fallos vag
fallos vag
Notapor pakito_lopez el 11 Abr 2010, 19:24
hola amigos le pasado el cable al ibiza de mi hermana porque vibra muchisimo el coche y le sale el pilotito del motor haber que podria ser gracias de antemano... digo no abria forma de ponerlo en español??? gracias y aqui dejo el scan:
VAG-COM Version: Release 311.2-N
Chassis Type: 6L - Seat Ibiza
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 01 -------------------------------------------------------
Controller: 03E 906 033 D
Component: 1,2l/4V SIMOS3 00HS4342
Coding: 00061
Shop #: WSC 06402
VSSZZZ6LZ2R018887 SEZ7Z0A1480328
1 Fault Found:
16686 - Cylinder 2 Misfire Detected
P0302 - 35-00 - -
Readiness: 1110 0101
Address 08 -------------------------------------------------------
Controller: 6L0 820 045
Component: Klimaanlage X0840
6 Faults Found:
00818 - Sensor for Evaporator Outlet Temperature (G263)
30-00 - Open or Short to B+
01271 - Positioning Motor for Temperature Flap (V68)
30-10 - Open or Short to B+ - Intermittent
01596 - Motor for Outside/Recirculated Air Flap (V154)
28-10 - Short to B+ - Intermittent
41-10 - Blocked or No Voltage - Intermittent
29-10 - Short to Ground - Intermittent
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049 B
Component: BORDNETZ-SG. 1S31
Coding: 16412
Shop #: WSC 06402
2 Faults Found:
01598 - Drive Battery Voltage
07-10 - Signal to Low - Intermittent
00907 - Intervention load Management
35-00 - -
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6L0 920 801
Component: KOMBI+WEGFAHRSP VDO V07
Coding: 00137
Shop #: WSC 00000
No fault code found.
Address 19 -------------------------------------------------------
Controller: 6N0909901
Component: Gateway K<->CAN 1S31
Coding: 00012
Shop #: WSC 06402
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 L
Component: LenkhilfeKYO V710
Coding: 00111
Shop #: WSC 06402
Controller: 6Q0 959 433 E
Component: 59 Komfortgerát 0001
Coding: 00067
Shop #: WSC 06402
1 Fault Found:
01179 - Incorrect Key Programming
35-00 - -
Address 56 -------------------------------------------------------
Controller: 6L0 035 152
Component: seat s04 GRO 0 67
Coding: 00201
Shop #: WSC 06402
End -------------------------------------------------------
pakito_lopez
Coche: Leon MK1 1.6 16v 105cv
Re: fallos vag
Notapor xylen2 el 11 Abr 2010, 22:16
pakito_lopez escribió:hola amigos le pasado el cable al ibiza de mi hermana porque vibra muchisimo el coche y le sale el pilotito del motor haber que podria ser gracias de antemano... digo no abria forma de ponerlo en español??? gracias y aqui dejo el scan:
Coding: 00061
Shop #: WSC 06402
1 Fault Found:
P0302 - 35-00 - -
Supongo que es un gasolina, según la wiki es un fallo en el bobinado del 2 cilindro.
pakito_lopez escribió:Address 08 -------------------------------------------------------
6 Faults Found:
Los intermitentes los borraría pero el sensor g263 te va ha tocar cambiarlo, por lo menos en mi coche va justo encima de la radio en la parte de atras, en el ibiza NPI
pakito_lopez escribió:Address 09 -------------------------------------------------------
Coding: 16412
Shop #: WSC 06402
2 Faults Found:
35-00 - -
Estos si no me equivoco son del bateria, borrarlos tranquilamente.
Un Saludo
SEAT Toledo TDI Final Stage
Powered By BND UNLIMITED
xylen2
Agradecido: 184 veces
Re: fallos vag
Notapor pakito_lopez el 12 Abr 2010, 01:16
gracias tio
pakito_lopez
