"Averia Motor" el coche se para
Seguidores: txemmmmmm, JoseLu
Notapor JoseLu el 03 Abr 2012, 18:46
Bueno pues es la segund vez que me ha pasado en dos semanas....
Me marca averia, parpadean el testigo de los calentadores y el coche se para.le vuelvo a dar al contacto y arranca.
Al rato de estar el coche en marcha se va la averia....
Le he metido el cable y me canta esto
VAG-COM Version: Release 311.2-N
Chassis Type: 1M - Seat Leon
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller: 038 906 019 KJ
Component: 1,9l R4 EDC G400SG 5256
Coding: 00002
Shop #: WSC 00813
VSSZZZ1MZ4R029048 SEZ7Z0C2158835
1 Fault Found:
16989 - Internal Control Module: ROM Error
P0605 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019970
Shop #: WSC 00001
No fault code found.
Address 08 -------------------------------------------------------
Controller: 1M0 820 043 E
Component: 1M-CLIMATRONIC
Coding: 00043
Shop #: WSC 06402
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1J0 920 826 C
Component: KOMBI+WEGFAHRSP VDO V13
Coding: 07124
Shop #: WSC 00813
WVWZZZ1JZ3B127250
2 Faults Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to B+ - Intermittent
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00046
1 Fault Found:
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 F
Component: AY Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 06402
1 Fault Found:
00928 - Locking Module for Central Locking: Front Driver Side (F220)
27-10 - Implausible Signal - Intermittent
Address 56 -------------------------------------------------------
Controller: 1M0 035 186 K
Component: Radio GRO 3 30
Coding: 01024
Shop #: WSC 00000
1 Fault Found:
01044 - Control Module Incorrectly Coded
35-00 - -
End -------------------------------------------------
haber si alguien me puede echar una mano..puede ser de la repro???
Un saludo y gracias
JoseLu
Agradecido: 24 veces
Re: "Averia Motor" el coche se para
Notapor chinotunero el 03 Abr 2012, 19:01
puede ser que te hayan cargado un archivo que no se corresponde con tu centralita y por eso te de ese error un saludo
chinotunero
Agradecido: 16 veces
Notapor JoseLu el 03 Abr 2012, 19:08
No jodas!!! Jajaja
A ver que nos dicen los genios...
Leon 130cv con 2056, egr off y cata vacío...
JoseLu
Notapor JoseLu el 03 Abr 2012, 23:25
Lo que no me hace gracia es que el coche se pare!!
JoseLu
Notapor txemmmmmm el 03 Abr 2012, 23:27
prueba cn el rele 109 aver si suena la flauta
txemmmmmm
Coche: Leon MK1 1.6 8v 100cv
Agradecido: 48 veces
Notapor JoseLu el 03 Abr 2012, 23:35
Y que hace ese rele??
JoseLu
Notapor ArkikomTdi el 04 Abr 2012, 14:16
Tienes un fallo en la rom,lo dice bien claro, fallo en la centralita.
Mete la de serie y prueba.
ArkikomTdi
Agradecido: 219 veces
Notapor JoseLu el 04 Abr 2012, 18:18
Cargo la de serie un tiempo a ver que me dice??
JoseLu
Notapor Masa5891 el 04 Abr 2012, 18:26
Si, sin duda, ademas tienes otros modulos que no conectan con la centralita.
Ponte la de serie, la que llevas está mal parece ser.
Masa5891
Coche: Leon MK1 1.6 16v 105cv
Agradecido: 71 veces
Notapor txemmmmmm el 04 Abr 2012, 19:33
seguro q te han cargado una repro del mismo coche pero con diferente terminacion de centralita..
ejemplo= fk,hk, kg etc..
txemmmmmm
Notapor chinotunero el 04 Abr 2012, 23:52
txemmmmmm escribió:seguro q te han cargado una repro del mismo coche pero con diferente terminacion de centralita..
por ahi deben de ir los tiros yo me equivoque en la numeracion al cargarsela al mio y el coche funcionaba pero no respondia bien le puse la de su numeracion y todo solucionado otra cosa puede ser que no le hayan corregido el checkssum y por eso no funcione bien un saludo.
chinotunero
Notapor JoseLu el 05 Abr 2012, 10:23
El coche va bien, Pero de vez en cuando salta la averia en el cuadro y el coche se apaga. Le vuelvo a dar al contacto y arranca, sl cabo de unos minutos la averia desaparece del cuadro....
Una buena prueba seria hacer un recode de la mi archivo original??
A ver si no salta la averia..
JoseLu
Notapor JoseLu el 05 Abr 2012, 10:25
Lo de las diferentes letras lo puedo mirar yo mediante vagcom??
JoseLu
Notapor JoseLu el 05 Abr 2012, 16:10
Alguien me puede explicar como hago el recode al archivo original???
JoseLu
Re:
Notapor txemmmmmm el 05 Abr 2012, 16:41
JoseLu escribió:Alguien me puede explicar como hago el recode al archivo original???
pero si te han metido la cartografia de otra centralita por mucho q le pongas de serie el coche seguira fallando...
metete en recode , tienes q cambiar el ultimo numero por 1,2, o 3 segun en q recode este todo cn el contacto dado y do IT.., quitas contacto y vuelves a dar y miras si ha cambiado al recode original del coxe..
PD= pero lo q te digo si te han metido archivo diferente de otra centralita fallara lo mismo de serie q repro..
txemmmmmm
Usuarios navegando por este Foro: AhrefsBot, Anthropic, Bing [Bot] y 17 invitados
