El hilo de VAGCOM y opciones/mods para MK3
Favoritos: El-Santo, J@VY, neraka, comodisimo, nhaxo, guirimg, Maestro, José R, JorgeAnteloC, gark81, Monilloxd, LeonST, josele887, Guitarrero18, Garfu, pttzarzadilla, reyes83, jicarriches, Raulin87, Leon pucelano, pocososinos, pintalberto, dani90, Mario1307, Albert87, genialsoft, Javigt, crcrodrigo, blankiblau, trekam, lobezno13, Morientes, Josito3, jorgee76, jliriz, Albino, seat leon fr 46, francesito, khris, Agonza86, clavelstreet, ocsido, acidheart, Korath, JPeraza, marcosgumiel, Josele., itsAdriaan96, cvillajos, ertate, LU1S3N_LE, Ludovicum, migcc, Vasmurcia, Charly24Fr, Jerjeskan, Javata, adrinek8, Paliciu, Samueleitor, Sdocid, Tomcat7733, ismacom, KaZaK, m170280, GaiteFRmklll, Mate, kijute, Kete32, los, javieret69, Alberto85, dranaco, joelsm, fre_19, Koltrix, franandas, Alleya, Juanquique, AiramTuning, chetelopez, little bastard, fur, mk3CAT, Juantxu, voxyman, Peje, javimacuo, JDCLEONFR, barrosdepor, steve_mad, Matias92, LordNelson, Elpuma7788, Revi, lopezm0, tuthankamenn, Miguelespino14, rock_ero, jordy, FranXP, albertolop91
Seguidores: sarge, dsorribes, Elpuma7788, fonsi008, genialsoft, Mario1307, P.carrizo.leonstfr, trumangs, robereto, rikirpa, Aaron7Abad, champinet, Ivan99rr, Miguelespino14, Besaygf, El3ndil, gogua, Pitufo_fr, crisFR, hectorcanu, Budoka, janfri, ixorreta, josele887, Jorge75016, jjimene89, cstrol, volkov, easyridergs, jmofcb, crcrodrigo, TeteFR, Dandy_gsi, Marc.22, Youkiler, iMonje, delko, dUeNdEr, Aegnorazo, marlop, pttzarzadilla, Platanot, berserk, Canary_280, La_jungla, davidbj, vigimuertos, Osky1983, chemacrown77, juanmaroger, sadanyac, Lionxp, coxmox, maxinew, nhaxo, Hecson.27, Valerofr150, Arcangel_89, edumachuca, daniel_44, JoseCa, kadettero, pablomus85, Mate, Albino, chuki_gcg, trekam, Ribers, FranGonzalez, Txutxiysilvia, César C., odelot, loeches, LeoST, jmfcoto, msmdraven, antelo85, kurbak, JPeraza, Diegokero, Robert_gti, chichopaco, Unaited, J.COSTA, jbaste, ertate, Javigt, Iosu21, Raul_22_, Daruma, kijute, LuichiFR, TITO CORUÑA, golf_1990, pitc3c14, lazandury_sur, iazofra, khris, Peje, Digon, car212121, Charly24Fr, Rasekfighter, aigort, Vasmurcia, Trivi83, Jeii90, MORKAS, Cantona, picard14, fbmxx, Zenobya, pirulo79, IRO, dookky, alonsodsg, carrasco13, Edu1589, elbirlo.dmm, bailyibz, Aluisdr26, aironsam14, franrx, Joseibz, elluna, hectordrums, chetelopez, llobet112, Kikote8, zenkun, Tomcat7733, djcastle, STFR, Sdocid, jezZu, jninomo, albertpg, neraka, joke2joke, Miguelpfdez94, Kete32, chisyelamos, molvi_mabad, alejandro_javier, borgio, carlosgzlez, Frekiyo, manupuente92, garrafa2, papo-182, pipaxy, joelsm, morpheusgt, leonfrsaha, joscasaster, bronce702, Dconnect, Agobo, DBS83, Luko, Leon pucelano, davics07, naikon_paul, Juanquique, abollao, Hovig, teltronik, oldaqgonzalez04, ivanmonty, jasoriab, undernok, Mramos1985, braulioT, JoseDel, DiegoR, KoToRRo, Gsclosada, Tunnig, João Ramos, cristian_l.m, ilargiman, Gus_Fring, eyebee, jluis, francisco.gamiz, sisma_eltrigo, VapaV, csabafr2013, guille771, cocorolito, artur.bp, sergi303, portela84, barret, Alba Morales, davidalba, JDCLEONFR, Luiggi7, dukaty, Maikermx, nitro_g4074, Senuto, yoflipo, damsolu, Mobi2004@gmail.com, josutdm, xexpir, cucci, Xabaco, fexposru, DJGrincho, chifli, MartinLeon, sgnwill, trazas, davidap13, ncx, Thor, ivanvidal, LordNelson, David_GT, vicius, javigomezserrano, josemag, iNFeCTeD, sistrax, manu5, galelir, Juanmidv, Chrohu, alex1, davidvilao, yurkli, carlo13, carloslmfr, lopezm0, jose.a.llamas, Gisbigas, Drovniak, diepecu2, JaquetónST, alrodri, ginyu 83, Ivanbustelo, Def89, Fisio, SantiPMI, Lata8, estudiante2003, talanito, wilsugar, perikolu, pedrorossello92, AlvaroRamlo, ebcuatro
Re: El hilo de VAGCOM y opciones/mods para MK3
Notapor alexdaoe el 21 Feb 2016, 07:47
cvillajos escribió:
alexdaoe escribió:Hola, viendo el super manual de Xagico, he visto esto, alguien sabe si al leon 3 se le puede activar este menu? Sería genial poder ir con este menu en la pantalla de la radio.
