Ayuda interprear errores vagcom
Notapor Pableeras el 04 Nov 2018, 15:15
Buenas tardes, no se si el post está bien puesto.
He hecho un scan con el Vagcom a mi Leon 5F y me han salido los siguientes errores que no tengo ni pajolera idea de interpretarlos. A ver si me podeis echar una mano, saludos.
Sunday,04,November,2018,15:09:40:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64
VCDS Version: 17.1.3.0 (x64)
Data version: 20170203 DS267.2
www.Ross-Tech.com
License Plate:
Chassis Type: 5F (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F
Mileage: 173320km-107696miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
Address 01: Engine (J623-CKFC) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 021 DS HW: 04L 907 309 D
Component: R4 2,0L EDC H22 5514
Revision: 83H22---
Coding: 11190012032401090000
Shop #: WSC 00049 770 00244
ASAM Dataset: EV_ECM20TDI01104L906021DS 002009
ROD: EV_ECM20TDI01104L906021DS_002.rod
VCID: 79FE36A6F8421289AE-802C
3 Faults Found:
18841 - Switch for Start-Stop Operation
P168E 00 [032] - Stuck Closed
Intermittent - Not Confirmed - Tested Since Memory Clear
18825 - Coolant Pump for Intercooler
P190E 00 [096] - Supply Voltage
21125 - Invalid Data Received from Airbag Control Module
U0452 00 [032] - -
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 907 379 R HW: 5Q0 907 379 F
Component: EMB8 EHCB H31 0356
Revision: 00000000 Serial number: 61683000000471
Coding: 18EE6292242109750080060841C8241846249000608224F200610070C002
Shop #: WSC 00049 770 00103
ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
ROD: EV_Brake1UDSContiMK100ESP_033.rod
VCID: 4B92BC6EE25E50194C-801E
No fault code found.
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5F0 907 044 D HW: 5F0 907 044 D
Component: Climatronic H03 0705
Revision: 00001K07
Coding: 04000104202100011005000000101000
ASAM Dataset: EV_ACClimaBHBVW37X 003017
ROD: EV_ACClimaBHBVW37X_003_VW37.rod
VCID: 275A20DE5E76547988-8072
Fresh Air Blower Front:
Refrigerant Pressure And Temperature Sender:
Air quality sensor:
3 Faults Found:
263426 - Air Quality Sensor
B10AF 31 [008] - No Signal
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 85
Reset counter: 179
Mileage: 166822 km
Date: 2018.08.19
Time: 10:37:16
Voltage terminal 30: 12.4 V
Outside air temperature: 23.0 °C
System run time-Engine running time: 255 s
System run time-Terminal 15 on: 255 s
1048834 - Functional Limitation due to Energy Management
B10CD 00 [008] - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 178
Mileage: 173153 km
Date: 2018.11.04
Time: 12:21:39
Voltage terminal 30: 11.5 V
Auxiliary heater: in stages-Enabling for auxiliary heater operation: No enabling
Auxiliary heater: in stages-Act.value: 1
Auxiliary heater: in stages-Specified value: 3
Auxiliary heater: in stages-Specified value for control: 3
1048835 - Functionality limited due to Engine Control Module
P1719 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 12
Reset counter: 179
Mileage: 170487 km
Date: 2018.10.05
Time: 08:04:52
Voltage terminal 30: 13.8 V
Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AA HW: 5Q0 937 084 AA
Component: BCM MQBAB H H14 0112
Serial number: 00011317700952
Coding: 08000A42420102FB4B64400040040328102A000000000000000000000000
ASAM Dataset: EV_BCMCONTI 011001
ROD: EV_BCMBOSCH_011.rod
VCID: 77FA309ECE5604F9D8-8022
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 5F1 955 119 HW: 5F1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 130626 041 0574
Serial number: 130627194436
Coding: 0BC5FD
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y13M06D29H17M14S55S1
Coding: 00885D
1 Fault Found:
