ayuda con scan de vag-com
Notapor juanjo85 el 09 Ago 2008, 18:55
hola,no se mucho de vag-com,hoy a sido la primera vez que se lo e pasado y me ha dado una serie de falos...alguien me podia indicar que fallos son??porke no tengo ni idea..
VAG-COM Version: Release 704.1
Data version: 20070422
Saturday,09,August,2008,17:45:10:55371
Chassis Type: 1M - Seat Leon/Toledo
Scan: 01 02 03 08 15 17 19 22 35 36 37 46 56
VIN: VSSZZZ1MZ6R009687 Mileage: 19960km/12402miles
Address 01: Engine Labels: 038-906-019-100.LBL
Part No: 038 906 019 KP
Component: 1,9l R4 EDC 0400SG 4902
Coding: 00002
Shop #: WSC 06402
VSSZZZ1MZ6R009687 SEZ7Z0F3366434
1 Fault Found:
16955 - Brake Switch (F): Implausible Signal
P0571 - 35-10 - - - Intermittent
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.LBL
Part No: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0001025
Shop #: WSC 00001
No fault code found.
Address 08: Auto HVAC Labels: None
Part No: 1M0 820 043 G
Component: 1M-CLIMATRONIC X0703
Coding: 00043
Shop #: WSC 06402
2 Faults Found:
01542 - Yaw Rate Sensor (G202)
15-00 - Adaptation Limit (Add) Not Reached
65535 - Internal Control Module Memory Error
08-10 - Control Limit Surpassed - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL
Part No: 1C0 909 605 A
Component: 1L AIRBAG VW51 0A 0008
Coding: 12620
Shop #: WSC 06401
Address 17: Instruments Labels: None
Part No: 1M0 920 822 E
Component: KOMBI+WEGFAHRSP VDO V06
Coding: 04122
Shop #: WSC 00000
Address 19: CAN Gateway Labels: 6N0-909-901.LBL
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06402
Address 46: Central Conv. Labels: 1C0-959-799.LBL
Part No: 1C0 959 799 E
Component: 99 Komfortgerát HLO 0004
Coding: 00066
Shop #: WSC 06402
Part No: 1C1959801A
Component: 99 Tõrsteuer.FS KLO 0202
Part No: 1C1959802A
Component: 99 Tõrsteuer.BF KLO 0202
1 Fault Found:
01044 - Control Module Incorrectly Coded
35-00 - -
End --------------------------------------------------------------------------------------------------
siento ser tan burro al copiarlo aki pero nose otra forma de subirlo,ke un administrador me lo suba como adjunto.gracias
juanjo85
Notapor juanjo85 el 10 Ago 2008, 16:31
nadie podria ayudarme??
No importa que tu coche se ponga a 200.....
lo que importa es el tiempo que tarda en ponerse.......
juanjo85
Notapor elGersonFr el 11 Ago 2008, 13:00
Hola.
El error del modulo 01 la averia que tienes es interruptor de luces de freno/posición del pedal de freno. Debe estar estropeado dicho interruptor tendras que sustituirlo.
El error del modulo 46 indica que esta codificado incorrectamente. Con el vag-com en función del equipamiento que tiene tu vehiculo y la centralita confort que es deberas codificarla adecuadamente. Busca información al respecto por aqui hay bastante y el post-it sobre el vag-com tambien.
Con respecto a los errores del modulo 08 no sabria decirte a ciencia cierta haber si alguien puede aportar algo mas de info, si no te tocara pasarte por seat.
Saludos ¡¡
elGersonFr
Agradecido: 32 veces
Notapor Lito69 el 11 Ago 2008, 13:22
Apostaria a que solo tienes elevalunas electricos delanteros y lo tienes mal codificado,tienes 00066,prueba a poner 00096 o sinó en seat deben saber que codificación le toca ahí.
Lito69
Agradecido: 240 veces
Notapor juanjo85 el 12 Ago 2008, 02:07
gracias a los dos!!y si tengo elevas delanteros solamente.donde tengo ke poner 00096?
hay algun lugar donde ponga la numeracion de cada fallo??para no tener ke estar aki preguntando y molestando por tonterias de varios fallos....
juanjo85
Notapor elGersonFr el 12 Ago 2008, 13:09
Hola.
Yo probaria con 00257 Apertura de todas las puertas al pulsar una vez el mando o 00256 Apertura de la puerta del conductor al pulsar una vez, y todas al pulsar dos seguidas el mando.
Como ya te comente por ejemplo en el post-it sobre el vag-com/vds-pro que hay en este mismo subforo tienes muchos manuales para hacer este típo de cosas como recodificar una unidad de control.
Por ejemplo tienes la guia rapida de procedimientos vag-com, en dicho post-it.
Saludos ¡¡
elGersonFr
Usuarios navegando por este Foro: Anthropic, Facebook/Meta/ExternalAgent y 11 invitados
