El hilo de VAGCOM y opciones/mods para MK3
Favoritos: El-Santo, J@VY, neraka, comodisimo, nhaxo, guirimg, Maestro, José R, JorgeAnteloC, gark81, Monilloxd, LeonST, josele887, Guitarrero18, Garfu, pttzarzadilla, reyes83, jicarriches, Raulin87, Leon pucelano, pocososinos, pintalberto, dani90, Mario1307, Albert87, genialsoft, Javigt, crcrodrigo, blankiblau, trekam, lobezno13, Morientes, Josito3, jorgee76, jliriz, Albino, seat leon fr 46, francesito, khris, Agonza86, clavelstreet, ocsido, acidheart, Korath, JPeraza, marcosgumiel, Josele., itsAdriaan96, cvillajos, ertate, LU1S3N_LE, Ludovicum, migcc, Vasmurcia, Charly24Fr, Jerjeskan, Javata, adrinek8, Paliciu, Samueleitor, Sdocid, Tomcat7733, ismacom, KaZaK, m170280, GaiteFRmklll, Mate, kijute, Kete32, los, javieret69, Alberto85, dranaco, joelsm, fre_19, Koltrix, franandas, Alleya, Juanquique, AiramTuning, chetelopez, little bastard, fur, mk3CAT, Juantxu, voxyman, Peje, javimacuo, JDCLEONFR, barrosdepor, steve_mad, Matias92, LordNelson, Elpuma7788, Revi, lopezm0, tuthankamenn, Miguelespino14, rock_ero, jordy, FranXP, albertolop91
Seguidores: sarge, dsorribes, Elpuma7788, fonsi008, genialsoft, Mario1307, P.carrizo.leonstfr, trumangs, robereto, rikirpa, Aaron7Abad, champinet, Ivan99rr, Miguelespino14, Besaygf, El3ndil, gogua, Pitufo_fr, crisFR, hectorcanu, Budoka, janfri, ixorreta, josele887, Jorge75016, jjimene89, cstrol, volkov, easyridergs, jmofcb, crcrodrigo, TeteFR, Dandy_gsi, Marc.22, Youkiler, iMonje, delko, dUeNdEr, Aegnorazo, marlop, pttzarzadilla, Platanot, berserk, Canary_280, La_jungla, davidbj, vigimuertos, Osky1983, chemacrown77, juanmaroger, sadanyac, Lionxp, coxmox, maxinew, nhaxo, Hecson.27, Valerofr150, Arcangel_89, edumachuca, daniel_44, JoseCa, kadettero, pablomus85, Mate, Albino, chuki_gcg, trekam, Ribers, FranGonzalez, Txutxiysilvia, César C., odelot, loeches, LeoST, jmfcoto, msmdraven, antelo85, kurbak, JPeraza, Diegokero, Robert_gti, chichopaco, Unaited, J.COSTA, jbaste, ertate, Javigt, Iosu21, Raul_22_, Daruma, kijute, LuichiFR, TITO CORUÑA, golf_1990, pitc3c14, lazandury_sur, iazofra, khris, Peje, Digon, car212121, Charly24Fr, Rasekfighter, aigort, Vasmurcia, Trivi83, Jeii90, MORKAS, Cantona, picard14, fbmxx, Zenobya, pirulo79, IRO, dookky, alonsodsg, carrasco13, Edu1589, elbirlo.dmm, bailyibz, Aluisdr26, aironsam14, franrx, Joseibz, elluna, hectordrums, chetelopez, llobet112, Kikote8, zenkun, Tomcat7733, djcastle, STFR, Sdocid, jezZu, jninomo, albertpg, neraka, joke2joke, Miguelpfdez94, Kete32, chisyelamos, molvi_mabad, alejandro_javier, borgio, carlosgzlez, Frekiyo, manupuente92, garrafa2, papo-182, pipaxy, joelsm, morpheusgt, leonfrsaha, joscasaster, bronce702, Dconnect, Agobo, DBS83, Luko, Leon