Hola muy buenas, tengo una duda, esta mañana he conectado el VAG-COM para que me dijero el problema que tengo con el AIRBAG, y el resultado ha sido este:
VCDS Version: Release 805.0
Data version: 20080625
Friday,06,August,2010,11:52:22:26365
Chassis Type: 1M - Seat Leon/Toledo
Scan: 01 02 03 08 15 17 19 22 35 36 37 46 56
VIN: VSSZZZ1MZ4R014245 Mileage: 175520km/109063miles
Address 01: Engine Labels: 038-906-019-ARL.lbl
Part No: 038 906 019 HK
Component: 1,9l R4 EDC G400SG 1492
Coding: 00002
Shop #: WSC 06402
VSSZZZ1MZ4R014245 SEZ7Z0C2135343
No fault code found.
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019970
Shop #: WSC 00001 001 00001
Address 08: Auto HVAC Labels: 1M0-820-043.lbl
Part No: 1M0 820 043 E
Component: 1M-CLIMATRONIC X0702
Coding: 00043
Shop #: WSC 06402
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 A
Component: 39 AIRBAG VW51 0A 0008
Coding: 13113
Shop #: WSC 06441
1 Fault Found:
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
36-10 - Open Circuit - Intermittent
Address 17: Instruments Labels: Redir Fail!
Part No: 1M0 920 822 E
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 05124
Shop #: WSC 00000
Address 19: CAN Gateway Labels: 6N0-909-901.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06402
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 F
Component: AY Komfortgerát HLO 0003
Coding: 00257
Shop #: WSC 09026
Part No: 1C1959801A
Component: AY Tõrsteuer.FS KLO 0202
Part No: 1C1959802A
Component: AY Tõrsteuer.BF KLO 0202
Part No: 1C0959811A
Component: AY Tõrsteuer.HL KLO 0202
Part No: 1C0959812A
Component: AY Tõrsteuer.HR KLO 0202
2 Faults Found:
01030 - Central Locking Key Switch; Driver Side; Lock
29-00 - Short to Ground
00934 - Electric Window Motor; Rear Left (V26)
35-10 - - - Intermittent
End ---------------------------------------------------------------------
Si alguien me puede echar una mano para interpretarlo, porque veo que tengo dos problemas, y como poder solucionarlo.
Y la Duda que tengo al rato de usar el VAG-COM a la hora más o menos me ha dejado de funcionar las dos pantallitas que tenemos en el cuadro, puede ser debio a algo que he tocado con el VAG-COM??
Gracias a todos.
Duda sobre el VAG-COM
4 mensajes
- Vistas: 388
JOSETE - Mi Leon me tiene miedo
- Agradecido: 91 veces
hugofr - Mi Leon me tiene miedo
- Agradecido: 29 veces
Re: Duda sobre el VAG-COM
Josete, creo que no eres nuevo y mas o menos te sabras las normas.. No deberias andar duplicando post asi que dime si quieres que cerremos el de mecanica y dejar este o al contrario..
Saludos..
Saludos..
carbu - Cansin@ de los leones
- Agradecido: 69 veces
Como te ha comentado Carbu, no deberías abrir los mismos posts en varias secciones...
Cierro este ya que en el otro es donde mas respuestas te han dado, y porque el error NO es algo de vagcom, sino de "mecánica / electricidad" (aunque lo hayas descubierto con el Vagcom)
saludos,
saludos,
BhEaN - Staff Admin
- Imágenes: 35
- Agradecido: 1577 veces
4 mensajes
No funciona el ventilador del habitáculo Foro: Leon I - Mecánica / Electricidad / Electrónica Autor: javi23 Respuestas: 1 |
Nuevo por el forito Foro: Presentaciones Autor: BPA13 Respuestas: 2 |
sobre señales de trafico en Fis MK3 Foro: Informática / Interfaces / Diagnosis Autor: rojas Respuestas: 1085 |
Se me ha destensado el tensor en motor BKD Foro: Leon II - Mecánica / Electricidad / Electrónica Autor: gabrielorellana377 Respuestas: 0 |
Saber si el coche está al dia de campañas Foro: General Autor: LeidenSpain Respuestas: 5 |
Usuarios navegando por este Foro: Anthropic, Majestic-12 [Bot] y 4 invitados
