problema al hacer un log
Notapor leonero 8 el 06 Feb 2014, 14:21
Muy buenas!!! :ayuda:
He estado haciendo unos log sobre la presion del turbo a mi seat leon fr con el vag-com. Despues de hacerlo he ido a abrirlo esperando encontrarme la tipica grafica que he visto que os aparece a vosotros pero me he encontrado con un microsf excel y no he entendido nada de lo que pone!! mi pregunta es que si hay que hacer algo con eso o lo abro con algun programa?? de todas formas os dejo aqui en archivo (espero aberlo hecho bien) :?
Gracias.
(EL LOG ESTA HECHO EN 6º DESDE 1300-4100 RPM)
Thursday,06,February,2014,13:18:21:32264,VCDS Version: Release 11.11.3,Data version: 20120401
038 906 019 KG,,1.9l R4 EDC 0000SG 5342,
,Group A:,'003,,,,Group B:,'011,,,,Group C:,'020
,,Engine speed,MAF (specified),MAF (actual),EGR duty cycle,,Engine speed,Spec. intake press.,Actual intake press.,D.cycle MAP,,RPM,Torque,Inj. Quantity,Inj. Quantity
,TIME,790-870,230-350,210-370,40-75%,TIME,2850-3150,2300-2600,2200-2800,35-80%,TIME,,,,
Marker,STAMP, /min, mg/str, mg/str, %,STAMP, /min,,, %,STAMP, /min, Nm, mg/str, mg/str
,0.69,1743,850.0,690.9,4.8,0.00,1722,2112.0,1056.0,24.7,0.34,1743,194.0,70.0,0.0
,1.76,1764,850.0,960.4,4.8,1.05,1743,2124.0,1548.0,28.7,1.40,1764,298.0,70.0,0.0
,2.72,1827,850.0,1019.2,4.8,2.07,1785,2160.0,2172.0,49.4,2.40,1806,334.0,70.0,0.0
,3.73,1869,850.0,975.1,4.8,3.04,1827,2184.0,2376.0,56.6,3.37,1848,344.0,70.0,0.0
,4.80,1932,850.0,945.7,4.8,4.08,1869,2220.0,2316.0,58.6,4.44,1911,350.0,70.0,0.0
,5.76,1974,850.0,945.7,4.8,5.11,1932,2268.0,2220.0,55.4,5.44,1953,346.0,70.0,0.0
,6.74,2016,850.0,955.5,4.8,6.08,1995,2280.0,2220.0,55.0,6.40,1995,344.0,70.0,0.0
,7.80,2079,850.0,980.0,4.8,7.09,2037,2292.0,2232.0,53.0,7.45,2058,348.0,70.0,0.0
,8.78,2121,850.0,975.1,4.8,8.14,2100,2316.0,2292.0,54.6,8.45,2100,348.0,70.0,0.0
,9.77,2163,850.0,989.8,4.8,9.10,2142,2328.0,2340.0,55.8,9.43,2142,350.0,70.0,0.0
,10.82,2205,850.0,1019.2,4.8,10.11,2184,2352.0,2364.0,57.4,10.46,2205,346.0,70.0,0.0
,11.83,2268,850.0,1004.5,4.8,11.17,2226,2376.0,2388.0,57.8,11.51,2247,348.0,70.0,0.0
,12.80,2331,850.0,1029.0,4.8,12.16,2289,2376.0,2400.0,58.2,12.48,2310,342.0,70.0,0.0
,13.85,2373,850.0,1038.8,4.8,13.13,2331,2388.0,2412.0,58.6,13.48,2352,344.0,70.0,0.0
,14.90,2394,850.0,1048.6,4.8,14.21,2394,2388.0,2412.0,59.4,14.57,2394,344.0,70.0,0.0
,15.88,2457,850.0,1048.6,4.8,15.24,2436,2400.0,2400.0,60.2,15.56,2436,340.0,70.0,0.0
,16.85,2499,850.0,1029.0,4.8,16.20,2478,2400.0,2400.0,60.2,16.52,2478,342.0,70.0,0.0
,17.92,2541,850.0,1024.1,4.8,17.22,2499,2400.0,2388.0,61.0,17.57,2520,342.0,70.0,0.0