pucelano, davics07, naikon_paul, Juanquique, abollao, Hovig, teltronik, oldaqgonzalez04, ivanmonty, jasoriab, undernok, Mramos1985, braulioT, JoseDel, DiegoR, KoToRRo, Gsclosada, Tunnig, João Ramos, cristian_l.m, ilargiman, Gus_Fring, eyebee, jluis, francisco.gamiz, sisma_eltrigo, VapaV, csabafr2013, guille771, cocorolito, artur.bp, sergi303, portela84, barret, Alba Morales, davidalba, JDCLEONFR, Luiggi7, dukaty, Maikermx, nitro_g4074, Senuto, yoflipo, damsolu, Mobi2004@gmail.com, josutdm, xexpir, cucci, Xabaco, fexposru, DJGrincho, chifli, MartinLeon, sgnwill, trazas, davidap13, ncx, Thor, ivanvidal, LordNelson, David_GT, vicius, javigomezserrano, josemag, iNFeCTeD, sistrax, manu5, galelir, Juanmidv, Chrohu, alex1, davidvilao, yurkli, carlo13, carloslmfr, lopezm0, jose.a.llamas, Gisbigas, Drovniak, diepecu2, JaquetónST, alrodri, ginyu 83, Ivanbustelo, Def89, Fisio, SantiPMI, Lata8, estudiante2003, talanito, wilsugar, perikolu, pedrorossello92, AlvaroRamlo, ebcuatro
Re: El hilo de VAGCOM y opciones/mods para MK3
Notapor Albino el 08 Oct 2015, 21:39
Ok @Qarl, en ese caso si lo necesitas hacer por vag-com
Albino
Agradecido: 61 veces
Notapor Gancedop el 08 Oct 2015, 22:23
Hola compañeros. Eh comprado él cable 12.12.3 y me eh decidido a hacer algún cambio como por ejemplo lo de las agujas y el fondo fibra en cuadro y pantalla, pero una de las q más me interesaba q era q al cerrar el coche se recojan los espejos no me a dejado. Me ponía algo referente a no tener esa función. Sabéis si ai otro modo o alguien más a teñido problemas? Gracias
Gancedop
Notapor txato70 el 08 Oct 2015, 23:20
Hola @qarl.la pagina stemei.de tiene todas las mods que quieras incluida la del espejo y bien explicadas usando el traductor.saludos.
txato70
Agradecido: 56 veces
Notapor Qarl el 09 Oct 2015, 01:09
txato70 escribió:Hola @qarl.la pagina stemei.de tiene todas las mods que quieras incluida la del espejo y bien explicadas usando el traductor.saludos.
Perfecto, ya lo he encontrado, no estaría mal que se añadiese al primer mensaje junto con los demás mods.
Qarl
Agradecido: 83 veces
Notapor TeteFR el 09 Oct 2015, 04:46
@Qarl pon aqui la mod y la pongo en el primer post.
TeteFR
Agradecido: 245 veces
Notapor Qarl el 09 Oct 2015, 08:18
TeteFR escribió:@Qarl pon aqui la mod y la pongo en el primer post.
Sí, por supuesto. Ayer no lo puse porque me metí desde el móvil y era incómodo :lol:
Bajar retrovisor derecho al engranar la marcha atrás (ayuda para aparcar)
  1. 52-Door Elect, Pass.
  2. Coding - 07
  3. Long Coding Helper
  4. Byte 04
  5. Activar Bit 2
  6. Acrivar Bit 3
  1. 09-Cent. Elect.
  2. Security Access - 16
  3. Introducir código: 31347
  4. Adaptation-10
  5. Canal: (17)-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt
  6. Poner valor: Active
Muchas gracias!!
