El hilo de VAGCOM y opciones/mods para MK3
Favoritos: El-Santo, J@VY, neraka, comodisimo, nhaxo, guirimg, Maestro, José R, JorgeAnteloC, gark81, Monilloxd, LeonST, josele887, Guitarrero18, Garfu, pttzarzadilla, reyes83, jicarriches, Raulin87, Leon pucelano, pocososinos, pintalberto, dani90, Mario1307, Albert87, genialsoft, Javigt, crcrodrigo, blankiblau, trekam, lobezno13, Morientes, Josito3, jorgee76, jliriz, Albino, seat leon fr 46, francesito, khris, Agonza86, clavelstreet, ocsido, acidheart, Korath, JPeraza, marcosgumiel, Josele., itsAdriaan96, cvillajos, ertate, LU1S3N_LE, Ludovicum, migcc, Vasmurcia, Charly24Fr, Jerjeskan, Javata, adrinek8, Paliciu, Samueleitor, Sdocid, Tomcat7733, ismacom, KaZaK, m170280, GaiteFRmklll, Mate, kijute, Kete32, los, javieret69, Alberto85, dranaco, joelsm, fre_19, Koltrix, franandas, Alleya, Juanquique, AiramTuning, chetelopez, little bastard, fur, mk3CAT, Juantxu, voxyman, Peje, javimacuo, JDCLEONFR, barrosdepor, steve_mad, Matias92, LordNelson, Elpuma7788, Revi, lopezm0, tuthankamenn, Miguelespino14, rock_ero, jordy, FranXP, albertolop91
Seguidores: sarge, dsorribes, Elpuma7788, fonsi008, genialsoft, Mario1307, P.carrizo.leonstfr, trumangs, robereto, rikirpa, Aaron7Abad, champinet, Ivan99rr, Miguelespino14, Besaygf, El3ndil, gogua, Pitufo_fr, crisFR, hectorcanu, Budoka, janfri, ixorreta, josele887, Jorge75016, jjimene89, cstrol, volkov, easyridergs, jmofcb, crcrodrigo, TeteFR, Dandy_gsi, Marc.22, Youkiler, iMonje, delko, dUeNdEr, Aegnorazo, marlop, pttzarzadilla, Platanot, berserk, Canary_280, La_jungla, davidbj, vigimuertos, Osky1983, chemacrown77, juanmaroger, sadanyac, Lionxp, coxmox, maxinew, nhaxo, Hecson.27, Valerofr150, Arcangel_89, edumachuca, daniel_44, JoseCa, kadettero, pablomus85, Mate, Albino, chuki_gcg, trekam, Ribers, FranGonzalez, Txutxiysilvia, César C., odelot, loeches, LeoST, jmfcoto, msmdraven, antelo85, kurbak, JPeraza, Diegokero, Robert_gti, chichopaco, Unaited, J.COSTA, jbaste, ertate, Javigt, Iosu21, Raul_22_, Daruma, kijute, LuichiFR, TITO CORUÑA, golf_1990, pitc3c14, lazandury_sur, iazofra, khris, Peje, Digon, car212121, Charly24Fr, Rasekfighter, aigort, Vasmurcia, Trivi83, Jeii90, MORKAS, Cantona, picard14, fbmxx, Zenobya, pirulo79, IRO, dookky, alonsodsg, carrasco13, Edu1589, elbirlo.dmm, bailyibz, Aluisdr26, aironsam14, franrx, Joseibz, elluna, hectordrums, chetelopez, llobet112, Kikote8, zenkun, Tomcat7733, djcastle, STFR, Sdocid, jezZu, jninomo, albertpg, neraka, joke2joke, Miguelpfdez94, Kete32, chisyelamos, molvi_mabad, alejandro_javier, borgio, carlosgzlez, Frekiyo, manupuente92, garrafa2, papo-182, pipaxy, joelsm, morpheusgt, leonfrsaha, joscasaster, bronce702, Dconnect, Agobo, DBS83, Luko, Leon pucelano, davics07, naikon_paul, Juanquique, abollao, Hovig, teltronik, oldaqgonzalez04, ivanmonty, jasoriab, undernok, Mramos1985, braulioT, JoseDel, DiegoR, KoToRRo, Gsclosada, Tunnig, João Ramos, cristian_l.m, ilargiman, Gus_Fring, eyebee, jluis, francisco.gamiz, sisma_eltrigo, VapaV, csabafr2013, guille771, cocorolito, artur.bp, sergi303, portela84, barret, Alba