Al arrancar salta luz motor en el cuadro (log vagcom)
NotaPublicado: 15 Jun 2013, 19:31
por Fayt
Hola que tal,mirad llevo 1 mes con esta luz encendida,le he metido el vagcom el coche va bien y me ha salido esto:
Chassis Type: 1M - Seat Leon/Toledo
Scan: 01 02 03 08 15 17 19 22 35 36 37 46 56
VIN: VSSZZZ1MZ5R050136 Mileage: 137790km/85618miles
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019970
Shop #: WSC 00001 001 00001
VCID: 346318E32CFB
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication
Address 08: Auto HVAC Labels: 1M0-820-043.lbl
Part No: 1M0 820 043 E
Component: 1M-CLIMATRONIC X0702
Coding: 00043
Shop #: WSC 06402
VCID: 2443E8A39C1B
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 A
Component: 39 AIRBAG VW51 0A 0008
Coding: 13113
Shop #: WSC 06401
VCID: 224FEEBB860F
Address 17: Instruments Labels: 1M0-920-xx2-17.lbl
Part No: 1M0 920 822 E
Component: KOMBI+WEGFAHRSP VDO V06
Coding: 06104
Shop #: WSC 00409
VCID: 2A5F069BFE3F
VSSZZZ1MZ5R050136 SEZ7Z0D2760870
1 Fault Found:
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06402
VCID: F0EB54F39863
1 Fault Found:
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 F
Component: AY Komfortgerát HLO 0004
Coding: 00258
Shop #: WSC 06402
VCID: 3A7F36DB0E9F
Subsystem 1 - Part No: 1C0959801B
Component: AY Tõrsteuer.FS KLO 0202
Subsystem 2 - Part No: 1C0959802C
Component: AY Tõrsteuer.BF KLO 0202
Subsystem 3 - Part No: 1C0959811A
Component: AY Tõrsteuer.HL KLO 0202
Subsystem 4 - Part No: 1C0959812A
Component: AY Tõrsteuer.HR KLO 0202
End ---------------------------------------------------------------------
Re: Al arrancar salta la luz motor en el cuadro
NotaPublicado: 17 Jun 2013, 19:23
por Fayt
Alguien sabe que puede ser porfavor?
Re: Al arrancar salta luz motor en el cuadro (log vagcom)
NotaPublicado: 17 Jun 2013, 19:49
por ruwencillo
No aparecen los fallos del motor modulo 01(engine 01)
NotaPublicado: 17 Jun 2013, 20:34
por Alanitu
En descargas tienes un PDF con lo ke significa cada error del vagcom
En tu caso, no comunica con la ECU o eso pone.
El coche va bien?????
NotaPublicado: 18 Jun 2013, 08:57
por Fayt
El coche va bien como siempre, he intentado borrarle los fallos pero no se puede, que puedo hacer quito bornes y vuelvo a poner o tengo que mirar otra cosa?
NotaPublicado: 21 Jun 2013, 10:49
por goyodesanctis
Quita la batería una media hora.Debería resetear la misma ECU.En este caso,hay veces que al cambiar la radio de serie,hay que tener mucho cuidado con las conexiones porque fastidian el inmovilizador (repartido entre cuadro y ECU motor) o el módulo confort.Si reseteas,mejor tener el login del cuadro por si pasara algo grave,con lo que necesitarias un software vag k+can commander 1.4.Mira los fusibles a ver el de la ECU,y ya de primeras descartamos.Saludos!
