BRICO - instalar control presion de neumaticos directo TMPS
- Seguidores: 65
- Favoritos: 11
- Vistas: 64.945
Favoritos: gymnos, Daruma, floppy666, rojas, Myvodoo, ismacom, ephreon, Alleya, craken, Marcos90, Danisisa_cupra
Seguidores: Octacon, DavidMK3, Robert_gti, Mago2, sghezz, Mr.Chuflas, daniel_44, mgrondona, javiperfor, MORKAS, msmdraven, Jorge75016, Rasekfighter, marlop, davidbj, nani_san, jmfcoto, Arcangel_89, paco_22_22, picard14, Edu1589, carlosgzlez, JOTTA, elbirlo.dmm, javinho10, Varo_F.f, gecox, aigort, jande, joke2joke, jairin13, Juande667, javierbbs, Warelio, nitro_g4074, sergi303, Dconnect, DiegoR, Jsgarri, VapaV, victor david, volkov, Senuto, Gsclosada, quikeramos1, undernok, Josep20, Maikermx, TripleAnto, Mycupri17, Victorzabal, gymnos, jose.a.llamas, Rotemburgero, trazas, Gendos22, SantiagoSanchez, Vagabundo, MrNiceguy, Romera, 05kar, Raulribarroja, rubendelcano, AlvaroRamlo, josean-opc
Re: BRICO - instalar control presion de neumaticos directo T
Hello,I used this part and soldered it on the tip of the positive cable of the TPMS RDKS kit, and applied a 10A fuse and plugged it into the lighter's positive, it turns off when you remove the ignition contact key.
Nelson Pirez - Leoner@ habitual
- Agradecido: 109 veces
Nelson Pirez escribió:Hello,I used this part and soldered it on the tip of the positive cable of the TPMS RDKS kit, and applied a 10A fuse and plugged it into the lighter's positive, it turns off when you remove the ignition contact key.
The picture doesn't seem to load for me, could you reupload it?
EDIT: Nevermind it loaded. Thank you very much!
MrNiceguy - Nuev@ por aqui
Romera escribió:Buenas.
Yo compro las unidades tpms en la vw directamente con hardware num 5Q0907273 y versión de hardware H06 con software 5Q0907273B y actualizo al software 5Q0907273D versión 0010, para el león va perfecto.
Enviado desde mi Mi 10 mediante Tapatalk
Buenas¡ Consulta rápida, los parámetros te marcan presiones distintas detras que adelante ? No consigo que me ponga una presión distinta. Podrías echarme una mano con eso ? un saludo
aigort - Leoner@ habitual
- Agradecido: 52 veces
So I connected everything and coded according to Xagico's manual so far so good.
The only problem I am having is that the antenna doesn't get a signal from the plugs, I have a permanent fault code "C111A31" in module 65.
Now I don't know if the sensors are just broken or that I'm missing some coding steps. I must say that I did buy cheap sensors, these are the ones that I bought: https://nl.aliexpress.com/item/1005001408241269.html?spm=a2g0s.9042311.0.0.3c004c4dvymQgh
Any help would be much appreciated!
Se trata de un archivo XML qué he generado específico para mi coche, con los valores que deseo llevar. Estos archivos solo son posibles cargarlos con ODIS.aigort escribió:Romera escribió:Buenas.
Es el archivo de parametrización.
Romera - Aqui + que con la novi@
- Agradecido: 328 veces
Compi , ya sé que son unos parámetros. Pero te pregunto por si tus parámetros marcan presión distinta en las ruedas delanteras y las traseras. Yo también tengo unos específicos para mi coche y es posible cargarlos con ODIS y VCP hay dos formas en las que se pueden generar esos archivos. Por lo menos como lo hago yo.Romera escribió:Se trata de un archivo XML qué he generado específico para mi coche, con los valores que deseo llevar. Estos archivos solo son posibles cargarlos con ODIS.aigort escribió:Romera escribió:Buenas.
Vaaalee vale vale, sí, tengo una aplicación que pongo las medidas deseadas de neumáticos así como cada neumático que presiones llevará.aigort escribió:Compi , ya sé que son unos parámetros. Pero te pregunto por si tus parámetros marcan presión distinta en las ruedas delanteras y las traseras. Yo también tengo unos específicos para mi coche y es posible cargarlos con ODIS y VCP hay dos formas en las que se pueden generar esos archivos. Por lo menos como lo hago yo.Romera escribió:Se trata de un archivo XML qué he generado específico para mi coche, con los valores que deseo llevar. Estos archivos solo son posibles cargarlos con ODIS.aigort escribió:Romera escribió:Buenas.
