El hilo de VAGCOM y opciones/mods para MK3
Favoritos: El-Santo, J@VY, neraka, comodisimo, nhaxo, guirimg, Maestro, José R, JorgeAnteloC, gark81, Monilloxd, LeonST, josele887, Guitarrero18, Garfu, pttzarzadilla, reyes83, jicarriches, Raulin87, Leon pucelano, pocososinos, pintalberto, dani90, Mario1307, Albert87, genialsoft, Javigt, crcrodrigo, blankiblau, trekam, lobezno13, Morientes, Josito3, jorgee76, jliriz, Albino, seat leon fr 46, francesito, khris, Agonza86, clavelstreet, ocsido, acidheart, Korath, JPeraza, marcosgumiel, Josele., itsAdriaan96, cvillajos, ertate, LU1S3N_LE, Ludovicum, migcc, Vasmurcia, Charly24Fr, Jerjeskan, Javata, adrinek8, Paliciu, Samueleitor, Sdocid, Tomcat7733, ismacom, KaZaK, m170280, GaiteFRmklll, Mate, kijute, Kete32, los, javieret69, Alberto85, dranaco, joelsm, fre_19, Koltrix, franandas, Alleya, Juanquique, AiramTuning, chetelopez, little bastard, fur, mk3CAT, Juantxu, voxyman, Peje, javimacuo, JDCLEONFR, barrosdepor, steve_mad, Matias92, LordNelson, Elpuma7788, Revi, lopezm0, tuthankamenn, Miguelespino14, rock_ero, jordy, FranXP, albertolop91
Seguidores: sarge, dsorribes, Elpuma7788, fonsi008, genialsoft, Mario1307, P.carrizo.leonstfr, trumangs, robereto, rikirpa, Aaron7Abad, champinet, Ivan99rr, Miguelespino14, Besaygf, El3ndil, gogua, Pitufo_fr, crisFR, hectorcanu, Budoka, janfri, ixorreta, josele887, Jorge75016, jjimene89, cstrol, volkov, easyridergs, jmofcb, crcrodrigo, TeteFR, Dandy_gsi, Marc.22, Youkiler, iMonje, delko, dUeNdEr, Aegnorazo, marlop, pttzarzadilla, Platanot, berserk, Canary_280, La_jungla, davidbj, vigimuertos, Osky1983, chemacrown77, juanmaroger, sadanyac, Lionxp, coxmox, maxinew, nhaxo, Hecson.27, Valerofr150, Arcangel_89, edumachuca, daniel_44, JoseCa, kadettero, pablomus85, Mate, Albino, chuki_gcg, trekam, Ribers, FranGonzalez, Txutxiysilvia, César C., odelot, loeches, LeoST, jmfcoto, msmdraven, antelo85, kurbak, JPeraza, Diegokero, Robert_gti, chichopaco, Unaited, J.COSTA, jbaste, ertate, Javigt, Iosu21, Raul_22_, Daruma, kijute, LuichiFR, TITO CORUÑA, golf_1990, pitc3c14, lazandury_sur, iazofra, khris, Peje, Digon, car212121, Charly24Fr, Rasekfighter, aigort, Vasmurcia, Trivi83, Jeii90, MORKAS, Cantona, picard14, fbmxx, Zenobya, pirulo79, IRO, dookky, alonsodsg, carrasco13, Edu1589, elbirlo.dmm, bailyibz, Aluisdr26, aironsam14, franrx, Joseibz, elluna, hectordrums, chetelopez, llobet112, Kikote8, zenkun, Tomcat7733, djcastle, STFR, Sdocid, jezZu, jninomo, albertpg, neraka, joke2joke, Miguelpfdez94, Kete32, chisyelamos, molvi_mabad, alejandro_javier, borgio, carlosgzlez, Frekiyo, manupuente92, garrafa2, papo-182, pipaxy, joelsm, morpheusgt, leonfrsaha, joscasaster, bronce702, Dconnect, Agobo, DBS83, Luko, Leon pucelano, davics07, naikon_paul, Juanquique, abollao, Hovig, teltronik, oldaqgonzalez04, ivanmonty, jasoriab, undernok, Mramos1985, braulioT, JoseDel, DiegoR, KoToRRo, Gsclosada, Tunnig, João Ramos, cristian_l.m, ilargiman, Gus_Fring, eyebee, jluis, francisco.gamiz, sisma_eltrigo, VapaV, csabafr2013, guille771, cocorolito, artur.bp, sergi303, portela84, barret, Alba Morales, davidalba, JDCLEONFR, Luiggi7, dukaty, Maikermx, nitro_g4074, Senuto, yoflipo, damsolu, Mobi2004@gmail.com, josutdm, xexpir, cucci, Xabaco, fexposru, DJGrincho, chifli, MartinLeon, sgnwill, trazas, davidap13, ncx, Thor, ivanvidal, LordNelson, David_GT, vicius, javigomezserrano, josemag, iNFeCTeD, sistrax, manu5, galelir, Juanmidv, Chrohu, alex1, davidvilao, yurkli, carlo13, carloslmfr, lopezm0, jose.a.llamas, Gisbigas, Drovniak, diepecu2, JaquetónST, alrodri, ginyu 83, Ivanbustelo, Def89, Fisio, SantiPMI, Lata8, estudiante2003, talanito, wilsugar, perikolu, pedrorossello92, AlvaroRamlo, ebcuatro
