OBDeleven - Dudas y Mods para León MK3
Favoritos: CrAfTy, neraka, fegavo, Petri, guirimg, El_Peyote, ositoerik, titosmart, VÍBORAfjvl, davix16, dmesanun, frhedie, tuning_69, gark81, rafaseten, Gerni9, hctlp, pocososinos, Maxpako, trakasjesus, blankiblau, luis77, Vilo, NikolaieV, crujipoyo, marcosgumiel, cvillajos, mikomiko, jorgecrackets, FrA1l3, Ucralek, juanpeeisafr, PwrDwnSys, Xperience, hectordrums, kossel, Myvodoo, estepi, Sdocid, JoRoGe, Mate, javieret69, dmejias, -alberto-, ferre7, Will Wallace, davrolo, Koltrix, Lotar, Jkirk, javierpg1990, Alleya, jafeor, Qore, Kasky, Dreziel, jotavc, craken, tonnety, Coabil, solnauj, jajereal, PabloAthletic, Peje, Trivi83, jordi-duck, dani10s, PULIDIN PULIDO, damsolu, Leoncity, Pepeulo, pantufle, barrosdepor, pepetgi, ManuelC, frigolin, jpmartinez, danihd, kapi21, ralebo, Bass8V, Juanjocantabria, _Juansp, lagucam, ISMAEL.K, gogorios, Piro25, toniRG, Warelio, JMR9, davidvalt, Jastur, imvand, LEMY69, CofKa, debian, theoldboy, charly425, pistoleromtb, Chinyero, rob3r7o, daviid_trivi, AbelR, javi.ferrer, Eibol, dct, amarvalbu, jevi19, Ralux, Ibiza.elbudi, CrisFRST5F, ericoperico, Serranolera
Seguidores: golf_1990, josusanchez5b, Jastur, r11ourense, MerioE, davidddgt, jose.a.llamas, gato125, Pkt, ebcuatro, byChule, Hovig, triguero, SorianoFco, jygalvan, Isra04, CubanPitbull, corderazo, israher, iDavid9669, nyro, pirulo79, Edu1589, ramargo75, javi.ferrer, kikelin, aleejandroogm, Trimmer, car212121, LeoST, Besaygf, kinipc, Rasekfighter, Romera, MartinLeon, ENRYKE200411, camamaleon, Aceroinox1a, jramis, Juanquique, josele77, marlop, Peje, Pedrost, bailyibz, wiki88, teltronik, gogua, sirkez, carlosgzlez, mcecho, genialsoft, aironsam14, JoseCa, Dandy_gsi, vanscampa, Joseibz, trekam, La_jungla, jorgecrackets, aigort, msmdraven, IRO, Jorge75016, alejandro_javier, ivan0909, jmfcoto, viktor_ct_95, maxxg2, olgalberto1, danifusi, Josepo79, er_trompe, miyobe, jande, Petri, itz18, jagman, serguey79, rafapadilla93, Mate, undernok, lead, lead, csabafr2013, jluis, olmeras, LeidenSpain, osjamil, Valerofr150, flope63, Herrdoktor, pocososinos, carrasco13, pichonclv, C.reina, Daner84, inamarlo, aguscalderon, BaZZ, yujakantabro, Fonek, LARABA, juanmaroger, juanmac, Kipu, IvanMc2, garrafa2, Linker89, mihai G, Igor, bronce702, creasy1977, Gsclosada, lebowski, jaro_84, charly425, leonfr76, DBS83, joseanvazquez501, M3rs, borgio, NOCIVOX, FcoJ.M.N., VillaSB, t4alberto, lytry32.hc, david_gz, Kasky, diegol147, jasoriab, jninomo, jmiturbe, chetelopez, utopia95, Dreziel, jonatan1988, xsoldadito, Illan, Fernandoestrada, jd_zuri, Juande667, xjuliox, Bettor, solanomor01, Chinyero, volkov, braulioT, Maikermx, iNowack, D83, MORKAS, dRoXe, JaviMarquez, danitre, Davi_TGI, DiegoR, ertate, cuenka16, nicotzioras, Spok68, urbion, linxes, kukikukarron, Talnoseque, Hyperr, VapaV, jfermar, Moigijon, slyjay73, DuckToy, nachomart, Iosu21, sbarri, sebasresa, Beiró, Llisus, agus_piscis10, Action