Hay programas que no consiguen marcar la misma presion en los neumaticos de delante y de atras, yo consegui un programa que si me marca diferentes presiones, si quereis hos lo paso.aigort escribió:Compi , ya sé que son unos parámetros. Pero te pregunto por si tus parámetros marcan presión distinta en las ruedas delanteras y las traseras. Yo también tengo unos específicos para mi coche y es posible cargarlos con ODIS y VCP hay dos formas en las que se pueden generar esos archivos. Por lo menos como lo hago yo.Romera escribió:Se trata de un archivo XML qué he generado específico para mi coche, con los valores que deseo llevar. Estos archivos solo son posibles cargarlos con ODIS.aigort escribió:Romera escribió:Buenas.
Octacon - Leoner@ avanzad@
- Agradecido: 95 veces
Si al alguno de los dos puede hablarme por privado y decirme el programa que usa os lo agradecería. A ver si es distinto al míoOctacon escribió:Hay programas que no consiguen marcar la misma presion en los neumaticos de delante y de atras, yo consegui un programa que si me marca diferentes presiones, si quereis hos lo paso.aigort escribió:Compi , ya sé que son unos parámetros. Pero te pregunto por si tus parámetros marcan presión distinta en las ruedas delanteras y las traseras. Yo también tengo unos específicos para mi coche y es posible cargarlos con ODIS y VCP hay dos formas en las que se pueden generar esos archivos. Por lo menos como lo hago yo.Romera escribió:Se trata de un archivo XML qué he generado específico para mi coche, con los valores que deseo llevar. Estos archivos solo son posibles cargarlos con ODIS.aigort escribió:Romera escribió:Buenas.
Un saludó
Estáis hablando de un programa que modifica el xml y luego con el odis lo metes y taca a comer?
Enviado desde mi SM-N986B mediante Tapatalk
javichuchacho - Aqui + que con la novi@
- Agradecido: 168 veces
Si, el mismojavichuchacho escribió:Estáis hablando de un programa que modifica el xml y luego con el odis lo metes y taca a comer?
Última edición por Octacon el 21 Jun 2021, 22:53, editado 1 vez en total
Solucionado
Buenas, alguien que lo haya hecho con el Kit de Aliexpress?? Que tal resultado da?? Hay que cortar algún cable para empalmar lo del Can High y Low??
Algún requisito necesario en el coche para que funcione?? Es un 2019.
Gracias.
Edit: Creo que se necesita una unidad "High", ¿es así? Si es así creo que no la tengo, en mi versión pone H50, a ver si alguien me puede decir.
¿Cuanto cuesta cambiarlo para que sea high?
Gracias.
RSCupra - Leoner@ habitual
- Agradecido: 36 veces
RSCupra escribió:Buenas, alguien que lo haya hecho con el Kit de Aliexpress?? Que tal resultado da?? Hay que cortar algún cable para empalmar lo del Can High y Low??
Gracias.
Yo he montado el de AliExpress en un MY19 y no he tenido problema. Según tengo entendido no es necesario tener unidad high, la tuya te debe servir sin problema.
Para el cableado yo no corté ningún cable del coche, usé el cableado canbus del conector blanco que hay donde está el tirador del capó.
La instalación no es muy complicada, llevas los cables hasta el tirador del capó, conectas las líneas can y de ahí mismo de la caja de fusibles sacas la corriente, yo use un roba fusible.
Ojo, el chino te lo manda con unos parámetros genéricos, para que se muestren las presiones correspondientes a tu coche deberás cargarle unos nuevos parámetros con ODIS.
Enviado desde mi Mi A3 mediante Tapatalk
mgrondona - Leoner@ habitual
- Agradecido: 112 veces
Encuesta - Que tipo de Gasoil utilizais Foro: General Autor: pirly Respuestas: 298 |
Manchas de alquitrán en la pintura Foro: Autolavado y limpieza general Autor: Martinastut Respuestas: 2 |
Perdida de potencia motor y Limp Mode!!! Foro: Leon I - Mecánica / Electricidad / Electrónica Autor: Paranohia Respuestas: 1 |
Manual de taller Foro: General Autor: JesusEli Respuestas: 99 |
Usuarios navegando por este Foro: Anthropic, Facebook/Meta/ExternalAgent, Google [Bot] y 13 invitados
