fallo testigo contaminación y calentadores
Notapor seatleon26 el 23 Abr 2011, 15:09
hola buenas,se me encendio de nuevo despues de muxo tiempo el testigo de los calentadores parpadeando y el de la egr,se los he borrado y hasta ahora perfecto,he hexo un autoscan a ver si alguno q entienda me dice algo:
VAG-COM Version: Release 311.2-N
Chassis Type: 1M - Seat Leon
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller: 038 906 012 JJ
Component: 1,9l R4 EDC G000SG 5539
Coding: 00102
Shop #: WSC 06402
VSSZZZ1MZ5R038275 SEZ7Z0D2733368
1 Fault Found:
17970 - Quantity Adjuster (N146): Upper Limit Reached
P1562 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0001025
Shop #: WSC 00001
No fault code found.
Address 08 -------------------------------------------------------
Controller: 1M0 820 043 E
Component: 1M-CLIMATRONIC X0702
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1M0 920 822 D
Component: KOMBI+WEGFAHRSP VDO V06
Coding: 06102
Shop #: WSC 00000
VSSZZZ1MZ5R077319
5 Faults Found:
00779 - Outside Air Temp Sensor (G17)
30-10 - Open or Short to B+ - Intermittent
01312 - Powertrain Data Bus
37-10 - Faulty - Intermittent
01314 - Engine Control Module
49-10 - No Communications - Intermittent
01316 - ABS Control Module
01321 - Control Module for Airbags (J234)
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06402
4 Faults Found:
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 E
Component: 99 Komfortgerát HLO 0004
Coding: 00066
Shop #: WSC 06402
1 Fault Found:
01044 - Control Module Incorrectly Coded
35-00 - -
Address 56 -------------------------------------------------------
Controller: 1M0 035 186 K
Component: Radio GRO 3 30
Coding: 00401
Shop #: WSC 06402
End -------------------------------------------------------
seatleon26
Re: fallo testigo contaminación y calentadores
Notapor Pumuki1986 el 23 Abr 2011, 15:42
el del modulo 46 lo tengo yo tambien en mi leon asv
Pumuki1986
Agradecido: 47 veces
Notapor seatleon26 el 24 Abr 2011, 15:44
vamos compis,dnd estan esos hachas del vag?
seatleon26
