OBDeleven-Diagnosis desde SmartPhone al detalle
Favoritos: zapaquad, trazas, Jastur, pistoleromtb, alaclaee, Eibol, rock_ero, Maverick.es, Cachorro, Cliff, davidddgt, Burguinak
Seguidores: davidddgt, carloscmangado, Koji Kabuto, bigpicha, recio2303, bluesbreaker88, Hovig, asaltacunas, Tonii25, rafafrias96, danieleon, rubendelcano, borjiguez, erlanz, gymnos, Edu1589, galelir, MORKAS, Link, manu5, BadaFR, Chinyero, D.Acuña, jasoriab, Mr.Chuflas, juanaco, luisvc91, r11ourense, trazas, JaquetónST, ginyu 83, ephreon, vanscampa, jerome_jsf, Mohoska, AlvaroRamlo, zainao, jesgargu, Maverick.es
Re: OBDeleven-Diagnosis desde SmartPhone al detalle
Notapor cvillajos el 18 Feb 2020, 15:52
Empiezo con el primero que gracias al enlace de @theoldboy al foro oficial de OBDeleven he sabido un poco más de él, y me parece un salto cualitativo para el interfaz (ojo!! que esto puede dejar las centralitas como "pisapaleles" si no se usa con conocimiento)
cvillajos escribió:Esto me gusta...
Alguien sabe cuándo lo han incorporado?
EEPROM function will let you read internal control unit memory and change parameters which is not possible to change by use coding or adaptations.
i.e. by use of this function you can activate folding mirrors from remote on MK6 Golf
also many more cool things but it requires professional knowledge so use this function very carefully!
Read more: http://forum.obdeleven.com/post/28092#ixzz6EJkTPTaq
cvillajos
Agradecido: 3611 veces
Notapor cvillajos el 18 Feb 2020, 15:58
theoldboy escribió:hello,
OBD11 Now gives you a warning about the software version on your control unit
As you can see in the attached photo OBD11 Have confirmed that this is just a warning that for your hardware version they have another car on the database with a software version number that is higher, there is no facility or plan to build process to upgrade the software. You need to speak with a dealer or get other tools to do it.
OBD11 ahora le da una advertencia sobre la versión del software en su unidad de control
Como puede ver en la foto adjunta OBD11. He confirmado que esto es solo una advertencia de que para su versión de hardware tienen otro automóvil en la base de datos con un número de versión de software que es más alto, no hay instalación o plan para construir un proceso para actualizar el software. Necesita hablar con un distribuidor u obtener otras herramientas para hacerlo.
Este también le tenía pendiente de postearlo por aquí...
Añado:
- No abandono la esperanza de que algún día pueda llegar a flashear y hacer scripting con OBDeleven :rezar:
cvillajos
Notapor theoldboy el 18 Feb 2020, 16:01
hello,
Next Gen Device - you can change the colors that appear when plugged in.
Please note the LED indication is only active when Device is plugged in and you are connected.
Update as per version 1.3.5 IOS Software does not support this function yet
Dispositivo de próxima generación: puede cambiar los colores que aparecen cuando está enchufado.
Tenga en cuenta que la indicación LED solo está activa cuando el dispositivo está enchufado y usted está conectado.
ACTUALIZACIÓN: tenga en cuenta que la versión 1.3.5 IOS no tiene esta función
Última edición por theoldboy el 02 Oct 2020, 20:05, editado 1 vez en total
2014 Modified Seat Cupra 280
Mi Fiera Y mi Construir sitio
Uso de OBD11 Siempre realice una copia de seguridad antes de codificar y NUNCA use el Restablecimiento de fábrica
theoldboy
Agradecido: 287 veces
Notapor cvillajos el 18 Feb 2020, 16:10
Otro más:
cvillajos escribió:
rvicario76 escribió:Perdona mi ignorancia, pero como se cambia de sesión para poder entrar en otro modulo y hacer un backup o una codificación?
Llevo meses leyendo este hilo, pero me hace falta algo de practica para ver como funciona el obdeleven
Un saludo,
Por defecto cuando entras en una unidad de control estás en una sesión "estándar", pero ciertas codificaciones/adaptaciones (y backups) pueden requerir bien de código de seguridad "login", bien de sesión específica para poder realizarse.
Por eso te pide login para hacer backup y por eso la exportación diferirá si haces el backup con sesión "estandar" o con sesión de "desarrollo" (por ejemplo).
Para cambiar de sesión la propia APP te lo indica en sus FAQs:
cvillajos
Notapor cvillajos el 18 Feb 2020, 16:23
Más cositas:
teltronik escribió:si la apicacion hiciera un backup de las unidades y luego las pudieras volcar otra vez..sera la leche
Ya me he dado cuenta que no :(
Todavía no he actualizado, pero leyendo las release notes dice 'look' no 'modify'. Por tanto, lo que habrán hecho es ampliar la funcionalidad 'off-line' de consulta para los canales de adaptación (función que ya existía para el coding).
P.D.: Además, has tenido que entrar en los canales de adaptación de manera "on-line" antes para que luego puedas leerlas "off-line".
cvillajos
Notapor theoldboy el 18 Feb 2020, 16:31
cvillajos escribió:Más cositas:
I am no expert but my understanding (and sorry if I have miss understood (google translate) ) is you need to run a Full Scan and a Backup of the control unit at that stage it is possible to see offline - Some Live Data elements, Adaptations and Long Coding and also any Charts that have been run.
theoldboy
Notapor theoldboy el 18 Feb 2020, 16:33
Hola
tenga en cuenta que los archivos de ayuda en línea no están actualizados, algunos son correctos y otros no.
