El hilo de VAGCOM y opciones/mods para MK3
Favoritos: El-Santo, J@VY, neraka, comodisimo, nhaxo, guirimg, Maestro, José R, JorgeAnteloC, gark81, Monilloxd, LeonST, josele887, Guitarrero18, Garfu, pttzarzadilla, reyes83, jicarriches, Raulin87, Leon pucelano, pocososinos, pintalberto, dani90, Mario1307, Albert87, genialsoft, Javigt, crcrodrigo, blankiblau, trekam, lobezno13, Morientes, Josito3, jorgee76, jliriz, Albino, seat leon fr 46, francesito, khris, Agonza86, clavelstreet, ocsido, acidheart, Korath, JPeraza, marcosgumiel, Josele., itsAdriaan96, cvillajos, ertate, LU1S3N_LE, Ludovicum, migcc, Vasmurcia, Charly24Fr, Jerjeskan, Javata, adrinek8, Paliciu, Samueleitor, Sdocid, Tomcat7733, ismacom, KaZaK, m170280, GaiteFRmklll, Mate, kijute, Kete32, los, javieret69, Alberto85, dranaco, joelsm, fre_19, Koltrix, franandas, Alleya, Juanquique, AiramTuning, chetelopez, little bastard, fur, mk3CAT, Juantxu, voxyman, Peje, javimacuo, JDCLEONFR, barrosdepor, steve_mad, Matias92, LordNelson, Elpuma7788, Revi, lopezm0, tuthankamenn, Miguelespino14, rock_ero, jordy, albertolop91
Seguidores: sarge, dsorribes, Elpuma7788, fonsi008, genialsoft, Mario1307, P.carrizo.leonstfr, trumangs, robereto, rikirpa, champinet, Miguelespino14, Besaygf, El3ndil, gogua, Pitufo_fr, crisFR, hectorcanu, Budoka, janfri, ixorreta, josele887, Jorge75016, jjimene89, cstrol, volkov, easyridergs, jmofcb, crcrodrigo, TeteFR, Dandy_gsi, Marc.22, Youkiler, iMonje, delko, dUeNdEr, Aegnorazo, marlop, pttzarzadilla, Platanot, berserk, Canary_280, La_jungla, davidbj, vigimuertos, Osky1983, chemacrown77, juanmaroger, sadanyac, Lionxp, coxmox, maxinew, nhaxo, Hecson.27, Valerofr150, Arcangel_89, edumachuca, daniel_44, JoseCa, kadettero, pablomus85, Mate, Albino, chuki_gcg, trekam, Ribers, FranGonzalez, Txutxiysilvia, César C., odelot, loeches, LeoST, jmfcoto, msmdraven, antelo85, kurbak, JPeraza, Diegokero, Robert_gti, chichopaco, Unaited, J.COSTA, jbaste, ertate, Javigt, Iosu21, Raul_22_, Daruma, kijute, LuichiFR, TITO CORUÑA, golf_1990, pitc3c14, lazandury_sur, iazofra, khris, Peje, Digon, car212121, Charly24Fr, Rasekfighter, aigort, Vasmurcia, Trivi83, Jeii90, MORKAS, Cantona, picard14, fbmxx, Zenobya, pirulo79, IRO, dookky, alonsodsg, carrasco13, Edu1589, elbirlo.dmm, bailyibz, Aluisdr26, aironsam14, franrx, Joseibz, elluna, hectordrums, chetelopez, llobet112, Kikote8, zenkun, Tomcat7733, djcastle, STFR, Sdocid, jninomo, albertpg, neraka, joke2joke, Miguelpfdez94, Kete32, chisyelamos, molvi_mabad, alejandro_javier, borgio, carlosgzlez, Frekiyo, manupuente92, garrafa2, papo-182, pipaxy, joelsm, morpheusgt, leonfrsaha, joscasaster, bronce702, Dconnect, Agobo, DBS83, Luko, Leon