir, no se si circulando volveran a aparecer.
Gracias.
Vag-Com varios Fallos ( sensores G-40 y G-28 )
11 mensajes
Damonzito - Leoner@ habitual
- Coche: Leon MK2 2.0 TFSI 185cv
- Agradecido: 4 veces
Re: Vag-Com varios Fallos ( sensores G-40 y G-28 )
Pues he bajado otra vez para ponerle el vag-com.
Y al volver a intentar arrancar el coche, he visto que parpadeaba la luz de la resistencia habiendole borrado los errores anteriormente. Bueno, pues intento arrancar y no arranca. Quito contacto y lo vuelvo a poner y desaparece la luz parpadeante y arranca.
Borro fallos de nuevo y saco este log.
Tuesday,15,January,2013,19:58:29:10074
VCDS Version: Beta 11.2.0
Data version: 20110305
Address 01: Engine (03G 906 018 GP)
19:58:16 Group 001
793 /min RPM
5.9 mg/str Inj. Quantity
4.2°KW Idle Stabilization
74.0°C Temperature
19:58:16 Group 002
801 /min RPM
0.0 % Duty Cycle
00001000 Bin. Bits
74.0°C Temperature
19:58:16 Group 003
807 /min RPM
280.0 mg/str Mass Air / Rev.
278.8 mg/str Mass Air / Rev.
56.8 % Duty Cycle
19:58:16 Group 001
793 /min RPM
74.0°C Temperature
19:58:16 Group 002
801 /min RPM
0.0 % Duty Cycle
00001000 Bin. Bits
74.0°C Temperature
19:58:16 Group 003
807 /min RPM
56.8 % Duty Cycle
Yo tenía problemas al arrancar en caliente, arrancaba tirandole 5 o 6 segundos, en frio siempre a la primera, y era del sensor G28. Borraba el fallo y en caliente arrancaba bien, pero lo mismo se tiraba bien 1 día q 1 hora, el fallo seguía estando ahí y volvia a fallar en caliente.
IvánR - Nuev@ por aqui
- Coche: Leon MK1 1.8 Cupra R 210cv
Buenos dias, alguien a tenido tiempo de pegarle una ojeadita?
Gracias.
Gracias.
@IvánR Vale, me queda mas o menos claro el error del G28 a mi me pasa exactamente igual.
Sobre el G40 alguien ve algo ahí¿?
Alguien sabe la Referencia del sensor G-28?
A mi me salió fallo del sensor G40 pero era a raíz del fallo del G28, cambié el G28 y listo, fallo mio por no habertelo comentado
, prueba a cambiar primero el G28 y ya ves si el fallo del otro viene de ahí
Mil gracias @IvánR, por casualidad, sabes la referencia?
Es este verdad? : http://www.recambiosviaweb.com/m104/d54 ... a-hoy.html
Edito:
Seria este exactamente el G28, no el anterior, no?
Edito:
Estoy viendo imagenes en google y leyendo un poco y no consigo sacar nada en claro de cual de los 2 es?
Diria que es este, lo que pasa que en los links de arriba los nombres estan cambiados?
De ser así, en el link del post superior, seria:
http://www.recambiosviaweb.com/m104/d5431/c19499/s3/g833/a100002/l1987080/i140299/generador-de-impulsos-ciguenal-hella-6pu-009-163-491-seat-leon-1p1-2005-05-hasta-hoy-20-tdi-170cv-diesel-2006-05-hasta-hoy.html
Entonces ese dice Generador de impulsos del cigueñal.
@IvánR recuerdas si era ese?
Bueno, pues... el martes al ir hacia casa , despues de salir de una rotonda... Noto un bajon en el coche, y perdida de potencia, le cuesta mucho subir de vueltas. Iba a una velocidad de 90-100km/h.
Cuando llegue a casa lo pare, y probe a ver si dejandolo un tiempo 30 minutos, volvia a estar bien. Le costó mucho arrancar, arrancó pero sigue igual.
He comprado la G28 y en estos dias la cambiare.
Aprovecho este hilo para comentar mi problema, y así no abrir un tema nuevo...
El otro día me saltó el temido mensaje "avería de motor. acuda a taller", junto al chivato de los calentadores (el muelle/resistencia). Apago y enciendo y todo ok, y sin signos de nada en el coche.
Le paso el VCDS y me da esto:
P3138 - 006 - Regulation Deviation - Intermittent
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 38
Mileage: 115340 km
Time Indication: 0
Date: 2000.00.00
Time: 21:23:56
Freeze Frame:
RPM: 2560 /min
Torque: 72.0 Nm
Speed: 61.0 km/h
Mass Air / Rev.: 566.8 mg/str
Mass Air / Rev.: 555.9 mg/str
Lambda: -17.2 %
Alguien puede compartir sus conocimientos?
Por cierto, es un 2.0 TDI 170CV del 2007 (BMN).
Es que googleando veo que le pasa mucho a los TFSI, pero el mio en un TDI.
Pero vamos, que no saco nada en claro. El coche va perfecto... ?¿?
Graciassss
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 38
Mileage: 115340 km
Time Indication: 0
Date: 2000.00.00
Time: 21:23:56
Freeze Frame:
RPM: 2560 /min
Torque: 72.0 Nm
Speed: 61.0 km/h
Lambda: -17.2 %
Graciassss
Seat Leon 1M Sport 1.9 TDI 110
tofimas - Asidu@ en la selva
tofimas escribió:Aprovecho este hilo para comentar mi problema, y así no abrir un tema nuevo...
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 38
Mileage: 115340 km
Time Indication: 0
Date: 2000.00.00
Time: 21:23:56
Freeze Frame:
RPM: 2560 /min
Torque: 72.0 Nm
Speed: 61.0 km/h
Lambda: -17.2 %
Graciassss
Estoy igual que tu en mi 170 como lo arreglaste?
Albertovema - Nuev@ por aqui
11 mensajes
Activar sensores parking delanteros baja velocidad leon 2 Foro: Leon II - Mecánica / Electricidad / Electrónica Autor: Arny Respuestas: 0 |
Usuarios con VAG-COM / OBD Eleven y otros por provincia Foro: Informática / Interfaces / Diagnosis Autor: XoXe Respuestas: 787 |
León Mk4 - Fallos en Infotainment Foro: AudioCar y MultimediaCar Autor: bernasanchez Respuestas: 111 |
activar y registrar Vag-com 409.1 Foro: Informática / Interfaces / Diagnosis Autor: fran_tobarra Respuestas: 78 |
Problema con sensores de Parking Foro: Leon III - Mecánica / Electricidad / Electrónica Autor: martin61 Respuestas: 5 |
