Diagnosis Vagcom
Seguidores: cuestaguadiana
Diagnosis Vagcom
Notapor cuestaguadiana el 03 Jun 2013, 11:45
Hola a todos:
A ver si alguien puede echarme una mano para interpretar este autoscan:
scan-1:
VCDS Version: Release 11.11.0 (x64)
Data version: 20111111
mio
Friday,31,May,2013,15:38:44:37412
Chassis Type: 1M - Seat Leon/Toledo
Scan: 01 02 03 08 15 17 19 22 35 36 37 46 56
VIN:xxxxxxxxxxxxxxxxxxxxxxxxxxxx Mileage: 198970km/123634miles
Address 01: Engine Labels: Redir Fail!
Part No: 038 906 012 FK
Component: 1,9l R4 EDC 0000SG 3357
Coding: 00002
Shop #: WSC 00046
VCID: 5EB9EFDCDA2C8AE
3 Faults Found:
17552 - Mass Air Flow Sensor (G70)
P1144 - 35-10 - Open or Short to Ground - Intermittent
17964 - Charge Pressure Control
P1556 - 35-10 - Negative Deviation - Intermittent
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-00 -
Readiness: N/A
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 C
Component: ABS FRONT MK60 0103
Coding: 0001025
Shop #: WSC 00046 615 1234567
VCID: 2A51730C86E436E
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 A
Component: 1L AIRBAG VW51 0A 01
Coding: 12620
Shop #: WSC 00046
VCID: 22419B2CAED4EEE
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 1M0-920-xx2-17.lbl
Part No: 1M0 920 802 D
Component: KOMBI+WEGFAHRSP VDO V01
Coding: 05122
Shop #: WSC 00046
VCID: 27578A38C5F60B6
2 Faults Found:
00562 - Sensor for Oil Level/Temperature (G266)
30-00 - Open or Short to Plus
00779 - Outside Air Temp Sensor (G17)
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00046
VCID: F0E52164B0B88CE
Address 46: Central Conv. Labels:
VCID: 55ABF0F0AC1A496
Note: Excessive Comm Errors
End ---------------------------------------------------------------------
scan 2:
mio
Friday,31,May,2013,16:27:29:37412
VIN: xxxxxxxxxxxxxxxxxxxxxxxxxxxx Mileage: 198970km/123634miles
Coding: 00002
Shop #: WSC 00046
1 Fault Found:
P1654 - 35-00 -
Readiness: N/A
Coding: 0001025
Coding: 05122
Shop #: WSC 00046
2 Faults Found:
Coding: 00006
Shop #: WSC 00046
Espero que alguien me pueda echar una mano.
Última edición por cuestaguadiana el 05 Jun 2013, 21:12, editado 1 vez en total
cuestaguadiana
Re: Diagnosis Vagcom
Notapor Gurin el 03 Jun 2013, 16:52
Lo prmero de todo bienvenido.
Lo segundo edita el mensaje y borra el número de bastidor del coche, por lo que pueda pasar.
Te esta dando fallo el caudalímetro.
Regulación de la presión de sobrealimentación, límite no alcanzado.
Tensión de alimentación
Sensor de nievel/temperatura del aceite
Sensor par la temperatura exterior.
SEAT LEON FR TDI
Gurin
Agradecido: 294 veces
Notapor cuestaguadiana el 04 Jun 2013, 08:45
y este
cuestaguadiana
Notapor cuestaguadiana el 05 Jun 2013, 23:19
¿Donde está esta caja?
cuestaguadiana
Notapor Gurin el 08 Jun 2013, 23:01
Debajo del volante.
SEAT LEON FR TDI
Gurin
Notapor cuestaguadiana el 09 Jun 2013, 18:02
Bien.Pues despues de probar fusibles y caja de reles sin anomalias me decidi a probar esto:
https://www.youtube.com/watch?v=Afvu5MOM9ak
Yo creo que no cabe duda que es la centralita.
Se agradecen conclusiones.
cuestaguadiana
Notapor cuestaguadiana el 10 Jun 2013, 13:25
se puede ver directamente en youtube,click aqui:
cuestaguadiana