SVG, Alc16, Trivi83, eyebee, riclanico, Per3zo, Qore, lolorm, abollao, Alvi, sergi303, Xilenos, barret, Gus_Fring, malloc, TomH30, jmofcb, paco_22_22, luigi323, Chelazo, dani10s, victor david, Yeiem93, Luiggi7, Guillen222, yoflipo, nenazojuanma, nitro_g4074, Senuto, gabivvamesia, javichu312, richard_11, Yery, Ivensound, El_pelos44, rvicario76, Mr.Chuflas, subaru_3, eruizm, Gomez89, barubita, Nicoplas, javibmw, el_noi_80, kapi21, satoo, barrosdepor, camaon99, craken, Flow-Rider, Castro87, Kikedecefe, xexpir, Cristian2014mx, _Juansp, jornefra, cucci, Pablitofr, Pablitofr, Rober_SR, kevinhtbs, chocoleitos, RamonLaC, cesarsl, drnrd, conquepoquico, hectordrums, Neuw84, bertoco, dondani96, cupralex, Octacon, pablomus85, josean-opc, davidap13, Raaz, erlanz, canijo82, MarcosRG86, Alianma, SinName, mSx, evomaoleon, BertopenST, a.cuadros71, Lumara, Gendos22, borjayadri2, litllevill, Jandrew, galelir, Josep20, borjiguez, THC77, di360, Juanjocantabria, grijan 2.0, copii92, JDMG, Morales92, nadiia.bcn93, yo_javi89, yurkli, Atajunen, carlo13, Desertcuervo, floppy666, amg129, manjerico, Franr50, iNFeCTeD, Rotemburgero, Link, kivamz, dj_ferrix, manu5, Vagabundo, aaronfdez, Manzi, Perilla, pepetgi, pistoleromtb, cp_jj, diepecu2, Freddy169, Welmonk, JaquetónST, alrodri, LuisNM, Rekoba, bizu, ginyu 83, ephreon, rr7mo, Def89, CrisFRST5F, Mohoska, gilen44, ayl, SantiPMI, Jesús Peinado, 05kar, Lata8, Adrián pcg, Warelio, carlosVACA, trazas, barris31, danieleon, enriquevalera, antonioagui95, tito68, Sarge86, victorvOrtiz, bigpicha, ericoperico, JulinM, AlvaroRamlo, josermancol, Davidv, flotter, V de Viana, zainao, LeónST, rubiotuning, RacingSport
Re: OBDeleven-Diagnosis y mods desde SmartPhone al detalle
Notapor cvillajos el 26 Nov 2016, 15:01
txato70 escribió:
miceor escribió:Tu coche lleva una Mib1.
En vez de salirte en Control de Acceso 2, te saldrá todo junto en Control de Acceso.
Busca en esa sección todos los pasos
Lo de la temperatura en reposo va en el modulo 17 y el codigo es 25327
Puede que te dé un error al meterlo pero comprueba a pesar del error si se han guardado los datos del cambio realizado.
A veces da ese error pero hace la modificación
ok @miceor.muchas gracias por tu atencion.un saludo.
20103 también vale para la 17
cvillajos
Agradecido: 3610 veces
Notapor txato70 el 26 Nov 2016, 15:13
ah ok.probare a ver que tal.gracias @cvillajos.
txato70
Agradecido: 56 veces
Notapor Juan Fran el 26 Nov 2016, 18:03
Juan Fran escribió:
stewei escribió:
Juan Fran escribió:
stewei escribió:Has seguido todos los pasos? O solo has hecho lo que has puesto?