Qarl
Notapor Adikubens el 09 Oct 2015, 12:10
Buenas compañeros, alguien me podría decir si ha probado este mod y si le funciona o hace lo que dice que es??
activar los antinieblas delanteros al dar marcha atras
1. 09 central electric
2. 16 security access Unlock code 31347
3. 10 adaptations From drop down
4. select - (1) static AFS light-bei Rueckwaertsfahrt Set value to Double Sided from OFF
5. Do It
yo lo he hecho tal y como dice, se hace todo correcto, se graba la nueva configuración pero luego cuando doy marcha atrás no se encienden los antinieblas. Tengo activado que al echar las ráfagas se enciendan antinieblas y eso si me funciona, no se si al tener eso activo es incompatible con este mod que quiero activar. a ver si alguien me arroja algo de "luz" porque o yo estoy activando algo que no se que es y para que sirve o a mi no me hace nada.
un saludo!!
Adikubens
Coche: Leon MK3 1.4 TSI 122cv
Notapor Albino el 09 Oct 2015, 12:13
Adikubens escribió:Buenas compañeros, alguien me podría decir si ha probado este mod y si le funciona o hace lo que dice que es??
5. Do It
un saludo!!
Yo llevo ese mod pero sin haberlo hecho especificmente. Me explico, al hacer el mod del cornering ya va incluido o al menos en mi caso
Albino
Notapor Adikubens el 09 Oct 2015, 12:14
  2. Coding - 07
  4. Byte 04
  5. Activar Bit 2
  6. Acrivar Bit 3
  1. 09-Cent. Elect.
  4. Adaptation-10
Muchas gracias!!
hola, este lo he intentado hacer pero al pinchar en el long coding me dice que mi ECU no tiene acceso a esto y no me sale el menu para poder ir al byte 4 y seguir con el resto de la configuración :( :(
Adikubens
Notapor Adikubens el 09 Oct 2015, 12:18
5. Do It
un saludo!!
que curioso, yo active el mod de cornering y me funcionaba bien pero lo quite porque al llevar luces LED no me gustaba como se veía la mezcla de blanco led con el amarillo halógeno, pensé que algún día le cambiaria la lámpara al antiniebla y quité el mod. Lo que no me fijé es si al dar marcha atrás se activaban los antinieblas, pero se te activan los dos? o es porque al dar marcha atras giras el volante y se enciende el antiniebla del lado que giras?
saludos y gracias por tu respuesta
Adikubens
Notapor Qarl el 09 Oct 2015, 12:33
Adikubens escribió:hola, este lo he intentado hacer pero al pinchar en el long coding me dice que mi ECU no tiene acceso a esto y no me sale el menu para poder ir al byte 4 y seguir con el resto de la configuración :( :(
Tienes el contacto puesto??
Qarl
Notapor Adikubens el 09 Oct 2015, 12:50
si, siempre hago el mismo proceder, enchufo el cable al coche, luego al ordenador, abro el VCDS y doy contacto, de hecho tengo el portátil enchufado a la corriente del coche porque la bateria me dura un suspiro y sino esta el contacto dado no da corriente la toma de 12v y no puedo hacer nada porque se me apaga el portátil. No se porqué me pasará eso :(
Adikubens
Notapor CarlosTSi el 09 Oct 2015, 13:07
@Adikubens nunca, pero nunca enchufes el ordenador al mechero del coche directamente te puedes cargar el cable y más sí es el "pirata".... Pon un transformador de 12 a 220/230V y lo enchufas al transformador
Cupra R 300 DSG
CarlosTSi
Agradecido: 938 veces
Notapor Albino el 09 Oct 2015, 13:13
5. Do It
un saludo!!
Se encienden ambos al engranar la marcha atrás independientemente de la posición del volante. Yo recuerdo haber leído algo al respecto pero ni me acorde hasta que un mes casi después de hacer el mod del cornering use la marcha atrás de noche
Albino
Notapor Adikubens el 09 Oct 2015, 13:34
Hola Homersimpson, tengo un transformador ufff que suste me has dado al leerlo de primeras no había reparado que me decías lo del transformador. primero enchufo el transformador al mechero y éste al portatil, mi portatil trabaja a 19v entonces el transformador tiene un selector de voltaje y tu ya pones el que te convenga según el voltaje que trabaje tu máquina. mira es este:
un saludo ;)
Adikubens
