resultado auto scan vagcom
Seguidores: Tunnig
Notapor mago62 el 28 Jun 2016, 20:35
VCDS Version: Release 12.12.0
Data version: 20130910
Tuesday,28,June,2016,19:52:25:62939
Chassis Type: 1M (1M - Seat Leon (2000 > 2005))
Scan: 01 02 03 08 15 17 19 22 35 36 37 46 56
VIN: VSSZZZ1MZ3R112801 Mileage: 147200km/91465miles
Address 01: Engine Labels: Redir Fail!
Part No: 038 906 012 FK
Component: 1,9l R4 EDC 0000SG 3357
Coding: 00002
Shop #: WSC 06402
VCID: 5EB378F3DAC24EEEC6F-49D8
VSSZZZ1MZ3R112801 SEZ7Z0C1916509
1 Fault Found:
17965 - Charge Pressure Control
P1557 - 35-10 - Positive Deviation - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019458
Shop #: WSC 00001 001 00001
VCID: 3467FA5B54CEB4BE40B-5000
No fault code found.
Address 08: Auto HVAC Labels: 1M0-820-043.lbl
Part No: 1M0 820 043 E
Component: 1M-CLIMATRONIC X0702
Coding: 00043
Shop #: WSC 06402
VCID: 24470A1BB42E243ED0B-2566
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 A
Component: 39 AIRBAG VW51 0A 0008
Coding: 13113
Shop #: WSC 06441
VCID: 224B0C03AE3A2A0EA27-5072
Address 17: Instruments Labels: 1M0-920-xx2-17.lbl
Part No: 1M0 920 822 D
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 05122
Shop #: WSC 00000
VCID: 29591B2FD30CF956E3D-5000
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06402
VCID: F0EFB64BB056489EE43-5000
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 F
Component: AY Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 06402
VCID: 3A7BD46326AA42CE9A7-4A3A
Subsystem 1 - Part No: 1C1959801A
Component: AY Tõrsteuer.FS KLO 0009
Subsystem 2 - Part No: 1C1959802A
Component: AY Tõrsteuer.BF KLO 0009
Subsystem 3 - Part No: 1C0959811A
Component: AY Tõrsteuer.HL KLO 0009
Subsystem 4 - Part No: 1C0959812A
Component: AY Tõrsteuer.HR KLO 0009
2 Faults Found:
01135 - Interior Monitoring Sensors
36-10 - Open Circuit - Intermittent
00928 - Locking Module for Central Locking; Front Driver Side (F220)
27-00 - Implausible Signal
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1M0 035 186 D
Component: Radio 0001
Coding: 00403
Shop #: WSC 06402
VCID: 29591B2FD30CF956E3D-4A9C
1 Fault Found:
00856 - Radio Antenna
36-00 - Open Circuit
End ---------------------------------------------------------------------
hola compañer@s,lo primero deciros que soy nuevo en esto del vagcom,he recibido el cable y he hecho un autoscan,y me pregunto si alguien me pudiera orientar un poco en el resultado,gracias sl2 :ayuda:
mago62
Re: resultado auto scan vagcom
Notapor Abilan el 29 Jun 2016, 00:23
@mago62 si es la primera vez que has echo el scan bora los fallos date una vuelta y pasa otra vez el scan aver que es lo que queda. Con lo que queda se ve lo que hay que arreglar :)
Abilan
Agradecido: 100 veces
Notapor mago62 el 29 Jun 2016, 19:54
gracias abilan en cuanto tenga un rato me pongo,estoy con el dichoso lim mode,a ver si me aclaro un poco con vagcom y le hago un log,lo de los fallos ya me han pasado un listado gracias por contestar :ok:
mago62
Notapor Abilan el 30 Jun 2016, 00:54
@mago62 nada para esto estamos ;)
Abilan
Notapor dashtgn el 01 Jul 2016, 22:53
- Buenas, casualmente tuve estos mismos fallos la primera vez que le pase el VAG COM también, te explico un poco lo que a mi me sucedió:
P1557 - 35-10 - Positive Deviation - Intermittent (Este, el conocido limp mode, caudalimetro, suciedad en los alabes del turbo, N75...) Este es el cuento de nunca acabar. A mi me queda probar con un caudalimetro nuevo pues el turbo ya lo desmonte para limpiarlo y igual. A ratos bien, a ratos mal.
Los otros que te salen en el modulo del cierre centralizado, a mi me ocurria en la puerta trasera derecha, a veces no actuaba el cierre. Tras un tiempo con la puerta bloqueada la conseguí abrir, tire de 3 en 1 y aguanto bien un tiempo, pero al tiempo ocurría lo mismo, fue debido a que el coche tenia la puerta mal encajada, y centrando el cierre que se ubica en la carrocería y que permite a la cerradura bloquear la puerta se solucionó hasta el día de hoy. Si has tenido algún golpe con el coche mira si están bien encuadradas, si no por aquí indicaron 3 en 1 y grasa industrial.
Espero haber sido de ayuda!
Gracias!
dashtgn
Notapor mago62 el 02 Jul 2016, 20:34
dashtgn escribió:- Buenas, casualmente tuve estos mismos fallos la primera vez que le pase el VAG COM también, te explico un poco lo que a mi me sucedió:
Gracias!
gracias por contestar,elprimer fallo ya me lo esperaba el puñetero limp mode ando trasteando como tu a ver si lo puedo solucionar,el segungo ya se el motivo,hise el autoscan con la puerta abierta del copiloto,por novato sl2
mago62
Notapor dashtgn el 02 Jul 2016, 22:18
Gracias!
Del limp mode aqui tienes mucha información, lo primero que se suele descartar es caudalimetro. Cometí el error de comprobar antes el resto con el tiempo que eso supone, y al final limpiando el caudalimetro dejaba de fallar tanto, hasta dia de hoy que cansado de limpiarlo voy a comprar uno nuevo. Por ebay los hay bastante bien de precio sin irte a los 100€ de intercambio.
dashtgn
Usuarios navegando por este Foro: Anthropic, Facebook/Meta/ExternalAgent, Google [Bot] y 29 invitados