Como digo, no tengo el OBD Eleven, sólo VAG-COM. He hecho lo que he indicado: en la codificación extendida activar el Bit 0 del Byte 12. Y luego en la Adaptación he activado los dos que he indicado antes.
El problema para mí es que en el brico pone lo siguiente (pongo en verde lo que he podido hacer, y en rojo lo que no):
Activar alarma con bocina
1 - Módulo 09 - Centralita electrónica. Code (31347)
2 - Codificación extendida (Bytes)
3 - Byte 12
4 - Activar Bit 0 (Anti-theft system installed/active)
5 - Adaptación
6 - Submenú - Proteccion antirrobo
7 - DWA Alarmverzoegerung (Cambiar valor a "driver door contact thatcham")
8 - DWA Camper Modus (Cambiar valor a "activado")
9 - Ueberwachung Innenentriegelungshelbel (Cambiar valor a "activado")
10 - Akustischer Alarm Signalhorn (Cambiar valor a "activado")
11 - Submenú - Señales de respuesta
12 - Akustische Rueckmeldung global (Cambiar valor a "activado")
13 - Akustische Rueckmeldung Signalhorn (Cambiar valor a "activado")
Y para lo que pongo en rojo es lo que pido ayuda:
¿Está también en Adaptación con el VAG-COM? ¿Alguien que tenga el mod hecho y VAG-COM podría confirmármelo?
Gracias!
@Juan Fran
Ya he encontrado el adapmap que hice en un principio con VCDS. Ahí van los canales:
(3)-Anti-theft device-DWA Alarmverzoegerung
(4)-Anti-theft device-DWA Camper Modus
(5)-Anti-theft device-Ueberwachung Innenentriegelungshebel
(7)-Anti-theft device-Akustischer Alarm Signalhorn
Modifica esos valores como ponen en el mod, pruebas y nos cuentas.
Un saludo :ok:
Muchísimas gracias, con esto no hay pérdida.
Lo malo es que hasta las vacaciones de diciembre (23/12) por trabajo estaré en Valladolid, y no tendré el León conmigo. Pero me pongo una alarma para entonces y lo anoto, para probar en cuanto lo tenga.
Mil gracias de nuevo, en un mes os contaré cómo ha salido, y si eso, lo anunciamos también en el hilo del VAG COM.
Hola de nuevo
Muchas gracias de nuevo @stewei, hoy hemos podido probar el mod en el coche de @danielo3, y va perfectamente.
Ya podemos decir que con el VCDS también se puede activar la alarma.
Voy a poner la info en el hilo del VAG-COM, de todas formas lo pongo aquí también:
1. Módulo 09 - Centralita electrónica.
2. Security access – 16
3. Introducir 31347 -> Do it!
4. Coding - 07
5. Long coding helper
6. Seleccionar Byte 12
7. Activar Bit 0 (Anti-theft system installed/active)
6. Exit (arriba a la izquierda)
7. Do it!
8. Adaptation – 10
9. Seleccionar y activar los siguientes canales:
(8)-Acknowledgement signals-Akustiche Rueckmeldung global
(9)-Acknowledgement signals-Akustische Rueckmeldung Signalhorn
10. Do it!
Ya tenéis activada vuestra alarma de monitorización de puertas y capó.
Juan Fran
Agradecido: 31 veces
Notapor galaxis el 26 Nov 2016, 20:49
Hola miceor
Para intentar modificar la intensidad de luz interior, he realizado el siguiente mod:
"Controlar la iluminación interior por zonas desde el Menú CAR
Con este mod, activamos nuevas opciones en Ajustes-Luces desde donde podremos controlar las luces por zonas.
