Leon mk3 problems with retrofit rear pdc / ops
Hi!
First have to say, I´m sorry to write in English because I don´t understand or speak Spanish...
Hope you dont´t mind!
So my issue is that I bought rear PDC/OPS parking retrofit kit from cars-equipment.com
Now I have installed the kit and everything else is should be ok, but can´t get any kind of signal to head unit screen?!?
So those beeping sounds work fine, but those optical "lines" doesn´t show up.
I have made coding according marlop´s guide for installation... so park/steer assist has added in can-gateway installation list and 10-park/steer assist has coding 0000050001 at the moment... so I have Leon without camera, without acc and manual gearbox. I also activated those three options in 5F-Infotainment> Adaptation.
So everthing seems to be ok, but still that ops doesn´t work...
I have full auto-scan from vcds if someone wants to see that and also adaptation list from 5f module...
That autoscan shows no error in any module.
Control module which came with that kit is 5Q0919283F.... so I think it is newer version than in marlop´s guide... could that be a problem? And that module was a new one, but I got it coded I think
In 10-Park/steer assist module in vcds in long coding helper has two options for BAP... version 3.3 and version 4.0.... Only coding for v. 4.0 works... if I try to change coding for BAP v. 3.3 it says "request out of range" and can´t be coded.... could that be a problem?? If that control module is too new and it needs BAP v. 4.0 but my car is older and needs v. 3.3..... Those are my thoughts only because this seems to be very weird...
Thanks in advance if someone could help me in any way!!
And greetings from Finland!!!