,18.91,2562,850.0,1038.8,4.8,18.26,2541,2400.0,2388.0,61.0,18.59,2562,338.0,70.0,0.0
,19.88,2604,850.0,1038.8,4.8,19.23,2583,2400.0,2388.0,61.0,19.56,2583,338.0,70.0,0.0
,20.90,2646,850.0,1043.7,4.8,20.19,2625,2400.0,2400.0,60.2,20.55,2646,336.0,70.0,0.0
,21.98,2688,850.0,1068.2,4.8,21.26,2667,2400.0,2400.0,61.8,21.62,2667,336.0,70.0,0.0
,22.93,2709,850.0,1078.0,4.8,22.30,2688,2400.0,2412.0,62.6,22.61,2688,336.0,70.0,0.0
,23.89,2751,850.0,1063.3,4.8,23.24,2730,2400.0,2400.0,61.4,23.55,2730,334.0,70.0,0.0
,24.95,2772,850.0,1073.1,4.8,24.24,2751,2400.0,2400.0,61.8,24.59,2751,334.0,70.0,0.0
,25.97,2793,850.0,1097.6,4.8,25.30,2772,2400.0,2400.0,63.0,25.63,2793,334.0,70.0,0.0
,26.93,2835,850.0,1073.1,4.8,26.29,2814,2400.0,2412.0,63.4,26.61,2814,334.0,70.0,0.0
,27.97,2856,850.0,1063.3,4.8,27.25,2835,2400.0,2400.0,63.0,27.60,2856,330.0,70.0,0.0
,29.03,2898,850.0,1068.2,4.8,28.32,2877,2400.0,2412.0,63.4,28.68,2877,334.0,70.0,0.0
,30.04,2919,850.0,1063.3,4.8,29.40,2898,2400.0,2412.0,64.1,29.72,2898,330.0,70.0,0.0
,31.01,2961,850.0,1073.1,4.8,30.35,2919,2400.0,2400.0,64.5,30.68,2940,330.0,70.0,0.0
,32.08,2982,850.0,1073.1,4.8,31.36,2940,2400.0,2400.0,64.5,31.72,2961,328.0,70.0,0.0
,33.11,3003,850.0,1068.2,4.8,32.44,2982,2400.0,2400.0,64.5,32.78,3003,328.0,70.0,0.0
,34.07,3045,850.0,1058.4,4.8,33.44,3024,2400.0,2388.0,64.5,33.75,3024,330.0,70.0,0.0
,35.08,3066,850.0,1068.2,4.8,34.39,3045,2400.0,2388.0,64.9,34.74,3066,328.0,70.0,0.0
,36.14,3087,850.0,1063.3,4.8,35.44,3066,2400.0,2388.0,64.5,35.80,3087,326.0,70.0,0.0
,37.11,3108,850.0,1048.6,4.8,36.48,3108,2400.0,2388.0,64.9,36.79,3108,324.0,70.0,0.0
,38.09,3150,850.0,1048.6,4.8,37.43,3129,2388.0,2388.0,65.3,37.75,3129,326.0,70.0,0.0
,39.18,3171,850.0,1038.8,4.8,38.44,3150,2388.0,2388.0,64.9,38.82,3171,322.0,70.0,0.0
,40.17,3192,850.0,1048.6,4.8,39.53,3171,2388.0,2388.0,65.7,39.85,3192,322.0,70.0,0.0
,41.14,3213,850.0,1043.7,4.8,40.50,3213,2388.0,2388.0,65.3,40.81,3213,322.0,70.0,0.0
,42.18,3234,850.0,1043.7,4.8,41.47,3213,2388.0,2376.0,65.3,41.82,3234,322.0,70.0,0.0
,43.20,3255,850.0,1033.9,4.8,42.54,3255,2376.0,2376.0,65.7,42.88,3255,320.0,70.0,0.0
,44.16,3276,850.0,1029.0,4.8,43.51,3276,2376.0,2376.0,65.7,43.83,3276,322.0,70.0,0.0
,45.14,3297,850.0,1033.9,4.8,44.48,3297,2376.0,2376.0,66.1,44.80,3297,320.0,70.0,0.0
,46.20,3339,850.0,1029.0,4.8,45.50,3318,2376.0,2376.0,66.1,45.86,3318,320.0,70.0,0.0
,47.23,3360,850.0,1043.7,4.8,46.56,3339,2376.0,2364.0,66.1,46.90,3339,320.0,70.0,0.0
,48.19,3381,850.0,1024.1,4.8,47.55,3360,2364.0,2364.0,66.5,47.87,3381,316.0,70.0,0.0