pucelano, davics07, naikon_paul, Juanquique, abollao, Hovig, teltronik, oldaqgonzalez04, ivanmonty, jasoriab, undernok, Mramos1985, braulioT, JoseDel, DiegoR, KoToRRo, Gsclosada, Tunnig, João Ramos, cristian_l.m, ilargiman, Gus_Fring, eyebee, jluis, francisco.gamiz, sisma_eltrigo, VapaV, csabafr2013, guille771, cocorolito, artur.bp, sergi303, portela84, barret, Alba Morales, davidalba, JDCLEONFR, Luiggi7, dukaty, Maikermx, nitro_g4074, Senuto, yoflipo, damsolu, Mobi2004@gmail.com, josutdm, xexpir, cucci, Xabaco, fexposru, DJGrincho, chifli, MartinLeon, sgnwill, trazas, davidap13, ncx, Thor, ivanvidal, LordNelson, David_GT, vicius, javigomezserrano, josemag, iNFeCTeD, sistrax, manu5, galelir, Juanmidv, Chrohu, alex1, davidvilao, yurkli, carlo13, carloslmfr, lopezm0, jose.a.llamas, Gisbigas, Drovniak, diepecu2, JaquetónST, alrodri, ginyu 83, Ivanbustelo, Def89, Fisio, SantiPMI, Lata8, estudiante2003, talanito, wilsugar, perikolu, pedrorossello92, AlvaroRamlo, ebcuatro
Re: El hilo de VAGCOM y opciones/mods para MK3
Notapor ANTMENPIN el 14 Jul 2021, 10:27
marlop escribió:
ANTMENPIN escribió:Por ahí leí que si no llevaba lavafaros no llevaba sensor…
Es justo eso. Además, con los lavafaros va también un depósito mayor, de 5 litros.
Ayer desactivé el bit del sensor con vcds y ya ha desaparecido el aviso del FIS. Gracias! ;)
ANTMENPIN
Coche: Leon MK3 1.2 TSI 110cv
Notapor Ivanbustelo el 01 Ago 2021, 14:12
Buenas. Alguien me puede pasar el mod para poner más frío en el clima que solo lo encuentro para OBD y yo tengo vagcom. Muchas gracias.
Enviado desde mi RMX2170 mediante Tapatalk
Ivanbustelo
Notapor luisporcel el 02 Ago 2021, 10:26
Algo así:
luisporcel
Agradecido: 91 veces
Notapor juanba el 09 Ago 2021, 01:21
Alguien hizo el mod de la luz de los intermitentes con las luces de las puertas??
Yo sigo los pasos tal cual,pero al poner el intermitente izquierdo por ejemplo parpadean ambas puertas a la vez.nonconsigo que parpadea solo la puerta correspondiente a cada intermitente.
juanba
Agradecido: 54 veces
Notapor dUeNdEr el 07 Dic 2021, 23:02
hola, necesito cambiar la fecha y hora del FIS (no tengo la radio original) y he pensado con el vagcom...pero no se donde esta eso....alguna idea?
Dios bendiga los foros...y el conocimiento gratuito compartido de ellos. No exijas, colabora!!
www.yamahaxj6.es
dUeNdEr
Agradecido: 15 veces
Notapor NeyTinh0 el 10 Dic 2021, 19:50
miceor escribió:
osjamil escribió:supongo que eso todavía no se puede hacer con obdeleven no? si no sería la leche
Con OBDeleven se hace exactamente igual.
En breve tendré terminados nuevos mods de iluminación, estoy optimizandolos para que no creen conflictos en los canales disponibles de cada luz.