Re: El hilo de VAGCOM y opciones/mods para MK3
Notapor stewei el 04 Ene 2016, 17:06
@cvillajos A mi lo que me paso al principio fue que configure la alerta de seguridad de exceso de velocidad desde el menu car, y esa alerta es la de neumaticos de invierno.
Pero no configuras esa y si configuras la alerta desde el FIS, esa es la que dice "exceso de velocidad". Pero esa la puedes quitar perfectamente sin tener que tirar de VCDS :mrgreen:
Seleccionas la opcion desde el FIS (creo que estaba en datos del viaje) y le das al OK del volante y listo: se pone como con rallitas (las mismas que la de la temperatura del aceite/agua cuando el coche esta frio) y listo.
stewei
Agradecido: 465 veces
Notapor xaacra el 04 Ene 2016, 22:33
jmofcb escribió:
aigort escribió:Chicos tengo una pregunta a ver si alguien sabe. La cosa es que activar que el limpia trasero al dar marcha atrás haga una pasada no consigo hacer que me aparezca en el menu car así que cuando hice la prueba y vi que no funcionaba fue activar y desactivarlo pero hoy que estaba lloviendo y tenía los limpias puestos me e dado cuenta que mientras tenga la marcha atrás siempre esta funcionando el limpia de atrás esto le pasa a todo el mundo?
En los 3 leones que tenemos nos vino de serie y si es asi, tanto un leon mk2 stylance como los leon mk3 fr.
Y nadie sabe como se puede desactivar
xaacra
Agradecido: 9 veces
Notapor jmofcb el 05 Ene 2016, 12:51
Pues yo ni me ha dado por mirarlo porque ya me gusta llevarlo, en el leon mk2 si se puede, es por vagcom y en el leon mk3, a lo mejor por menú, car, ajustes.
Edito: En el mk3 no sale la opción de desactivar limpia trasero al poner marcha atrás con el menú car ajustes.
jmofcb
Agradecido: 10 veces
Notapor alexdaoe el 05 Ene 2016, 18:53
Hola una cosa, he hecho un check del del coche para ver errores y me han salido 3 errores que no se bien bien como solucionar, decir que ya hace 1 mes hice el check y borre todos los errores por si volvian a salir. Pues bien son estos:
1 Fault Found:
1555 - Check Software Version Management
B201A 00 [009] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 1
Este es el que mas me preocupa no se muy bien que significa ni en que repercute
Y estos dos:
0531 - Footwell Illimunation
B11FF 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
11274 - Bulb for Center Brake Light
B12C6 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 1
Fault Frequency: 3
Este del center brake light tengo el aleron del cupra instalado, no se si me esta diciendo que esta fundiendose o que, tambien si no recuerdo mal al intalar el aleron del cupra no me suena para nada que se pudiera desmontar o cambiar/reparar del aleron del cupra la luz de freno.
alexdaoe
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 48 veces
Notapor alexdaoe el 05 Ene 2016, 18:56
alexdaoe escribió:
alexdaoe escribió:Hola, he intentado desactivar por completo el asistente de frenada en pendiente del coche ya que a pesar de que ya tengo el mod de early, me sigue pegando el tiron en bastantes semaforos a pesar de que son en superficies planas, pues bien investigando en adaptations he encontrado esto que pone 3%.