,49.22,3402,850.0,1024.1,4.8,48.52,3402,2364.0,2376.0,66.9,48.86,3402,318.0,70.0,0.0
,50.25,3444,850.0,1014.3,4.8,49.56,3423,2364.0,2364.0,67.3,49.90,3423,314.0,70.0,0.0
,51.26,3465,850.0,1014.3,4.8,50.60,3444,2364.0,2364.0,67.3,50.93,3444,312.0,70.0,0.0
,52.22,3486,850.0,1024.1,4.8,51.57,3465,2364.0,2364.0,67.7,51.89,3486,312.0,70.0,0.0
,53.22,3507,850.0,1019.2,4.8,52.54,3486,2352.0,2364.0,67.7,52.88,3486,314.0,70.0,0.0
,54.30,3528,850.0,999.6,4.8,53.58,3507,2352.0,2364.0,68.1,53.94,3528,312.0,70.0,0.0
,55.29,3549,850.0,1019.2,4.8,54.64,3528,2352.0,2352.0,68.5,54.97,3549,312.0,70.0,0.0
,56.26,3570,850.0,999.6,4.8,55.61,3549,2352.0,2352.0,68.1,55.94,3570,308.0,70.0,0.0
,57.30,3591,850.0,989.8,4.8,56.58,3570,2340.0,2340.0,68.5,56.94,3591,308.0,70.0,0.0
,58.36,3612,850.0,984.9,4.8,57.66,3591,2340.0,2328.0,68.1,58.02,3612,300.0,70.0,0.0
,59.31,3612,850.0,975.1,4.8,58.67,3612,2328.0,2328.0,68.5,58.99,3612,306.0,70.0,0.0
,60.28,3633,850.0,999.6,4.8,59.64,3612,2328.0,2328.0,68.5,59.95,3633,304.0,70.0,0.0
,61.34,3654,850.0,980.0,4.8,60.61,3633,2328.0,2328.0,68.5,60.98,3654,302.0,70.0,0.0
,62.37,3675,850.0,980.0,4.8,61.70,3654,2328.0,2328.0,68.5,62.04,3654,302.0,70.0,0.0
,63.36,3675,850.0,970.2,4.8,62.71,3654,2328.0,2328.0,68.9,63.03,3675,302.0,70.0,0.0
,64.36,3675,850.0,975.1,4.8,63.68,3675,2328.0,2328.0,68.9,64.01,3675,302.0,70.0,0.0
,65.44,3696,850.0,960.4,4.8,64.72,3696,2316.0,2316.0,68.5,65.08,3696,302.0,70.0,0.0
,66.43,3696,850.0,965.3,4.8,65.78,3696,2316.0,2316.0,68.5,66.11,3696,300.0,70.0,0.0
,67.39,3696,850.0,965.3,4.8,66.75,3696,2316.0,2328.0,68.9,67.08,3696,298.0,70.0,0.0
,68.44,3696,850.0,970.2,4.8,67.73,3696,2316.0,2316.0,68.9,68.08,3696,302.0,70.0,0.0
,69.51,3696,850.0,960.4,4.8,68.80,3696,2316.0,2316.0,69.3,69.16,3696,300.0,70.0,0.0
,70.47,3717,850.0,965.3,4.8,69.83,3696,2316.0,2316.0,68.9,70.15,3717,296.0,70.0,0.0
,71.50,3717,850.0,965.3,4.8,70.79,3717,2316.0,2316.0,69.3,71.15,3717,300.0,70.0,0.0
,72.57,3717,850.0,950.6,4.8,71.86,3717,2316.0,2316.0,68.9,72.22,3717,300.0,70.0,0.0
,73.55,3717,850.0,955.5,4.8,72.90,3717,2316.0,2316.0,69.3,73.23,3717,296.0,70.0,0.0
,74.53,3738,850.0,965.3,4.8,73.87,3717,2316.0,2304.0,68.5,74.19,3738,298.0,70.0,0.0
,75.58,3738,850.0,980.0,4.8,74.88,3738,2316.0,2316.0,69.3,75.24,3738,300.0,70.0,0.0
,76.57,3717,850.0,445.9,4.8,75.93,3738,2316.0,2316.0,68.9,76.25,3696,152.0,70.0,0.0
,77.54,3633,850.0,470.4,4.8,76.89,3675,1044.0,1440.0,47.8,77.21,3654,0.0,70.0,0.0
,78.60,3549,640.0,470.4,4.8,77.89,3612,1032.0,1380.0,47.4,78.24,3570,0.0,70.0,0.0