En concreto ese es así con OBDeleven:
Intermitentes traseros contrafase con los dos pilotos traseros led (Pilotos LED)
1 - Módulo 09 - Centralita electrónica. Code (31347)
2 - Adaptación
3 - Leuchte23SL HLC10
4 - Lichtfunktion E 23 -- (Cambiar valor a Blinken links Dunkelphase)
5 - Dimmwert EF 23 -- (Cambiar valor a 100)
6 - Dimming diection EF 23 -- (Cambiar valor a Maximize)
7 - Lichtfunktion G 23 -- (Cambiar valor a Blinken links Hellphase)
8 - Dimmwert GH 23 -- (Cambiar valor a 0)
9 - Dimming diection EF 23 -- (Cambiar valor a Minimize)
10 - Leuchte24SL HRA65
11 - Lichtfunktion E 24 -- (Cambiar valor a Blinken rechts Dunkelphase)
12 - Dimmwert EF 24 -- (Cambiar valor a 100)
13 - Dimming diection EF 24 -- (Cambiar valor a Maximize)
14 - Lichtfunktion G 24 -- (Cambiar valor a Blinken rechts Hellphase)
15 - Dimmwert GH 24 -- (Cambiar valor a 0)
16 - Dimming diection EF 24 -- (Cambiar valor a Minimize)
17- Leuchte26NSL LA 72
18 - Lichtfunktion E 26 -- (Cambiar valor a Blinken links Dunkelphase)
19 - Dimmwert EF 26 -- (Cambiar valor a 100)
20 - Dimming diection EF 26 -- (Cambiar valor a Maximize)
21 - Lichtfunktion G 26 -- (Cambiar valor a Blinken links Hellphase)
22 - Dimmwert GH 26 -- (Cambiar valor a 0)
23 - Dimming diection EF 26 -- (Cambiar valor a Minimize)
24- Leuchte27NSL RC6
25 - Lichtfunktion E 27 -- (Cambiar valor a Blinken rechts Dunkelphase)
26 - Dimmwert EF 27 -- (Cambiar valor a 100)
27 - Dimming diection EF 27 -- (Cambiar valor a Maximize)
28 - Lichtfunktion G 27 -- (Cambiar valor a Blinken rechts Hellphase)
29 - Dimmwert GH 27 -- (Cambiar valor a 0)
30 - Dimming diection EF 27 -- (Cambiar valor a Minimize)
Buenas miceor, sabes cómo se desactiva este mod? El tema es que cuando pongo los 4 intermitentes estos estan en contrafase con todos los pilotos traseros y me gustaría desactivarlo pero no encuentro como hacerlo, podrías echarme un cable? Gracias por todo lo aportado
NeyTinh0
Notapor dUeNdEr el 16 Dic 2021, 01:59
miceor escribió:Supongo que habrás tocado otras cosas, pero esa modificación que comentas es unicamente para el maletero.
Para que no se cierre con la velocidad :
------ Automatisches verriegeln bei geschwindigkeit -- Opciones (Activado - Inactivo)
Para que desbloquee automaticamente :
------ Automatisches entriegeln -- Opciones (Activado - Inactivo)
Si quieres que bloquee la tapa de combustible automaticamente :
------ Geschwindigkeitsabhaengige tankdeckelverriegelung -- Opciones (Activado - Inactivo)
Mi coche jamás se ha cerrado solo, le dejes el tiempo que le dejes y la verdad que el de mi hermano si lo hace.
Nunca me pareció buena opción y por tanto no lo he investigado, pero supongo que con activar esta linea se quedará activo, no estoy seguro, pero podria ser por el terminal 15.
------ Funk bei klemme 15 ein -- Opciones (Inactivo - Activado)
probado (pretendo activar el cierre automatico al superar los 15 kms/h) y nada... :(
www.yamahaxj6.es
dUeNdEr
Notapor Javicorne el 18 Dic 2021, 08:29
snako79 escribió:Señales de trafico recodificadas, y funcionando perfectamente, gracias por la ayuda, el tutorial del principio del hilo, no valia para mi modelo
Ahora tengo que ver como hago el de los intermitentes en las luces de ambiente de las puertas, pero ufff, que locura buscar en algunos modulos de adaptacion, y encima, mi portatil es de 10" y me dejo la vista, jajajajaja
Pero bueno, al menos consegui un cable que funciona perfecto en un MY20, es version UDS, y no da ningun fallo en los MY20, por lo que muy contento con las 4 modificaciones que le hice, ya veremos si encuentro alguna mas interesante para hacerle.
