Monday,23,January,2012,18:47:32:10074
VCDS Version: Beta 11.2.0
Data version: 20110305
Chassis Type: 7N0
Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 56 62 72
VIN: VSSZZZ1PZBR074692
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (BK2-CAXC) Labels: None
Part No SW: 03C 906 016 AP HW: 03C 906 016 AP
Component: 1.4l R4/4V TS H12 8179
Revision: LCH12--- Serial number:
Coding: 00190012002400000000
Shop #: WSC 06402 785 00200
ASAM Dataset: EV_ECM14TFS01103C906016AP 001006
ROD: EV_ECM14TFS01103C906016AP.rod
VCID: 6DD5CD870F51
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 113B4012092900FE881102ED901B0040350800
Shop #: WSC 04941 000 00000
VCID: 76E7E2EB7A07
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5P0 907 044 P HW: 5P0 907 044 P
Component: Climatronic H15 0702
Revision: 00001001
Coding: 0000000002
ASAM Dataset: EV_Climatronic A01006
ROD: EV_Climatronic_SE35.rod
VCID: 3D753DC71FB1
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 086 J HW: 5K0 937 086 J
Component: BCM PQ35 M 011 0048
Revision: BC011001
Coding: 46180A3E8025B0C0428800809500810442519DA8427D89605C8040000040
Shop #: WSC 07900 781 97356
VCID: 3B7133DF01A5
Subsystem 1 - Part No: 1P0 955 119 C
Component: Wischer 27041 22 0611
Coding: 00DB90
Subsystem 2 - Part No SW: 1P0 955 559 A HW: 1P0 955 559 A
Component: REGENLICHTSEN H04 0003
Coding: 02542E
Subsystem 3 - Part No: 1P0 951 171
Component: Innenraumuebe 010 4971
Coding: 000000
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Coding: 000000
1 Fault Found:
01135 - Interior Monitoring Sensors
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 56
Reset counter: 251
Mileage: 1619 km
Time Indication: 0
Date: 2003.14.15
Time: 11:51:01
Freeze Frame:
Term 15 Off
Voltage: 12.55 V
OFF
ON
OFF
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels: None
Part No SW: 5P0 919 475 B HW: 5P0 919 475
Component: PARKHILFE 4K H07 0005
Revision: -------- Serial number: 89341109214569
Coding: 000001
VCID: 3A7F36DB0E9F
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 R HW: 5N0 959 655 R
Component: J234__A0A VW10 HI 1918
Revision: 22014000 Serial number: 003K0P7SX6XQ
Coding: 0012353
VCID: 4C936003540B
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 521 BN HW: 5K0 953 569 E
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20110421300164
Coding: 1082140002
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: N/A
VCID: 79FDE9D74B19
Subsystem 1 - Part No SW: 1P0 959 538 D HW: 1P0 959 538 D
Component: E221__MFL-TAP H02 0102
Coding: E20000
No ASAM data for: "EV_SMLSNGVOLWSXS" (SE35)
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 1P0 920 850 F HW: 1P0 920 850 F
Component: KOMBI H06 0420
Serial number: 00000000000000
Coding: 110B00
Shop #: WSC 131071 1023 2097151
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 2F69178FC5DD
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 150411F2000503
Coding: 350202
VCID: 306B14F3D8E3
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H06 0420
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_SE35.rod
VCID: EADF469BBEBF
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
Component: SG EXT.PLAYER H13 0150
Revision: A1001003 Serial number: 7669863380
Coding: 010000
VCID: 285BFC93E033
Address 37: Navigation (J794) Labels: 3C0-035-270.clb
Part No SW: 5P0 035 191 D HW: 5P0 035 191 D
Component: RNS315 H05 0010
Serial number: SEZAZ2L9128383
Coding: 040004010402000000000000
ASAM Dataset: EV_RNS315SeatEUV1UDS A01005
ROD: EV_RNS315SeatEUV1UDS_SE35.rod
VCID: 2C530083F4CB
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C8 959 701 HW: 3C0 959 793 C
Component: TUER-SG FT 002 0507
Revision: 12110009 Serial number: 0002565617
Coding: 0010B0
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: N/A
VCID: EDD54D878F51
Subsystem 1 - Part No SW: 1K0 959 703 AF HW: 1K0 959 795 S
Component: J388__TSG-HL 006 1401
Serial number: 00000005738709
Coding: 000090
No ASAM data for: "EV_TSGFPQ35BRFVW46X" (SE35)
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 65 3201
Revision: 00H20000
VCID: 346318E32CFB
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C8 959 702 HW: 3C0 959 792 C
Component: TUER-SG BT 002 0507
Revision: 14110009 Serial number: 0002568401
Coding: 0010B0
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: N/A
VCID: EED74A8B8257
Subsystem 1 - Part No SW: 1K0 959 704 AF HW: 1K0 959 794 S
Component: J389__TSG-HR 006 1401
Serial number: 00000005736918
Coding: 000090
No ASAM data for: "EV_TSGBPQ35BRFVW46X" (SE35)
Address 62: Door, Rear Left
Cannot be reached
Address 72: Door, Rear Right
Cannot be reached
End ---------------------------------------------------------------------
que error es ese que me da de la centralita electrica ? muy agradecido
Me pueden ayudar con este log
3 mensajes
- Vistas: 1.168
jjzele - Nuev@ por aqui
Re: Me pueden ayudar con este log
tampoco consigo entrar al modulo 46 para activar los pitidos de abrir y cerrar el coche , a la radio mas de lo mismo . error de comunicación
Algun alma caritativa me podria ayudar con esto por favor
3 mensajes
BRICO - Instalación BSD+RTA (asistente ángulo muerto con asi Foro: Leon III - Mecánica / Electricidad / Electrónica Autor: rojas Respuestas: 674 |
Problema con la radio. No se que hacer ya Foro: Leon I - Mecánica / Electricidad / Electrónica Autor: Aaron_20VT Respuestas: 32 |
Bombillas h7. Leds con la tapa puesta del faro? Foro: Leon I - Mecánica / Electricidad / Electrónica Autor: arjleon90 Respuestas: 20 |
Ayuda con plegado espejos leon 1p restyling del 2010 Foro: Leon II - Mecánica / Electricidad / Electrónica Autor: DanielSampedro Respuestas: 4 |
Me presento con mi segundo Leon Foro: Presentaciones Autor: Yeraygm88 Respuestas: 3 |
