BRICO - instalar control presion de neumaticos directo TMPS
Favoritos: gymnos, Daruma, floppy666, rojas, Myvodoo, ismacom, ephreon, Alleya, craken, Marcos90, Danisisa_cupra
Seguidores: Octacon, DavidMK3, Robert_gti, Mago2, sghezz, Mr.Chuflas, daniel_44, mgrondona, javiperfor, MORKAS, msmdraven, Jorge75016, Rasekfighter, marlop, davidbj, nani_san, jmfcoto, Arcangel_89, paco_22_22, picard14, Edu1589, carlosgzlez, JOTTA, elbirlo.dmm, javinho10, Varo_F.f, gecox, aigort, jande, joke2joke, jairin13, Juande667, javierbbs, Warelio, nitro_g4074, sergi303, Dconnect, DiegoR, Jsgarri, VapaV, victor david, volkov, Senuto, Gsclosada, quikeramos1, undernok, Josep20, Maikermx, TripleAnto, Mycupri17, Victorzabal, gymnos, jose.a.llamas, Rotemburgero, trazas, Gendos22, SantiagoSanchez, Vagabundo, MrNiceguy, Romera, 05kar, Raulribarroja, rubendelcano, AlvaroRamlo, josean-opc
Re: BRICO - instalar control presion de neumaticos directo T
Notapor Josep20 el 24 Nov 2020, 14:09
agustin1 escribió:Byte27 Vehicle Equipment Byte Information
Bit 0 VAQ Installed
Bit 1 PLA2 w/ Braking Intervention Installed
Bit 2~3 Dynamic Start Assist
Bit 4~6 TPMS Configuration======================> Bit 4, 5, & 6 unchecked Without TPMS (PR. 7K0) OR TPMS High (PR. 7K3)
Bit 7 DCC Installed Bit 5 checked TPMS (PR. 7K9) w/o Radio (PR. 8AA)
Bit 4 & 5 checked TPMS (PR. 7K9) w/ Radio (PR. I8A/I8B/I8D/I8E/I8H)
Bit 4 & 6 checked TPMS (PR. 7K6) w/ Radio (PR. I8A/I8B/I8D/I8E/I8F/I8H)
Bit 5 & 6 checked TPMS (PR. 7K1) w/o Radio (PR. 8AA)
Bit 4, 5 & 6 checked TPMS (PR. 7K1) w/ Radio (PR. I8A/I8B/I8D/I8E/I8H)
Byte28
Bit 0~1 Driver Out Apply Version. (Possibly EPB related)
Bit 2 Autohold turn on message
Bit 3 Forward Collision Warning Pedestrian
Bit 4 BAP - Autohold
Bit 5 BAP - Hill Descent Control
Bit 6 BAP - ESC Button
Bit 7 BAP - TPMS button (PR. 7K1, 7K6, 7K9)
Acabo de ponerlo como estaba, ahora ya me va como antes, sin querer había desmarcado el bit 3 del byte 27, menos mal que está lo del historial ImagenImagen
Enviado desde mi Mi A2 Lite mediante Tapatalk
Seat León Mk3 ST 1.4 TSI FR Advanced 150cv Rojo Desire
Josep20
Agradecido: 83 veces
Notapor Josep20 el 24 Nov 2020, 14:11
Y ya he metido el XML con odis e para poner la presión que quiero en cada modo ImagenImagenImagen
Josep20
Notapor plus el 26 Nov 2020, 09:19
rojas escribió:Hola a todos , os dejo otro brico para quien se quiera animar , es muy facil ya que solo tiene 4 cables ( positivo , masa , linea can extended ). Se trata del control de presion de neumaticos , actualmente de fabrica sale con este sistema de forma indirecta a traves de los sensores ABS , cuando nota una irregularidad en la circunferencia te salta el aviso , lo que vamos hacer es algo completamente diferente , es un sistema directo , con una antena que es la centralita , y 4 sensores , uno en cada rueda , que va mandando informacion continuamente a la antena y se visualiza en el fis
¿Habría alguna pega en rotar los neumáticos de alante a atrás y viceversa sin tener el nuevo sistema instalado? ¿no requiere ningún tipo de codificación? Iba a realizarlo este fin de semana y me entró la duda.Gracias
plus
Agradecido: 36 veces
Notapor agustin1 el 26 Nov 2020, 15:10
si llevas el sistema de monitoreo por ABS creo que no hay problema y con este creo que tampoco pues detecta los sensores por la distancia del modulo.
agustin1
Notapor dmesanun el 26 Nov 2020, 21:16
Hola
Lo llevaba instalado en mi antiguo MK3, es de lo más útil que se puede poner a un coche junto a la cámara trasera, ahora lo hecho mucho de menos en mi MK4, supongo que hablar de instalar este sistema TMPS en el MK4, por ahora es sólo un sueño ¿Verdad?
dmesanun
Agradecido: 197 veces
Notapor stewei el 27 Nov 2020, 12:07
Sin problema. Yo no llevo (por desgracia, aún...) este sistema directo, y yo roto los neumáticos cada revisión y sin problema :ok:
stewei
Agradecido: 465 veces
Notapor serpasoria el 07 Feb 2021, 20:12
Muy buenas .
Estoy interesado en este brico para hacerlo en el Octavia MK3, pero se han caido las fotos del principio, las podrian volver a subir ??
Y para codificar , es suficiente el obd11/vagcom ???
serpasoria
Notapor agustin1 el 08 Feb 2021, 16:49
serpasoria escribió:Muy buenas .
en la pagina 8 tienes las fotos y la explicación de la instalación
agustin1
Notapor serpasoria el 14 Feb 2021, 20:22
Muchas gracias niño , voy a ver !!! :comediante:
serpasoria
Notapor serpasoria el 24 Feb 2021, 22:17
He revisado todo el hilo y no he encontrado ese post , te importa ponerme enlace directo .....
Estoy tonto ...... lo se .....
serpasoria
Notapor Octacon el 24 Feb 2021, 23:18
https://r.tapatalk.com/shareLink/topic? ... source=app
Octacon
Agradecido: 95 veces
Notapor OSCAR77 el 25 Feb 2021, 22:39
Alguien para hacerlo en Barcelona?
OSCAR77
Agradecido: 15 veces
Notapor javichuchacho el 26 Feb 2021, 12:17
OSCAR77 escribió:Alguien para hacerlo en Barcelona?
Tienes a vagretrofits, unos profesionales!!!
Enviado desde mi SM-N986B mediante Tapatalk
javichuchacho
Agradecido: 168 veces
Notapor OSCAR77 el 26 Feb 2021, 19:40
Ya pero buscava unos precios mas normales, tienen unas tarifas por las nuevos...
OSCAR77
Notapor Romera el 26 Feb 2021, 22:30
Mándame privado, tengo taller propio y me dedico a hacer estas cosas, estamos en Ripollet, próximamente seré empresa colaboradora del foro y tendré descuentos para socios del foro.
Enviado desde mi Mi 10 mediante Tapatalk
Romera
Agradecido: 328 veces