525838 - Limp Mode
C10CA 00 [009] - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 168
Mileage: 128453 km
Date: 2017.03.24
Time: 18:21:30
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 B HW: 5Q0 919 294 A
Component: PARKHILFE 8K 002 0026
Revision: -------- Serial number: 94231317302255
Coding: 0031051001
ASAM Dataset: EV_EPHVA18AU3700000 002016
ROD: EV_EPHVA18AU3700000_VW37.rod
VCID: 3A7CE9AABDC4D991E7-806E
Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
Part No SW: 3Q0 959 655 AC HW: 3Q0 959 655 AC
Component: Airbag VW20 011 0188
Revision: -------- Serial number: 003P4PD6KDF
Coding: 98CCC000000000005C0000CC000800000065
ASAM Dataset: EV_AirbaVW20TS6VW48X 001116
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7F0AD8BEE6663CB990-802A
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 454 001 906 13
Component: SideSensor_Df 008 0887
Serial number: 3576U000000034544D0+
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 454 001 906 13
Component: SideSensor_Pf 008 0887
Serial number: 3586U000000222992D05
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 454 802 806 13
Component: SideSensor_Dr 111 0148
Serial number: 3516RB22F7D010000007
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 454 802 806 13
Component: SideSensor_Pr 111 0148
Serial number: 3526R04FB7C010000007
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No SW: ----------- HW: 454 801 706 13
Component: FrontSensor_D 114 0149
Serial number: 3556VBF296E01000000M
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 AC HW: 5Q0 953 549
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 06051304400717
Coding: 9400
ASAM Dataset: EV_SMLSKLOMQB 009001
ROD: EV_SMLSKLOMQB_SE37.rod
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 5F0 920 871 A HW: 5F0 920 871 A
Component: KOMBI 303 2210
Coding: 07AC0A002980000800086A00000000
ASAM Dataset: EV_DashBoardVDDMQBAB 008031
ROD: EV_DashBoardVDDMQBAB_008_VW26.rod
Address 19: CAN Gateway (J533) Labels: 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 F
Component: GW MQB High 125 1144
Revision: -------- Serial number: 0000802255
Coding: 030100F40B087600EF0006C8080F00010001000000000000000000000000
ASAM Dataset: EV_GatewLear 009013
ROD: EV_GatewLear_009.rod
VCID: 3B72ECAEB2FEE099FC-806E
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 5F0 959 537 B HW: 5F0 959 537 B
Component: E221__MFL-PR6 H03 0120
Serial number: 000000000A0611310513
Coding: 002000
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 D HW: 5Q0 915 181 D
Component: J367-BDM H08 0192
Serial number: 00000000004051714061
Address 42: Door Elect, Driver (J386) Labels: 5QX-959-X93-42.clb
Part No SW: 5Q4 959 593 HW: 5Q4 959 593
Component: TSG FS 007 0006
Serial number: 0000066520463
Coding: 00100320D000020100001000
ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 020C514A95945151FF-8056
Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
Component: EPS_MQB_ZFLS 119 1021
Coding: 81
ASAM Dataset: EV_SteerAssisMQB 008022
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D76E2B6ACEAEEA9C2-8068
Address 52: Door Elect, Pass. (J387) Labels: 5QX-959-X92-52.clb
Part No SW: 5Q4 959 592 HW: 5Q4 959 592
Component: TSG BFS 007 0006
Serial number: 0000066720835
ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 010E5E4690924A49E6-8054
Address 55: Headlight Range (J431) Labels: 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0070
Revision: -------- Serial number: --------------
Coding: 048A000009000000
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB_VW26.rod
VCID: 75E63A96D45A76E9CA-8020
Address 5F: Information Electr. (J794) Labels: Redir Fail!
