He pasado scaneo vagcom MK3. Quéue significa estos errores?
Notapor LEON2014 el 04 Jul 2016, 20:51
he hecho un scaneo del vag.com 15.7.1 y me han salido los siguientes errores que aun dandole a borrar siguen saliendo.
Alguien me puede decir que significa?
Sobretodo me interesa el del modulo 09, que tengo un problema con la alarma y no sé que le ocurre.
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5F0 907 044 D HW: 5F0 907 044 D
Component: Climatronic H03 0705
Revision: 00001K07
Coding: 00000014200100011005000000101000
Shop #: WSC 00049 770 00102
ASAM Dataset: EV_ACClimaBHBVW37X 003017
ROD: EV_ACClimaBHBVW37X_SE37.rod
VCID: 275A63B35EFEB3063C-8072
1 Fault Found:
459025 - Databus
U1121 00 [009] - Missing Message
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 94
Mileage: 29061 km
Date: 2016.07.04
Time: 20:05:33
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0134
Serial number: 01011424803953
Coding: 08100A42424102FB0BA44080B10403281400000000000000000000000000
Shop #: WSC 00049 770 00124
ASAM Dataset: EV_BCMCONTI 013000
ROD: EV_BCMBOSCH_SE37.rod
VCID: 0008182F9B10A43E5D-8054
Slave 1:
Subsystem 1 - Part No SW: 5F1 955 119 HW: 5F1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 140805 041 0574
Serial number: 140818022632
Coding: 0BC5FD
Slave 2:
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S4Y14M09D15H08M52S48
Coding: 00095D
Subsystem 3 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY1531539M5
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000060528107
Subsystem 5 - Part No SW: 6R0 959 591 C HW: 6R0 959 591 B
Component: J245 PS72.026 H02 0007
Serial number: WOO31699114
Coding: 180102
2 Faults Found:
262661 - Sensor for Anti-Theft Alarm System
B1330 F0 [009] - Data Record Invalid
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 94
Mileage: 29061 km
Date: 2016.07.04
Time: 20:12:24
545301 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 94
Mileage: 29061 km
Date: 2016.07.04
Time: 20:07:49
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 5F0 920 862 HW: 5F0 920 862
Component: KOMBI 202 4270
Coding: 07AC02002980000800081A001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009037
ROD: EV_DashBoardVDDMQBAB_SE37.rod
VCID: 66C42EB799746A0EC7-8032
1 Fault Found:
16777019 - Control module
B2001 00 [008] - Incorrect software version
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 134
Mileage: 29061 km
Date: 2016.07.04
Time: 20:08:27
Gracias.
Última edición por cvillajos el 05 Feb 2020, 07:37, editado 1 vez en total
Razón: Edición título para incorporar modelo
LEON2014
Agradecido: 37 veces
Re: He pasado scaneo vag.com que significa estos errores?
Notapor LEON2014 el 05 Jul 2016, 15:35
alguien me puede decir a que se refiere los errores en los módulos 08 y 09 ?
gracias.
LEON2014
Notapor cvillajos el 07 Jul 2016, 08:34
Ni idea, además, los "Missing message" son tan genéricos que ni sabes por donde vienen... El que sí tienen relación con la alarma es el B1330, pero no he encontrado info buscando por Internet.
cvillajos
Agradecido: 3613 veces
Notapor arlot el 07 Jul 2016, 09:58
@leon2014 A ver si esto te puede ayudar referente al error B1330
viewtopic.php?f=40&t=108569&p=1751834&hilit=que+son+estos+errores#p1751834
A mi me salió y es porque dejaron de funcionar la subida/bajada de ventanillas y plegado/desplagado de los retrovisores con una pulsación larga del mando.
Prueba a ver si a ti te funciona lo de la pulsación larga; por aquello de ir descartando
Vamoooooooooooooos
arlot
Agradecido: 977 veces
Notapor LEON2014 el 07 Jul 2016, 10:23
arlot escribió:@leon2014 A ver si esto te puede ayudar referente al error B1330
https://www.clubseatleon.net/viewtopic. ... s#p1751834
arlot, desde la puerta del conductor me bajan automaticamente todas las ventanillas y al cerrar y abrir el coche se plegan/desplegan los retrovisores.
El error que me sale de la alarma no sé porque es, lo único que te puedo decir, es que salta la alarma sin motivo.
Ya sea en el parking como en la calle.
Cuando salta la alarma, no hay nadie en la calle ni el coche tiene indicios de que alguien haya intentado algo.
Tanto salta a las 4 de la mañana como a las 11 de la mañana, después de comer etc.
Pero ese fallo en el módulo 9, diría al 100% que es lo que está provocando que salte la alarma.
La alarma es la de serie.
Gracias.
LEON2014
