BRICO Alarma (Vigilancia habitáculo e inclinación)
Favoritos: Sdocid, Alleya, little bastard, craken, Fleicar, Wisa, Alexlopezsk
Seguidores: jose.a.llamas, Arcangel_89, kijute, aigort, Jorge75016, jande, joke2joke, osjamil, Fonek, Edu1589, ertate, javierbbs, Montydaka, Gus_Fring, carlosgzlez, Gendos22, chetelopez, Davido2790, nitro_g4074, dekompeti, Josep20, TripleAnto, Flow-Rider, marlop, Romera, Octacon, Hovig, M_Riol, Warelio, Mr.Chuflas, danieleon
Re: BRICO Alarma (Vigilancia habitáculo e inclinación)
Notapor Romera el 24 Jun 2023, 21:23
davidrb89 escribió:Buenas,
He conseguido que desaparezca el error, para ello, he desactivado todas las activaciones referentes a la alarma en la 09 y he vuelto a activar las que tenía, quedando así:
Código: Seleccionar todo
IDE04928-ENG115867 - Anti-theft protection - Akusticher Alarm signalhorn; Active
IDE04928-ENG115864 - Anti-theft protection - Alarmsignal; Frecuency Modulated
IDE04928-ENG115867 - Anti-theft protection - Alarm System; Active
IDE04928-ENG154588 - Anti-theft protection - Deaktivierung dwa sensoren via doppelklick; Active
IDE04928-ENG154589 - Anti-theft protection - Deaktivierung dwa sensoren hmi; Active
IDE04928-ENG115865 - Anti-theft protection - Dwa alarmverzoegerung; Driver Door Contact thatcham
IDE04928-ENG115812 - Anti-theft protection - Dwa camper modus; Not Active
IDE04928-ENG142007 - Anti-theft protection - Dwa einfachhorn oder sounder; Horn_verbaut
IDE04928-ENG141961 - Anti-theft protection - Heickscheibenbruchsensor; Not Installed
IDE04928-ENG142249 - Anti-theft protection - OBD Alarm; Not Active
IDE04928-ENG154722 - Anti-theft protection - RHF Panikalarm; Not Active
IDE04928-ENG142010 - Anti-theft protection - Schiliesszylinder in richtung oeffen aktiv; Yes
IDE04928-ENG115866 - Anti-theft protection - Sirenen Alarmzahl; 10 Alarme
IDE04928-ENG142008 - Anti-theft protection - Tilt sensor; Yes
IDE04928-ENG126842 - Anti-theft protection - Ueberwauching Innenentriegelungshebel; Not Active
IDE04928-ENG115868 - Anti-theft protection - Verozoegerung Panikalarm; Keine Verzoegerung
Por arte de magia, el error ha desaparecido y permite que salten los volumétricos interiores, ahora sólo me queda un pequeño problema, que es hacer que suene el claxón, ya que cuando salta, parpadean los intermitentes, pero no suena, ¿alguien sabe cual es la configuración correcta?
Agradecer también a todos los que me estáis ayudando, en especial a @Octacon, que me ha estado ayudando :)
Haz el brico alarma gratis que hay, el que hace saltar alarma cuando se abren las puertas.
Con eso tendrás resuelto.
Romera
Agradecido: 328 veces
Notapor davidrb89 el 25 Jun 2023, 08:37
Romera escribió:Haz el brico alarma gratis que hay, el que hace saltar alarma cuando se abren las puertas.
Gracias @Romera, en efecto, con eso me ha servido para que suene el cláxon.
Pongo los parámetros que en mi caso (MY19) he tenido que modificar con VCDS para que funcionase, por si puede servir en un futuro:
Muchas gracias a todos por la ayuda!
davidrb89
Notapor kike_j el 13 Abr 2024, 15:27
otro my19 por aquí activado! Gracias por el resumen davidrb89. Puntualizar que en mi FR la ENG142007, que es el oder sounder, para que suene por la bocina del coche tuve que poner NO instalada, con eso empezó a pitar tanto con los sensores como los pitidos de cierre / apertura. Lo de corto o normal no me funcionó, siempre suena igual.
En este ya me venia el claxon activo sin contacto, pero indicar que también existe el parámetro a revisar ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15.
kike_j
Coche: Leon MK3 2.0 TSI 190cv
Notapor Cachorro el 12 May 2025, 18:43
Sdocid escribió:Hola chicos. Pues al fin he tenido tiempo de hacer el Brico completo, y resulta que como no podía ser de otra manera tengo un pequeño problema.
Me sale fallo de comunicación con el sensor de movimiento e inclinación (o sea los volumétricos).
He comprovado los cables el voltaje y demás y todo ok.
Lo único que tengo diferente es en el modelo de voluméteicos que venían en el plafón que compre es de VW y no de Seat. O sea que en vez del modelo Sensor volumétrico e inclinación Seat (5Q0 951 171) es el Sensor volumétrico e inclinación VW (1K8 951 171).
La programación la hice con OBDELEVEN y todo esta ok, pero lo que no se es si ese fallo es por falta de parameteización de los voluméteicos (ya sea en taller o con el Vag com Pro...etc) para que funcionen o de lo contrario esos no sirven y tendré que comprar los que son específicos para nuestro Seat.
Haber si hay alguien.. dígase @Rojas @miceor @Javichuchacho @cvillajos o cualquier otro de los que nos salvan el culo siempre que sepa algo y me puede ayudar a aclarar el tema y dejarlo funcionando.
Pd: Resto de alarma funciona ok, el único fallo es la comunicación con los volumétricos.
Buenas! Podrias decirme la codificación con obdeleven? Tengo todo instalado a falta de codificar y buscando me he dado cuenta que no esta publicada en el hilo
Cachorro
Usuarios navegando por este Foro: Anthropic, Semrush y 20 invitados