Por ejemplo, si mira el archivo de ayuda de Copia de seguridad, habla sobre el proceso anterior uno por uno, no sobre las nuevas unidades de control de una sola vez.
theoldboy
Notapor cvillajos el 18 Feb 2020, 16:37
Releyendo antiguos post del información "general" del interfaz y de la APP veo por ahí se enlazaba a la tabla de características Normal/Pro de OBDeleven: https://obdeleven.com/es/inicio/11-acti ... 05165.html y al detalle de la Play Store: https://play.google.com/store/apps/deta ... even&hl=es
También veo que han actualizado la tabla de características con la incorporación de IOS. Se ve que todavía lo tienen un poco "verde" pero digo yo que irán ampliando...
cvillajos
Notapor theoldboy el 18 Feb 2020, 16:42
En Configuración, configure la lista de puerta de enlace de Autocode para mostrar
El propósito de este bit de software es mantener siempre todas sus unidades de control activas en el dispositivo, si agrega una unidad de control que no está en el automóvil o elimina una que sí lo está, entonces el software la eliminará o la agregará nuevamente.
Si recibe este mensaje (que puede desactivar aquí o en la pantalla de configuración) y seleccione sí, el software volverá a agregar las unidades de control que faltan.
Probé esto quitando una unidad de control y luego seleccioné SÍ aquí y agregó la unidad de control nuevamente. Tenga en cuenta que el mensaje que recibirá hablará sobre la puerta de enlace (19) pero no muestra los elementos agregados o eliminados, esa información es solo disponible en la sección Historial.
Además, cuando revise su archivo de historial, verá que se agrega nuevamente.
ACTUALIZAR.
Me preguntaron en otro foro qué sucede si agrega una nueva unidad de control, la probó y agregó en la unidad de control 04 (sensor del ángulo de dirección) tan pronto como lo hice, apareció la pantalla de codificación automática y le pedí que se ejecutara y software eliminado 04 (correctamente). Además, antes de ejecutar el código automático, pude ver que el estado de la unidad de control era negro (por ejemplo, no puedo comunicarme con el automóvil).
Última edición por theoldboy el 02 Oct 2020, 20:13, editado 2 veces en total
theoldboy
Notapor cvillajos el 18 Feb 2020, 16:55
theoldboy escribió:I am no expert but my understanding (and sorry if I have miss understood (google translate) ) is you need to run a Full Scan and a Backup of the control unit at that stage it is possible to see offline - Some Live Data elements, Adaptations and Long Coding and also any Charts that have been run.
Hi @theoldboy ,
Saved Charts, Backups and Live Data are accesible anytime from the APP ("on-line" or "off-line") without the need to run a complete Backup or FullScan. Coding/LongCoding needs at least a FullScan in order to be accesible "off-line". But some other "off-line" information (like Adaptations), must be accessed "on-line" or Backed up previously in order to be available "off-line".
Let me know if you didn't understand me.
Regards!!
cvillajos
Notapor theoldboy el 18 Feb 2020, 17:22
Hi @theoldboy ,
Regards!!
Yes understand, what i forgot to say was that if I have your car's VIN in my garage and you have run a Scan and a Backup then I can see your adaptations and long coding and charts even though I have never attached to your car.
theoldboy
Notapor cvillajos el 18 Feb 2020, 19:38
theoldboy escribió:
Hi @theoldboy ,
Regards!!
WTF!!
Remind me never share my VIN with you (or with anyone) :no:
Regards!!
cvillajos
Notapor theoldboy el 18 Feb 2020, 20:29
How to change your OBD11 App name, email address, password or link to another facebook account
From the main menu select Profile (first pic), select the pen (second pic) and you will get the option to change the details.
If you try to log in and forgot your password then use the Forgot password button, enter your valid email address and it will email you a reset link
Cómo cambiar el nombre, la dirección de correo electrónico, la contraseña o el enlace de su aplicación OBD11 a otra cuenta de Facebook
En el menú principal, seleccione Perfil (primera imagen), seleccione el lápiz (segunda imagen) y obtendrá la opción de cambiar los detalles.
Si intenta iniciar sesión y olvidó su contraseña, use el botón Olvidé mi contraseña, ingrese su dirección de correo electrónico válida y le enviará un enlace de restablecimiento.
theoldboy
Notapor theoldboy el 18 Feb 2020, 20:58
Dongle 6 digit password - forgotten
When you first get your device you are asked to create a 6 digit passcode.
Many months later it ask you for the code and you cant recall it....
As you can see in picture 1 there is a Forgot Password link, click on it and OBD11 Will send you an email (see picture 2) with your password included.
If you buy a secondhand dongle and you have not been able to connect to it then it is possible the email address will not be your one but the original owners.
Dongle contraseña de 6 dígitos - olvidado
Cuando obtiene su dispositivo por primera vez, se le pide que cree un código de acceso de 6 dígitos.
Muchos meses después te pide el código y no puedes recordarlo ...
Como puede ver en la imagen 1, hay un enlace Olvidé mi contraseña, haga clic en él y OBD11 le enviará un correo electrónico (vea la imagen 2) con su contraseña incluida.
Si compra un dongle de segunda mano y no ha podido conectarse, es posible que la dirección de correo electrónico no sea la suya, sino la de los propietarios originales.
Última edición por theoldboy el 20 Feb 2020, 11:06, editado 1 vez en total
theoldboy
Notapor theoldboy el 19 Feb 2020, 14:20
Última edición por theoldboy el 19 Feb 2020, 15:21, editado 1 vez en total
theoldboy