Morales, davidalba, JDCLEONFR, Luiggi7, dukaty, Maikermx, nitro_g4074, Senuto, yoflipo, damsolu, Mobi2004@gmail.com, josutdm, xexpir, cucci, Xabaco, fexposru, DJGrincho, chifli, MartinLeon, sgnwill, trazas, davidap13, ncx, Thor, ivanvidal, LordNelson, David_GT, vicius, javigomezserrano, josemag, iNFeCTeD, sistrax, manu5, galelir, Juanmidv, Chrohu, alex1, davidvilao, yurkli, carlo13, carloslmfr, lopezm0, jose.a.llamas, Gisbigas, Drovniak, diepecu2, JaquetónST, alrodri, ginyu 83, Ivanbustelo, Def89, Fisio, SantiPMI, Lata8, estudiante2003, talanito, wilsugar, perikolu, pedrorossello92, AlvaroRamlo, ebcuatro
Re: El hilo de VAGCOM y opciones/mods para MK3
Notapor stewei el 25 Nov 2015, 11:54
Josito3 escribió:No tengo huevos a hacer este mod chicos... todo el rato me sale el error, lo intente bastante veces, lo quite todo del principio y lo volvi a poner y nada,,, no sale!!!! :(
Poner modo carbono en FIS
1. 17 – Instruments
2. Adaptation – 10
3. En Channel seleccionar Display depiction
4. En New value seleccionar Version 2 (a veces aun no se porque da error out of range, pero a mi me ha salido probando más de una vez)
5. Do it!
@Josito3 Creo que una vez estas en 17-instruments, hay que poner en 16-codigo de seguridad primero y despues hacer todo.
stewei
Agradecido: 465 veces
Notapor Josito3 el 25 Nov 2015, 12:21
@stewei y que codigo de seguridad hay que poner? 31347 ?
gracias
Josito3
Agradecido: 18 veces
Notapor arlot el 25 Nov 2015, 12:37
1. 17 – Instruments
2. Adaptation – 10
5. Do it!
Yo lo hice en su día con los pasos que indica @Josito3 y me funcionó, para este mod a mi no me hizo falta poner ningún código de seguridad, lo he puesto y quitado varias veces cuando ha tenido que ir al taller.
Por probar de poner el código de seguridad no pierdes nada, quizás hayan cambiado algún parámetro de las centralitas o algo.
Vamoooooooooooooos
arlot
Agradecido: 977 veces
Notapor Vasmurcia el 25 Nov 2015, 13:41
@arlot y para mi problema, sabrías decirme si se puede arreglar?
Al corte en un misil azul :mad:
Vasmurcia
Agradecido: 39 veces
Notapor arlot el 25 Nov 2015, 14:10
Vasmurcia escribió:Haciendo un escaneo de fallos me sale esto
Como lo soluciono?
Vasmurcia escribió:@arlot y para mi problema, sabrías decirme si se puede arreglar?
No sabría decirte, has borrado el error?
Yo probaría varias opciones:
1- Borrar el error
2- Sacar y volver a insertar la SD
3- Volver a dejarlo como estaba (sin efecto carbono en FIS y pantalla)
3.1 Si vuelve a funcionar, volver a poner los fondos de carbono
3.2 Si no funciona, sacar y volver a inserta SD, reiniciar el easy, pasarle otra vez el VAG a ver si sale de nuevo el error.
4- Si no funciona aún sacando los efectos de carbono, al concesionario (lo llevas tal y como te lo dieron)
5- No se me ocurre nada más
Vamoooooooooooooos
arlot
Notapor Vasmurcia el 25 Nov 2015, 14:32
No he borrado el error
He sacado y vuelta a meter la sd y nada
Lo he dejado como estaba y nada
He vuelto a pasar el vagcom, reiniciado el easy y sigue ahí el p.... error
Al final, lo he dejado como estaba y lo he llevado a la seat. Me avisaran para mirarlo y ver que le pasa porque ni cambiando la sd de ranura funciona.
