17987 - Throttle Actuator (J338)
P1579 - 35-00 - Adaptation Not Started
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V!)
P1297 - 35-00-
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28)
P1340 - 35-00- Incor. Correlation
16804 - Catalyst System; Bank 1
P0420 - 35-00- Effciency Below Threshold
17953 - Throttle Valve Controller
P1545 - 35-10 - Malfunction - Intermittent
17579 - Angle Sensor 2 for Throttle Actuator (G188) Implausible Signal
P1171 - 35-00
17950 - Angle Sensor 1 for Throttle Actuator (G187)
P1542 - 35-10 Implausible Signal - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10- - Intermittent
16685 - Cylinder 1
P0301- 35-10 Misfire Detected - Intermittent
16687 - Cylinder 3
P0303- 35-10 Misfire Detected - Intermittent
16688 - Cylinder 4
P0304- 35-10 Misfire Detected - Intermittent
17704- Error in Mapped Cooling System (check Temp-Sensor an Thermostat)
P1296 -35-00
a ver si me pueden echar la mano, este carro me tiene amolado