Part No SW: 5F0 035 846 A HW: 5F0 035 846 A
Component: MU-S-N-ER 040 0407
Serial number: E1F02706130758
Coding: 04731001D70E000021110001000800002F0201040100010066
ASAM Dataset: EV_MUStd6C1PASE 002030
ROD: EV_MUStd6C1PASE_VW37.rod
VCID: 26442DDA597C4D71B3-8072
Operating And Display Unit 1:
Subsystem 1 - Part No SW: 5F0 919 603 A HW: 5F0 919 603 A
Component: ABTmin_Std_Nv H45 0020
Serial number: SEZ8Z9N5600PXC
Data medium:
Subsystem 2 - Part No SW: 5F0 919 866 E HW: -----------
Component: ECE 2013/14 --- 0034
Serial number: --------------------
3 Faults Found:
1543 - Control Module Incorrectly Coded
U1014 00 [009] - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 27
Mileage: 166459 km
Date: 2018.08.08
Time: 16:35:23
Voltage terminal 30: 12.1 V
Byte_Coding_Condition-byte_0_condition: OK
Byte_Coding_Condition-byte_1_condition: OK
Byte_Coding_Condition-byte_10_condition: ERROR
Byte_Coding_Condition-byte_11_condition: ERROR
Byte_Coding_Condition-byte_12_condition: ERROR
Byte_Coding_Condition-byte_13_condition: ERROR
Byte_Coding_Condition-byte_14_condition: ERROR
Byte_Coding_Condition-byte_15_condition: ERROR
Byte_Coding_Condition-byte_16_condition: ERROR
Byte_Coding_Condition-byte_17_condition: ERROR
Byte_Coding_Condition-byte_18_condition: ERROR
Byte_Coding_Condition-byte_19_condition: ERROR
Byte_Coding_Condition-byte_2_condition: OK
Byte_Coding_Condition-byte_20_condition: ERROR
Byte_Coding_Condition-byte_21_condition: ERROR
Byte_Coding_Condition-byte_22_condition: ERROR
Byte_Coding_Condition-byte_23_condition: ERROR
Byte_Coding_Condition-byte_24_condition: ERROR
Byte_Coding_Condition-byte_25_condition: ERROR
Byte_Coding_Condition-byte_26_condition: ERROR
Byte_Coding_Condition-byte_27_condition: ERROR
Byte_Coding_Condition-byte_3_condition: OK
Byte_Coding_Condition-byte_4_condition: OK
Byte_Coding_Condition-byte_5_condition: OK
Byte_Coding_Condition-byte_6_condition: OK
Byte_Coding_Condition-byte_7_condition: OK
Byte_Coding_Condition-byte_8_condition: OK
Byte_Coding_Condition-byte_9_condition: OK
0538 - Loudspeaker Channel 6
B13A5 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 27
Mileage: 166459 km
Date: 2018.08.08
Time: 16:23:51
7201 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 27
Mileage: 166459 km
Date: 2018.08.08
Time: 16:05:52
Voltage terminal 30: 12.2 V
BAP-BAP_Function_ID: 02
End-------------------------(Elapsed Time: 03:31)--------------------------
Pableeras
Re: Ayuda interprear errores vagcom
Notapor cvillajos el 04 Nov 2018, 18:01
Los errores de motor y de clima son intermitentes, incluso los de motor "sin confirmar" por lo que no hay datos ni de fechas, ni de frecuencia, ni kilometraje, ni nada. Los de clima sí, el de sensor de calidad de aire tiene bastantes ocurrencias, lo más fácil sería cambiar el filtro del habitáculo a ver si "mejora". Prueba a borrarlos todos y revisa cada cierto tiempo.
El de la centralita electrónica indica que el coche entró en "limp mode" allá por el 2017. Solo una ocurrencia. Borra también.
Donde tienes más problemas es en el Infotainment. Una codificación incorrecta (Qué MODs has ralizado? Y tienes copia de seguridad?... Si no, revisa el CodingLog.TXT allá por el 8 de Agosto y reviertes a una codificación correcta). Otro error de algún altavoz que ni idea. Y otro error muy genérico sin una descripción que lo identifique.
cvillajos
Agradecido: 3611 veces
Notapor Pableeras el 04 Nov 2018, 20:38
cvillajos escribió:Los errores de motor y de clima son intermitentes, incluso los de motor "sin confirmar" por lo que no hay datos ni de fechas, ni de frecuencia, ni kilometraje, ni nada. Los de clima sí, el de sensor de calidad de aire tiene bastantes ocurrencias, lo más fácil sería cambiar el filtro del habitáculo a ver si "mejora". Prueba a borrarlos todos y revisa cada cierto tiempo.
Muchas gracias por contestar.
Los mods que hice son tipo lo de la radio de fondo de carbono y eso..
Lo que he notado desde anoche es que cuando pongo la calefaccion, solo me sale caliente por mi rejilla... por las demas sale feio
Pableeras
Usuarios navegando por este Foro: Anthropic, Facebook/Meta/ExternalAgent y 6 invitados