Informaré por aquí de como acaba todo
Gracias @arlot por tus esfuerzos
Vasmurcia
Notapor cvillajos el 25 Nov 2015, 14:35
Yo hubiera probado con otra SD (original) de otro compi antes de llevarlo al conce. A lo mejor se había jodido por algo...
cvillajos
Agradecido: 3613 veces
Notapor Vasmurcia el 26 Nov 2015, 13:26
cvillajos escribió:Yo hubiera probado con otra SD (original) de otro compi antes de llevarlo al conce. A lo mejor se había jodido por algo...
@cvillajos si no recuerdo mal, las sd de cartografía de Seat son válidas únicamente para cada coche, es decir, la de otro compi no me vale en el mio. Por el tema de que cuando te la instalan, hace una especie de grabado en la tarjeta que la inválida para otro coche.
Si me equivoco, corregirme
Vasmurcia
Notapor cvillajos el 26 Nov 2015, 13:39
Pues ni idea, pero si la metes en la ranura con la pestaña 'lock' activada (como a mí me hizo el comercial en mis narices el día de la entrega) poco o nada puede escribirse en la SD.
Cosa distinta es que la unidad de la guantera se quede con el ID de la tarjeta y no admita otras salvo reseteo o similar...
Pero ya te digo, esto es desde mi desconocimiento @Vasmurcia
cvillajos
Notapor Vasmurcia el 26 Nov 2015, 13:43
A eso me refiero @cvillajos que no la lee. Ese es el problema
Vasmurcia
Notapor selexjtd el 27 Nov 2015, 09:24
hoy os vengo a contar,que ayer ROJAS,fue capaz de arreglarme el problemilla que tenia con la unidad de control de mi coche,ya me aparecen los menus bien! muchas gracias Rojas,por tu amabilidad,y coño,por tu conocimiento!! menuda maquina que estas hecho!! ahora ya veo los menos,y hasta lo del clima!!! jajajaj,ayer fue como re estrenar coche,ya que tenia menus nuevos!!!
y por supuesto video en movimiento y seat sound system :comediante: :comediante: :comediante:
Gracias [Rojas] :reverencia: :reverencia:
selexjtd
Notapor alexdaoe el 28 Nov 2015, 17:53
Nuevo mod que le interesara a mucha gente:
Probado hoy con un LEON 2, que alguien lo pruebe con el LEON 3, pero estoy casi seguro que es identico con el LEON 3:
Desactivación completa del asistente de ayuda en pendiente:
-03-ABS Brakes
-07: Coding
-Long coding helper
-byte 16
-bit 0 (Sale escrito al lado Hill hold control (Numeros) Active/Intalled
Quitais el tick de esa opción y ya esta el asistente completamente eliminado.
alexdaoe
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 48 veces
Notapor pitc3c14 el 28 Nov 2015, 19:26
alexdaoe escribió:Nuevo mod que le interesara a mucha gente:
-03-ABS Brakes
-07: Coding
-Long coding helper
-byte 16
Y serviría para activarlo en un Reference que no lo trae activado?
pitc3c14
Agradecido: 50 veces
Notapor rojas el 29 Nov 2015, 00:50
-03-ABS Brakes
-07: Coding
-Long coding helper
-byte 16
seguramente que no
rojas
Agradecido: 1889 veces
Notapor arlot el 29 Nov 2015, 09:31
-03-ABS Brakes
-07: Coding
-Long coding helper
-byte 16
Yo ya lo llevo en "Early" la posición más suave, y funciona muy muy suave, una vez te acostumbras al sistema ni jarto vino lo desactivo
Vamoooooooooooooos
arlot
Liquido de refrigeración G12 Evo!!!
Autor: Fernix72
Respuestas: 906
Hilo del León mkIV e-hybrid
Foro: General
Autor: vkr84
Respuestas: 666
Nuevo en el foro
Foro: Presentaciones
Autor: Achuguayo
Respuestas: 0
Leds legales a partir del 1 de noviembre
Foro: General
Autor: arjleon90
Respuestas: 130
Correa distribución leon mk3
Autor: noxon
Respuestas: 106
