Ayuda con fallos
Seguidores: samuelss
Ayuda con fallos
Notapor samuelss el 12 Ago 2010, 22:10
Hola a todos, desde hace una temporadilla me aparecen estos fallos y no se de que pueden ser y hoy fui a la Seta y no me alludaron en nada, simplemente me dijeron que no se podian borrar.
Thursday,12,August,2010,21:14:04:46862
VCDS Version: Beta 912.0
Data version: 20091201
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: VSSZZZ1PZ9R049158 Mileage: 36520km/22692miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
Address 01: Engine Labels: Redir Fail!
Part No SW: 03G 906 056 AA HW: 03G 906 021 AB
Component: R4 1,9L EDC G000SG 2898
Revision: --H09--- Serial number: SEX7Z0I131G048
Coding: 0050071
Shop #: WSC 03735 807 96506
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Coding: 113B201209260003880C04E9902100413400
Shop #: WSC 04941 000 00000
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1P0 907 044 D
Component: ClimatronicPQ35 011 0702
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000009333196
Coding: F1885FAF00041000535D0000320000800001FF0F5C00080C000000000000
Shop #: WSC 07070 781 175406
Part No: 1P0 955 119 B
Component: Wischer 160109 022 0601
Coding: 00056208
Shop #: WSC 07070
Part No: 1P0 955 559
Component: REGENLICHTSENSORH01 X010
Coding: 00137517
Shop #: WSC 07070
1 Fault Found:
02390 - Control / Regulation for Ambience Lighting (E400)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 189
Mileage: 36524 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.20 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__A01 VW10 HI 1815
Revision: 19013000 Serial number: 0039DP0F0SMT
Coding: 0012337
Shop #: WSC 06402 785 00200
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BK HW: 1K0 953 549 BK
Component: J0527 051 0101
Coding: 0002042
Part No: XXXXXXXXXXX
Component: E0221 002 0010
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
014 - Defective
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1P0 920 807 L
Component: KOMBIINSTRUMENT VO3 0952
Coding: 0702101
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K0913105B2
Coding: E9801F06000202000202
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO VO3 0952
Address 42: Door Elect, Driver Labels: None
Part No SW: 1T0 959 701 K HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1505
Revision: 72009005 Serial number: 00000273688820
Coding: 0000048
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.065 H08 1901
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 CP
Component: KSG 0401
Coding: 98D000CC7F008F0F484B012004CC
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: None
Part No SW: 1T0 959 702 K HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1505
Revision: 72009005 Serial number: 00000263588811
Coding: 0000048
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1P1 035 186 B
Component: Radio BVX 0007
Coding: 0040404
Shop #: WSC 07070 781 75406
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
End ---------------------------------------------------------------------
Y aqui os adjunto unos pantallazos que hice de la configuración del sensor, limpia y centralita.
Espero vuestras soluciones urgentemente si alguien me puede ayudar.
samuelss
Re: Ayuda con fallos
Notapor hugofr el 14 Ago 2010, 12:11
Has toqueteado algo?
Un V6 con tracción integral
hugofr
Agradecido: 29 veces
Notapor samuelss el 15 Ago 2010, 03:16
pues en su dia le active las luces diurnas, cornering, le instale el sensor de luces y lluvia y me iva todo bien pero hace un mes +- cambie el cable y le hice un autoscan despues de intentar activar el leavin y el conmin home y me aparecio esto y en la seta no me dan solución, decir que mi leon es un 1.9 105 ecomotive y es un my 09 pre-restylin.
samuelss
Notapor hugofr el 15 Ago 2010, 13:11
Borra todos los errores, y vuelve a hacerle un scan.
En cuanto a lo que has modificado, si no te ha funcionado has vuelto a dejar los bits como los habias encontrado?
El tema de la radio, si haces el scan con ella apagada en ocasiones sale el Status Malfunction, ya que a mi me tiene pasado.
Lo que no me gusta, es el tema de la direccion asistida, asi comenzo el mio, y hubo que sustituirle la famosa caja de direccion que a la larga daba fallo, y creo que el tuyo no se va a librar, porque aun lleva la antigüa GII, al igual que cuando compre el mio.
hugofr
Notapor samuelss el 15 Ago 2010, 19:01
provare a volver a dejar todo como estaba antes de toquetearlo y haber que pasa.
gracias
samuelss