2 - Codigo extendido (Modo Bytes)
3 - Byte 17
4 - Activar Bit 3 (Control de luz ambiental)
5 - Activar Bit 2 (Todas las zonas)
6 - Activar Bit 1 (Intensidad luz puerta)"
Una vez realizado el mod, no me aparece ninguna nueva opción en el menu CAR. También he restaurado a los valores de fábrica. Yo tengo MIB gen1 pantalla de 5´8
Mi duda es si este mod sirve para modificar la luz interior y si es así preguntarte si he hecho alguna cosa mal.
En el historial del OBDeleven me aparece lo siguiente:
Unidad de Control: 09 Centralita electrónica
Valor antiguo:
08000942424102FB4BE44000400403081000000000000000000000000000
Nuevo valor:
08000942424102FB4BE4400040040308100E000000000000000000000000
Kilometraje: 33108 km
Fecha: 2016-11-12 14:11
Valor antiguo:
Nuevo valor:
Kilometraje: 33107 km
Fecha: 2016-11-12 13:57
Valor antiguo:
Nuevo valor:
Gracias por todo
galaxis
Notapor ramargo75 el 26 Nov 2016, 23:33
Buenas! Después de hacer varias modificaciones en mi Xperience, todas sin problemas, ahora mi me abre el maletero de forma manual, solo con el mando a distancia. A alguien le paso lo mismo?
Enviado desde mi Aquaris M5 mediante Tapatalk
ramargo75
Notapor txato70 el 27 Nov 2016, 11:19
pues nada @miceor tampoco me salen esos pasos para activar cierre con lluvia,quizas las mib1 no se pueda o mi sensor no vale aqui te paso foto de mi sensor.por cierto el otro mod si lo hice con el codigo que me dijo @cvillajos.un saludo y gracias.
txato70
Notapor MORKAS el 27 Nov 2016, 11:28
Ese sensor tendria que valerte....es el de 6 puntos azules
MORKAS
Agradecido: 369 veces
Notapor txato70 el 27 Nov 2016, 12:31
@morkas y @miceor es mas lo del RLHS tampoco me sale que cosa mas rara no?.
txato70
Notapor cvillajos el 27 Nov 2016, 12:36
Y qué subsistemas te salen en el desplegable @txato70 ?
cvillajos
Notapor txato70 el 27 Nov 2016, 12:52
pues ahora mismo @cvillajos no estoy con el obd en cuanto pueda mando foto con lo que,sale en control de acceso 1 y con el 2.gracias.
txato70
Notapor txato70 el 28 Nov 2016, 12:56
hola @cvillajos esto es lo que me sale.control acceso y control acceso 2.gracias.
txato70
Notapor txato70 el 28 Nov 2016, 12:58
estos son los que me salen @cvillajos.gracias y un saludo.
txato70
Notapor cvillajos el 28 Nov 2016, 13:07
Me refería a los subsistemas de la 09. Si no te sale RLHS ¿Qué te sale? ¿RLFS?
cvillajos
Notapor miceor el 28 Nov 2016, 13:18
Por lo que veo, en tu modulo han unido :
------ Regenschliessen ein aus -- Opciones (Inactivo - Activado)
------ Regenschliessen art -- Opciones (Once - Permanent)
En una sola linea : Regenschliessen y lo tienes en permanente.
Por tanto, yo haria lo siguiente:
2 - Adaptación
3 - Seleccionar - Control de acceso 2
4 - Submenú - Regenschliessen (Dejarlo como está)
5 - Submenú - Menuesteuerung regenschliessen
6 - Cambiar valor a Active
Nos vamos al subsistema RLHS
01 - Codificación extendida (Modo Bytes)
02 - Byte 0
03 - Activar Bits 1 y 2
Una vez realizado, entra en el menú del coche - Apertura y cierre y tendrás una nueva opción.
Cierre automático en caso de lluvia . Activala y prueba a ver si te cierra ventanillas
miceor
Agradecido: 1258 veces
Notapor txato70 el 28 Nov 2016, 17:53
txato70