De eso precisamente estábamos hablando @alexdaoe :cafe:
A vale supongo que te refieres a lo de mib1 o mib2, no? Deciros que he visto que el cupra si que tiene esta pantalla, asi que es esperanzador, a ver si se consigue!
alexdaoe
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 48 veces
Notapor cvillajos el 21 Feb 2016, 08:09
Las MIB2 (6.5") con DCC también la llevan, lo que no recuerdo es si en todas las motorizaciones. La cuestión es que alguien con esa MIB y sin DCC lo puede probar para ver si le aparece la nueva ventana en "Menú > CAR > Vista"...
Aunque si tiene que ser obligatoriamente con el 15.7.3 será difícil, porque ese cable pocos lo tienen por aquí.
cvillajos
Agradecido: 3613 veces
Notapor jony83 el 21 Feb 2016, 10:30
Yo tengo el cable 15.7 . si me decís pasos a seguir lo intento esta tarde
jony83
Agradecido: 20 veces
Notapor javigody el 21 Feb 2016, 10:33
jony83 escribió:Yo tengo el cable 15.7 . si me decís pasos a seguir lo intento esta tarde
Segun el manual de xagico, estos son los pasos.
SEAT León MK3 FR 1.4 TSI 150CV ACT
Instalador en Málaga -> VIM, bricos MK3, tempomat MK1 y más
--- ¡Colabora con nosotros y con la comunidad con tus backups de OBDeleven/Vagcom/VCDS en el siguiente enlace!: viewtopic.php?f=8&t=120732 ¡Gracias!---
javigody
Agradecido: 274 veces
Notapor jony83 el 21 Feb 2016, 11:01
Luego lo pruebo!!
jony83
Notapor aigort el 21 Feb 2016, 11:54
Esos relojes que indican?
aigort
Coche: Leon MK3 1.2 TSI 105cv
Agradecido: 52 veces
Notapor javigody el 21 Feb 2016, 12:22
Creo que indican temperatura del aceite, presión del turbo, fuerzas g, etc
javigody
Notapor jony83 el 21 Feb 2016, 18:35
Con mi cable no me deja entrar en esa función. Ohhh
jony83
Notapor stewei el 22 Feb 2016, 11:32
jony83 escribió:Con mi cable no me deja entrar en esa función. Ohhh
@jony83 Que cable es el que tu tienes? as puesto primero el código de acceso?
stewei
Agradecido: 465 veces
Notapor Stonemaker el 22 Feb 2016, 12:44
Deciros que he activado el menú offroad, y a mi solo me indica altitud, brujula, temperatura de aceite y agua y grados de inclinación de las ruedas, cuando lo activas te lo sustituye por la pantalla que te dice lo eficiente que estas conduciendo.
También comentar y no se si es un daño colateral o es por que toqué otra cosa relacionada con el ESP a la vez que me ha desaparecido en CAR/ajustes el menú para configurar el ESP, si alguien sabe como volver a sacarlo...
Para volver a activar el menú original yo he activado la opción 140 y algo o la 180 y algo, no lo recuerdo bien.
Stonemaker
Agradecido: 25 veces
Notapor gogua el 22 Feb 2016, 12:54
@stonemaker poned con que cable haceis las cosas.
Yo el menú offroad lo tengo por defecto, si nos se puede poner el sport nie molesto
- Seat Leon MK1 - FR TDI 150cv (2004)
- Seat Leon MK3 - X-Perience TDI 184cv DSG (MY16)
Galeria MK3
gogua
Agradecido: 171 veces
Notapor cvillajos el 22 Feb 2016, 13:57
Stonemaker escribió:Deciros que he activado el menú offroad, y a mi solo me indica altitud, brujula, temperatura de aceite y agua y grados de inclinación de las ruedas, cuando lo activas te lo sustituye por la pantalla que te dice lo eficiente que estas conduciendo.
Gracias por las pruebas @Stonemaker
Por este hilo a otro compi le desapareció la opción ESC pero no he vuelto a saber qué pasó...
http://www.clubseatleon.net/viewtopic.php?f=8&t=115801
cvillajos
Notapor jony83 el 22 Feb 2016, 19:00
No! Lo hice tal cual el manual. Dnd hay que poner y cual es el número de acceso???
jony83
Notapor cvillajos el 22 Feb 2016, 20:15
En la pantalla del módulo, antes de hacer modificaciones "Security Access - 16"
Aquí tienes algunos de ellos:
http://www.clubseatleon.net/viewtopic.php?f=8&t=108159
Y en el PDF de @XaGiCo también están listados.
cvillajos
Notapor jony83 el 22 Feb 2016, 21:18
Mañana lo pruebo que ahora no me apetece pasar frio en el garaje :avergonzado:
jony83