,79.59,3486,455.0,460.6,4.8,78.96,3528,1032.0,1332.0,47.0,79.27,3507,0.0,70.0,0.0
,80.56,3423,345.0,455.7,4.8,79.91,3465,1032.0,1296.0,46.6,80.23,3444,0.0,70.0,0.0
,81.64,3339,340.0,470.4,4.8,80.92,3402,1020.0,1284.0,45.8,81.28,3360,0.0,70.0,0.0
,82.63,3276,335.0,460.6,4.8,81.99,3318,1020.0,1284.0,45.4,82.31,3297,0.0,70.0,0.0
,83.59,3192,325.0,436.1,4.8,82.95,3234,1020.0,1272.0,44.6,83.27,3213,0.0,70.0,0.0
,84.64,3129,320.0,465.5,4.8,83.92,3171,1008.0,1260.0,44.2,84.28,3150,0.0,70.0,0.0
,85.65,3066,315.0,455.7,4.8,85.00,3108,1008.0,1248.0,43.4,85.33,3087,0.0,70.0,0.0
,86.61,3003,310.0,460.6,4.8,85.97,3045,1008.0,1248.0,43.0,86.29,3024,0.0,70.0,0.0
,87.62,2940,305.0,460.6,4.8,86.93,2982,996.0,1248.0,42.6,87.26,2961,0.0,70.0,0.0
,88.70,2877,300.0,485.1,4.8,87.98,2919,996.0,1236.0,41.8,88.33,2898,0.0,70.0,0.0
,89.69,2814,295.0,470.4,4.8,89.05,2856,996.0,1236.0,41.0,89.37,2835,0.0,70.0,0.0
,90.68,2772,290.0,475.3,4.8,90.01,2793,996.0,1224.0,40.6,90.33,2793,0.0,70.0,0.0
,91.76,2709,285.0,480.2,4.8,91.04,2751,984.0,1224.0,40.2,91.40,2730,0.0,70.0,0.0
,92.77,2646,280.0,475.3,4.8,92.10,2688,984.0,1200.0,39.4,92.43,2667,0.0,70.0,0.0
,93.73,2583,275.0,465.5,4.8,93.09,2625,984.0,1188.0,39.0,93.41,2604,0.0,70.0,0.0
,94.80,2541,270.0,470.4,4.8,94.08,2583,984.0,1164.0,38.3,94.44,2562,0.0,70.0,0.0
,95.81,2478,265.0,455.7,4.8,95.16,2520,972.0,1152.0,37.9,95.48,2499,0.0,70.0,0.0
,96.77,2436,260.0,455.7,4.8,96.13,2457,972.0,1140.0,37.5,96.45,2436,0.0,70.0,0.0
,97.78,2373,260.0,455.7,4.8,97.09,2415,972.0,1128.0,37.5,97.42,2394,0.0,70.0,0.0
,98.84,2331,255.0,441.0,4.8,98.14,2352,972.0,1116.0,37.5,98.48,2331,0.0,70.0,0.0
,99.83,2268,250.0,441.0,4.8,99.18,2310,972.0,1104.0,37.5,99.51,2289,0.0,70.0,0.0
,100.79,2226,245.0,436.1,4.8,100.15,2268,972.0,1092.0,37.1,100.47,2247,0.0,70.0,0.0
,101.84,2163,240.0,441.0,4.8,101.13,2205,960.0,1080.0,36.7,101.48,2184,0.0,70.0,0.0
,102.89,2121,235.0,431.2,4.8,102.20,2163,960.0,1068.0,36.7,102.56,2142,0.0,70.0,0.0
,103.85,2058,235.0,426.3,4.8,103.21,2100,960.0,1056.0,35.9,103.53,2079,0.0,70.0,0.0
,104.85,2016,230.0,431.2,4.8,104.17,2037,960.0,1056.0,35.5,104.49,2037,0.0,70.0,0.0
,105.92,1974,230.0,431.2,4.8,105.20,1995,960.0,1044.0,35.5,105.56,1995,0.0,70.0,0.0
,106.95,1911,230.0,421.4,4.8,106.27,1953,960.0,1044.0,35.1,106.62,1932,0.0,70.0,0.0
,107.91,1869,230.0,416.5,4.8,107.27,1890,960.0,1032.0,34.7,107.59,1890,0.0,70.0,0.0
,108.92,1827,230.0,436.1,4.8,108.23,1848,960.0,1032.0,34.3,108.56,1848,0.0,70.0,0.0
,109.97,1785,230.0,411.6,4.8,109.26,1827,960.0,1020.0,33.9,109.62,1806,0.0,70.0,0.0