Entiendo que es que se activa el hill hold en pendientes superiores al 3% , no? Pues bien querría preguntar si alguien ha modificado este valor y si le ha ido mejor o ha sido menos intrusivo cuando no hace falta el asistente. Gracias
Hola, pues bien para quien le interese al final lo he probado y muy contento he quedado al principio lo he intentado poner a 15%, es decir que solo active la frenada en pendientes de 15% o superiores, pero me ha dado out of range y con 10% si que me ha dejado metelo y contentissimo ya no me frena el coche en plano y asi cuando salgo del semaforo no me pega el tirón.
alexdaoe
Notapor Dyoner009 el 06 Ene 2016, 21:53
Alguien me puede poner algún enlace de algún tuto para usar el vag , lo necesario para empezar en un león mk3 2015
Dyoner009
Agradecido: 22 veces
Notapor gogua el 06 Ene 2016, 21:56
Dyoner009 escribió:Alguien me puede poner algún enlace de algún tuto para usar el vag , lo necesario para empezar en un león mk3 2015
Si miras las chinchetas, verás esto
viewtopic.php?t=12583
- Seat Leon MK1 - FR TDI 150cv (2004)
- Seat Leon MK3 - X-Perience TDI 184cv DSG (MY16)
Galeria MK3
gogua
Agradecido: 171 veces
Notapor Dyoner009 el 06 Ene 2016, 22:06
http://www.clubseatleon.net/viewtopic.php?t=12583
Pero esos tutos vale para cualquier modelo de seat?
Dyoner009
Notapor cvillajos el 06 Ene 2016, 22:42
Yo la primera vez que lo usé seguí este hilo de @arlot al dedillo. Oye, una maravilla!! que quizá también mereciese una chincheta...
http://www.clubseatleon.net/viewtopic.php?f=8&t=108591
cvillajos
Agradecido: 3612 veces
Notapor cvillajos el 06 Ene 2016, 23:36
alexdaoe escribió:Hola una cosa, he hecho un check del del coche para ver errores y me han salido 3 errores que no se bien bien como solucionar, decir que ya hace 1 mes hice el check y borre todos los errores por si volvian a salir. Pues bien son estos:
1 Fault Found:
B201A 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 1
Y estos dos:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Freeze Frame:
Fault Priority: 1
Fault Frequency: 3
Pues exáctamente tampoco sabría decirte @alexdaoe qué son esos fallos pero primero y segundo no tienen prioridad elevada [6] sin embargo el tercero tiene una gran prioridad [1], hasta el punto de que el manual del VCDS dice que hay que parar inmediatamente :shock:
cvillajos
Notapor txato70 el 07 Ene 2016, 23:01
Hola y saludos.el 2° aviso (footwell illumination),es la luz de los pies que falla o parpadea me imagino que habrás puesto bombillas led.un saludo.
txato70
Agradecido: 56 veces
Notapor alexmon92 el 07 Ene 2016, 23:30
http://www.mundodiagnosis.es/grupo-vag/ ... nuevo.html
este es el que me tengo que comprar?
alexmon92
Notapor aigort el 07 Ene 2016, 23:48
alexmon92 escribió:http://www.mundodiagnosis.es/grupo-vag/16-vag-12123-antibloqueo-nuevo.html
Yo te aconsejaría un 15.7.1
aigort
Coche: Leon MK3 1.2 TSI 105cv
Agradecido: 52 veces
Notapor alexmon92 el 08 Ene 2016, 13:09
Algun sitio fiable? Encuentro el 12.12 el otro solo en una pag y estaba agotado :s
alexmon92
Notapor cvillajos el 08 Ene 2016, 13:11
En MundoDiagnosis lo tienen (aunque no aparezca en la web). Ponte en contacto con ellos por tlf. o por mail
cvillajos