Un saludo, y gracias por la ayuda nuevamente
También te reconoce otras señales como fin de prohibición, prohibido adelantar,etc? En mi caso MY19 solo aparecen las de velocidad.
A mi me acaba de llegar el cable esta semana y también funciona con UDS, ali tiene de todo jejej
Javicorne
Notapor miceor el 18 Dic 2021, 09:09
2 - Adaptación
Hola. Unicamente tendras que cambiar en todas esas luces (23,24,26 y 27) a estos valores:
Lichtfunktion E 23: nicht aktiv
Lichtfunktion F 23: nicht aktiv
Dimmwert EF 23: 0
Dimming Direction EF 23: maximize
Lichtfunktion G 23: nicht aktiv
Lichtfunktion H 23: nicht aktiv
Dimmwert GH 23: 0
Dimming Direction GH 23: maximize
Igual para el resto, (24, 26 y 27)
miceor
Agradecido: 1256 veces
Notapor mgrondona el 18 Dic 2021, 09:51
El mío es MY19 y si que reconoce las de prohibido adelantar y cuando pasas por el fin de prohibición se quita. También me reconoce cuando un límite de velocidad es restringido a un horario, me aparece por ejemplo la habitual de la vía (50) y me aparece otra del límite durante el horario (30) con un reloj abajo, el reloj es genérico, no te indica el horario, solo te informa de que hay una limitación horaria para esa velocidad.
Enviado desde mi M2007J20CG mediante Tapatalk
mgrondona
Agradecido: 110 veces
Notapor NeyTinh0 el 18 Dic 2021, 12:36
2 - Adaptación
Dimmwert EF 23: 0
Dimmwert GH 23: 0
Muchas gracias compañero.
NeyTinh0
Notapor sgnwill el 22 Mar 2022, 17:30
Buenas tardes,
soy nuevo en el foro y tengo un Leon 1.8 FR 180cv del 2015 y me gustaría saber si puedo hacer todas estas modificaciones que salen en la página 1 de este hilo, tengo un vagcom que no he usado nunca.
sgnwill
Notapor dUeNdEr el 22 Mar 2022, 20:26
sgnwill escribió:Buenas tardes,
claro, algunas te funcionaran y otras no depende (si no tienes el fis a color no podras poner el FR y cosas asi..) pero otras muchas si.
Yo tengo un mk3 del 2014 y llevo puestas 5bo 6 mejoras.
www.yamahaxj6.es
dUeNdEr
Notapor cvillajos el 22 Mar 2022, 22:22
Pues depende del equipamiento que montes algunos podrás y otros no. También depende del año MY'XX (fabricado en 2015 será MY'15 o MY'16). La mayoría de los MODs de la primera página se redactaron pre-restiling (que es cuando mayor número de cambios ha habido), dado que el tuyo es pre-restiling muchos te valdrán, pero cuidado que puede haber cosas que no.
cvillajos
Agradecido: 3575 veces
Notapor rikirpa el 21 Abr 2023, 22:09
hola buenas, soy propietario de un seat leon mk3 desde hace años, he realizado varias codificaciones las cuales salen en este post.
Hasta ahi todo bien, lo unico que ahora mismo tengo un problema, la funcion de antinieblas con largas en rafaga, la quiero desactivar para pasar la itv y no me deja.
Si me pudierais echar un cable, os lo agradeceria.
Última edición por cvillajos el 21 Abr 2023, 23:29, editado 1 vez en total
Razón: Edición quote y negrita
rikirpa