,110.97,1743,230.0,421.4,4.8,110.33,1764,960.0,1020.0,33.1,110.65,1764,0.0,70.0,0.0
,111.93,1701,230.0,416.5,4.8,111.29,1722,960.0,1020.0,32.7,111.61,1722,0.0,70.0,0.0
,113.02,1659,235.0,445.9,4.8,112.30,1680,960.0,1020.0,32.7,112.66,1680,0.0,70.0,0.0
,114.05,1617,235.0,426.3,4.8,113.38,1659,960.0,1008.0,32.3,113.74,1638,0.0,70.0,0.0
,115.01,1596,240.0,431.2,4.8,114.37,1617,960.0,1008.0,31.9,114.69,1596,0.0,70.0,0.0
,115.99,1554,240.0,416.5,4.8,115.33,1575,960.0,1008.0,31.9,115.65,1575,0.0,70.0,0.0
,117.08,1512,245.0,431.2,4.8,116.36,1554,960.0,996.0,31.5,116.72,1533,0.0,70.0,0.0
,118.05,1491,250.0,436.1,4.8,117.40,1512,960.0,996.0,31.1,117.73,1491,0.0,70.0,0.0
,119.01,1449,250.0,416.5,4.8,118.37,1470,960.0,996.0,31.1,118.69,1470,0.0,70.0,0.0
,120.02,1407,250.0,411.6,4.8,119.33,1449,960.0,984.0,31.1,119.66,1428,0.0,70.0,0.0
,121.10,1386,250.0,416.5,4.8,120.38,1407,960.0,984.0,30.7,120.74,1386,0.0,70.0,0.0
,122.11,1344,250.0,436.1,4.8,121.46,1365,960.0,972.0,30.7,121.78,1365,0.0,70.0,0.0
,123.06,1323,250.0,426.3,4.8,122.43,1344,960.0,972.0,30.7,122.74,1323,0.0,70.0,0.0
,124.04,1281,250.0,426.3,4.8,123.38,1302,960.0,972.0,30.7,123.71,1302,0.0,70.0,0.0
,125.11,1260,250.0,416.5,4.8,124.40,1281,960.0,960.0,30.7,124.76,1260,0.0,70.0,0.0
,126.16,1218,250.0,416.5,4.8,125.48,1239,960.0,960.0,30.7,125.83,1239,0.0,70.0,0.0
,127.14,1197,250.0,426.3,4.8,126.48,1218,960.0,948.0,30.7,126.82,1197,0.0,70.0,0.0
,128.12,1155,250.0,421.4,4.8,127.46,1176,960.0,948.0,30.7,127.78,1176,0.0,70.0,0.0
,129.19,1134,250.0,421.4,4.8,128.47,1155,960.0,948.0,30.7,128.83,1134,0.0,70.0,0.0
,130.25,1092,250.0,406.7,4.8,129.55,1113,960.0,936.0,29.5,129.91,1113,0.0,70.0,0.0
,131.21,1071,250.0,396.9,4.8,130.56,1092,960.0,936.0,28.3,130.88,1071,0.0,70.0,0.0
,132.18,1029,250.0,411.6,4.8,131.52,1050,960.0,936.0,27.5,131.84,1050,0.0,70.0,0.0
,133.25,1008,250.0,406.7,4.8,132.54,1029,960.0,936.0,25.9,132.89,1029,0.0,70.0,0.0
,134.26,987,250.0,387.1,68.1,133.60,987,960.0,936.0,24.7,133.95,987,0.0,70.0,0.0
,135.22,945,250.0,392.0,84.5,134.58,966,960.0,924.0,24.7,134.90,966,0.0,70.0,0.0
,136.18,924,250.0,392.0,84.5,135.54,945,960.0,924.0,24.7,135.86,945,0.0,70.0,0.0
,137.23,903,250.0,387.1,84.5,136.51,924,960.0,924.0,24.7,136.86,924,0.0,70.0,0.0
,138.31,882,250.0,387.1,84.5,137.59,903,984.0,924.0,24.7,137.95,903,20.0,70.0,0.0
leonero 8
Re: problema al hacer un log
Notapor Dcero el 06 Feb 2014, 18:04
Dcero
Agradecido: 92 veces
Notapor leonero 8 el 07 Feb 2014, 14:02
Muchas gracias!! Ya lo conseguí!!
leonero 8
Usuarios navegando por este Foro: No hay usuarios registrados visitando el Foro y 39 invitados
